GSoC: RTEMS directory for FreeBSD imports
Niteesh G. S. niteesh.gs at gmail.com
Thu May 14 16:59:58 UTC 2020
On Thu, May 14, 2020 at 4:30 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 13/05/2020 20:15, Niteesh G. S. wrote:
> > Hello,
> > This mail is to regain attention for this topic and also to discuss a
> > few details
> > regarding the porting process.
> > In the previous thread, Sebastian mentioned that we will be hard wiring
> > the OF
> > functions with the FDT implementation. For reasons please have a look at
> > previous thread.
> > https://lists.rtems.org/pipermail/devel/2020-May/059762.html
> > This will be achieved by inlining the functions in openfirm.h with
> functions
> > defined in ofw_fdt.c. This approach is valid for most functions but not
> all.
> > Since not all functions have a one to one mapping.
> > For example,
> >    The OF_peer can be directly mapped to ofw_fdt_peer.
> >    But for OF_getencprop it calls ofw_fdt_getprop after few
> manipulations.
> > Inlining these functions doesn't seem like a good practice for me.
> > One way to approach this would be to add the implementation for these
> > functions in
> > ofw_fdt.c but this would cause code redundancy if we plan to import
> > openfirm.c
> > in future since these functions are already defined in openfirm.c.
> Are the functions exact clones of the the ones in openfirm.c? In that
> case I would suggest to import openfirm.c and put #ifndef __rtems__
> around everything you don't need. Eveni if it means that you only use
> 10% of the file.
Yes, implementation of the mentioned
functions(OF_getencprop, OF_getencprop_alloc etc)
will be a copy of the ones in openfirm.c.
> > Another approach will be to import openfirm.c also and redefine the OFW_*
> > macro to directly call the respective functions.
> That sounds like a better aproach.
We can also call the respective functions directly from the functions in
openfirm.c
instead of redefining the OFW_* macro. Which one do you prefer?
I will wait for a couple for everyone to participate in the discussion and
then start
implementing it.
> > I don't really know if there is any other better way to approach this.
> > Any suggestion on
> > how to proceed.
> > Once this is resolved I will proceed with the porting even if we haven't
> > finalized the
> > directory since it is just a matter of moving files once we are
> finalized.
> > If you think this is too early to start with coding for GSoC please
> > understand that my
> > university exams haven't been conducted yet. And due to the COVID
> > pandemic, the
> > dates are quite uncertain. But it is mostly expected to happen during
> > the coding period (july/aug)
> > and this would eat up quite a lot of time. So just to be one the safe
> > side I started
> > quite early.
> > Thank,
> > Niteesh.
> > On Mon, May 11, 2020 at 12:48 PM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> >     On 11/05/2020 09:11, Chris Johns wrote:
> >     > On 11/5/20 4:55 pm, Christian Mauderer wrote:
> >     >> On 11/05/2020 06:57, Chris Johns wrote:
> >     >>> On 11/5/20 2:03 pm, Niteesh G. S. wrote:
> >     >>>> On Mon, May 11, 2020 at 4:34 AM Chris Johns <chrisj at rtems.org
> >     <mailto:chrisj at rtems.org>
> >     >>>> <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> >     >>>>      On 10/5/20 6:17 pm, Niteesh G. S. wrote:
> >     >>>>       > This thread is a continuation of "GSoC 2020:
> Implementation
> >     >>>> of OFW
> >     >>>>       > functions".
> >     >>>>       > A summary of points discussed in that thread is given
> >     below.
> >     >>>>       > Below is a short description of my GSoC project. For
> more
> >     >>>>      information please
> >     >>>>       > refer to the wiki.
> https://devel.rtems.org/wiki/GSoC/2020/Beagle_FDT_initialization
> >     >>>>       > My GSoC project deals with refactoring the Beagle BSP
> >     to add
> >     >>>>      support for FDT
> >     >>>>       > based initialization. As part of this process, I will
> >     have to
> >     >>>>      import the
> >     >>>>       > pin mux driver
> >     >>>>       > into RTEMS which currently is present in libBSD.
> >     >>>>       > This would require having support for OFW functions
> >     which are
> >     >>>>      currently
> >     >>>>       > not implemented
> >     >>>>       > in RTEMS. Some drivers(eg: imx_iomux.c) which require
> these
> >     >>>>      functions
> >     >>>>       > provide
> >     >>>>       > a local implementation using libFDT.
> >     >>>>      I hope you do not mind if I wind back a couple of steps...
> >     >>>>      OFW? Is this http://wiki.laptop.org/go/Open_Firmware?
> >     >>>>      How does OFW related to FDT?
> >     >>>> We are only interested in the device tree interface provided by
> >     the OF.
> >     >>>> Functions like OF_getprop, OF_parent, etc.
> >     >>> Why not call libfdt functions? I am wondering what there is in
> >     FreeBSD
> >     >>> that is calling these functions? I am not questioning the need,
> >     it is a
> >     >>> case of not understanding the dependency.
> >     >> The use case for the OF_... and ofw_... functions is more or less
> a
> >     >> simple import from FreeBSD drivers. Beneath that there are some
> quite
> >     >> nice shortcuts in the OF_... and ofw_... functions that would
> >     have to be
> >     >> re-implemented in each driver (like ofw_bus_node_status_okay()).
> >     >> Some drivers already use hacked versions of the functions. For
> >     example:
> >     >> bsps/sparc64/shared/clock/ckinit.c
> >     >> bsps/arm/imx/start/imx_iomux.c
> >     >> A use case where the OF_... stuff would have been handy:
> >     >> For the imx pin initialization I would have loved to just use the
> >     >> fdt_pinctrl_configure_tree() from FreeBSD. But that one had a lot
> of
> >     >> OF_.. stuff. Therefore I had to reimplement that function in a
> >     >> imx_pinctrl_configure_children(). My implementation basically does
> >     >> exactly the same thing but uses fdt_... functions instead of the
> >     OF_...
> >     >> functions.
> >     > Thanks. I think I understand. The scope seems to be the low level
> SoC
> >     > type initialisation. This makes sense.
> >     And maybe some low level drivers like serial or I2C. I don't think
> that
> >     we should go much further in complexity. Basically everything that is
> >     beyond getting the board up and running is more of a libbsd topic.
> >     >>>>      You discuss importing drivers from FreeBSD? Do you know
> >     which core
> >     >>>>      FreeBSD pieces would need to also come over for the
> >     drivers listed
> >     >>>>      below?
> >     >>>> We had discussed this in the previous thread.
> >     >>>> https://lists.rtems.org/pipermail/devel/2020-May/059765.html
> >     >>>> For OF_* functions we will only have to import the following
> files.
> >     >>>> 1) openfirm.h
> >     >>>> 2) ofw_fdt.c
> >     >>> You say below some drivers are being imported from FreeBSD, it
> >     is these
> >     >>> I am asking about.
> >     >>>>      Is seamless integration with rtems-libbsd required or does
> >     it also
> >     >>>>      include copies of the same code?
> >     >>>> I am sorry. I don't really understand what you are asking :(.
> >     >>> I am asking if the changes effect rtems-libbsd?
> >     >> I think the first step will be copies. It depends a bit on how
> >     well the
> >     >> functions can be integrated into RTEMS (the "node" parameter
> >     maybe is a
> >     >> bit difficult) but I'm confident that the OF_... and ofw_...
> >     stuff can
> >     >> be replaced sooner or later.
> >     > Sure, this is sensible. I am just mapping out in my head how this
> all
> >     > goes together.
> >     That's fine and necessary. It's good if we find critical points
> before
> >     Niteesh starts to add stuff.
> >     For the OF and ofw parts I'm a bit worried about the node parameter.
> But
> >     I'm sure we find a solution.
> >     >>>>       > In the previous thread, it has been decided to import
> >     the OFW
> >     >>>>      functions from
> >     >>>>       > FreeBSD but the directory where it has to be imported
> into
> >     >>>> RTEMS
> >     >>>>      is not yet
> >     >>>>       > decided. This thread has been created to discuss it.
> >     >>>>       > It should also be noted that some drivers for example
> >     I2C, SPI
> >     >>>>      are being
> >     >>>>       > imported
> >     >>>>       > into RTEMS from FreeBSD for some BSPs.
> >     >>>>       > Now, since a large amount of code being imported from
> >     FreeBSD
> >     >>>> it is
> >     >>>>       > planned to
> >     >>>>       > add to a synchronization script(Yet to discussed in
> >     detail) to
> >     >>>>      stay in
> >     >>>>       > sync with
> >     >>>>       > FreeBSD.
> >     >>>>       > So now is it necessary to choose a directory that is
> future
> >     >>>>      compatible
> >     >>>>       > with the
> >     >>>>       > synchronization script. We should also discuss if we
> >     want to
> >     >>>> have
> >     >>>>      all
> >     >>>>       > imports
> >     >>>>       > under a single directory or have the imports in their
> >     >>>> respective
> >     >>>>       > directories for eg
> >     >>>>       > a device driver could be placed in its BSP directories
> than
> >     >>>> in a
> >     >>>>      common
> >     >>>>       > folder
> >     >>>>       > along with other imports. But it should also be noted
> >     that the
> >     >>>>      latter
> >     >>>>       > makes it
> >     >>>>       > difficult to sync and the former.
> >     >>>>      Gedare covered these issues in the other thread in an
> >     excellent
> >     >>>> post
> >     >>>>      [1]
> >     >>>>      and I would like to reference that as I agree with it.
> >     >>>>      When importing from such a large and complex code base like
> >     >>>> FreeBSD we
> >     >>>>      need to be careful we do not pull on a thread and pull in
> >     large
> >     >>>> pieces
> >     >>>>      of FreeBSD.
> >     >>>>      Gedare's point about making sure all imported pieces are
> >     from the
> >     >>>> same
> >     >>>>      version is important and I think a base requirement.
> >     >>>>      I am OK with some code being in rtems.git if there is a
> >     clear use
> >     >>>>      outside of rtems-libbsd. FDT support is one use, another
> >     is the
> >     >>>> NFS
> >     >>>>      client code in FreeBSD being used with the legacy stack
> >     (there are
> >     >>>> BSPs
> >     >>>>      with only legacy driver support still in use) and the
> existing
> >     >>>>      client is
> >     >>>>      only NFSv2.
> >     >>>>      We need a place to collect the common base parts of FreeBSD
> >     >>>> that are
> >     >>>>      shared by the various imported pieces. Isolated pieces
> could
> >     >>>> lead to
> >     >>>>      repeated imports common pieces if we do not do this.
> >     >>>>      I believe Sebastian said the new build system should
> >     handle the
> >     >>>>      synchronisation? This is a good idea. Could it manage
> >     separated
> >     >>>> pieces?
> >     >>>>      Could the build system read in all the sync pieces and
> >     >>>> logically join
> >     >>>>      them based on the upstream source and operate on them as a
> >     group?
> >     >>>> This
> >     >>>>      way we can have drivers in a BSP, NFS in libnfs (or where
> >     ever).
> >     >>>> I am not really familiar with the new build system. So can we
> >     please
> >     >>>> wait
> >     >>>> until Sebastian answers this.
> >     >>> Sure.
> >     >> Although note that I suggested to see the discussion as a
> >     _preparation_
> >     >> for that import. Doing the import right is quite a bit of work.
> >     It would
> >     >> change the target of Niteeshs GSoC project quite a lot. So we
> should
> >     >> make sure that a good location is selected and that the same
> >     rules like
> >     >> in libbsd are used. But I don't think that the actual script will
> be
> >     >> added in that project.
> >     > Again this is sensible. Thank you for clarifying things.
> >     > Chris
> >     Best regards
> >     Christian
> >     embedded brains GmbH
> >     Herr Christian Mauderer
> >     Dornierstr. 4
> >     D-82178 Puchheim
> >     Germany
> >     email: christian.mauderer at embedded-brains.de
> >     Phone: +49-89-18 94 741 - 18
> >     Fax:   +49-89-18 94 741 - 08
> >     PGP: Public key available on request.
> >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200514/7a31d931/attachment-0001.html>
