Adding fenv support for ARM
Eshan Dhawan
eshandhawan51 at gmail.com
Fri May 22 19:02:11 UTC 2020
hello,
There is error in the default fenv environment declaration as it is
defined in libm/fenv
as well as machine/arm/fenv.c (the FreeBSD file added)
so should I add fe_dfl_evn.c file to machine/arm pointing to fenv_stub,ar
remove it from fenv.c file :)
error :
arm-rtems5-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
-mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -B./../../lib/libbsp/arm/xilinx-zynq
-B/home/eshan/development/rtems/kernel/rtems/bsps/arm/xilinx-zynq/start
-specs bsp_specs -qrtems -L./../../cpukit
-L/home/eshan/development/rtems/kernel/rtems/bsps/arm/shared/start
-Wl,--wrap=printf -Wl,--wrap=puts -Wl,--wrap=putchar -Wl,--gc-sections -o
psxfile01.exe psxfile01/psxfile01-main.o psxfile01/psxfile01-test.o
psxfile01/psxfile01-test_cat.o psxfile01/psxfile01-test_extend.o
psxfile01/psxfile01-test_write.o
./../../lib/libbsp/arm/xilinx-zynq/librtemsbsp.a
./../../cpukit/librtemscpu.a ./../../cpukit/librtemstest.a
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/neon/hard/libm.a(lib_a-fenv.o):(.data._fe_dfl_env+0x0):
multiple definition of `_fe_dfl_env';
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/neon/hard/libm.a(lib_a-fe_dfl_env.o):(.data._fe_dfl_env+0x0):
first defined here
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/neon/hard/libm.a(lib_a-fenv.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/neon/hard/newlib/libm/machine/arm/../../../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:52:
multiple definition of `__fe_dfl_env';
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/neon/hard/libm.a(lib_a-fe_dfl_env.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/neon/hard/newlib/libm/fenv/../../../../../../../../../gcc-7.5.0/newlib/libm/fenv/fe_dfl_env.c:40:
first defined here
Thanks
-Eshan
On Thu, May 21, 2020 at 10:21 PM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> Hi
> I am testing another approach for this, Creating a new header fenv-vfp.h.
> And add all the inline assembly as well as the static inline functions to
> that file.
> calling it from fenv-vfp.c instead of fenv.c.
> fenv-vfp is the one file that has the main ARM specific code.
> Fenv.c is the file that calls the vfp functions.
> I will keep the results posted. :)
> -Eshan :)
> On Thu, May 21, 2020 at 4:55 AM Joel Sherrill <joel at rtems.org> wrote:
>> Back on the list. :)
>> Thanks for making sure everything on the branch was up to date.
>> I decided take a simple shot. I disabled anything in sys/fev.h that
>> looked like it would conflict with an implementation in a C file.
>> $ git diff
>> diff --git a/newlib/libc/machine/arm/sys/fenv.h
>> b/newlib/libc/machine/arm/sys/fenv.h
>> index aada676..2d3836b 100644
>> --- a/newlib/libc/machine/arm/sys/fenv.h
>> +++ b/newlib/libc/machine/arm/sys/fenv.h
>> @@ -94,6 +94,7 @@ extern const fenv_t *_fe_dfl_env;
>> #define _ENABLE_MASK (FE_ALL_EXCEPT << _FPUSW_SHIFT)
>> #endif
>> +#if 0
>> #ifndef __ARM_PCS_VFP
>> int feclearexcept(int excepts);
>> @@ -274,6 +275,7 @@ fegetexcept(void)
>> #endif /* __BSD_VISIBLE */
>> #endif /* __ARM_PCS_VFP */
>> +#endif
>> #ifdef __cplusplus
>> Let's proceed a bit with this "if 0" in place. The code in that block may
>> be simpler to delete if it isn't used by the libm/arm/fenv-XXX.c files.
>> That got it building again but when I looked in the installed libm.a, it
>> was clear that the arm specific code wasn't in the library. I did the
>> following command and searched for "<fe" to see the fenv methods, what
>> assembly code was there, and what file was compiled to produce it:
>> $ arm-rtems5-objdump -da --source ../install/arm-rtems5/lib/libm.a| less
>> I then looked in the build log and fenv-vfp.c wasn't compiled. That was
>> the most obvious arm specific file name. Looking in libm/arm, I did this:
> fenv-vpf is the one file that has the main ARM specific code
>> joel at localhost arm]$ grep fenv- Makefile.*
>> Makefile.am: fenv-vfp.c \
>> Makefile.am: fenv-softfp.c
>> Makefile.in needs to be regenerated. Or you can simply hack and add those
>> to the Makefile.in if that's all you added to the Makefile.am.
>> --joel
>> On Wed, May 20, 2020 at 2:47 PM Joel Sherrill <joel at rtems.org> wrote:
>>> On Wed, May 20, 2020 at 2:40 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>>> I compiled the fenv-vpf.c and got this output.
>>>> output file:
>>>> https://github.com/eshandhawan51/rough_notes/blob/master/gcc_fenv-vfp.txt
>>>> A strange thing happened today I reset the branch to the previous
>>>> commit from removing the inline functions from sys/fenv.h
>>>> and the redefinition error disappeared and the error changed.
>>>> make[5]: Entering directory
>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm/machine'
>>>> Making all in arm
>>>> make[6]: Entering directory
>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm/machine/arm'
>>>> arm-rtems5-gcc
>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/
>>>> -isystem
>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include
>>>> -isystem /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include
>>>> -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
>>>> -DPACKAGE_VERSION=\"3.3.0\" -DPACKAGE_STRING=\"newlib\ 3.3.0\"
>>>> -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -I.
>>>> -I../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
>>>> ../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
>>>> -fno-builtin -ffunction-sections -fdata-sections -D_COMPILING_NEWLIB
>>>> -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED
>>>> -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP
>>>> -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN
>>>> -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET -D_NO_WORDEXP
>>>> -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI -g -O2 -c -o
>>>> lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
>>>> '../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
>>>> /tmp/ccqybjKL.s: Assembler messages:
>>>> /tmp/ccqybjKL.s:35: Error: selected processor does not support `vmrs
>>>> r3,fpscr' in ARM mode
>>> This looks like a bit of progress to me. As bad as getting a compile
>>> error sounds.
>>> I do not see any -mXXX options on the gcc invocation above. fenv-vfp.c
>>> is being compiled in this situation which is understandable because newlib
>>> builds every file independent of if it is appropriate for the CPU model
>>> variant or not. This file needs to have its contents wrapped in "#if
>>> vfp_avaiable" or whatever gcc defines when vfp is available. The other fenv
>>> variant files will have to have the opposite of that to ensure that the no
>>> VFP variant is not built when vfp is available.
>>> Does that make sense? All the files in libm/arm are going to get
>>> compiled. The contents need to be disabled if that implementation is not
>>> right for the CPU model variant. In the end, only one implementation of the
>>> fenv methods should get real code produced.
>>>> /tmp/ccqybjKL.s:46: Error: selected processor does not support `vmsr
>>>> fpscr,r0' in ARM mode
>>>> /tmp/ccqybjKL.s:76: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:111: Error: selected processor does not support `vmrs
>>>> r2,fpscr' in ARM mode
>>>> /tmp/ccqybjKL.s:126: Error: selected processor does not support `vmsr
>>>> fpscr,r1' in ARM mode
>>>> /tmp/ccqybjKL.s:158: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:171: Error: selected processor does not support `vmsr
>>>> fpscr,r3' in ARM mode
>>>> /tmp/ccqybjKL.s:203: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:233: Error: selected processor does not support `vmrs
>>>> r0,fpscr' in ARM mode
>>>> /tmp/ccqybjKL.s:264: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:278: Error: selected processor does not support `vmsr
>>>> /tmp/ccqybjKL.s:310: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:343: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:357: Error: selected processor does not support `vmsr
>>>> /tmp/ccqybjKL.s:388: Error: selected processor does not support `vmsr
>>>> /tmp/ccqybjKL.s:418: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:427: Error: selected processor does not support `vmsr
>>>> fpscr,r2' in ARM mode
>>>> /tmp/ccqybjKL.s:439: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:463: Error: selected processor does not support `vmsr
>>>> /tmp/ccqybjKL.s:498: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:512: Error: selected processor does not support `vmsr
>>>> /tmp/ccqybjKL.s:544: Error: selected processor does not support `vmrs
>>>> /tmp/ccqybjKL.s:557: Error: selected processor does not support `vmsr
>>>> /tmp/ccqybjKL.s:588: Error: selected processor does not support `vmrs
>>>> Makefile:476: recipe for target 'lib_a-fenv-vfp.o' failed
>>>> make[6]: *** [lib_a-fenv-vfp.o] Error 1
>>>> make[6]: Target 'all' not remade because of errors.
>>>> make[6]: Leaving directory
>>>> Making all in .
>>>> make[6]: Nothing to be done for 'all-am'.
>>>> Makefile:324: recipe for target 'all-recursive' failed
>>>> make[5]: *** [all-recursive] Error 1
>>>> make[5]: Target 'all' not remade because of errors.
>>>> make[5]: Leaving directory
>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm'
>>>> make[5]: Nothing to be done for 'all-am'.
>>>> Makefile:553: recipe for target 'all-recursive' failed
>>>> make[4]: *** [all-recursive] Error 1
>>>> make[4]: Target 'all' not remade because of errors.
>>>> make[4]: Leaving directory
>>>> Making all in doc
>>>> make[4]: Entering directory
>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/doc'
>>>> make[4]: Nothing to be done for 'all'.
>>>> Making all in .
>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib'
>>>> Makefile:641: recipe for target 'all-recursive' failed
>>>> make[3]: *** [all-recursive] Error 1
>>>> make[3]: Leaving directory
>>>> Makefile:452: recipe for target 'all' failed
>>>> make[2]: *** [all] Error 2
>>>> make[2]: Leaving directory
>>>> Makefile:8491: recipe for target 'all-target-newlib' failed
>>>> make[1]: *** [all-target-newlib] Error 2
>>>> make[1]: Target 'all-target' not remade because of errors.
>>>> make[1]: Leaving directory
>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib'
>>>> Makefile:878: recipe for target 'all' failed
>>>> make: *** [all] Error 2
>>>> On Wed, May 20, 2020 at 4:44 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Tue, May 19, 2020 at 5:20 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>> wrote:
>>>>>> On Wed, May 20, 2020 at 3:43 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, May 20, 2020 at 2:25 AM Joel Sherrill <joel at rtems.org>
>>>>>>> wrote:
>>>>>>>> On Tue, May 19, 2020 at 3:52 PM Eshan Dhawan <
>>>>>>>> eshandhawan51 at gmail.com> wrote:
>>>>>>>>> On Wed, May 20, 2020 at 1:55 AM Eshan Dhawan <
>>>>>>>>>> On Wed, May 20, 2020 at 1:42 AM Joel Sherrill <joel at rtems.org>
>>>>>>>>>> wrote:
>>>>>>>>>>> There shouldn't need to be an arm/fenv.c file after this is over
>>>>>>>>>>> if I am thinking right. Each method will be split into its own file. I
>>>>>>>>>>> think that's how the riscv is done.
>>>>>>>>>> The files in sys/fenv are the one having inline assembly, But the
>>>>>>>>>> methods in fenv.c have the files for soft float, and vpf.
>>>>>>>>> could all the files be retailed under different #ifdef conditions
>>>>>>>>> similar to that followed in FreeBSD
>>>>>>>> Hmmm... maybe the methods in sys/fenv.h are redundant. If the
>>>>>>>> bodies in fenv.c cover all the multilibs, then delete the static inlines.
>>>>>>> This may be the case
>>>>>>> but the files in Fenv.h are the once with the assembly code.
>>>>>>> the files in fenv.c are calling functions from fenv-softfp.c and
>>>>>>> fenv-vfp.c
>>>>>>> which inturn call files for fenv.h and fenv-softfloat.h
>>>>>>> If we remove the inline declaration of the functions from Fenv.h
>>>>>>> they won't be able to get the definitions
>>>>>>> and will cause errors.
>>>>>> Warning the compiler generates:
>>>>>> arm-rtems5-gcc
>>>>>> -isystem
>>>>>> ../../../../../../newlib-cygwin/newlib/libm/machine/arm/fenv-vfp.c:29:24:
>>>>>> warning: inline function '__vfp_fegetexcept' declared but never defined
>>>>>> #define FENV_MANGLE(x) __vfp_ ##x
>>>>> Hmm... trace the naming patch from the mangled declaration to a
>>>>> method. You can drop into the build directory and run the gcc command by
>>>>> hand. Tinker with it to add a -E and save the output (not -o...). That will
>>>>> let you see the preprocessed output. Something specific and subtle is
>>>>> happening. Decode that and you win.
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:52:21:
>>>>>> note: in expansion of macro 'FENV_MANGLE'
>>>>>> #define fegetexcept FENV_MANGLE(fegetexcept)
>>>>>> warning: inline function '__vfp_fedisableexcept' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:51:25:
>>>>>> #define fedisableexcept FENV_MANGLE(fedisableexcept)
>>>>>> warning: inline function '__vfp_feenableexcept' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:50:24:
>>>>>> #define feenableexcept FENV_MANGLE(feenableexcept)
>>>>>> warning: inline function '__vfp_feupdateenv' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:49:21:
>>>>>> #define feupdateenv FENV_MANGLE(feupdateenv)
>>>>>> warning: inline function '__vfp_fesetenv' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:48:18:
>>>>>> #define fesetenv FENV_MANGLE(fesetenv)
>>>>>> warning: inline function '__vfp_feholdexcept' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:47:22:
>>>>>> #define feholdexcept FENV_MANGLE(feholdexcept)
>>>>>> warning: inline function '__vfp_fegetenv' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:46:18:
>>>>>> #define fegetenv FENV_MANGLE(fegetenv)
>>>>>> warning: inline function '__vfp_fesetround' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:45:20:
>>>>>> #define fesetround FENV_MANGLE(fesetround)
>>>>>> warning: inline function '__vfp_fegetround' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:44:20:
>>>>>> #define fegetround FENV_MANGLE(fegetround)
>>>>>> warning: inline function '__vfp_fetestexcept' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:43:22:
>>>>>> #define fetestexcept FENV_MANGLE(fetestexcept)
>>>>>> warning: inline function '__vfp_fesetexceptflag' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:41:25:
>>>>>> #define fesetexceptflag FENV_MANGLE(fesetexceptflag)
>>>>>> warning: inline function '__vfp_feraiseexcept' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:42:23:
>>>>>> #define feraiseexcept FENV_MANGLE(feraiseexcept)
>>>>>> warning: inline function '__vfp_fegetexceptflag' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:40:25:
>>>>>> #define fegetexceptflag FENV_MANGLE(fegetexceptflag)
>>>>>> warning: inline function '__vfp_feclearexcept' declared but never defined
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:39:23:
>>>>>> #define feclearexcept FENV_MANGLE(feclearexcept)
>>>>>> arm-rtems5-gcc
>>>>>> -isystem
>>>>>> lib_a-fenv-softfp.o `test -f 'fenv-softfp.c' || echo
>>>>>> '../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-softfp.c
>>>>>> rm -f lib.a
>>>>>> arm-rtems5-ar cru lib.a lib_a-e_sqrt.o lib_a-ef_sqrt.o lib_a-s_ceil.o
>>>>>> lib_a-s_floor.o lib_a-s_nearbyint.o lib_a-s_rint.o lib_a-s_round.o
>>>>>> lib_a-s_trunc.o lib_a-sf_ceil.o lib_a-sf_floor.o lib_a-sf_nearbyint.o
>>>>>> lib_a-sf_rint.o lib_a-sf_round.o lib_a-sf_trunc.o lib_a-feclearexcept.o
>>>>>> lib_a-fegetenv.o lib_a-fegetexceptflag.o lib_a-fegetround.o
>>>>>> lib_a-feholdexcept.o lib_a-fenv.o lib_a-feraiseexcept.o lib_a-fesetenv.o
>>>>>> lib_a-fesetexceptflag.o lib_a-fesetround.o lib_a-fetestexcept.o
>>>>>> lib_a-feupdateenv.o lib_a-fenv-vfp.o lib_a-fenv-softfp.o
>>>>>> arm-rtems5-ar: `u' modifier ignored since `D' is the default (see `U')
>>>>>> arm-rtems5-ranlib lib.a
>>>>>> Making all in .
>>>>>> rm -f lib.a
>>>>>> ln arm/lib.a lib.a >/dev/null 2>/dev/null || \
>>>>>> cp arm/lib.a lib.a
>>>>>> rm -f libm.a
>>>>>> rm -rf tmp
>>>>>> mkdir tmp
>>>>>> cd tmp; \
>>>>>> for i in math/lib.a common/lib.a complex/lib.a fenv/lib.a
>>>>>> machine/lib.a; do \
>>>>>> arm-rtems5-ar x ../$i; \
>>>>>> done; \
>>>>>> arm-rtems5-ar rc ../libm.a *.o
>>>>>> arm-rtems5-ranlib libm.a
>>>>>> rm -rf tmp
>>>>>> Making all in doc
>>>>>> gcc -g -g -O2 -c ../../../../newlib-cygwin/newlib/doc/makedoc.c
>>>>>> gcc -g -O2 -o makedoc makedoc.o
>>>>>> Making all in .
>>>>>> rm -f libm.a
>>>>>> ln libm/libm.a libm.a >/dev/null 2>/dev/null || cp libm/libm.a libm.a
>>>>>> rm -rf libc.a libg.a tmp
>>>>>> mkdir tmp
>>>>>> cd tmp; \
>>>>>> arm-rtems5-ar x ../libm.a lib_a-s_fpclassify.o lib_a-sf_fpclassify.o
>>>>>> lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o lib_a-sf_isnan.o
>>>>>> lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o lib_a-sf_isnanf.o
>>>>>> lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o lib_a-sf_ldexp.o
>>>>>> lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o lib_a-sf_modf.o
>>>>>> lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o lib_a-sf_finite.o
>>>>>> lib_a-s_copysign.o lib_a-sf_copysign.o ; \
>>>>>> arm-rtems5-ar x ../libc/libc.a ; \
>>>>>> arm-rtems5-ar rc ../libc.a *.o
>>>>>> arm-rtems5-ranlib libc.a
>>>>>> ln libc.a libg.a >/dev/null 2>/dev/null || cp libc.a libg.a
>>>>>> rm -rf tmp
>>>>>> rm -f crt0.o
>>>>>> ln libc/crt0.o crt0.o >/dev/null 2>/dev/null || cp libc/crt0.o crt0.o
>>>>>>>> --joel
>>>>>>>>>>> --joel
>>>>>>>>>>> On Tue, May 19, 2020 at 3:05 PM Eshan Dhawan <
>>>>>>>>>>>> On Wed, May 20, 2020 at 12:47 AM Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Crap! The default mode <sys/fenv.h> is working is turning the
>>>>>>>>>>>>> methods into static inline which conflicts with the default implementation.
>>>>>>>>>>>>> That's what is happening.
>>>>>>>>>>>>> Cut the static inline bodies out of the arm sys/fenv.h and
>>>>>>>>>>>>> distribute them to libm/arm/XXX.c based on their method name. Drop
>>>>>>>>>>>>> __fenv_static completely.
>>>>>>>>>>>> What will happen to the fenv methods in the fenv.c file
>>>>>>>>>>>>> Make the new split out feXXX.c files FreeBSD copyright. You
>>>>>>>>>>>>> should add a note that you adapted them from their sys/fenv.h with static
>>>>>>>>>>>>> inline to have the bodies in separate files. Make the same type of note in
>>>>>>>>>>>>> the arm sys/fenv.h.
>>>>>>>>>>>>> Sorry to beat the copyright/credit thing but it is important
>>>>>>>>>>>>> to note that the meat of the code came from FreeBSD and you split it into
>>>>>>>>>>>>> files.
>>>>>>>>>>>>> --joel
>>>>>>>>>>>>> On Tue, May 19, 2020 at 1:48 PM Eshan Dhawan <
>>>>>>>>>>>>>> Hello
>>>>>>>>>>>>>> I have encountered a new error
>>>>>>>>>>>>>> the error is coming from libm/fenv
>>>>>>>>>>>>>> link to GitHub repository:
>>>>>>>>>>>>>> https://github.com/eshandhawan51/newlib-cygwin/tree/add_fenv_support
>>>>>>>>>>>>>> Make file log:
>>>>>>>>>>>>>> eshan at EDs-pc:~/development/newlib/c-arm-rtems5-newlib$ make
>>>>>>>>>>>>>> -k
>>>>>>>>>>>>>> make[1]: Entering directory
>>>>>>>>>>>>>> make[2]: Entering directory
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/etc'
>>>>>>>>>>>>>> make[2]: Nothing to be done for 'all'.
>>>>>>>>>>>>>> Checking multilib configuration for newlib...
>>>>>>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2"
>>>>>>>>>>>>>> "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g -O2"
>>>>>>>>>>>>>> "INSTALL=/usr/bin/install -c" "LDFLAGS=" "LIBCFLAGS=-g -O2"
>>>>>>>>>>>>>> "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
>>>>>>>>>>>>>> --split-size=5000000 --split-size=5000000 " "PICFLAG="
>>>>>>>>>>>>>> "PICFLAG_FOR_TARGET=" "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest"
>>>>>>>>>>>>>> "RUNTESTFLAGS=" "exec_prefix=/usr/local" "infodir=/usr/local/share/info"
>>>>>>>>>>>>>> "libdir=/usr/local/lib" "prefix=/usr/local" "tooldir=/usr/local/arm-rtems5"
>>>>>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib" "AR=arm-rtems5-ar"
>>>>>>>>>>>>>> "AS=arm-rtems5-as" "CC=arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> " "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2" "NM=arm-rtems5-nm" "PICFLAG="
>>>>>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
>>>>>>>>>>>>>> make[3]: Entering directory
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
>>>>>>>>>>>>>> if [ -z "thumb vfp/hard thumb/armv6-m thumb/armv7-a
>>>>>>>>>>>>>> thumb/armv7-r thumb/cortex-m3 thumb/cortex-m4 thumb/armv7-a/neon/hard
>>>>>>>>>>>>>> thumb/armv7-r/vfpv3-d16/hard thumb/cortex-m4/fpv4-sp-d16/hard
>>>>>>>>>>>>>> thumb/cortex-m7/fpv5-d16/hard eb/thumb/armv7-r
>>>>>>>>>>>>>> eb/thumb/armv7-r/vfpv3-d16/hard" ]; then \
>>>>>>>>>>>>>> true; \
>>>>>>>>>>>>>> else \
>>>>>>>>>>>>>> rootpre=`${PWDCMD-pwd}`/; export rootpre; \
>>>>>>>>>>>>>> srcrootpre=`cd ../../../newlib-cygwin/newlib;
>>>>>>>>>>>>>> ${PWDCMD-pwd}`/; export srcrootpre; \
>>>>>>>>>>>>>> lib=`echo "${rootpre}" | sed -e
>>>>>>>>>>>>>> 's,^.*/\([^/][^/]*\)/$,\1,'`; \
>>>>>>>>>>>>>> compiler="arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> for i in `${compiler} --print-multi-lib 2>/dev/null`; do \
>>>>>>>>>>>>>> dir=`echo $i | sed -e 's/;.*$//'`; \
>>>>>>>>>>>>>> if [ "${dir}" = "." ]; then \
>>>>>>>>>>>>>> true; \
>>>>>>>>>>>>>> else \
>>>>>>>>>>>>>> if [ -d ../${dir}/${lib} ]; then \
>>>>>>>>>>>>>> flags=`echo $i | sed -e 's/^[^;]*;//' -e 's/@/ -/g'`; \
>>>>>>>>>>>>>> if (cd ../${dir}/${lib}; make "AR_FLAGS=rc"
>>>>>>>>>>>>>> "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2" "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g
>>>>>>>>>>>>>> -O2" "CFLAGS_FOR_TARGET=-g -O2" "INSTALL=/usr/bin/install -c" "LDFLAGS="
>>>>>>>>>>>>>> "LIBCFLAGS=-g -O2" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make"
>>>>>>>>>>>>>> "MAKEINFO=makeinfo --split-size=5000000 --split-size=5000000 " "PICFLAG="
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" \
>>>>>>>>>>>>>> CFLAGS="-g -O2 ${flags}" \
>>>>>>>>>>>>>> CCASFLAGS="-g -O2 ${flags}" \
>>>>>>>>>>>>>> FCFLAGS=" ${flags}" \
>>>>>>>>>>>>>> FFLAGS=" ${flags}" \
>>>>>>>>>>>>>> ADAFLAGS=" ${flags}" \
>>>>>>>>>>>>>> prefix="/usr/local" \
>>>>>>>>>>>>>> exec_prefix="/usr/local" \
>>>>>>>>>>>>>> GCJFLAGS=" ${flags}" \
>>>>>>>>>>>>>> GOCFLAGS="-O2 -g ${flags}" \
>>>>>>>>>>>>>> CXXFLAGS="-g -O2 ${flags}" \
>>>>>>>>>>>>>> LIBCFLAGS="-g -O2 ${flags}" \
>>>>>>>>>>>>>> LIBCXXFLAGS="-g -O2 -fno-implicit-templates ${flags}" \
>>>>>>>>>>>>>> LDFLAGS=" ${flags}" \
>>>>>>>>>>>>>> MULTIFLAGS="${flags}" \
>>>>>>>>>>>>>> DESTDIR="" \
>>>>>>>>>>>>>> INSTALL="/usr/bin/install -c" \
>>>>>>>>>>>>>> INSTALL_DATA="/usr/bin/install -c -m 644" \
>>>>>>>>>>>>>> INSTALL_PROGRAM="/usr/bin/install -c" \
>>>>>>>>>>>>>> INSTALL_SCRIPT="/usr/bin/install -c" \
>>>>>>>>>>>>>> all); then \
>>>>>>>>>>>>>> true; \
>>>>>>>>>>>>>> else \
>>>>>>>>>>>>>> exit 1; \
>>>>>>>>>>>>>> fi; \
>>>>>>>>>>>>>> else true; \
>>>>>>>>>>>>>> fi; \
>>>>>>>>>>>>>> fi; \
>>>>>>>>>>>>>> done; \
>>>>>>>>>>>>>> fi
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib'
>>>>>>>>>>>>>> -mthumb" "CCASFLAGS=-g -O2 -mthumb" "CFLAGS_FOR_BUILD=-g -O2"
>>>>>>>>>>>>>> "CFLAGS_FOR_TARGET=-g -O2" "INSTALL=/usr/bin/install -c" "LDFLAGS=-mthumb"
>>>>>>>>>>>>>> "LIBCFLAGS=-g -O2 -mthumb" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make"
>>>>>>>>>>>>>> "PICFLAG=" "PICFLAG_FOR_TARGET=" "SHELL=/bin/bash" "EXPECT=expect"
>>>>>>>>>>>>>> "RUNTEST=runtest" "RUNTESTFLAGS=" "exec_prefix=/usr/local"
>>>>>>>>>>>>>> "infodir=/usr/local/share/info" "libdir=/usr/local/lib" "prefix=/usr/local"
>>>>>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib/thumb" "AR=arm-rtems5-ar"
>>>>>>>>>>>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include
>>>>>>>>>>>>>> -mthumb" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2 -mthumb" "NM=arm-rtems5-nm"
>>>>>>>>>>>>>> "PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
>>>>>>>>>>>>>> true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> "PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
>>>>>>>>>>>>>> Making all in libc
>>>>>>>>>>>>>> make[7]: Entering directory
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc'
>>>>>>>>>>>>>> Making all in argz
>>>>>>>>>>>>>> make[8]: Entering directory
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/argz'
>>>>>>>>>>>>>> make[8]: Nothing to be done for 'all'.
>>>>>>>>>>>>>> make[8]: Leaving directory
>>>>>>>>>>>>>> Making all in stdlib
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdlib'
>>>>>>>>>>>>>> Making all in ctype
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ctype'
>>>>>>>>>>>>>> Making all in search
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/search'
>>>>>>>>>>>>>> Making all in stdio
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdio'
>>>>>>>>>>>>>> Making all in string
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/string'
>>>>>>>>>>>>>> Making all in signal
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/signal'
>>>>>>>>>>>>>> Making all in time
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/time'
>>>>>>>>>>>>>> Making all in locale
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/locale'
>>>>>>>>>>>>>> Making all in sys
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys'
>>>>>>>>>>>>>> Making all in rtems
>>>>>>>>>>>>>> make[9]: Entering directory
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys/rtems'
>>>>>>>>>>>>>> make[9]: Nothing to be done for 'all'.
>>>>>>>>>>>>>> make[9]: Leaving directory
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> make[9]: Nothing to be done for 'all-am'.
>>>>>>>>>>>>>> Making all in reent
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/reent'
>>>>>>>>>>>>>> Making all in errno
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/errno'
>>>>>>>>>>>>>> Making all in misc
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/misc'
>>>>>>>>>>>>>> Making all in machine
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine'
>>>>>>>>>>>>>> Making all in arm
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine/arm'
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> Making all in unix
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/unix'
>>>>>>>>>>>>>> Making all in posix
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/posix'
>>>>>>>>>>>>>> Making all in ssp
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ssp'
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> make[8]: Nothing to be done for 'all-am'.
>>>>>>>>>>>>>> make[7]: Leaving directory
>>>>>>>>>>>>>> Making all in libm
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm'
>>>>>>>>>>>>>> Making all in math
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/math'
>>>>>>>>>>>>>> Making all in common
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/common'
>>>>>>>>>>>>>> Making all in complex
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/complex'
>>>>>>>>>>>>>> Making all in fenv
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/fenv'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine'
>>>>>>>>>>>>>> Making all in arm
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine/arm'
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> rm -f thumb/crt0.o
>>>>>>>>>>>>>> ln libc/crt0.o thumb/crt0.o >/dev/null 2>/dev/null || cp
>>>>>>>>>>>>>> rm -f thumb/libc.a ./thumb/libg.a
>>>>>>>>>>>>>> ln libc.a thumb/libc.a >/dev/null 2>/dev/null || cp libc.a
>>>>>>>>>>>>>> thumb/libc.a
>>>>>>>>>>>>>> ln libg.a ./thumb/libg.a >/dev/null 2>/dev/null || \
>>>>>>>>>>>>>> cp libg.a ./thumb/libg.a
>>>>>>>>>>>>>> rm -f thumb/libm.a
>>>>>>>>>>>>>> ln libm.a thumb/libm.a >/dev/null 2>/dev/null || cp libm.a
>>>>>>>>>>>>>> thumb/libm.a
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib'
>>>>>>>>>>>>>> -mfpu=vfp -mfloat-abi=hard" "CCASFLAGS=-g -O2 -mfpu=vfp -mfloat-abi=hard"
>>>>>>>>>>>>>> "INSTALL=/usr/bin/install -c" "LDFLAGS=-mfpu=vfp -mfloat-abi=hard"
>>>>>>>>>>>>>> "LIBCFLAGS=-g -O2 -mfpu=vfp -mfloat-abi=hard" "LIBCFLAGS_FOR_TARGET=-g
>>>>>>>>>>>>>> -O2" "MAKE=make" "MAKEINFO=makeinfo --split-size=5000000
>>>>>>>>>>>>>> --split-size=5000000 " "PICFLAG=" "PICFLAG_FOR_TARGET="
>>>>>>>>>>>>>> "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest" "RUNTESTFLAGS="
>>>>>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib/vfp/hard" "AR=arm-rtems5-ar"
>>>>>>>>>>>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include
>>>>>>>>>>>>>> -mfpu=vfp -mfloat-abi=hard" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2
>>>>>>>>>>>>>> -mfpu=vfp -mfloat-abi=hard" "NM=arm-rtems5-nm" "PICFLAG="
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> Making all in libc
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc'
>>>>>>>>>>>>>> Making all in argz
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/argz'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdlib'
>>>>>>>>>>>>>> Making all in ctype
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ctype'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/search'
>>>>>>>>>>>>>> Making all in stdio
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdio'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/string'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/signal'
>>>>>>>>>>>>>> Making all in time
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/time'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/locale'
>>>>>>>>>>>>>> Making all in sys
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys'
>>>>>>>>>>>>>> Making all in rtems
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys/rtems'
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> Making all in reent
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/reent'
>>>>>>>>>>>>>> Making all in errno
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/errno'
>>>>>>>>>>>>>> Making all in misc
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/misc'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine'
>>>>>>>>>>>>>> Making all in arm
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine/arm'
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> Making all in unix
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/unix'
>>>>>>>>>>>>>> Making all in posix
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/posix'
>>>>>>>>>>>>>> Making all in ssp
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ssp'
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> Making all in libm
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm'
>>>>>>>>>>>>>> Making all in math
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/math'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/common'
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/complex'
>>>>>>>>>>>>>> Making all in fenv
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/fenv'
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> -mfpu=vfp -mfloat-abi=hard -DPACKAGE_NAME=\"newlib\"
>>>>>>>>>>>>>> -DPACKAGE_TARNAME=\"newlib\" -DPACKAGE_VERSION=\"3.3.0\"
>>>>>>>>>>>>>> -DPACKAGE_STRING=\"newlib\ 3.3.0\" -DPACKAGE_BUGREPORT=\"\"
>>>>>>>>>>>>>> -I../../../../../../../newlib-cygwin/newlib/libm/fenv -fno-builtin
>>>>>>>>>>>>>> -ffunction-sections -fdata-sections -D_COMPILING_NEWLIB -DCLOCK_PROVIDED
>>>>>>>>>>>>>> -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED -DGETREENT_PROVIDED
>>>>>>>>>>>>>> -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL
>>>>>>>>>>>>>> -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS
>>>>>>>>>>>>>> -D_NO_SIGSET -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI
>>>>>>>>>>>>>> -fbuiltin -fno-math-errno -g -O2 -mfpu=vfp -mfloat-abi=hard -c -o
>>>>>>>>>>>>>> lib_a-feclearexcept.o `test -f 'feclearexcept.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feclearexcept.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:64:5:
>>>>>>>>>>>>>> error: redefinition of 'feclearexcept'
>>>>>>>>>>>>>> In file included from
>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:15:0,
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:126:1:
>>>>>>>>>>>>>> note: previous definition of 'feclearexcept' was here
>>>>>>>>>>>>>> Makefile:347: recipe for target 'lib_a-feclearexcept.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-feclearexcept.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-fegetenv.o `test -f 'fegetenv.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetenv.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:64:5:
>>>>>>>>>>>>>> error: redefinition of 'fegetenv'
>>>>>>>>>>>>>> int fegetenv(fenv_t *envp)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:198:1:
>>>>>>>>>>>>>> note: previous definition of 'fegetenv' was here
>>>>>>>>>>>>>> Makefile:359: recipe for target 'lib_a-fegetenv.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-fegetenv.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-fegetexceptflag.o `test -f 'fegetexceptflag.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetexceptflag.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:65:5:
>>>>>>>>>>>>>> error: redefinition of 'fegetexceptflag'
>>>>>>>>>>>>>> int fegetexceptflag(fexcept_t *flagp, int excepts)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:137:1:
>>>>>>>>>>>>>> note: previous definition of 'fegetexceptflag' was here
>>>>>>>>>>>>>> Makefile:365: recipe for target 'lib_a-fegetexceptflag.o'
>>>>>>>>>>>>>> failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-fegetexceptflag.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-fegetround.o `test -f 'fegetround.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetround.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:63:5:
>>>>>>>>>>>>>> error: redefinition of 'fegetround'
>>>>>>>>>>>>>> int fegetround(void)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:177:1:
>>>>>>>>>>>>>> note: previous definition of 'fegetround' was here
>>>>>>>>>>>>>> fegetround(void)
>>>>>>>>>>>>>> Makefile:371: recipe for target 'lib_a-fegetround.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-fegetround.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-feholdexcept.o `test -f 'feholdexcept.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feholdexcept.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:67:5:
>>>>>>>>>>>>>> error: redefinition of 'feholdexcept'
>>>>>>>>>>>>>> int feholdexcept(fenv_t *envp)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:206:1:
>>>>>>>>>>>>>> note: previous definition of 'feholdexcept' was here
>>>>>>>>>>>>>> Makefile:377: recipe for target 'lib_a-feholdexcept.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-feholdexcept.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-feraiseexcept.o `test -f 'feraiseexcept.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feraiseexcept.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:64:5:
>>>>>>>>>>>>>> error: redefinition of 'feraiseexcept'
>>>>>>>>>>>>>> int feraiseexcept(int excepts)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:159:1:
>>>>>>>>>>>>>> note: previous definition of 'feraiseexcept' was here
>>>>>>>>>>>>>> Makefile:383: recipe for target 'lib_a-feraiseexcept.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-feraiseexcept.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-fesetenv.o `test -f 'fesetenv.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetenv.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:69:5:
>>>>>>>>>>>>>> error: redefinition of 'fesetenv'
>>>>>>>>>>>>>> int fesetenv(const fenv_t *envp)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:218:1:
>>>>>>>>>>>>>> note: previous definition of 'fesetenv' was here
>>>>>>>>>>>>>> Makefile:389: recipe for target 'lib_a-fesetenv.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-fesetenv.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-fesetexceptflag.o `test -f 'fesetexceptflag.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetexceptflag.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:70:5:
>>>>>>>>>>>>>> error: redefinition of 'fesetexceptflag'
>>>>>>>>>>>>>> int fesetexceptflag(const fexcept_t *flagp, int excepts)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:147:1:
>>>>>>>>>>>>>> note: previous definition of 'fesetexceptflag' was here
>>>>>>>>>>>>>> Makefile:395: recipe for target 'lib_a-fesetexceptflag.o'
>>>>>>>>>>>>>> failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-fesetexceptflag.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-fesetround.o `test -f 'fesetround.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetround.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:64:5:
>>>>>>>>>>>>>> error: redefinition of 'fesetround'
>>>>>>>>>>>>>> int fesetround(int round)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:186:1:
>>>>>>>>>>>>>> note: previous definition of 'fesetround' was here
>>>>>>>>>>>>>> Makefile:401: recipe for target 'lib_a-fesetround.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-fesetround.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-fetestexcept.o `test -f 'fetestexcept.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fetestexcept.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:65:5:
>>>>>>>>>>>>>> error: redefinition of 'fetestexcept'
>>>>>>>>>>>>>> int fetestexcept(int excepts)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:30:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:168:1:
>>>>>>>>>>>>>> note: previous definition of 'fetestexcept' was here
>>>>>>>>>>>>>> Makefile:407: recipe for target 'lib_a-fetestexcept.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-fetestexcept.o] Error 1
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>> lib_a-feupdateenv.o `test -f 'feupdateenv.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feupdateenv.c
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:69:5:
>>>>>>>>>>>>>> error: redefinition of 'feupdateenv'
>>>>>>>>>>>>>> int feupdateenv(const fenv_t *envp)
>>>>>>>>>>>>>> from
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:29:
>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:226:1:
>>>>>>>>>>>>>> note: previous definition of 'feupdateenv' was here
>>>>>>>>>>>>>> Makefile:413: recipe for target 'lib_a-feupdateenv.o' failed
>>>>>>>>>>>>>> make[8]: *** [lib_a-feupdateenv.o] Error 1
>>>>>>>>>>>>>> make[8]: Target 'all' not remade because of errors.
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine'
>>>>>>>>>>>>>> Making all in arm
>>>>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine/arm'
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> rm -f libm.a
>>>>>>>>>>>>>> rm -rf tmp
>>>>>>>>>>>>>> mkdir tmp
>>>>>>>>>>>>>> cd tmp; \
>>>>>>>>>>>>>> machine/lib.a; do \
>>>>>>>>>>>>>> done; \
>>>>>>>>>>>>>> arm-rtems5-ar: ../fenv/lib.a: No such file or directory
>>>>>>>>>>>>>> rm -rf tmp
>>>>>>>>>>>>>> make[7]: *** [all-recursive] Error 1
>>>>>>>>>>>>>> make[7]: Target 'all' not remade because of errors.
>>>>>>>>>>>>>> Making all in .
>>>>>>>>>>>>>> rm -f libm.a
>>>>>>>>>>>>>> libm/libm.a libm.a
>>>>>>>>>>>>>> mkdir tmp
>>>>>>>>>>>>>> cd tmp; \
>>>>>>>>>>>>>> lib_a-sf_fpclassify.o lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o
>>>>>>>>>>>>>> lib_a-sf_isnan.o lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o
>>>>>>>>>>>>>> lib_a-sf_isnanf.o lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o
>>>>>>>>>>>>>> lib_a-sf_ldexp.o lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o
>>>>>>>>>>>>>> lib_a-sf_modf.o lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o
>>>>>>>>>>>>>> lib_a-sf_finite.o lib_a-s_copysign.o lib_a-sf_copysign.o ; \
>>>>>>>>>>>>>> rm -rf tmp
>>>>>>>>>>>>>> rm -f vfp/hard/crt0.o
>>>>>>>>>>>>>> ln libc/crt0.o vfp/hard/crt0.o >/dev/null 2>/dev/null || cp
>>>>>>>>>>>>>> rm -f vfp/hard/libc.a ./vfp/hard/libg.a
>>>>>>>>>>>>>> ln libc.a vfp/hard/libc.a >/dev/null 2>/dev/null || cp libc.a
>>>>>>>>>>>>>> vfp/hard/libc.a
>>>>>>>>>>>>>> ln libg.a ./vfp/hard/libg.a >/dev/null 2>/dev/null || \
>>>>>>>>>>>>>> cp libg.a ./vfp/hard/libg.a
>>>>>>>>>>>>>> rm -f vfp/hard/libm.a
>>>>>>>>>>>>>> ln libm.a vfp/hard/libm.a >/dev/null 2>/dev/null || cp libm.a
>>>>>>>>>>>>>> vfp/hard/libm.a
>>>>>>>>>>>>>> make[6]: *** [all-recursive] Error 1
>>>>>>>>>>>>>> make[5]: *** [all] Error 2
>>>>>>>>>>>>>> Makefile:1260: recipe for target 'multi-do' failed
>>>>>>>>>>>>>> make[4]: *** [multi-do] Error 1
>>>>>>>>>>>>>> Makefile:1176: recipe for target 'all-multi' failed
>>>>>>>>>>>>>> make[3]: *** [all-multi] Error 2
>>>>>>>>>>>>>> make[3]: Target 'all-recursive' not remade because of errors.
>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>> -Eshan :)
>>>>>>>>>>>>>> On Sat, May 16, 2020 at 8:09 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> On Fri, May 15, 2020, 5:59 PM Eshan Dhawan <
>>>>>>>>>>>>>>>> On Fri, May 15, 2020 at 2:22 AM Eshan Dhawan <
>>>>>>>>>>>>>>>>> On Wed, May 13, 2020 at 7:40 PM Joel Sherrill <
>>>>>>>>>>>>>>>>>> National free hint day!!!
>>>>>>>>>>>>>>>>>> Look above the line that is reported. You will see
>>>>>>>>>>>>>>>>>> __BEGIN_DECL. It isn't defined. It is intended to expand to the __cplusplus
>>>>>>>>>>>>>>>>>> wrapper.
>>>>>>>>>>>>>>>>>> After you fix this, you will sequentially find 2 other
>>>>>>>>>>>>>>>>>> things to change in this file.
>>>>>>>>>>>>>>>>>> I have made those changes when a new error occurs from
>>>>>>>>>>>>>>>>> the assembler in arm thumb mode
>>>>>>>>>>>>>>>>> There is no support for vfp instructions in arm thumb.
>>>>>>>>>>>>>>>>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html
>>>>>>>>>>>>>>>>> So in which file will the compiler instructions given in
>>>>>>>>>>>>>>>>> the page
>>>>>>>>>>>>>>>>> <http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html>
>>>>>>>>>>>>>>>>> added?
>>>>>>>>>>>>>>>> FreeBSD has added file and architecture-specific flags in
>>>>>>>>>>>>>>>> their makefile.inc
>>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/Makefile.inc
>>>>>>>>>>>>>>>> How will it be added in newlib
>>>>>>>>>>>>>>>> I tried adding the flags -mfpu=vfp -mfloat-abi=softfp (used
>>>>>>>>>>>>>>>> in FreeBSD) to makefile.in but no effect.
>>>>>>>>>>>>>>> This isn't going to work with newlib. They don't specify CPU
>>>>>>>>>>>>>>> flags that way.
>>>>>>>>>>>>>>> The fenv code is going to have to compile for every multilib
>>>>>>>>>>>>>>> variant built by arm-rtems and arm-eabi. You will have to use conditionals
>>>>>>>>>>>>>>> based on the flags gcc uses to indicate the various cpu features. This
>>>>>>>>>>>>>>> command should be close to how you you dump them.
>>>>>>>>>>>>>>> gcc -dM -E - </dev/null
>>>>>>>>>>>>>>> Add a CPU flag and see how the setting change.
>>>>>>>>>>>>>>> You can also look in rtems score cpu arm for examples since
>>>>>>>>>>>>>>> the core arm code will be dealing with these.
>>>>>>>>>>>>>>> --joel
>>>>>>>>>>>>>>>> thanks
>>>>>>>>>>>>>>>> -Eshan
>>>>>>>>>>>>>>>>> Errors :
>>>>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>>>>> -mthumb -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
>>>>>>>>>>>>>>>>> -I../../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
>>>>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
>>>>>>>>>>>>>>>>> -fno-builtin -mfpu=vfpv2 -ffunction-sections -fdata-sections
>>>>>>>>>>>>>>>>> -D_COMPILING_NEWLIB -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED
>>>>>>>>>>>>>>>>> -DSIGNAL_PROVIDED -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED
>>>>>>>>>>>>>>>>> -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC
>>>>>>>>>>>>>>>>> -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET
>>>>>>>>>>>>>>>>> -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI -g -O2
>>>>>>>>>>>>>>>>> -mthumb -c -o lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
>>>>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s: Assembler messages:
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:37: Error: selected processor does not
>>>>>>>>>>>>>>>>> support `vmrs r3,fpscr' in Thumb mode
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:48: Error: selected processor does not
>>>>>>>>>>>>>>>>> support `vmsr fpscr,r3' in Thumb mode
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:81: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:119: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:134: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:169: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:182: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:217: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:251: Error: selected processor does not
>>>>>>>>>>>>>>>>> support `vmrs r0,fpscr' in Thumb mode
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:288: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:303: Error: selected processor does not
>>>>>>>>>>>>>>>>> support `vmsr fpscr,r0' in Thumb mode
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:340: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:374: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:390: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:424: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:457: Error: selected processor does not
>>>>>>>>>>>>>>>>> support `vmrs r1,fpscr' in Thumb mode
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:466: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:478: Error: selected processor does not
>>>>>>>>>>>>>>>>> support `vmrs r2,fpscr' in Thumb mode
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:503: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:543: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:559: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:595: Error: selected processor does not
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:612: Error: selected processor does not
>>>>>>>>>>>>>>>>> support `vmsr fpscr,r2' in Thumb mode
>>>>>>>>>>>>>>>>> /tmp/ccEHiFws.s:647: Error: selected processor does not
>>>>>>>>>>>>>>>>> make[9]: *** [lib_a-fenv-vfp.o] Error 1
>>>>>>>>>>>>>>>>> make[8]: *** [all-recursive] Error 1
>>>>>>>>>>>>>>>>> -Eshan
>>>>>>>>>>>>>>>>>> Then we need to make a decision whether the static inline
>>>>>>>>>>>>>>>>>> versions of the methods in sys/fenv.h are appropriate for newlib or not.
>>>>>>>>>>>>>>>>>> --joel
>>>>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 5:20 PM Joel Sherrill <
>>>>>>>>>>>>>>>>>>> Gedare is right but one more piece of information is
>>>>>>>>>>>>>>>>>>> needed. When newlib is being built, it lays target dependent files on top
>>>>>>>>>>>>>>>>>>> of generic ones. So the default sys/fenv.h is replaced with something like
>>>>>>>>>>>>>>>>>>> libc/machine/arm/sys/fenv.h. Make sure that
>>>>>>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h is
>>>>>>>>>>>>>>>>>>> in fact the file you think it should be.
>>>>>>>>>>>>>>>>>>> Also look at what is supposed to be in the generic
>>>>>>>>>>>>>>>>>>> fenv.h and <sys/fenv.h>. You will probably have to tweak it some.
>>>>>>>>>>>>>>>>>>> Check out what is in x86_64/fenv.h and riscv/fenv.h with
>>>>>>>>>>>>>>>>>>> respect to the default environment variable. It looks to be declared
>>>>>>>>>>>>>>>>>>> differently in the other ports so you may have to make it match.
>>>>>>>>>>>>>>>>>>> But more output does help.
>>>>>>>>>>>>>>>>>>> --joel
>>>>>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 4:53 PM Gedare Bloom <
>>>>>>>>>>>>>>>>>>> gedare at rtems.org> wrote:
>>>>>>>>>>>>>>>>>>>> Take the first error reported, and show what is being
>>>>>>>>>>>>>>>>>>>> compiled. You've
>>>>>>>>>>>>>>>>>>>> trimmed off too much preceding this to know what is
>>>>>>>>>>>>>>>>>>>> being compiled and
>>>>>>>>>>>>>>>>>>>> how this might be influencing your error.
>>>>>>>>>>>>>>>>>>>> The specific error you're getting is often due to some
>>>>>>>>>>>>>>>>>>>> syntax errors
>>>>>>>>>>>>>>>>>>>> preceding the line shown.
>>>>>>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 2:59 PM Eshan Dhawan <
>>>>>>>>>>>>>>>>>>>> > Hello everyone,
>>>>>>>>>>>>>>>>>>>> > After adding the files and compiling. I am
>>>>>>>>>>>>>>>>>>>> > getting a few errors which I am not able to rectify.
>>>>>>>>>>>>>>>>>>>> > If you could take a look and tell how to sort them.
>>>>>>>>>>>>>>>>>>>> > link to newlib's git repo:
>>>>>>>>>>>>>>>>>>>> > errors :
>>>>>>>>>>>>>>>>>>>> > from
>>>>>>>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include/sys/fenv.h:82:1:
>>>>>>>>>>>>>>>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'extern'
>>>>>>>>>>>>>>>>>>>> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:0:
>>>>>>>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:22:1:
>>>>>>>>>>>>>>>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'int'
>>>>>>>>>>>>>>>>>>>> > thanks
>>>>>>>>>>>>>>>>>>>> > -Eshan
>>>>>>>>>>>>>>>>>>>> > On Sat, May 9, 2020 at 2:53 AM Joel Sherrill <
>>>>>>>>>>>>>>>>>>>> >> On Thu, May 7, 2020 at 1:33 PM Eshan Dhawan <
>>>>>>>>>>>>>>>>>>>> >>> Hello everyone,
>>>>>>>>>>>>>>>>>>>> >>> This the tread to discuss adding fenv support for
>>>>>>>>>>>>>>>>>>>> ARM architecture in newlib.
>>>>>>>>>>>>>>>>>>>> >>> Link to previous thread:
>>>>>>>>>>>>>>>>>>>> https://lists.rtems.org/pipermail/devel/2020-March/058473.html
>>>>>>>>>>>>>>>>>>>> >>> ---FreeBSD Source
>>>>>>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>>>>>>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/blob/master/sys/arm/include/ieeefp.h
>>>>>>>>>>>>>>>>>>>> >>> ---NetBSD Source
>>>>>>>>>>>>>>>>>>>> https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>>>>>>>>>>>>>>>>>>>> >>> --- Musl has no implementation for fenv support for
>>>>>>>>>>>>>>>>>>>> ARM in it
>>>>>>>>>>>>>>>>>>>> >>> After going through the implementations both
>>>>>>>>>>>>>>>>>>>> FreeBSD and NetBSD have a stub implementation.
>>>>>>>>>>>>>>>>>>>> >>> But then FreeBSD implementation seems to be more
>>>>>>>>>>>>>>>>>>>> portable compared to that in NetBSD.
>>>>>>>>>>>>>>>>>>>> >>> Should I start porting it from FreeBSD?
>>>>>>>>>>>>>>>>>>>> >>> And which ARM BSP should I use for testing the
>>>>>>>>>>>>>>>>>>>> changes?
>>>>>>>>>>>>>>>>>>>> >>> Currently, I have xilinx_zynq_a9_qemu build
>>>>>>>>>>>>>>>>>>>> >> I think the FreeBSD implementation is the one to
>>>>>>>>>>>>>>>>>>>> use. It looks to support hard and soft floating point implementations.
>>>>>>>>>>>>>>>>>>>> >> I think the fenv.h file there will have to be worked
>>>>>>>>>>>>>>>>>>>> on so some of the contents go into sys or machine/fenv.h. There is a
>>>>>>>>>>>>>>>>>>>> portable fenv.h.
>>>>>>>>>>>>>>>>>>>> >>> There would also be a requirement to discuss where
>>>>>>>>>>>>>>>>>>>> to place the files in Newlib.
>>>>>>>>>>>>>>>>>>>> >> Not much to discuss. It should go into
>>>>>>>>>>>>>>>>>>>> newlib-cygwin/newlib/libm/machine/arm.
>>>>>>>>>>>>>>>>>>>> >>> Thanks
>>>>>>>>>>>>>>>>>>>> >>> -Eshan
>>>>>>>>>>>>>>>>>>>> > _______________________________________________
>>>>>>>>>>>>>>>>>>>> > devel mailing list
>>>>>>>>>>>>>>>>>>>> > devel at rtems.org
>>>>>>>>>>>>>>>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200523/388ec512/attachment-0001.html>
