[PATCH] Adding fenv support arm.
Eshan dhawan
eshandhawan51 at gmail.com
Fri May 22 23:36:32 UTC 2020
This patch adds FENV support for ARM
The code is ported from FreeBSD.
Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
newlib/libc/machine/arm/machine/acle-compat.h | 182 ++++++++++
newlib/libc/machine/arm/machine/fenv-mangle.h | 53 +++
.../libc/machine/arm/machine/fenv-softfloat.h | 187 ++++++++++
newlib/libc/machine/arm/machine/fenv-vfp.h | 187 ++++++++++
newlib/libc/machine/arm/sys/fenv.h | 122 +++++++
newlib/libm/machine/arm/Makefile.am | 18 +-
newlib/libm/machine/arm/Makefile.in | 174 +++++++++-
newlib/libm/machine/arm/fe_dfl_env.c | 7 +
newlib/libm/machine/arm/feclearexcept.c | 7 +
newlib/libm/machine/arm/fegetenv.c | 7 +
newlib/libm/machine/arm/fegetexceptflag.c | 7 +
newlib/libm/machine/arm/fegetround.c | 7 +
newlib/libm/machine/arm/feholdexcept.c | 7 +
newlib/libm/machine/arm/fenv-softfp.c | 32 ++
newlib/libm/machine/arm/fenv-vfp.c | 32 ++
newlib/libm/machine/arm/fenv.c | 328 ++++++++++++++++++
newlib/libm/machine/arm/feraiseexcept.c | 7 +
newlib/libm/machine/arm/fesetenv.c | 7 +
newlib/libm/machine/arm/fesetexceptflag.c | 7 +
newlib/libm/machine/arm/fesetround.c | 7 +
newlib/libm/machine/arm/fetestexcept.c | 7 +
newlib/libm/machine/arm/feupdateenv.c | 7 +
22 files changed, 1380 insertions(+), 19 deletions(-)
create mode 100644 newlib/libc/machine/arm/machine/acle-compat.h
create mode 100644 newlib/libc/machine/arm/machine/fenv-mangle.h
create mode 100644 newlib/libc/machine/arm/machine/fenv-softfloat.h
create mode 100644 newlib/libc/machine/arm/machine/fenv-vfp.h
create mode 100644 newlib/libc/machine/arm/sys/fenv.h
create mode 100644 newlib/libm/machine/arm/fe_dfl_env.c
create mode 100644 newlib/libm/machine/arm/feclearexcept.c
create mode 100644 newlib/libm/machine/arm/fegetenv.c
create mode 100644 newlib/libm/machine/arm/fegetexceptflag.c
create mode 100644 newlib/libm/machine/arm/fegetround.c
create mode 100644 newlib/libm/machine/arm/feholdexcept.c
create mode 100644 newlib/libm/machine/arm/fenv-softfp.c
create mode 100644 newlib/libm/machine/arm/fenv-vfp.c
create mode 100644 newlib/libm/machine/arm/fenv.c
create mode 100644 newlib/libm/machine/arm/feraiseexcept.c
create mode 100644 newlib/libm/machine/arm/fesetenv.c
create mode 100644 newlib/libm/machine/arm/fesetexceptflag.c
create mode 100644 newlib/libm/machine/arm/fesetround.c
create mode 100644 newlib/libm/machine/arm/fetestexcept.c
create mode 100644 newlib/libm/machine/arm/feupdateenv.c
diff --git a/newlib/libc/machine/arm/machine/acle-compat.h b/newlib/libc/machine/arm/machine/acle-compat.h
new file mode 100644
index 000000000..888ae2ea8
--- /dev/null
+++ b/newlib/libc/machine/arm/machine/acle-compat.h
@@ -0,0 +1,182 @@
+ * Copyright (c) 2014 ARM Ltd
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 3. The name of the company may not be used to endorse or promote
+ * products derived from this software without specific prior written
+ * permission.
+ * THIS SOFTWARE IS PROVIDED BY ARM LTD ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL ARM LTD BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
+ * TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+ * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+ * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+ * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#ifndef __ARM_ARCH
+/* ACLE standardises a set of pre-defines that describe the ARM architecture.
+ These were mostly implemented in GCC around GCC-4.8; older versions
+ have no, or only partial support. To provide a level of backwards
+ compatibility we try to work out what the definitions should be, given
+ the older pre-defines that GCC did produce. This isn't complete, but
+ it should be enough for use by routines that depend on this header. */
+/* No need to handle ARMv8, GCC had ACLE support before that. */
+# ifdef __ARM_ARCH_7__
+/* The common subset of ARMv7 in all profiles. */
+# define __ARM_ARCH 7
+# define __ARM_ARCH_ISA_THUMB 2
+# define __ARM_FEATURE_CLZ
+# define __ARM_FEATURE_LDREX 7
+# define __ARM_FEATURE_UNALIGNED
+# endif
+# if defined (__ARM_ARCH_7A__) || defined (__ARM_ARCH_7R__)
+# define __ARM_ARCH_ISA_ARM
+# define __ARM_FEATURE_SIMD32
+# define __ARM_FEATURE_DSP
+# define __ARM_FEATURE_QBIT
+# define __ARM_FEATURE_SAT
+# define __ARM_FEATURE_LDREX 15
+# ifdef __ARM_ARCH_7A__
+# define __ARM_ARCH_PROFILE 'A'
+# else
+# define __ARM_ARCH_PROFILE 'R'
+# endif
+# endif
+# ifdef __ARM_ARCH_7EM__
+# define __ARM_ARCH_PROFILE 'M'
+# endif
+# ifdef __ARM_ARCH_7M__
+# endif
+# ifdef __ARM_ARCH_6T2__
+# define __ARM_ARCH 6
+# define __ARM_FEATURE_LDREX 4
+# endif
+# ifdef __ARM_ARCH_6M__
+# define __ARM_ARCH_ISA_THUMB 1
+# endif
+# if defined (__ARM_ARCH_6__) || defined (__ARM_ARCH_6J__) \
+ || defined (__ARM_ARCH_6K__) || defined (__ARM_ARCH_6Z__) \
+ || defined (__ARM_ARCH_6ZK__)
+# ifndef __thumb__
+# if defined (__ARM_ARCH_6K__) || defined (__ARM_ARCH_6ZK__)
+# else
+# endif
+# endif
+# endif
+# if defined (__ARM_ARCH_5TE__) || defined (__ARM_ARCH_5E__)
+# define __ARM_ARCH 5
+# ifdef __ARM_ARCH_5TE__
+# endif
+# endif
+# if defined (__ARM_ARCH_5T__) || defined (__ARM_ARCH_5__)
+# endif
+# endif
+# ifdef __ARM_ARCH_4T__
+# define __ARM_ARCH 4
+# endif
+# ifdef __ARM_ARCH_4__
+# endif
+# if defined (__ARM_ARCH_3__) || defined (__ARM_ARCH_3M__)
+# define __ARM_ARCH 3
+# endif
+# ifdef __ARM_ARCH_2__
+# define __ARM_ARCH 2
+# endif
+# ifdef __ARMEB__
+# define __ARM_BIG_ENDIAN
+# endif
+/* If we still don't know what the target architecture is, then we're
+ probably not using GCC. */
+# ifndef __ARM_ARCH
+# error Unable to determine architecture version.
+# endif
+#endif /* __ARM_ARCH */
diff --git a/newlib/libc/machine/arm/machine/fenv-mangle.h b/newlib/libc/machine/arm/machine/fenv-mangle.h
index 000000000..476f7b20c
--- /dev/null
+++ b/newlib/libc/machine/arm/machine/fenv-mangle.h
@@ -0,0 +1,53 @@
+ * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifdef _FENV_MANGLE_H_
+#error Only include fenv-mangle.h once
+#endif
+#define _FENV_MANGLE_H_
+#ifndef FENV_MANGLE
+#error FENV_MANGLE is undefined
+#endif
+#define feclearexcept FENV_MANGLE(feclearexcept)
+#define fegetexceptflag FENV_MANGLE(fegetexceptflag)
+#define fesetexceptflag FENV_MANGLE(fesetexceptflag)
+#define feraiseexcept FENV_MANGLE(feraiseexcept)
+#define fetestexcept FENV_MANGLE(fetestexcept)
+#define fegetround FENV_MANGLE(fegetround)
+#define fesetround FENV_MANGLE(fesetround)
+#define fegetenv FENV_MANGLE(fegetenv)
+#define feholdexcept FENV_MANGLE(feholdexcept)
+#define fesetenv FENV_MANGLE(fesetenv)
+#define feupdateenv FENV_MANGLE(feupdateenv)
+#define feenableexcept FENV_MANGLE(feenableexcept)
+#define fedisableexcept FENV_MANGLE(fedisableexcept)
+#define fegetexcept FENV_MANGLE(fegetexcept)
diff --git a/newlib/libc/machine/arm/machine/fenv-softfloat.h b/newlib/libc/machine/arm/machine/fenv-softfloat.h
index 000000000..e53e54f54
--- /dev/null
+++ b/newlib/libc/machine/arm/machine/fenv-softfloat.h
@@ -0,0 +1,187 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2004-2011 David Schultz <das at FreeBSD.ORG>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SYS_FENV_H_
+#error "This file is meant to be included only by <sys/fenv.h>."
+#endif
+/* the file can be added from architecture specific fenv.h file found in
+ *libc/sys/arch/sys *
+ * This file implements the functionality of <fenv.h> on platforms that
+ * lack an FPU and use softfloat in libc for floating point. To use it,
+ * you must write an <fenv.h> that provides the following:
+ * - a typedef for fenv_t, which may be an integer or struct type
+ * - a typedef for fexcept_t (XXX This file assumes fexcept_t is a
+ * simple integer type containing the exception mask.)
+ * - definitions of FE_* constants for the five exceptions and four
+ * rounding modes in IEEE 754, as described in fenv(3)
+ * - a definition, and the corresponding external symbol, for FE_DFL_ENV
+ * - a macro __set_env(env, flags, mask, rnd), which sets the given fenv_t
+ * from the exception flags, mask, and rounding mode
+ * - macros __env_flags(env), __env_mask(env), and __env_round(env), which
+ * extract fields from an fenv_t
+ * - a definition of __fenv_static
+ * If the architecture supports an optional FPU, it's recommended that you
+ * define fenv_t and fexcept_t to match the hardware ABI. Otherwise, it
+ * doesn't matter how you define them.
+extern int __softfloat_float_exception_flags;
+extern int __softfloat_float_exception_mask;
+extern int __softfloat_float_rounding_mode;
+void __softfloat_float_raise(int);
+__fenv_static inline int
+feclearexcept(int excepts)
+ __softfloat_float_exception_flags &= ~excepts;
+ return (0);
+fegetexceptflag(fexcept_t *flagp, int excepts)
+ *flagp = __softfloat_float_exception_flags & excepts;
+ return (0);
+fesetexceptflag(const fexcept_t *flagp, int excepts)
+ __softfloat_float_exception_flags |= *flagp & excepts;
+ return (0);
+feraiseexcept(int excepts)
+ __softfloat_float_raise(excepts);
+ return (0);
+fetestexcept(int excepts)
+ return (__softfloat_float_exception_flags & excepts);
+fegetround(void)
+ return (__softfloat_float_rounding_mode);
+fesetround(int round)
+ __softfloat_float_rounding_mode = round;
+ return (0);
+fegetenv(fenv_t *envp)
+ __set_env(*envp, __softfloat_float_exception_flags,
+ __softfloat_float_exception_mask, __softfloat_float_rounding_mode);
+ return (0);
+feholdexcept(fenv_t *envp)
+ fenv_t __env;
+ fegetenv(envp);
+ __softfloat_float_exception_flags = 0;
+ __softfloat_float_exception_mask = 0;
+ return (0);
+fesetenv(const fenv_t *envp)
+ __softfloat_float_exception_flags = __env_flags(*envp);
+ __softfloat_float_exception_mask = __env_mask(*envp);
+ __softfloat_float_rounding_mode = __env_round(*envp);
+ return (0);
+feupdateenv(const fenv_t *envp)
+ int __oflags = __softfloat_float_exception_flags;
+ fesetenv(envp);
+ feraiseexcept(__oflags);
+ return (0);
+#if __BSD_VISIBLE
+/* We currently provide no external definitions of the functions below. */
+feenableexcept(int __mask)
+ int __omask = __softfloat_float_exception_mask;
+ __softfloat_float_exception_mask |= __mask;
+ return (__omask);
+fedisableexcept(int __mask)
+ __softfloat_float_exception_mask &= ~__mask;
+ return (__omask);
+fegetexcept(void)
+ return (__softfloat_float_exception_mask);
+#endif /* __BSD_VISIBLE */
diff --git a/newlib/libc/machine/arm/machine/fenv-vfp.h b/newlib/libc/machine/arm/machine/fenv-vfp.h
index 000000000..25d71f3ab
--- /dev/null
+++ b/newlib/libc/machine/arm/machine/fenv-vfp.h
@@ -0,0 +1,187 @@
+ * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#define vmrs_fpscr(__r) __asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
+#define vmsr_fpscr(__r) __asm __volatile("vmsr fpscr, %0" : : "r"(__r))
+#define _FPU_MASK_SHIFT 8
+__fenv_static inline int feclearexcept(int excepts)
+ fexcept_t __fpsr;
+ vmrs_fpscr(__fpsr);
+ __fpsr &= ~excepts;
+ vmsr_fpscr(__fpsr);
+ return (0);
+ fexcept_t __fpsr;
+ *flagp = __fpsr & excepts;
+ return (0);
+ fexcept_t __fpsr;
+ __fpsr |= *flagp & excepts;
+ return (0);
+ fexcept_t __ex = excepts;
+ fesetexceptflag(&__ex, excepts); /* XXX */
+ return (0);
+ fexcept_t __fpsr;
+ return (__fpsr & excepts);
+fegetround(void)
+ fenv_t __fpsr;
+ return (__fpsr & _ROUND_MASK);
+ fenv_t __fpsr;
+ __fpsr &= ~(_ROUND_MASK);
+ __fpsr |= round;
+ return (0);
+ vmrs_fpscr(*envp);
+ return (0);
+ fenv_t __env;
+ vmrs_fpscr(__env);
+ *envp = __env;
+ __env &= ~(FE_ALL_EXCEPT);
+ vmsr_fpscr(__env);
+ return (0);
+ vmsr_fpscr(*envp);
+ return (0);
+ fexcept_t __fpsr;
+ feraiseexcept(__fpsr & FE_ALL_EXCEPT);
+ return (0);
+#if __BSD_VISIBLE
+ fenv_t __old_fpsr, __new_fpsr;
+ vmrs_fpscr(__old_fpsr);
+ __new_fpsr = __old_fpsr |
+ ((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
+ vmsr_fpscr(__new_fpsr);
+ return ((__old_fpsr >> _FPU_MASK_SHIFT) & FE_ALL_EXCEPT);
+ __new_fpsr = __old_fpsr &
+ ~((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
+fegetexcept(void)
+ fenv_t __fpsr;
+ return (__fpsr & FE_ALL_EXCEPT);
diff --git a/newlib/libc/machine/arm/sys/fenv.h b/newlib/libc/machine/arm/sys/fenv.h
index 000000000..af74c5f47
--- /dev/null
+++ b/newlib/libc/machine/arm/sys/fenv.h
@@ -0,0 +1,122 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#define _SYS_FENV_H_ 1
+#include <sys/_types.h>
+#include <sys/cdefs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifndef __fenv_static
+#define __fenv_static static
+#endif
+typedef int fenv_t;
+typedef int fexcept_t;
+/* Exception flags */
+#define FE_INVALID 0x0001
+#define FE_DIVBYZERO 0x0002
+#define FE_OVERFLOW 0x0004
+#define FE_UNDERFLOW 0x0008
+#define FE_INEXACT 0x0010
+#ifdef __ARM_PCS_VFP
+#define FE_DENORMAL 0x0080
+#define FE_ALL_EXCEPT (FE_DIVBYZERO | FE_INEXACT | \
+ FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW | FE_DENORMAL)
+#else
+ FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW)
+#endif
+/* Rounding modes */
+#define VFP_FE_TONEAREST 0x00000000
+#define VFP_FE_UPWARD 0x00400000
+#define VFP_FE_DOWNWARD 0x00800000
+#define VFP_FE_TOWARDZERO 0x00c00000
+#define FE_TONEAREST VFP_FE_TONEAREST
+#define FE_UPWARD VFP_FE_UPWARD
+#define FE_DOWNWARD VFP_FE_DOWNWARD
+#define FE_TOWARDZERO VFP_FE_TOWARDZERO
+#else
+#define FE_TONEAREST 0x0000
+#define FE_TOWARDZERO 0x0001
+#define FE_UPWARD 0x0002
+#define FE_DOWNWARD 0x0003
+#endif
+#define _ROUND_MASK (FE_TONEAREST | FE_DOWNWARD | \
+ FE_UPWARD | FE_TOWARDZERO)
+/* Default floating-point environment */
+extern const fenv_t *_fe_dfl_env;
+#define FE_DFL_ENV (_fe_dfl_env)
+/* We need to be able to map status flag positions to mask flag positions */
+#ifndef __ARM_PCS_VFP
+#define _FPUSW_SHIFT 16
+#define _ENABLE_MASK (FE_ALL_EXCEPT << _FPUSW_SHIFT)
+#endif
+int feclearexcept(int excepts);
+int fegetexceptflag(fexcept_t *flagp, int excepts);
+int fesetexceptflag(const fexcept_t *flagp, int excepts);
+int feraiseexcept(int excepts);
+int fetestexcept(int excepts);
+int fegetround(void);
+int fesetround(int round);
+int fegetenv(fenv_t *envp);
+int feholdexcept(fenv_t *envp);
+int fesetenv(const fenv_t *envp);
+int feupdateenv(const fenv_t *envp);
+#if __BSD_VISIBLE
+int feenableexcept(int __mask);
+int fedisableexcept(int __mask);
+int fegetexcept(void);
+#endif /* __ARM_PCS_VFP */
+#ifdef __cplusplus
+#endif
+#endif /* _SYS_FENV_H_ */
diff --git a/newlib/libm/machine/arm/Makefile.am b/newlib/libm/machine/arm/Makefile.am
index 1f10a7a40..a64ee59d5 100644
--- a/newlib/libm/machine/arm/Makefile.am
+++ b/newlib/libm/machine/arm/Makefile.am
@@ -19,7 +19,23 @@ LIB_SOURCES = \
sf_nearbyint.c \
sf_rint.c \
sf_round.c \
- sf_trunc.c
+ sf_trunc.c \
+ feclearexcept.c \
+ fe_dfl_env.c\
+ fegetenv.c \
+ fegetexceptflag.c \
+ fegetround.c \
+ feholdexcept.c \
+ fenv.c \
+ feraiseexcept.c \
+ fesetenv.c \
+ fesetexceptflag.c \
+ fesetround.c \
+ fetestexcept.c \
+ feupdateenv.c \
+ fenv-vfp.c \
+ fenv-softfp.c
noinst_LIBRARIES = lib.a
lib_a_SOURCES = $(LIB_SOURCES)
diff --git a/newlib/libm/machine/arm/Makefile.in b/newlib/libm/machine/arm/Makefile.in
index 0a5a27327..70b03df46 100644
--- a/newlib/libm/machine/arm/Makefile.in
+++ b/newlib/libm/machine/arm/Makefile.in
@@ -1,9 +1,8 @@
-# Makefile.in generated by automake 1.11.6 from Makefile.am.
+# Makefile.in generated by automake 1.12.6 from Makefile.am.
# @configure_input@
-# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
-# 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software
-# Foundation, Inc.
+# Copyright (C) 1994-2012 Free Software Foundation, Inc.
# This Makefile.in is free software; the Free Software Foundation
# gives unlimited permission to copy and/or distribute it,
# with or without modifications, as long as this notice is preserved.
@@ -54,7 +53,7 @@ build_triplet = @build@
host_triplet = @host@
DIST_COMMON = $(srcdir)/../../../Makefile.shared $(srcdir)/Makefile.in \
$(srcdir)/Makefile.am $(top_srcdir)/configure \
- $(am__configure_deps) $(srcdir)/../../../../mkinstalldirs
+ $(am__configure_deps) $(top_srcdir)/../../../../mkinstalldirs
subdir = .
ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
am__aclocal_m4_deps = $(top_srcdir)/../../../acinclude.m4 \
@@ -76,7 +75,15 @@ am__objects_1 = lib_a-e_sqrt.$(OBJEXT) lib_a-ef_sqrt.$(OBJEXT) \
lib_a-s_round.$(OBJEXT) lib_a-s_trunc.$(OBJEXT) \
lib_a-sf_ceil.$(OBJEXT) lib_a-sf_floor.$(OBJEXT) \
lib_a-sf_nearbyint.$(OBJEXT) lib_a-sf_rint.$(OBJEXT) \
- lib_a-sf_round.$(OBJEXT) lib_a-sf_trunc.$(OBJEXT)
+ lib_a-sf_round.$(OBJEXT) lib_a-sf_trunc.$(OBJEXT) \
+ lib_a-feclearexcept.$(OBJEXT) lib_a-fe_dfl_env.$(OBJEXT) \
+ lib_a-fegetenv.$(OBJEXT) lib_a-fegetexceptflag.$(OBJEXT) \
+ lib_a-fegetround.$(OBJEXT) lib_a-feholdexcept.$(OBJEXT) \
+ lib_a-fenv.$(OBJEXT) lib_a-feraiseexcept.$(OBJEXT) \
+ lib_a-fesetenv.$(OBJEXT) lib_a-fesetexceptflag.$(OBJEXT) \
+ lib_a-fesetround.$(OBJEXT) lib_a-fetestexcept.$(OBJEXT) \
+ lib_a-feupdateenv.$(OBJEXT) lib_a-fenv-vfp.$(OBJEXT) \
+ lib_a-fenv-softfp.$(OBJEXT)
am_lib_a_OBJECTS = $(am__objects_1)
lib_a_OBJECTS = $(am_lib_a_OBJECTS)
DEFAULT_INCLUDES = -I. at am__isrc@
@@ -95,6 +102,8 @@ am__can_run_installinfo = \
DATA = $(noinst_DATA)
ETAGS = etags
CTAGS = ctags
+CSCOPE = cscope
+AM_RECURSIVE_TARGETS = cscope
ACLOCAL = @ACLOCAL@
AMTAR = @AMTAR@
AR = @AR@
@@ -216,7 +225,22 @@ LIB_SOURCES = \
sf_nearbyint.c \
sf_rint.c \
sf_round.c \
- sf_trunc.c
+ sf_trunc.c \
+ feclearexcept.c \
+ fe_dfl_env.c\
+ fegetenv.c \
+ fegetround.c \
+ feholdexcept.c \
+ fenv.c \
+ feraiseexcept.c \
+ fesetenv.c \
+ fesetround.c \
+ fetestexcept.c \
+ feupdateenv.c \
+ fenv-vfp.c \
+ fenv-softfp.c
@@ -378,6 +402,96 @@ lib_a-sf_trunc.o: sf_trunc.c
lib_a-sf_trunc.obj: sf_trunc.c
$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-sf_trunc.obj `if test -f 'sf_trunc.c'; then $(CYGPATH_W) 'sf_trunc.c'; else $(CYGPATH_W) '$(srcdir)/sf_trunc.c'; fi`
+lib_a-feclearexcept.o: feclearexcept.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feclearexcept.o `test -f 'feclearexcept.c' || echo '$(srcdir)/'`feclearexcept.c
+lib_a-feclearexcept.obj: feclearexcept.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feclearexcept.obj `if test -f 'feclearexcept.c'; then $(CYGPATH_W) 'feclearexcept.c'; else $(CYGPATH_W) '$(srcdir)/feclearexcept.c'; fi`
+lib_a-fe_dfl_env.o: fe_dfl_env.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fe_dfl_env.o `test -f 'fe_dfl_env.c' || echo '$(srcdir)/'`fe_dfl_env.c
+lib_a-fe_dfl_env.obj: fe_dfl_env.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fe_dfl_env.obj `if test -f 'fe_dfl_env.c'; then $(CYGPATH_W) 'fe_dfl_env.c'; else $(CYGPATH_W) '$(srcdir)/fe_dfl_env.c'; fi`
+lib_a-fegetenv.o: fegetenv.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetenv.o `test -f 'fegetenv.c' || echo '$(srcdir)/'`fegetenv.c
+lib_a-fegetenv.obj: fegetenv.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetenv.obj `if test -f 'fegetenv.c'; then $(CYGPATH_W) 'fegetenv.c'; else $(CYGPATH_W) '$(srcdir)/fegetenv.c'; fi`
+lib_a-fegetexceptflag.o: fegetexceptflag.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetexceptflag.o `test -f 'fegetexceptflag.c' || echo '$(srcdir)/'`fegetexceptflag.c
+lib_a-fegetexceptflag.obj: fegetexceptflag.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetexceptflag.obj `if test -f 'fegetexceptflag.c'; then $(CYGPATH_W) 'fegetexceptflag.c'; else $(CYGPATH_W) '$(srcdir)/fegetexceptflag.c'; fi`
+lib_a-fegetround.o: fegetround.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetround.o `test -f 'fegetround.c' || echo '$(srcdir)/'`fegetround.c
+lib_a-fegetround.obj: fegetround.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetround.obj `if test -f 'fegetround.c'; then $(CYGPATH_W) 'fegetround.c'; else $(CYGPATH_W) '$(srcdir)/fegetround.c'; fi`
+lib_a-feholdexcept.o: feholdexcept.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feholdexcept.o `test -f 'feholdexcept.c' || echo '$(srcdir)/'`feholdexcept.c
+lib_a-feholdexcept.obj: feholdexcept.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feholdexcept.obj `if test -f 'feholdexcept.c'; then $(CYGPATH_W) 'feholdexcept.c'; else $(CYGPATH_W) '$(srcdir)/feholdexcept.c'; fi`
+lib_a-fenv.o: fenv.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv.o `test -f 'fenv.c' || echo '$(srcdir)/'`fenv.c
+lib_a-fenv.obj: fenv.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv.obj `if test -f 'fenv.c'; then $(CYGPATH_W) 'fenv.c'; else $(CYGPATH_W) '$(srcdir)/fenv.c'; fi`
+lib_a-feraiseexcept.o: feraiseexcept.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feraiseexcept.o `test -f 'feraiseexcept.c' || echo '$(srcdir)/'`feraiseexcept.c
+lib_a-feraiseexcept.obj: feraiseexcept.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feraiseexcept.obj `if test -f 'feraiseexcept.c'; then $(CYGPATH_W) 'feraiseexcept.c'; else $(CYGPATH_W) '$(srcdir)/feraiseexcept.c'; fi`
+lib_a-fesetenv.o: fesetenv.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetenv.o `test -f 'fesetenv.c' || echo '$(srcdir)/'`fesetenv.c
+lib_a-fesetenv.obj: fesetenv.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetenv.obj `if test -f 'fesetenv.c'; then $(CYGPATH_W) 'fesetenv.c'; else $(CYGPATH_W) '$(srcdir)/fesetenv.c'; fi`
+lib_a-fesetexceptflag.o: fesetexceptflag.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetexceptflag.o `test -f 'fesetexceptflag.c' || echo '$(srcdir)/'`fesetexceptflag.c
+lib_a-fesetexceptflag.obj: fesetexceptflag.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetexceptflag.obj `if test -f 'fesetexceptflag.c'; then $(CYGPATH_W) 'fesetexceptflag.c'; else $(CYGPATH_W) '$(srcdir)/fesetexceptflag.c'; fi`
+lib_a-fesetround.o: fesetround.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetround.o `test -f 'fesetround.c' || echo '$(srcdir)/'`fesetround.c
+lib_a-fesetround.obj: fesetround.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetround.obj `if test -f 'fesetround.c'; then $(CYGPATH_W) 'fesetround.c'; else $(CYGPATH_W) '$(srcdir)/fesetround.c'; fi`
+lib_a-fetestexcept.o: fetestexcept.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fetestexcept.o `test -f 'fetestexcept.c' || echo '$(srcdir)/'`fetestexcept.c
+lib_a-fetestexcept.obj: fetestexcept.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fetestexcept.obj `if test -f 'fetestexcept.c'; then $(CYGPATH_W) 'fetestexcept.c'; else $(CYGPATH_W) '$(srcdir)/fetestexcept.c'; fi`
+lib_a-feupdateenv.o: feupdateenv.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.o `test -f 'feupdateenv.c' || echo '$(srcdir)/'`feupdateenv.c
+lib_a-feupdateenv.obj: feupdateenv.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.obj `if test -f 'feupdateenv.c'; then $(CYGPATH_W) 'feupdateenv.c'; else $(CYGPATH_W) '$(srcdir)/feupdateenv.c'; fi`
+lib_a-fenv-vfp.o: fenv-vfp.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo '$(srcdir)/'`fenv-vfp.c
+lib_a-fenv-vfp.obj: fenv-vfp.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-vfp.obj `if test -f 'fenv-vfp.c'; then $(CYGPATH_W) 'fenv-vfp.c'; else $(CYGPATH_W) '$(srcdir)/fenv-vfp.c'; fi`
+lib_a-fenv-softfp.o: fenv-softfp.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-softfp.o `test -f 'fenv-softfp.c' || echo '$(srcdir)/'`fenv-softfp.c
+lib_a-fenv-softfp.obj: fenv-softfp.c
+ $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-softfp.obj `if test -f 'fenv-softfp.c'; then $(CYGPATH_W) 'fenv-softfp.c'; else $(CYGPATH_W) '$(srcdir)/fenv-softfp.c'; fi`
ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
unique=`for i in $$list; do \
@@ -427,8 +541,32 @@ GTAGS:
&& $(am__cd) $(top_srcdir) \
&& gtags -i $(GTAGS_ARGS) "$$here"
+cscope: cscope.files
+ test ! -s cscope.files \
+ || $(CSCOPE) -b -q $(AM_CSCOPEFLAGS) $(CSCOPEFLAGS) -i cscope.files $(CSCOPE_ARGS)
+clean-cscope:
+ -rm -f cscope.files
+cscope.files: clean-cscope cscopelist
+cscopelist: $(HEADERS) $(SOURCES) $(LISP)
+ list='$(SOURCES) $(HEADERS) $(LISP)'; \
+ case "$(srcdir)" in \
+ [\\/]* | ?:[\\/]*) sdir="$(srcdir)" ;; \
+ *) sdir=$(subdir)/$(srcdir) ;; \
+ esac; \
+ for i in $$list; do \
+ if test -f "$$i"; then \
+ echo "$(subdir)/$$i"; \
+ else \
+ echo "$$sdir/$$i"; \
+ fi; \
+ done >> $(top_builddir)/cscope.files
distclean-tags:
-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
+ -rm -f cscope.out cscope.in.out cscope.po.out cscope.files
check-am:
check: check-am
all-am: Makefile $(LIBRARIES) $(DATA)
@@ -537,17 +675,17 @@ uninstall-am:
.MAKE: install-am install-strip
.PHONY: CTAGS GTAGS all all-am am--refresh check check-am clean \
- clean-generic clean-noinstLIBRARIES ctags distclean \
- distclean-compile distclean-generic distclean-tags dvi dvi-am \
- html html-am info info-am install install-am install-data \
- install-data-am install-dvi install-dvi-am install-exec \
- install-exec-am install-html install-html-am install-info \
- install-info-am install-man install-pdf install-pdf-am \
- install-ps install-ps-am install-strip installcheck \
- installcheck-am installdirs maintainer-clean \
- maintainer-clean-generic mostlyclean mostlyclean-compile \
- mostlyclean-generic pdf pdf-am ps ps-am tags uninstall \
- uninstall-am
+ clean-cscope clean-generic clean-noinstLIBRARIES cscope \
+ cscopelist ctags distclean distclean-compile distclean-generic \
+ distclean-tags dvi dvi-am html html-am info info-am install \
+ install-am install-data install-data-am install-dvi \
+ install-dvi-am install-exec install-exec-am install-html \
+ install-html-am install-info install-info-am install-man \
+ install-pdf install-pdf-am install-ps install-ps-am \
+ install-strip installcheck installcheck-am installdirs \
+ maintainer-clean maintainer-clean-generic mostlyclean \
+ mostlyclean-compile mostlyclean-generic pdf pdf-am ps ps-am \
+ tags uninstall uninstall-am
objectlist.awk.in: $(noinst_LTLIBRARIES)
-rm -f objectlist.awk.in
diff --git a/newlib/libm/machine/arm/fe_dfl_env.c b/newlib/libm/machine/arm/fe_dfl_env.c
index 000000000..8cbee7771
--- /dev/null
+++ b/newlib/libm/machine/arm/fe_dfl_env.c
@@ -0,0 +1,7 @@
+ * (c) Copyright 2019 Joel Sherrill <joel at rtems.org>
+#include "../../fenv/fenv_stub.c"
diff --git a/newlib/libm/machine/arm/feclearexcept.c b/newlib/libm/machine/arm/feclearexcept.c
--- /dev/null
+++ b/newlib/libm/machine/arm/feclearexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fegetenv.c b/newlib/libm/machine/arm/fegetenv.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fegetenv.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fegetexceptflag.c b/newlib/libm/machine/arm/fegetexceptflag.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fegetexceptflag.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fegetround.c b/newlib/libm/machine/arm/fegetround.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fegetround.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/feholdexcept.c b/newlib/libm/machine/arm/feholdexcept.c
--- /dev/null
+++ b/newlib/libm/machine/arm/feholdexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fenv-softfp.c b/newlib/libm/machine/arm/fenv-softfp.c
index 000000000..a576cc1b2
--- /dev/null
+++ b/newlib/libm/machine/arm/fenv-softfp.c
@@ -0,0 +1,32 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#define FENV_MANGLE(x) __softfp_ ##x
+#include <machine/fenv-mangle.h>
+#include "fenv.c"
diff --git a/newlib/libm/machine/arm/fenv-vfp.c b/newlib/libm/machine/arm/fenv-vfp.c
index 000000000..297e81296
--- /dev/null
+++ b/newlib/libm/machine/arm/fenv-vfp.c
@@ -0,0 +1,32 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#define FENV_MANGLE(x) __vfp_ ##x
+#include "fenv.c"
diff --git a/newlib/libm/machine/arm/fenv.c b/newlib/libm/machine/arm/fenv.c
index 000000000..278de8633
--- /dev/null
+++ b/newlib/libm/machine/arm/fenv.c
@@ -0,0 +1,328 @@
+ * Copyright (c) 2004 David Schultz <das at FreeBSD.ORG>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#include <fenv.h>
+#include <machine/acle-compat.h>
+#if __ARM_ARCH >= 6
+#define FENV_ARMv6
+#endif
+/* When SOFTFP_ABI is defined we are using the softfp ABI. */
+#if defined(__VFP_FP__) && !defined(__ARM_PCS_VFP)
+#define SOFTFP_ABI
+#endif
+ * Hopefully the system ID byte is immutable, so it's valid to use
+ * this as a default environment.
+fenv_t __fe_dfl_env = { 0 };
+const fenv_t *_fe_dfl_env = &__fe_dfl_env;
+#endif
+/* If this is a non-mangled softfp version special processing is required */
+#if defined(FENV_MANGLE) || !defined(SOFTFP_ABI) || !defined(FENV_ARMv6)
+ * The following macros map between the softfloat emulator's flags and
+ * the hardware's FPSR. The hardware this file was written for doesn't
+ * have rounding control bits, so we stick those in the system ID byte.
+#define __set_env(env, flags, mask, rnd) env = ((flags) \
+ | (mask)<<_FPUSW_SHIFT \
+ | (rnd) << 24)
+#define __env_flags(env) ((env) & FE_ALL_EXCEPT)
+#define __env_mask(env) (((env) >> _FPUSW_SHIFT) \
+ & FE_ALL_EXCEPT)
+#define __env_round(env) (((env) >> 24) & _ROUND_MASK)
+#include <machine/fenv-softfloat.h>
+#else /* __ARM_PCS_VFP PRESENT */
+#include <machine/fenv-vfp.h>
+#ifdef __GNUC_GNU_INLINE__
+#error "This file must be compiled with C99 'inline' semantics"
+#endif
+extern inline int feclearexcept(int excepts);
+extern inline int fegetexceptflag(fexcept_t *flagp, int excepts);
+extern inline int fesetexceptflag(const fexcept_t *flagp, int excepts);
+extern inline int feraiseexcept(int excepts);
+extern inline int fetestexcept(int excepts);
+extern inline int fegetround(void);
+extern inline int fesetround(int round);
+extern inline int fegetenv(fenv_t *envp);
+extern inline int feholdexcept(fenv_t *envp);
+extern inline int fesetenv(const fenv_t *envp);
+extern inline int feupdateenv(const fenv_t *envp);
+extern inline int feenableexcept(int __mask);
+extern inline int fedisableexcept(int __mask);
+extern inline int fegetexcept(void);
+#else /* !FENV_MANGLE && SOFTFP_ABI */
+/* Set by libc when the VFP unit is enabled */
+extern int _libc_arm_fpu_present;
+int __softfp_feclearexcept(int excepts);
+int __softfp_fegetexceptflag(fexcept_t *flagp, int excepts);
+int __softfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
+int __softfp_feraiseexcept(int excepts);
+int __softfp_fetestexcept(int excepts);
+int __softfp_fegetround(void);
+int __softfp_fesetround(int round);
+int __softfp_fegetenv(fenv_t *envp);
+int __softfp_feholdexcept(fenv_t *envp);
+int __softfp_fesetenv(const fenv_t *envp);
+int __softfp_feupdateenv(const fenv_t *envp);
+int __softfp_feenableexcept(int __mask);
+int __softfp_fedisableexcept(int __mask);
+int __softfp_fegetexcept(void);
+int __vfp_feclearexcept(int excepts);
+int __vfp_fegetexceptflag(fexcept_t *flagp, int excepts);
+int __vfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
+int __vfp_feraiseexcept(int excepts);
+int __vfp_fetestexcept(int excepts);
+int __vfp_fegetround(void);
+int __vfp_fesetround(int round);
+int __vfp_fegetenv(fenv_t *envp);
+int __vfp_feholdexcept(fenv_t *envp);
+int __vfp_fesetenv(const fenv_t *envp);
+int __vfp_feupdateenv(const fenv_t *envp);
+int __vfp_feenableexcept(int __mask);
+int __vfp_fedisableexcept(int __mask);
+int __vfp_fegetexcept(void);
+static int
+__softfp_round_to_vfp(int round)
+ switch (round) {
+ case FE_TONEAREST:
+ default:
+ return VFP_FE_TONEAREST;
+ case FE_TOWARDZERO:
+ return VFP_FE_TOWARDZERO;
+ case FE_UPWARD:
+ return VFP_FE_UPWARD;
+ case FE_DOWNWARD:
+ return VFP_FE_DOWNWARD;
+static int
+__softfp_round_from_vfp(int round)
+ switch (round) {
+ case VFP_FE_TONEAREST:
+ default:
+ return FE_TONEAREST;
+ case VFP_FE_TOWARDZERO:
+ return FE_TOWARDZERO;
+ case VFP_FE_UPWARD:
+ return FE_UPWARD;
+ case VFP_FE_DOWNWARD:
+ return FE_DOWNWARD;
+ if (_libc_arm_fpu_present)
+ __vfp_feclearexcept(excepts);
+ __softfp_feclearexcept(excepts);
+ return (0);
+ fexcept_t __vfp_flagp;
+ __vfp_flagp = 0;
+ __vfp_fegetexceptflag(&__vfp_flagp, excepts);
+ __softfp_fegetexceptflag(flagp, excepts);
+ *flagp |= __vfp_flagp;
+ return (0);
+ __vfp_fesetexceptflag(flagp, excepts);
+ __softfp_fesetexceptflag(flagp, excepts);
+ return (0);
+ __vfp_feraiseexcept(excepts);
+ __softfp_feraiseexcept(excepts);
+ return (0);
+ int __got_excepts;
+ __got_excepts = 0;
+ __got_excepts = __vfp_fetestexcept(excepts);
+ __got_excepts |= __softfp_fetestexcept(excepts);
+ return (__got_excepts);
+ return __softfp_round_from_vfp(__vfp_fegetround());
+ return __softfp_fegetround();
+ __vfp_fesetround(__softfp_round_to_vfp(round));
+ __softfp_fesetround(round);
+ return (0);
+ fenv_t __vfp_envp;
+ __vfp_envp = 0;
+ __vfp_fegetenv(&__vfp_envp);
+ __softfp_fegetenv(envp);
+ *envp |= __vfp_envp;
+ return (0);
+ __vfp_envp = 0;
+ __vfp_feholdexcept(&__vfp_envp);
+ __softfp_feholdexcept(envp);
+ return (0);
+ __vfp_fesetenv(envp);
+ __softfp_fesetenv(envp);
+ return (0);
+ __vfp_feupdateenv(envp);
+ __softfp_feupdateenv(envp);
+ return (0);
+ int __unmasked;
+ __unmasked = 0;
+ __unmasked = __vfp_feenableexcept(__mask);
+ __unmasked |= __softfp_feenableexcept(__mask);
+ return (__unmasked);
+ int __unmasked;
+ __unmasked = 0;
+ __unmasked = __vfp_fedisableexcept(__mask);
+ __unmasked |= __softfp_fedisableexcept(__mask);
+ int __unmasked;
+ __unmasked = 0;
+ __unmasked = __vfp_fegetexcept();
+ __unmasked |= __softfp_fegetexcept();
+#endif
diff --git a/newlib/libm/machine/arm/feraiseexcept.c b/newlib/libm/machine/arm/feraiseexcept.c
--- /dev/null
+++ b/newlib/libm/machine/arm/feraiseexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fesetenv.c b/newlib/libm/machine/arm/fesetenv.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fesetenv.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fesetexceptflag.c b/newlib/libm/machine/arm/fesetexceptflag.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fesetexceptflag.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fesetround.c b/newlib/libm/machine/arm/fesetround.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fesetround.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fetestexcept.c b/newlib/libm/machine/arm/fetestexcept.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fetestexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/feupdateenv.c b/newlib/libm/machine/arm/feupdateenv.c
--- /dev/null
+++ b/newlib/libm/machine/arm/feupdateenv.c
@@ -0,0 +1,7 @@
2.17.1
