[PATCH] Adding fenv support arm.
Eshan Dhawan eshandhawan51 at gmail.com
Sat May 23 17:57:53 UTC 2020
Hello Dr Joel,
I ran the script, The logs show error in soft float variants and don't show
there exe files as well.
I have attached the log file.
Thanks
-Eshan
On Sat, May 23, 2020 at 10:29 PM Joel Sherrill <joel at rtems.org> wrote:
> This is both a holiday weekend and my birthday weekend. I won't get a
> chance to review this for a bit.
> But I am attaching a simple shell script and test program which iterates
> over all multilib variants, compiles a simple program which should end up
> linking against every multilib variant. If the script looks right, then
> this should prove useful in the future.
> Please check that the right set of exe's for the various multilib options
> is generated and the fenv code is code for each. My parsing of the multilib
> variants from gcc needs a double check.
> On Fri, May 22, 2020 at 6:36 PM Eshan dhawan <eshandhawan51 at gmail.com>
> wrote:
>> This patch adds FENV support for ARM
>> The code is ported from FreeBSD.
>> Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
>>  newlib/libc/machine/arm/machine/acle-compat.h | 182 ++++++++++
>>  newlib/libc/machine/arm/machine/fenv-mangle.h |  53 +++
>>  .../libc/machine/arm/machine/fenv-softfloat.h | 187 ++++++++++
>>  newlib/libc/machine/arm/machine/fenv-vfp.h    | 187 ++++++++++
>>  newlib/libc/machine/arm/sys/fenv.h            | 122 +++++++
>>  newlib/libm/machine/arm/Makefile.am           |  18 +-
>>  newlib/libm/machine/arm/Makefile.in           | 174 +++++++++-
>>  newlib/libm/machine/arm/fe_dfl_env.c          |   7 +
>>  newlib/libm/machine/arm/feclearexcept.c       |   7 +
>>  newlib/libm/machine/arm/fegetenv.c            |   7 +
>>  newlib/libm/machine/arm/fegetexceptflag.c     |   7 +
>>  newlib/libm/machine/arm/fegetround.c          |   7 +
>>  newlib/libm/machine/arm/feholdexcept.c        |   7 +
>>  newlib/libm/machine/arm/fenv-softfp.c         |  32 ++
>>  newlib/libm/machine/arm/fenv-vfp.c            |  32 ++
>>  newlib/libm/machine/arm/fenv.c                | 328 ++++++++++++++++++
>>  newlib/libm/machine/arm/feraiseexcept.c       |   7 +
>>  newlib/libm/machine/arm/fesetenv.c            |   7 +
>>  newlib/libm/machine/arm/fesetexceptflag.c     |   7 +
>>  newlib/libm/machine/arm/fesetround.c          |   7 +
>>  newlib/libm/machine/arm/fetestexcept.c        |   7 +
>>  newlib/libm/machine/arm/feupdateenv.c         |   7 +
>>  22 files changed, 1380 insertions(+), 19 deletions(-)
>>  create mode 100644 newlib/libc/machine/arm/machine/acle-compat.h
>>  create mode 100644 newlib/libc/machine/arm/machine/fenv-mangle.h
>>  create mode 100644 newlib/libc/machine/arm/machine/fenv-softfloat.h
>>  create mode 100644 newlib/libc/machine/arm/machine/fenv-vfp.h
>>  create mode 100644 newlib/libc/machine/arm/sys/fenv.h
>>  create mode 100644 newlib/libm/machine/arm/fe_dfl_env.c
>>  create mode 100644 newlib/libm/machine/arm/feclearexcept.c
>>  create mode 100644 newlib/libm/machine/arm/fegetenv.c
>>  create mode 100644 newlib/libm/machine/arm/fegetexceptflag.c
>>  create mode 100644 newlib/libm/machine/arm/fegetround.c
>>  create mode 100644 newlib/libm/machine/arm/feholdexcept.c
>>  create mode 100644 newlib/libm/machine/arm/fenv-softfp.c
>>  create mode 100644 newlib/libm/machine/arm/fenv-vfp.c
>>  create mode 100644 newlib/libm/machine/arm/fenv.c
>>  create mode 100644 newlib/libm/machine/arm/feraiseexcept.c
>>  create mode 100644 newlib/libm/machine/arm/fesetenv.c
>>  create mode 100644 newlib/libm/machine/arm/fesetexceptflag.c
>>  create mode 100644 newlib/libm/machine/arm/fesetround.c
>>  create mode 100644 newlib/libm/machine/arm/fetestexcept.c
>>  create mode 100644 newlib/libm/machine/arm/feupdateenv.c
>> diff --git a/newlib/libc/machine/arm/machine/acle-compat.h
>> b/newlib/libc/machine/arm/machine/acle-compat.h
>> new file mode 100644
>> index 000000000..888ae2ea8
>> --- /dev/null
>> +++ b/newlib/libc/machine/arm/machine/acle-compat.h
>> @@ -0,0 +1,182 @@
>> + * Copyright (c) 2014 ARM Ltd
>> + * All rights reserved.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the
>> distribution.
>> + * 3. The name of the company may not be used to endorse or promote
>> + *    products derived from this software without specific prior written
>> + *    permission.
>> + * THIS SOFTWARE IS PROVIDED BY ARM LTD ``AS IS'' AND ANY EXPRESS OR
>> IMPLIED
>> + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
>> + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
>> + * IN NO EVENT SHALL ARM LTD BE LIABLE FOR ANY DIRECT, INDIRECT,
>> INCIDENTAL,
>> + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
>> LIMITED
>> + * TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
>> + * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
>> + * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
>> + * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
>> + * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>> +#ifndef __ARM_ARCH
>> +/* ACLE standardises a set of pre-defines that describe the ARM
>> architecture.
>> +   These were mostly implemented in GCC around GCC-4.8; older versions
>> +   have no, or only partial support.  To provide a level of backwards
>> +   compatibility we try to work out what the definitions should be, given
>> +   the older pre-defines that GCC did produce.  This isn't complete, but
>> +   it should be enough for use by routines that depend on this header.
>> +/* No need to handle ARMv8, GCC had ACLE support before that.  */
>> +# ifdef __ARM_ARCH_7__
>> +/* The common subset of ARMv7 in all profiles.  */
>> +#  define __ARM_ARCH 7
>> +#  define __ARM_ARCH_ISA_THUMB 2
>> +#  define __ARM_FEATURE_CLZ
>> +#  define __ARM_FEATURE_LDREX 7
>> +#  define __ARM_FEATURE_UNALIGNED
>> +# endif
>> +# if defined (__ARM_ARCH_7A__) || defined (__ARM_ARCH_7R__)
>> +#  define __ARM_ARCH_ISA_ARM
>> +#  define __ARM_FEATURE_SIMD32
>> +#  define __ARM_FEATURE_DSP
>> +#  define __ARM_FEATURE_QBIT
>> +#  define __ARM_FEATURE_SAT
>> +#  define __ARM_FEATURE_LDREX 15
>> +#  ifdef __ARM_ARCH_7A__
>> +#   define __ARM_ARCH_PROFILE 'A'
>> +#  else
>> +#   define __ARM_ARCH_PROFILE 'R'
>> +#  endif
>> +# endif
>> +# ifdef __ARM_ARCH_7EM__
>> +#  define __ARM_ARCH_PROFILE 'M'
>> +# endif
>> +# ifdef __ARM_ARCH_7M__
>> +# endif
>> +# ifdef __ARM_ARCH_6T2__
>> +#  define __ARM_ARCH 6
>> +#  define __ARM_FEATURE_LDREX 4
>> +# endif
>> +# ifdef __ARM_ARCH_6M__
>> +#  define __ARM_ARCH_ISA_THUMB 1
>> +# endif
>> +# if defined (__ARM_ARCH_6__) || defined (__ARM_ARCH_6J__) \
>> +  || defined (__ARM_ARCH_6K__) || defined (__ARM_ARCH_6Z__) \
>> +  || defined (__ARM_ARCH_6ZK__)
>> +#  ifndef __thumb__
>> +#   if defined (__ARM_ARCH_6K__) || defined (__ARM_ARCH_6ZK__)
>> +#   else
>> +#   endif
>> +#  endif
>> +# endif
>> +# if defined (__ARM_ARCH_5TE__) || defined (__ARM_ARCH_5E__)
>> +#  define __ARM_ARCH 5
>> +#  ifdef __ARM_ARCH_5TE__
>> +#  endif
>> +# endif
>> +# if defined (__ARM_ARCH_5T__) || defined (__ARM_ARCH_5__)
>> +#  endif
>> +# endif
>> +# ifdef __ARM_ARCH_4T__
>> +#  define __ARM_ARCH 4
>> +# endif
>> +# ifdef __ARM_ARCH_4__
>> +# endif
>> +# if defined (__ARM_ARCH_3__) || defined (__ARM_ARCH_3M__)
>> +#  define __ARM_ARCH 3
>> +# endif
>> +# ifdef __ARM_ARCH_2__
>> +#  define __ARM_ARCH 2
>> +# endif
>> +# ifdef __ARMEB__
>> +#  define __ARM_BIG_ENDIAN
>> +# endif
>> +/* If we still don't know what the target architecture is, then we're
>> +   probably not using GCC.  */
>> +# ifndef __ARM_ARCH
>> +#  error Unable to determine architecture version.
>> +# endif
>> +#endif /* __ARM_ARCH  */
>> diff --git a/newlib/libc/machine/arm/machine/fenv-mangle.h
>> b/newlib/libc/machine/arm/machine/fenv-mangle.h
>> index 000000000..476f7b20c
>> --- /dev/null
>> +++ b/newlib/libc/machine/arm/machine/fenv-mangle.h
>> @@ -0,0 +1,53 @@
>> + * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
>> + * are met:
>> distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
>> LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
>> GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
>> STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
>> WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifdef _FENV_MANGLE_H_
>> +#error Only include fenv-mangle.h once
>> +#endif
>> +#define        _FENV_MANGLE_H_
>> +#ifndef FENV_MANGLE
>> +#error FENV_MANGLE is undefined
>> +#endif
>> +#define        feclearexcept   FENV_MANGLE(feclearexcept)
>> +#define        fegetexceptflag FENV_MANGLE(fegetexceptflag)
>> +#define        fesetexceptflag FENV_MANGLE(fesetexceptflag)
>> +#define        feraiseexcept   FENV_MANGLE(feraiseexcept)
>> +#define        fetestexcept    FENV_MANGLE(fetestexcept)
>> +#define        fegetround      FENV_MANGLE(fegetround)
>> +#define        fesetround      FENV_MANGLE(fesetround)
>> +#define        fegetenv        FENV_MANGLE(fegetenv)
>> +#define        feholdexcept    FENV_MANGLE(feholdexcept)
>> +#define        fesetenv        FENV_MANGLE(fesetenv)
>> +#define        feupdateenv     FENV_MANGLE(feupdateenv)
>> +#define        feenableexcept  FENV_MANGLE(feenableexcept)
>> +#define        fedisableexcept FENV_MANGLE(fedisableexcept)
>> +#define        fegetexcept     FENV_MANGLE(fegetexcept)
>> diff --git a/newlib/libc/machine/arm/machine/fenv-softfloat.h
>> b/newlib/libc/machine/arm/machine/fenv-softfloat.h
>> index 000000000..e53e54f54
>> --- /dev/null
>> +++ b/newlib/libc/machine/arm/machine/fenv-softfloat.h
>> @@ -0,0 +1,187 @@
>> + * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
>> + * Copyright (c) 2004-2011 David Schultz <das at FreeBSD.ORG>
>> + * are met:
>> distribution.
>> PURPOSE
>> LIABLE
>> CONSEQUENTIAL
>> GOODS
>> STRICT
>> WAY
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef        _SYS_FENV_H_
>> +#error "This file is meant to be included only by <sys/fenv.h>."
>> +#endif
>> +/* the file can be added from architecture specific fenv.h file found in
>> + *libc/sys/arch/sys *
>> + * This file implements the functionality of <fenv.h> on platforms that
>> + * lack an FPU and use softfloat in libc for floating point.  To use it,
>> + * you must write an <fenv.h> that provides the following:
>> + *   - a typedef for fenv_t, which may be an integer or struct type
>> + *   - a typedef for fexcept_t (XXX This file assumes fexcept_t is a
>> + *     simple integer type containing the exception mask.)
>> + *   - definitions of FE_* constants for the five exceptions and four
>> + *     rounding modes in IEEE 754, as described in fenv(3)
>> + *   - a definition, and the corresponding external symbol, for
>> FE_DFL_ENV
>> + *   - a macro __set_env(env, flags, mask, rnd), which sets the given
>> fenv_t
>> + *     from the exception flags, mask, and rounding mode
>> + *   - macros __env_flags(env), __env_mask(env), and __env_round(env),
>> which
>> + *     extract fields from an fenv_t
>> + *   - a definition of __fenv_static
>> + * If the architecture supports an optional FPU, it's recommended that
>> you
>> + * define fenv_t and fexcept_t to match the hardware ABI.  Otherwise, it
>> + * doesn't matter how you define them.
>> +extern int __softfloat_float_exception_flags;
>> +extern int __softfloat_float_exception_mask;
>> +extern int __softfloat_float_rounding_mode;
>> +void __softfloat_float_raise(int);
>> +__fenv_static inline int
>> +feclearexcept(int excepts)
>> +       __softfloat_float_exception_flags &= ~excepts;
>> +       return (0);
>> +fegetexceptflag(fexcept_t *flagp, int excepts)
>> +       *flagp = __softfloat_float_exception_flags & excepts;
>> +       return (0);
>> +fesetexceptflag(const fexcept_t *flagp, int excepts)
>> +       __softfloat_float_exception_flags |= *flagp & excepts;
>> +       return (0);
>> +feraiseexcept(int excepts)
>> +       __softfloat_float_raise(excepts);
>> +       return (0);
>> +fetestexcept(int excepts)
>> +       return (__softfloat_float_exception_flags & excepts);
>> +fegetround(void)
>> +       return (__softfloat_float_rounding_mode);
>> +fesetround(int round)
>> +       __softfloat_float_rounding_mode = round;
>> +       return (0);
>> +fegetenv(fenv_t *envp)
>> +       __set_env(*envp, __softfloat_float_exception_flags,
>> +           __softfloat_float_exception_mask,
>> +       return (0);
>> +feholdexcept(fenv_t *envp)
>> +       fenv_t __env;
>> +       fegetenv(envp);
>> +       __softfloat_float_exception_flags = 0;
>> +       __softfloat_float_exception_mask = 0;
>> +       return (0);
>> +fesetenv(const fenv_t *envp)
>> +       __softfloat_float_exception_flags = __env_flags(*envp);
>> +       __softfloat_float_exception_mask = __env_mask(*envp);
>> +       __softfloat_float_rounding_mode = __env_round(*envp);
>> +       return (0);
>> +feupdateenv(const fenv_t *envp)
>> +       int __oflags = __softfloat_float_exception_flags;
>> +       fesetenv(envp);
>> +       feraiseexcept(__oflags);
>> +       return (0);
>> +#if __BSD_VISIBLE
>> +/* We currently provide no external definitions of the functions below.
>> +feenableexcept(int __mask)
>> +       int __omask = __softfloat_float_exception_mask;
>> +       __softfloat_float_exception_mask |= __mask;
>> +       return (__omask);
>> +fedisableexcept(int __mask)
>> +       __softfloat_float_exception_mask &= ~__mask;
>> +       return (__omask);
>> +fegetexcept(void)
>> +       return (__softfloat_float_exception_mask);
>> +#endif /* __BSD_VISIBLE */
>> diff --git a/newlib/libc/machine/arm/machine/fenv-vfp.h
>> b/newlib/libc/machine/arm/machine/fenv-vfp.h
>> index 000000000..25d71f3ab
>> --- /dev/null
>> +++ b/newlib/libc/machine/arm/machine/fenv-vfp.h
>> @@ -0,0 +1,187 @@
>> + * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
>> + * are met:
>> distribution.
>> PURPOSE
>> LIABLE
>> CONSEQUENTIAL
>> GOODS
>> STRICT
>> WAY
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#define        vmrs_fpscr(__r) __asm __volatile("vmrs %0, fpscr" :
>> "=&r"(__r))
>> +#define        vmsr_fpscr(__r) __asm __volatile("vmsr fpscr, %0" : :
>> "r"(__r))
>> +#define _FPU_MASK_SHIFT        8
>> +__fenv_static inline int feclearexcept(int excepts)
>> +       fexcept_t __fpsr;
>> +       vmrs_fpscr(__fpsr);
>> +       __fpsr &= ~excepts;
>> +       vmsr_fpscr(__fpsr);
>> +       return (0);
>> +       fexcept_t __fpsr;
>> +       *flagp = __fpsr & excepts;
>> +       return (0);
>> +       fexcept_t __fpsr;
>> +       __fpsr |= *flagp & excepts;
>> +       return (0);
>> +       fexcept_t __ex = excepts;
>> +       fesetexceptflag(&__ex, excepts);        /* XXX */
>> +       return (0);
>> +       fexcept_t __fpsr;
>> +       return (__fpsr & excepts);
>> +fegetround(void)
>> +       fenv_t __fpsr;
>> +       return (__fpsr & _ROUND_MASK);
>> +       fenv_t __fpsr;
>> +       __fpsr &= ~(_ROUND_MASK);
>> +       __fpsr |= round;
>> +       return (0);
>> +       vmrs_fpscr(*envp);
>> +       return (0);
>> +       fenv_t __env;
>> +       vmrs_fpscr(__env);
>> +       *envp = __env;
>> +       __env &= ~(FE_ALL_EXCEPT);
>> +       vmsr_fpscr(__env);
>> +       return (0);
>> +       vmsr_fpscr(*envp);
>> +       return (0);
>> +       fexcept_t __fpsr;
>> +       feraiseexcept(__fpsr & FE_ALL_EXCEPT);
>> +       return (0);
>> +#if __BSD_VISIBLE
>> +       fenv_t __old_fpsr, __new_fpsr;
>> +       vmrs_fpscr(__old_fpsr);
>> +       __new_fpsr = __old_fpsr |
>> +           ((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
>> +       vmsr_fpscr(__new_fpsr);
>> +       return ((__old_fpsr >> _FPU_MASK_SHIFT) & FE_ALL_EXCEPT);
>> +       __new_fpsr = __old_fpsr &
>> +           ~((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
>> +fegetexcept(void)
>> +       fenv_t __fpsr;
>> +       return (__fpsr & FE_ALL_EXCEPT);
>> diff --git a/newlib/libc/machine/arm/sys/fenv.h
>> b/newlib/libc/machine/arm/sys/fenv.h
>> index 000000000..af74c5f47
>> --- /dev/null
>> +++ b/newlib/libc/machine/arm/sys/fenv.h
>> @@ -0,0 +1,122 @@
>> + * are met:
>> distribution.
>> PURPOSE
>> LIABLE
>> CONSEQUENTIAL
>> GOODS
>> STRICT
>> WAY
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#define _SYS_FENV_H_ 1
>> +#include <sys/_types.h>
>> +#include <sys/cdefs.h>
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> +#ifndef        __fenv_static
>> +#define        __fenv_static static
>> +#endif
>> +typedef int fenv_t;
>> +typedef int fexcept_t;
>> +/* Exception flags */
>> +#define        FE_INVALID      0x0001
>> +#define        FE_DIVBYZERO    0x0002
>> +#define        FE_OVERFLOW     0x0004
>> +#define        FE_UNDERFLOW    0x0008
>> +#define        FE_INEXACT      0x0010
>> +#ifdef __ARM_PCS_VFP
>> +#define        FE_DENORMAL     0x0080
>> +#define        FE_ALL_EXCEPT   (FE_DIVBYZERO | FE_INEXACT | \
>> +                        FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW |
>> FE_DENORMAL)
>> +#else
>> +                        FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW)
>> +#endif
>> +/* Rounding modes */
>> +#define        VFP_FE_TONEAREST        0x00000000
>> +#define        VFP_FE_UPWARD           0x00400000
>> +#define        VFP_FE_DOWNWARD         0x00800000
>> +#define        VFP_FE_TOWARDZERO       0x00c00000
>> +#define        FE_TONEAREST    VFP_FE_TONEAREST
>> +#define        FE_UPWARD       VFP_FE_UPWARD
>> +#define        FE_DOWNWARD     VFP_FE_DOWNWARD
>> +#define        FE_TOWARDZERO   VFP_FE_TOWARDZERO
>> +#else
>> +#define        FE_TONEAREST    0x0000
>> +#define        FE_TOWARDZERO   0x0001
>> +#define        FE_UPWARD       0x0002
>> +#define        FE_DOWNWARD     0x0003
>> +#endif
>> +#define        _ROUND_MASK     (FE_TONEAREST | FE_DOWNWARD | \
>> +                        FE_UPWARD | FE_TOWARDZERO)
>> +/* Default floating-point environment */
>> +extern const fenv_t    *_fe_dfl_env;
>> +#define        FE_DFL_ENV      (_fe_dfl_env)
>> +/* We need to be able to map status flag positions to mask flag
>> positions */
>> +#ifndef __ARM_PCS_VFP
>> +#define        _FPUSW_SHIFT    16
>> +#define        _ENABLE_MASK    (FE_ALL_EXCEPT << _FPUSW_SHIFT)
>> +#endif
>> +int feclearexcept(int excepts);
>> +int fegetexceptflag(fexcept_t *flagp, int excepts);
>> +int fesetexceptflag(const fexcept_t *flagp, int excepts);
>> +int feraiseexcept(int excepts);
>> +int fetestexcept(int excepts);
>> +int fegetround(void);
>> +int fesetround(int round);
>> +int fegetenv(fenv_t *envp);
>> +int feholdexcept(fenv_t *envp);
>> +int fesetenv(const fenv_t *envp);
>> +int feupdateenv(const fenv_t *envp);
>> +#if __BSD_VISIBLE
>> +int feenableexcept(int __mask);
>> +int fedisableexcept(int __mask);
>> +int fegetexcept(void);
>> +#endif /* __ARM_PCS_VFP */
>> +#ifdef __cplusplus
>> +#endif
>> +#endif /* _SYS_FENV_H_ */
>> diff --git a/newlib/libm/machine/arm/Makefile.am
>> b/newlib/libm/machine/arm/Makefile.am
>> index 1f10a7a40..a64ee59d5 100644
>> --- a/newlib/libm/machine/arm/Makefile.am
>> +++ b/newlib/libm/machine/arm/Makefile.am
>> @@ -19,7 +19,23 @@ LIB_SOURCES = \
>>         sf_nearbyint.c \
>>         sf_rint.c \
>>         sf_round.c \
>> -       sf_trunc.c
>> +       sf_trunc.c \
>> +       feclearexcept.c \
>> +       fe_dfl_env.c\
>> +       fegetenv.c \
>> +       fegetexceptflag.c \
>> +       fegetround.c \
>> +       feholdexcept.c \
>> +       fenv.c \
>> +       feraiseexcept.c \
>> +       fesetenv.c \
>> +       fesetexceptflag.c \
>> +       fesetround.c \
>> +       fetestexcept.c \
>> +       feupdateenv.c \
>> +       fenv-vfp.c \
>> +       fenv-softfp.c
>>  noinst_LIBRARIES = lib.a
>>  lib_a_SOURCES = $(LIB_SOURCES)
>> diff --git a/newlib/libm/machine/arm/Makefile.in
>> b/newlib/libm/machine/arm/Makefile.in
>> index 0a5a27327..70b03df46 100644
>> --- a/newlib/libm/machine/arm/Makefile.in
>> +++ b/newlib/libm/machine/arm/Makefile.in
>> @@ -1,9 +1,8 @@
>> -# Makefile.in generated by automake 1.11.6 from Makefile.am.
>> +# Makefile.in generated by automake 1.12.6 from Makefile.am.
>>  # @configure_input@
>> -# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
>> -# 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software
>> -# Foundation, Inc.
>> +# Copyright (C) 1994-2012 Free Software Foundation, Inc.
>>  # This Makefile.in is free software; the Free Software Foundation
>>  # gives unlimited permission to copy and/or distribute it,
>>  # with or without modifications, as long as this notice is preserved.
>> @@ -54,7 +53,7 @@ build_triplet = @build@
>>  host_triplet = @host@
>>  DIST_COMMON = $(srcdir)/../../../Makefile.shared $(srcdir)/Makefile.in \
>>         $(srcdir)/Makefile.am $(top_srcdir)/configure \
>> -       $(am__configure_deps) $(srcdir)/../../../../mkinstalldirs
>> +       $(am__configure_deps) $(top_srcdir)/../../../../mkinstalldirs
>>  subdir = .
>>  ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
>>  am__aclocal_m4_deps = $(top_srcdir)/../../../acinclude.m4 \
>> @@ -76,7 +75,15 @@ am__objects_1 = lib_a-e_sqrt.$(OBJEXT)
>> lib_a-ef_sqrt.$(OBJEXT) \
>>         lib_a-s_round.$(OBJEXT) lib_a-s_trunc.$(OBJEXT) \
>>         lib_a-sf_ceil.$(OBJEXT) lib_a-sf_floor.$(OBJEXT) \
>>         lib_a-sf_nearbyint.$(OBJEXT) lib_a-sf_rint.$(OBJEXT) \
>> -       lib_a-sf_round.$(OBJEXT) lib_a-sf_trunc.$(OBJEXT)
>> +       lib_a-sf_round.$(OBJEXT) lib_a-sf_trunc.$(OBJEXT) \
>> +       lib_a-feclearexcept.$(OBJEXT) lib_a-fe_dfl_env.$(OBJEXT) \
>> +       lib_a-fegetenv.$(OBJEXT) lib_a-fegetexceptflag.$(OBJEXT) \
>> +       lib_a-fegetround.$(OBJEXT) lib_a-feholdexcept.$(OBJEXT) \
>> +       lib_a-fenv.$(OBJEXT) lib_a-feraiseexcept.$(OBJEXT) \
>> +       lib_a-fesetenv.$(OBJEXT) lib_a-fesetexceptflag.$(OBJEXT) \
>> +       lib_a-fesetround.$(OBJEXT) lib_a-fetestexcept.$(OBJEXT) \
>> +       lib_a-feupdateenv.$(OBJEXT) lib_a-fenv-vfp.$(OBJEXT) \
>> +       lib_a-fenv-softfp.$(OBJEXT)
>>  am_lib_a_OBJECTS = $(am__objects_1)
>>  lib_a_OBJECTS = $(am_lib_a_OBJECTS)
>>  DEFAULT_INCLUDES = -I. at am__isrc@
>> @@ -95,6 +102,8 @@ am__can_run_installinfo = \
>>  DATA = $(noinst_DATA)
>>  ETAGS = etags
>>  CTAGS = ctags
>> +CSCOPE = cscope
>> +AM_RECURSIVE_TARGETS = cscope
>>  ACLOCAL = @ACLOCAL@
>>  AMTAR = @AMTAR@
>>  AR = @AR@
>> @@ -216,7 +225,22 @@ LIB_SOURCES = \
>>         sf_nearbyint.c \
>>         sf_rint.c \
>>         sf_round.c \
>> -       sf_trunc.c
>> +       sf_trunc.c \
>> +       feclearexcept.c \
>> +       fe_dfl_env.c\
>> +       fegetenv.c \
>> +       fegetround.c \
>> +       feholdexcept.c \
>> +       fenv.c \
>> +       feraiseexcept.c \
>> +       fesetenv.c \
>> +       fesetround.c \
>> +       fetestexcept.c \
>> +       feupdateenv.c \
>> +       fenv-vfp.c \
>> +       fenv-softfp.c
>> @@ -378,6 +402,96 @@ lib_a-sf_trunc.o: sf_trunc.c
>>  lib_a-sf_trunc.obj: sf_trunc.c
>>         $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS)
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-sf_trunc.obj `if test -f
>> 'sf_trunc.c'; then $(CYGPATH_W) 'sf_trunc.c'; else $(CYGPATH_W)
>> '$(srcdir)/sf_trunc.c'; fi`
>> +lib_a-feclearexcept.o: feclearexcept.c
>> +       $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS)
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feclearexcept.o `test -f
>> 'feclearexcept.c' || echo '$(srcdir)/'`feclearexcept.c
>> +lib_a-feclearexcept.obj: feclearexcept.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feclearexcept.obj `if
>> test -f 'feclearexcept.c'; then $(CYGPATH_W) 'feclearexcept.c'; else
>> $(CYGPATH_W) '$(srcdir)/feclearexcept.c'; fi`
>> +lib_a-fe_dfl_env.o: fe_dfl_env.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fe_dfl_env.o `test -f
>> 'fe_dfl_env.c' || echo '$(srcdir)/'`fe_dfl_env.c
>> +lib_a-fe_dfl_env.obj: fe_dfl_env.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fe_dfl_env.obj `if test
>> -f 'fe_dfl_env.c'; then $(CYGPATH_W) 'fe_dfl_env.c'; else $(CYGPATH_W)
>> '$(srcdir)/fe_dfl_env.c'; fi`
>> +lib_a-fegetenv.o: fegetenv.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetenv.o `test -f
>> 'fegetenv.c' || echo '$(srcdir)/'`fegetenv.c
>> +lib_a-fegetenv.obj: fegetenv.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetenv.obj `if test -f
>> 'fegetenv.c'; then $(CYGPATH_W) 'fegetenv.c'; else $(CYGPATH_W)
>> '$(srcdir)/fegetenv.c'; fi`
>> +lib_a-fegetexceptflag.o: fegetexceptflag.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetexceptflag.o `test
>> -f 'fegetexceptflag.c' || echo '$(srcdir)/'`fegetexceptflag.c
>> +lib_a-fegetexceptflag.obj: fegetexceptflag.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetexceptflag.obj `if
>> test -f 'fegetexceptflag.c'; then $(CYGPATH_W) 'fegetexceptflag.c'; else
>> $(CYGPATH_W) '$(srcdir)/fegetexceptflag.c'; fi`
>> +lib_a-fegetround.o: fegetround.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetround.o `test -f
>> 'fegetround.c' || echo '$(srcdir)/'`fegetround.c
>> +lib_a-fegetround.obj: fegetround.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetround.obj `if test
>> -f 'fegetround.c'; then $(CYGPATH_W) 'fegetround.c'; else $(CYGPATH_W)
>> '$(srcdir)/fegetround.c'; fi`
>> +lib_a-feholdexcept.o: feholdexcept.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feholdexcept.o `test -f
>> 'feholdexcept.c' || echo '$(srcdir)/'`feholdexcept.c
>> +lib_a-feholdexcept.obj: feholdexcept.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feholdexcept.obj `if test
>> -f 'feholdexcept.c'; then $(CYGPATH_W) 'feholdexcept.c'; else $(CYGPATH_W)
>> '$(srcdir)/feholdexcept.c'; fi`
>> +lib_a-fenv.o: fenv.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv.o `test -f 'fenv.c'
>> || echo '$(srcdir)/'`fenv.c
>> +lib_a-fenv.obj: fenv.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv.obj `if test -f
>> 'fenv.c'; then $(CYGPATH_W) 'fenv.c'; else $(CYGPATH_W) '$(srcdir)/fenv.c';
>> fi`
>> +lib_a-feraiseexcept.o: feraiseexcept.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feraiseexcept.o `test -f
>> 'feraiseexcept.c' || echo '$(srcdir)/'`feraiseexcept.c
>> +lib_a-feraiseexcept.obj: feraiseexcept.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feraiseexcept.obj `if
>> test -f 'feraiseexcept.c'; then $(CYGPATH_W) 'feraiseexcept.c'; else
>> $(CYGPATH_W) '$(srcdir)/feraiseexcept.c'; fi`
>> +lib_a-fesetenv.o: fesetenv.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetenv.o `test -f
>> 'fesetenv.c' || echo '$(srcdir)/'`fesetenv.c
>> +lib_a-fesetenv.obj: fesetenv.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetenv.obj `if test -f
>> 'fesetenv.c'; then $(CYGPATH_W) 'fesetenv.c'; else $(CYGPATH_W)
>> '$(srcdir)/fesetenv.c'; fi`
>> +lib_a-fesetexceptflag.o: fesetexceptflag.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetexceptflag.o `test
>> -f 'fesetexceptflag.c' || echo '$(srcdir)/'`fesetexceptflag.c
>> +lib_a-fesetexceptflag.obj: fesetexceptflag.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetexceptflag.obj `if
>> test -f 'fesetexceptflag.c'; then $(CYGPATH_W) 'fesetexceptflag.c'; else
>> $(CYGPATH_W) '$(srcdir)/fesetexceptflag.c'; fi`
>> +lib_a-fesetround.o: fesetround.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetround.o `test -f
>> 'fesetround.c' || echo '$(srcdir)/'`fesetround.c
>> +lib_a-fesetround.obj: fesetround.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetround.obj `if test
>> -f 'fesetround.c'; then $(CYGPATH_W) 'fesetround.c'; else $(CYGPATH_W)
>> '$(srcdir)/fesetround.c'; fi`
>> +lib_a-fetestexcept.o: fetestexcept.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fetestexcept.o `test -f
>> 'fetestexcept.c' || echo '$(srcdir)/'`fetestexcept.c
>> +lib_a-fetestexcept.obj: fetestexcept.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fetestexcept.obj `if test
>> -f 'fetestexcept.c'; then $(CYGPATH_W) 'fetestexcept.c'; else $(CYGPATH_W)
>> '$(srcdir)/fetestexcept.c'; fi`
>> +lib_a-feupdateenv.o: feupdateenv.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.o `test -f
>> 'feupdateenv.c' || echo '$(srcdir)/'`feupdateenv.c
>> +lib_a-feupdateenv.obj: feupdateenv.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.obj `if test
>> -f 'feupdateenv.c'; then $(CYGPATH_W) 'feupdateenv.c'; else $(CYGPATH_W)
>> '$(srcdir)/feupdateenv.c'; fi`
>> +lib_a-fenv-vfp.o: fenv-vfp.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-vfp.o `test -f
>> 'fenv-vfp.c' || echo '$(srcdir)/'`fenv-vfp.c
>> +lib_a-fenv-vfp.obj: fenv-vfp.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-vfp.obj `if test -f
>> 'fenv-vfp.c'; then $(CYGPATH_W) 'fenv-vfp.c'; else $(CYGPATH_W)
>> '$(srcdir)/fenv-vfp.c'; fi`
>> +lib_a-fenv-softfp.o: fenv-softfp.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-softfp.o `test -f
>> 'fenv-softfp.c' || echo '$(srcdir)/'`fenv-softfp.c
>> +lib_a-fenv-softfp.obj: fenv-softfp.c
>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-softfp.obj `if test
>> -f 'fenv-softfp.c'; then $(CYGPATH_W) 'fenv-softfp.c'; else $(CYGPATH_W)
>> '$(srcdir)/fenv-softfp.c'; fi`
>>  ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
>>         list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
>>         unique=`for i in $$list; do \
>> @@ -427,8 +541,32 @@ GTAGS:
>>           && $(am__cd) $(top_srcdir) \
>>           && gtags -i $(GTAGS_ARGS) "$$here"
>> +cscope: cscope.files
>> +       test ! -s cscope.files \
>> +         || $(CSCOPE) -b -q $(AM_CSCOPEFLAGS) $(CSCOPEFLAGS) -i
>> cscope.files $(CSCOPE_ARGS)
>> +clean-cscope:
>> +       -rm -f cscope.files
>> +cscope.files: clean-cscope  cscopelist
>> +cscopelist:  $(HEADERS) $(SOURCES) $(LISP)
>> +       list='$(SOURCES) $(HEADERS) $(LISP)'; \
>> +       case "$(srcdir)" in \
>> +         [\\/]* | ?:[\\/]*) sdir="$(srcdir)" ;; \
>> +         *) sdir=$(subdir)/$(srcdir) ;; \
>> +       esac; \
>> +       for i in $$list; do \
>> +         if test -f "$$i"; then \
>> +           echo "$(subdir)/$$i"; \
>> +         else \
>> +           echo "$$sdir/$$i"; \
>> +         fi; \
>> +       done >> $(top_builddir)/cscope.files
>>  distclean-tags:
>>         -rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
>> +       -rm -f cscope.out cscope.in.out cscope.po.out cscope.files
>>  check-am:
>>  check: check-am
>>  all-am: Makefile $(LIBRARIES) $(DATA)
>> @@ -537,17 +675,17 @@ uninstall-am:
>>  .MAKE: install-am install-strip
>>  .PHONY: CTAGS GTAGS all all-am am--refresh check check-am clean \
>> -       clean-generic clean-noinstLIBRARIES ctags distclean \
>> -       distclean-compile distclean-generic distclean-tags dvi dvi-am \
>> -       html html-am info info-am install install-am install-data \
>> -       install-data-am install-dvi install-dvi-am install-exec \
>> -       install-exec-am install-html install-html-am install-info \
>> -       install-info-am install-man install-pdf install-pdf-am \
>> -       install-ps install-ps-am install-strip installcheck \
>> -       installcheck-am installdirs maintainer-clean \
>> -       maintainer-clean-generic mostlyclean mostlyclean-compile \
>> -       mostlyclean-generic pdf pdf-am ps ps-am tags uninstall \
>> -       uninstall-am
>> +       clean-cscope clean-generic clean-noinstLIBRARIES cscope \
>> +       cscopelist ctags distclean distclean-compile distclean-generic \
>> +       distclean-tags dvi dvi-am html html-am info info-am install \
>> +       install-am install-data install-data-am install-dvi \
>> +       install-dvi-am install-exec install-exec-am install-html \
>> +       install-html-am install-info install-info-am install-man \
>> +       install-pdf install-pdf-am install-ps install-ps-am \
>> +       install-strip installcheck installcheck-am installdirs \
>> +       maintainer-clean maintainer-clean-generic mostlyclean \
>> +       mostlyclean-compile mostlyclean-generic pdf pdf-am ps ps-am \
>> +       tags uninstall uninstall-am
>>  objectlist.awk.in: $(noinst_LTLIBRARIES)
>>         -rm -f objectlist.awk.in
>> diff --git a/newlib/libm/machine/arm/fe_dfl_env.c
>> b/newlib/libm/machine/arm/fe_dfl_env.c
>> index 000000000..8cbee7771
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fe_dfl_env.c
>> @@ -0,0 +1,7 @@
>> + * (c) Copyright 2019 Joel Sherrill <joel at rtems.org>
>> +#include "../../fenv/fenv_stub.c"
>> diff --git a/newlib/libm/machine/arm/feclearexcept.c
>> b/newlib/libm/machine/arm/feclearexcept.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/feclearexcept.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/fegetenv.c
>> b/newlib/libm/machine/arm/fegetenv.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fegetenv.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/fegetexceptflag.c
>> b/newlib/libm/machine/arm/fegetexceptflag.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fegetexceptflag.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/fegetround.c
>> b/newlib/libm/machine/arm/fegetround.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fegetround.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/feholdexcept.c
>> b/newlib/libm/machine/arm/feholdexcept.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/feholdexcept.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/fenv-softfp.c
>> b/newlib/libm/machine/arm/fenv-softfp.c
>> index 000000000..a576cc1b2
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fenv-softfp.c
>> @@ -0,0 +1,32 @@
>> + * are met:
>> distribution.
>> PURPOSE
>> LIABLE
>> CONSEQUENTIAL
>> GOODS
>> STRICT
>> WAY
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#define        FENV_MANGLE(x)  __softfp_ ##x
>> +#include <machine/fenv-mangle.h>
>> +#include "fenv.c"
>> diff --git a/newlib/libm/machine/arm/fenv-vfp.c
>> b/newlib/libm/machine/arm/fenv-vfp.c
>> index 000000000..297e81296
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fenv-vfp.c
>> @@ -0,0 +1,32 @@
>> + * are met:
>> distribution.
>> PURPOSE
>> LIABLE
>> CONSEQUENTIAL
>> GOODS
>> STRICT
>> WAY
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#define        FENV_MANGLE(x)  __vfp_ ##x
>> +#include "fenv.c"
>> diff --git a/newlib/libm/machine/arm/fenv.c
>> b/newlib/libm/machine/arm/fenv.c
>> index 000000000..278de8633
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fenv.c
>> @@ -0,0 +1,328 @@
>> + * Copyright (c) 2004 David Schultz <das at FreeBSD.ORG>
>> + * are met:
>> distribution.
>> PURPOSE
>> LIABLE
>> CONSEQUENTIAL
>> GOODS
>> STRICT
>> WAY
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#include <fenv.h>
>> +#include <machine/acle-compat.h>
>> +#if __ARM_ARCH >= 6
>> +#define FENV_ARMv6
>> +#endif
>> +/* When SOFTFP_ABI is defined we are using the softfp ABI. */
>> +#if defined(__VFP_FP__) && !defined(__ARM_PCS_VFP)
>> +#define SOFTFP_ABI
>> +#endif
>> + * Hopefully the system ID byte is immutable, so it's valid to use
>> + * this as a default environment.
>> +fenv_t __fe_dfl_env = { 0 };
>> +const fenv_t *_fe_dfl_env = &__fe_dfl_env;
>> +#endif
>> +/* If this is a non-mangled softfp version special processing is
>> required */
>> +#if defined(FENV_MANGLE) || !defined(SOFTFP_ABI) || !defined(FENV_ARMv6)
>> + * The following macros map between the softfloat emulator's flags and
>> + * the hardware's FPSR.  The hardware this file was written for doesn't
>> + * have rounding control bits, so we stick those in the system ID byte.
>> +#define        __set_env(env, flags, mask, rnd) env = ((flags)
>> +                                               | (mask)<<_FPUSW_SHIFT  \
>> +                                               | (rnd) << 24)
>> +#define        __env_flags(env)                ((env) & FE_ALL_EXCEPT)
>> +#define        __env_mask(env)                 (((env) >> _FPUSW_SHIFT)
>> +                                               & FE_ALL_EXCEPT)
>> +#define        __env_round(env)                (((env) >> 24) &
>> _ROUND_MASK)
>> +#include <machine/fenv-softfloat.h>
>> +#else /* __ARM_PCS_VFP PRESENT */
>> +#include <machine/fenv-vfp.h>
>> +#ifdef __GNUC_GNU_INLINE__
>> +#error "This file must be compiled with C99 'inline' semantics"
>> +#endif
>> +extern inline int feclearexcept(int excepts);
>> +extern inline int fegetexceptflag(fexcept_t *flagp, int excepts);
>> +extern inline int fesetexceptflag(const fexcept_t *flagp, int excepts);
>> +extern inline int feraiseexcept(int excepts);
>> +extern inline int fetestexcept(int excepts);
>> +extern inline int fegetround(void);
>> +extern inline int fesetround(int round);
>> +extern inline int fegetenv(fenv_t *envp);
>> +extern inline int feholdexcept(fenv_t *envp);
>> +extern inline int fesetenv(const fenv_t *envp);
>> +extern inline int feupdateenv(const fenv_t *envp);
>> +extern inline int feenableexcept(int __mask);
>> +extern inline int fedisableexcept(int __mask);
>> +extern inline int fegetexcept(void);
>> +#else /* !FENV_MANGLE && SOFTFP_ABI */
>> +/* Set by libc when the VFP unit is enabled */
>> +extern int _libc_arm_fpu_present;
>> +int __softfp_feclearexcept(int excepts);
>> +int __softfp_fegetexceptflag(fexcept_t *flagp, int excepts);
>> +int __softfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
>> +int __softfp_feraiseexcept(int excepts);
>> +int __softfp_fetestexcept(int excepts);
>> +int __softfp_fegetround(void);
>> +int __softfp_fesetround(int round);
>> +int __softfp_fegetenv(fenv_t *envp);
>> +int __softfp_feholdexcept(fenv_t *envp);
>> +int __softfp_fesetenv(const fenv_t *envp);
>> +int __softfp_feupdateenv(const fenv_t *envp);
>> +int __softfp_feenableexcept(int __mask);
>> +int __softfp_fedisableexcept(int __mask);
>> +int __softfp_fegetexcept(void);
>> +int __vfp_feclearexcept(int excepts);
>> +int __vfp_fegetexceptflag(fexcept_t *flagp, int excepts);
>> +int __vfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
>> +int __vfp_feraiseexcept(int excepts);
>> +int __vfp_fetestexcept(int excepts);
>> +int __vfp_fegetround(void);
>> +int __vfp_fesetround(int round);
>> +int __vfp_fegetenv(fenv_t *envp);
>> +int __vfp_feholdexcept(fenv_t *envp);
>> +int __vfp_fesetenv(const fenv_t *envp);
>> +int __vfp_feupdateenv(const fenv_t *envp);
>> +int __vfp_feenableexcept(int __mask);
>> +int __vfp_fedisableexcept(int __mask);
>> +int __vfp_fegetexcept(void);
>> +static int
>> +__softfp_round_to_vfp(int round)
>> +       switch (round) {
>> +       case FE_TONEAREST:
>> +       default:
>> +               return VFP_FE_TONEAREST;
>> +       case FE_TOWARDZERO:
>> +               return VFP_FE_TOWARDZERO;
>> +       case FE_UPWARD:
>> +               return VFP_FE_UPWARD;
>> +       case FE_DOWNWARD:
>> +               return VFP_FE_DOWNWARD;
>> +static int
>> +__softfp_round_from_vfp(int round)
>> +       switch (round) {
>> +       case VFP_FE_TONEAREST:
>> +       default:
>> +               return FE_TONEAREST;
>> +       case VFP_FE_TOWARDZERO:
>> +               return FE_TOWARDZERO;
>> +       case VFP_FE_UPWARD:
>> +               return FE_UPWARD;
>> +       case VFP_FE_DOWNWARD:
>> +               return FE_DOWNWARD;
>> +       if (_libc_arm_fpu_present)
>> +               __vfp_feclearexcept(excepts);
>> +       __softfp_feclearexcept(excepts);
>> +       return (0);
>> +       fexcept_t __vfp_flagp;
>> +       __vfp_flagp = 0;
>> +               __vfp_fegetexceptflag(&__vfp_flagp, excepts);
>> +       __softfp_fegetexceptflag(flagp, excepts);
>> +       *flagp |= __vfp_flagp;
>> +       return (0);
>> +               __vfp_fesetexceptflag(flagp, excepts);
>> +       __softfp_fesetexceptflag(flagp, excepts);
>> +       return (0);
>> +               __vfp_feraiseexcept(excepts);
>> +       __softfp_feraiseexcept(excepts);
>> +       return (0);
>> +       int __got_excepts;
>> +       __got_excepts = 0;
>> +               __got_excepts = __vfp_fetestexcept(excepts);
>> +       __got_excepts |= __softfp_fetestexcept(excepts);
>> +       return (__got_excepts);
>> +               return __softfp_round_from_vfp(__vfp_fegetround());
>> +       return __softfp_fegetround();
>> +               __vfp_fesetround(__softfp_round_to_vfp(round));
>> +       __softfp_fesetround(round);
>> +       return (0);
>> +       fenv_t __vfp_envp;
>> +       __vfp_envp = 0;
>> +               __vfp_fegetenv(&__vfp_envp);
>> +       __softfp_fegetenv(envp);
>> +       *envp |= __vfp_envp;
>> +       return (0);
>> +       __vfp_envp = 0;
>> +               __vfp_feholdexcept(&__vfp_envp);
>> +       __softfp_feholdexcept(envp);
>> +       return (0);
>> +               __vfp_fesetenv(envp);
>> +       __softfp_fesetenv(envp);
>> +       return (0);
>> +               __vfp_feupdateenv(envp);
>> +       __softfp_feupdateenv(envp);
>> +       return (0);
>> +       int __unmasked;
>> +       __unmasked = 0;
>> +               __unmasked = __vfp_feenableexcept(__mask);
>> +       __unmasked |= __softfp_feenableexcept(__mask);
>> +       return (__unmasked);
>> +       int __unmasked;
>> +       __unmasked = 0;
>> +               __unmasked = __vfp_fedisableexcept(__mask);
>> +       __unmasked |= __softfp_fedisableexcept(__mask);
>> +       int __unmasked;
>> +       __unmasked = 0;
>> +               __unmasked = __vfp_fegetexcept();
>> +       __unmasked |= __softfp_fegetexcept();
>> +#endif
>> diff --git a/newlib/libm/machine/arm/feraiseexcept.c
>> b/newlib/libm/machine/arm/feraiseexcept.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/feraiseexcept.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/fesetenv.c
>> b/newlib/libm/machine/arm/fesetenv.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fesetenv.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/fesetexceptflag.c
>> b/newlib/libm/machine/arm/fesetexceptflag.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fesetexceptflag.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/fesetround.c
>> b/newlib/libm/machine/arm/fesetround.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fesetround.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/fetestexcept.c
>> b/newlib/libm/machine/arm/fetestexcept.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/fetestexcept.c
>> @@ -0,0 +1,7 @@
>> diff --git a/newlib/libm/machine/arm/feupdateenv.c
>> b/newlib/libm/machine/arm/feupdateenv.c
>> --- /dev/null
>> +++ b/newlib/libm/machine/arm/feupdateenv.c
>> @@ -0,0 +1,7 @@
>> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200523/591205de/attachment-0001.html>
eshan at EDs-pc:~/development/Tools/tmulti$ ./multilib_cycle_gcc.sh
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000008000
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:69: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:77: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:86: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:92: undefined reference to `__softfloat_float_raise'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:101: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fegetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:108: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fesetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:116: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fegetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `feholdexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fesetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `feupdateenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `feenableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:169: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fedisableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:178: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/libm.a(lib_a-fenv.o): in function `fegetexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/newlib/targ-include/machine/fenv-softfloat.h:185: undefined reference to `__softfloat_float_exception_mask'
collect2: error: ld returned 1 exit status
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:69: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:77: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:86: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:92: undefined reference to `__softfloat_float_raise'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:101: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fegetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:108: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fesetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:116: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fegetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `feholdexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fesetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `feupdateenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `feenableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:169: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fedisableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:178: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/libm.a(lib_a-fenv.o): in function `fegetexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/newlib/targ-include/machine/fenv-softfloat.h:185: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv.o): in function `feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:179: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv.o): in function `fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:193: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv.o): in function `fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:203: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv.o): in function `feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:213: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv.o): in function `fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:225: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:163: more undefined references to `_libc_arm_fpu_present' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:69: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:77: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:86: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:92: undefined reference to `__softfloat_float_raise'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:101: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:108: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:116: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feholdexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feupdateenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feenableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:169: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fedisableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:178: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv6-m/newlib/targ-include/machine/fenv-softfloat.h:185: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feclearexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feraiseexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fetestexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feholdexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feupdateenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feenableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fedisableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv6-m/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv.o): in function `feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:174: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:174: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv.o): in function `fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:186: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:186: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv.o): in function `fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:198: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:198: more undefined references to `_libc_arm_fpu_present' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:67: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:67: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:75: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:75: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:83: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:83: more undefined references to `__softfloat_float_exception_flags' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:92: undefined reference to `__softfloat_float_raise'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:100: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:100: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:107: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:107: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:114: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:114: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:122: more undefined references to `__softfloat_float_rounding_mode' follow
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:142: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:142: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:143: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:144: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feupdateenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:151: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:151: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feenableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:165: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:165: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fedisableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:174: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:174: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:184: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-softfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:184: more undefined references to `__softfloat_float_exception_mask' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feclearexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:83: more undefined references to `__softfloat_float_exception_flags' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feraiseexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fetestexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:122: more undefined references to `__softfloat_float_rounding_mode' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feupdateenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feenableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fedisableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-a/libm.a(lib_a-fenv-vfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-a/newlib/targ-include/machine/fenv-softfloat.h:184: more undefined references to `__softfloat_float_exception_mask' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv.o): in function `feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:174: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:174: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv.o): in function `fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:186: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:186: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv.o): in function `fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:198: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:198: more undefined references to `_libc_arm_fpu_present' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:67: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:67: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:75: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:75: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:83: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:83: more undefined references to `__softfloat_float_exception_flags' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:92: undefined reference to `__softfloat_float_raise'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:100: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:100: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:107: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:107: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:114: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:114: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:143: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:143: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:142: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:144: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feupdateenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:151: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feenableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:165: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:165: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fedisableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:174: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:174: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:184: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:184: more undefined references to `__softfloat_float_exception_mask' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feclearexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:83: more undefined references to `__softfloat_float_exception_flags' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feraiseexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fetestexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feupdateenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feenableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fedisableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:184: more undefined references to `__softfloat_float_exception_mask' follow
collect2: error: ld returned 1 exit status
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000008000
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv.o): in function `feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:179: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv.o): in function `fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:193: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv.o): in function `fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:203: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv.o): in function `feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:213: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv.o): in function `fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:225: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:233: more undefined references to `_libc_arm_fpu_present' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:69: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:77: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:86: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:92: undefined reference to `__softfloat_float_raise'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:101: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:108: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:116: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feholdexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feupdateenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feenableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:169: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fedisableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:178: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m3/newlib/targ-include/machine/fenv-softfloat.h:185: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feclearexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feraiseexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fetestexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feholdexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feupdateenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feenableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fedisableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m3/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv.o): in function `feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:179: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv.o): in function `fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:193: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv.o): in function `fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:203: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv.o): in function `feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:213: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv.o): in function `fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:225: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/libm/machine/arm/../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:233: more undefined references to `_libc_arm_fpu_present' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:69: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:77: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:86: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:92: undefined reference to `__softfloat_float_raise'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:101: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:108: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:116: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:125: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feholdexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:136: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:146: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feupdateenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:156: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feenableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:169: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fedisableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:178: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/thumb/cortex-m4/newlib/targ-include/machine/fenv-softfloat.h:185: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feclearexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feraiseexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fetestexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feholdexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feupdateenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feenableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fedisableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/thumb/cortex-m4/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv.o): in function `feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:174: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:174: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv.o): in function `fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:186: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:186: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv.o): in function `fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:198: undefined reference to `_libc_arm_fpu_present'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/libm/machine/arm/../../../../../../../../../gcc-7.5.0/newlib/libm/machine/arm/fenv.c:198: more undefined references to `_libc_arm_fpu_present' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feclearexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:67: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:67: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:75: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:75: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetexceptflag':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:83: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:83: more undefined references to `__softfloat_float_exception_flags' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feraiseexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:92: undefined reference to `__softfloat_float_raise'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fetestexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:100: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:100: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:107: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:107: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetround':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:114: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:114: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:122: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fesetenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:143: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:143: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:142: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:144: undefined reference to `__softfloat_float_rounding_mode'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feupdateenv':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:151: undefined reference to `__softfloat_float_exception_flags'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_feenableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:165: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:165: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fedisableexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:174: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:174: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o): in function `__softfp_fegetexcept':
/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:184: undefined reference to `__softfloat_float_exception_mask'
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-softfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:184: more undefined references to `__softfloat_float_exception_mask' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feclearexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetexceptflag':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:83: more undefined references to `__softfloat_float_exception_flags' follow
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feraiseexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fetestexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetround':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fesetenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feupdateenv':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_feenableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fedisableexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o): in function `__vfp_fegetexcept':
/home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/eshan/development/rtems/5/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/lib/eb/thumb/armv7-r/libm.a(lib_a-fenv-vfp.o):/home/eshan/development/rtems/rsb/rtems/build/arm-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1/build/arm-rtems5/eb/thumb/armv7-r/newlib/targ-include/machine/fenv-softfloat.h:184: more undefined references to `__softfloat_float_exception_mask' follow
