Need help to execute/debug smpschededf02.exe on leon3
Richi Dubey richidubey at gmail.com
Mon May 25 14:38:20 UTC 2020
On executing run again on gdb, I am getting the following error:
0x00000000 in ?? ()
(gdb) run
The program being debugged has been started already.
Start it from the beginning? (y or n) y
../../gdb-9.1/gdb/thread.c:95: internal-error: thread_info*
inferior_thread(): Assertion `tp' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session? (y or n) y
This is a bug, please report it.  For instructions, see:
<http://www.gnu.org/software/gdb/bugs/>.
Create a core file of GDB? (y or n) y
Aborted (core dumped)
What might be going wrong?
On Mon, May 25, 2020 at 8:00 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hii everyone,
> When I am executing smpschededf02.exe on my leon3 bsp running on
> sparc5 with  sparc-rtems5-sis with -m 4 -leon3 option, it fails to
> execute properly.
> I have built leon3 with --enable-smp option and I am guessing the
> execution fails because I don not see any output of the test and I can
> only see the following output:
> ~/quick-start/rtems/5/bin$ ./sparc-rtems5-sis -leon3 -m 4
> ~/quick-start/build/leon3/sparc-rtems5/c/leon3/testsuites/smptests/smpschededf02.exe
>  SIS - SPARC/RISCV instruction simulator 2.21,  copyright Jiri Gaisler 2019
>  Bug-reports to jiri at gaisler.se
>  LEON3 emulation enabled, 4 cpus online, delta 50 clocks
>  Loaded /home/richi/quick-start/build/leon3/sparc-rtems5/c/leon3/testsuites/smptests/smpschededf02.exe,
> entry 0x40000000
> cpu0> run
> *** BEGIN OF TEST SMPSCHEDEDF 2 ***
> *** TEST VERSION: 5.0.0.20a8361de4724658112ecd33c28fae82a15919f8
> *** TEST STATE: EXPECTED_PASS
> *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (0b7e87143b76), Newlib fbaa096)
> *** END OF TEST SMPSCHEDEDF 2 ***
> cpu 1 in error mode (tt = 0x80)
>   3491850  40016360:  91d02000   ta  0x0
> On running the program with gdb with extended-remote and debugging
> with sis, I am encountering the following error:
> (gdb) target extended-remote localhost:1234
> Remote debugging using localhost:1234
> 0x00000000 in ?? ()
> (gdb)
> I even tried to execute sis with -m 2 option as smpschededf02/init.c
> has #define CPU_COUNT 2, but sis still shows the same output with no
> changes.
> I have attached the screenshots of my terminal. It'd be great if
> someone could please help me out.
> Thanks,
> Richi.
