[PATCH] Adding fenv support arm.
Eshan Dhawan eshandhawan51 at gmail.com
Mon May 25 19:29:15 UTC 2020
I removed the __softfloat_float_raise option and there seems some progress
Still log is showing some unrecognised option errors.
The function that required _softfloat_float_raise
I returned return (excepts  ?  -ENOTSUP : 0); from there
and there seems no new error.
But might require testing for other functions and arguments.
Log:
*eshan at EDs-pc*:*~/development/Tools/tmulti*$ ./multilib_cycle_gcc.sh
as: unrecognized option '-meabi=5'
as: unrecognized option '-mfloat-abi=hard'
Assembler messages:
Fatal error: invalid -march= option: `armv6-m'
Assembler messages:
Fatal error: invalid -march= option: `armv7-a'
Assembler messages:
Fatal error: invalid -march= option: `armv7-r'
as: unrecognized option '-mcpu=cortex-m3'
as: unrecognized option '-mcpu=cortex-m4'
Assembler messages:
Assembler messages:
as: unrecognized option '-mcpu=cortex-m7'
as: unrecognized option '-EB'
Thanks
-Eshan
On Mon, May 25, 2020 at 10:45 PM Joel Sherrill <joel at rtems.org> wrote:
> I suspect there are no fielded FreeBSD (or NetBSD) systems with soft
> floating point so this is just broken.
> On top of that, we will be using GCC's soft float implementation which
> will do something different.
> I'm going to ask this over on newlib's mailing list and cc you.
> --joel
> On Mon, May 25, 2020 at 11:50 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> Hello,
>> I ran the script and made a few changes
>> but there are errors in the soft float.
>> I have attached the logs with the mail.
>> the error is coming due to no definition of the function
>> I searched in freebsd for the definition but couldn't find any thing.
>> Thanks
>> -eshan
>> On Sat, May 23, 2020 at 11:27 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>>> Hello Dr Joel,
>>> I ran the script, The logs show error in soft float variants and don't
>>> show there exe files as well.
>>> I have attached the log file.
>>> Thanks
>>> -Eshan
>>> On Sat, May 23, 2020 at 10:29 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> This is both a holiday weekend and my birthday weekend. I won't get a
>>>> chance to review this for a bit.
>>>> But I am attaching a simple shell script and test program which
>>>> iterates over all multilib variants, compiles a simple program which should
>>>> end up linking against every multilib variant. If the script looks right,
>>>> then this should prove useful in the future.
>>>> Please check that the right set of exe's for the various multilib
>>>> options is generated and the fenv code is code for each. My parsing of the
>>>> multilib variants from gcc needs a double check.
>>>> On Fri, May 22, 2020 at 6:36 PM Eshan dhawan <eshandhawan51 at gmail.com>
>>>> wrote:
>>>>> This patch adds FENV support for ARM
>>>>> The code is ported from FreeBSD.
>>>>> Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
>>>>>  newlib/libc/machine/arm/machine/acle-compat.h | 182 ++++++++++
>>>>>  newlib/libc/machine/arm/machine/fenv-mangle.h |  53 +++
>>>>>  .../libc/machine/arm/machine/fenv-softfloat.h | 187 ++++++++++
>>>>>  newlib/libc/machine/arm/machine/fenv-vfp.h    | 187 ++++++++++
>>>>>  newlib/libc/machine/arm/sys/fenv.h            | 122 +++++++
>>>>>  newlib/libm/machine/arm/Makefile.am           |  18 +-
>>>>>  newlib/libm/machine/arm/Makefile.in           | 174 +++++++++-
>>>>>  newlib/libm/machine/arm/fe_dfl_env.c          |   7 +
>>>>>  newlib/libm/machine/arm/feclearexcept.c       |   7 +
>>>>>  newlib/libm/machine/arm/fegetenv.c            |   7 +
>>>>>  newlib/libm/machine/arm/fegetexceptflag.c     |   7 +
>>>>>  newlib/libm/machine/arm/fegetround.c          |   7 +
>>>>>  newlib/libm/machine/arm/feholdexcept.c        |   7 +
>>>>>  newlib/libm/machine/arm/fenv-softfp.c         |  32 ++
>>>>>  newlib/libm/machine/arm/fenv-vfp.c            |  32 ++
>>>>>  newlib/libm/machine/arm/fenv.c                | 328 ++++++++++++++++++
>>>>>  newlib/libm/machine/arm/feraiseexcept.c       |   7 +
>>>>>  newlib/libm/machine/arm/fesetenv.c            |   7 +
>>>>>  newlib/libm/machine/arm/fesetexceptflag.c     |   7 +
>>>>>  newlib/libm/machine/arm/fesetround.c          |   7 +
>>>>>  newlib/libm/machine/arm/fetestexcept.c        |   7 +
>>>>>  newlib/libm/machine/arm/feupdateenv.c         |   7 +
>>>>>  22 files changed, 1380 insertions(+), 19 deletions(-)
>>>>>  create mode 100644 newlib/libc/machine/arm/machine/acle-compat.h
>>>>>  create mode 100644 newlib/libc/machine/arm/machine/fenv-mangle.h
>>>>>  create mode 100644 newlib/libc/machine/arm/machine/fenv-softfloat.h
>>>>>  create mode 100644 newlib/libc/machine/arm/machine/fenv-vfp.h
>>>>>  create mode 100644 newlib/libc/machine/arm/sys/fenv.h
>>>>>  create mode 100644 newlib/libm/machine/arm/fe_dfl_env.c
>>>>>  create mode 100644 newlib/libm/machine/arm/feclearexcept.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fegetenv.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fegetexceptflag.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fegetround.c
>>>>>  create mode 100644 newlib/libm/machine/arm/feholdexcept.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fenv-softfp.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fenv-vfp.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fenv.c
>>>>>  create mode 100644 newlib/libm/machine/arm/feraiseexcept.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fesetenv.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fesetexceptflag.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fesetround.c
>>>>>  create mode 100644 newlib/libm/machine/arm/fetestexcept.c
>>>>>  create mode 100644 newlib/libm/machine/arm/feupdateenv.c
>>>>> diff --git a/newlib/libc/machine/arm/machine/acle-compat.h
>>>>> b/newlib/libc/machine/arm/machine/acle-compat.h
>>>>> new file mode 100644
>>>>> index 000000000..888ae2ea8
>>>>> --- /dev/null
>>>>> +++ b/newlib/libc/machine/arm/machine/acle-compat.h
>>>>> @@ -0,0 +1,182 @@
>>>>> + * Copyright (c) 2014 ARM Ltd
>>>>> + * All rights reserved.
>>>>> + * Redistribution and use in source and binary forms, with or without
>>>>> + * modification, are permitted provided that the following conditions
>>>>> + * are met:
>>>>> + * 1. Redistributions of source code must retain the above copyright
>>>>> + *    notice, this list of conditions and the following disclaimer.
>>>>> + * 2. Redistributions in binary form must reproduce the above
>>>>> copyright
>>>>> + *    notice, this list of conditions and the following disclaimer in
>>>>> the
>>>>> + *    documentation and/or other materials provided with the
>>>>> distribution.
>>>>> + * 3. The name of the company may not be used to endorse or promote
>>>>> + *    products derived from this software without specific prior
>>>>> written
>>>>> + *    permission.
>>>>> + * THIS SOFTWARE IS PROVIDED BY ARM LTD ``AS IS'' AND ANY EXPRESS OR
>>>>> IMPLIED
>>>>> + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
>>>>> OF
>>>>> + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
>>>>> DISCLAIMED.
>>>>> + * IN NO EVENT SHALL ARM LTD BE LIABLE FOR ANY DIRECT, INDIRECT,
>>>>> INCIDENTAL,
>>>>> + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
>>>>> LIMITED
>>>>> + * TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
>>>>> DATA, OR
>>>>> + * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
>>>>> THEORY OF
>>>>> + * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>>>>> (INCLUDING
>>>>> + * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
>>>>> + * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>>>>> +#ifndef __ARM_ARCH
>>>>> +/* ACLE standardises a set of pre-defines that describe the ARM
>>>>> architecture.
>>>>> +   These were mostly implemented in GCC around GCC-4.8; older versions
>>>>> +   have no, or only partial support.  To provide a level of backwards
>>>>> +   compatibility we try to work out what the definitions should be,
>>>>> given
>>>>> +   the older pre-defines that GCC did produce.  This isn't complete,
>>>>> but
>>>>> +   it should be enough for use by routines that depend on this
>>>>> header.  */
>>>>> +/* No need to handle ARMv8, GCC had ACLE support before that.  */
>>>>> +# ifdef __ARM_ARCH_7__
>>>>> +/* The common subset of ARMv7 in all profiles.  */
>>>>> +#  define __ARM_ARCH 7
>>>>> +#  define __ARM_ARCH_ISA_THUMB 2
>>>>> +#  define __ARM_FEATURE_CLZ
>>>>> +#  define __ARM_FEATURE_LDREX 7
>>>>> +#  define __ARM_FEATURE_UNALIGNED
>>>>> +# endif
>>>>> +# if defined (__ARM_ARCH_7A__) || defined (__ARM_ARCH_7R__)
>>>>> +#  define __ARM_ARCH_ISA_ARM
>>>>> +#  define __ARM_FEATURE_SIMD32
>>>>> +#  define __ARM_FEATURE_DSP
>>>>> +#  define __ARM_FEATURE_QBIT
>>>>> +#  define __ARM_FEATURE_SAT
>>>>> +#  define __ARM_FEATURE_LDREX 15
>>>>> +#  ifdef __ARM_ARCH_7A__
>>>>> +#   define __ARM_ARCH_PROFILE 'A'
>>>>> +#  else
>>>>> +#   define __ARM_ARCH_PROFILE 'R'
>>>>> +#  endif
>>>>> +# endif
>>>>> +# ifdef __ARM_ARCH_7EM__
>>>>> +#  define __ARM_ARCH_PROFILE 'M'
>>>>> +# endif
>>>>> +# ifdef __ARM_ARCH_7M__
>>>>> +# endif
>>>>> +# ifdef __ARM_ARCH_6T2__
>>>>> +#  define __ARM_ARCH 6
>>>>> +#  define __ARM_FEATURE_LDREX 4
>>>>> +# endif
>>>>> +# ifdef __ARM_ARCH_6M__
>>>>> +#  define __ARM_ARCH_ISA_THUMB 1
>>>>> +# endif
>>>>> +# if defined (__ARM_ARCH_6__) || defined (__ARM_ARCH_6J__) \
>>>>> +  || defined (__ARM_ARCH_6K__) || defined (__ARM_ARCH_6Z__) \
>>>>> +  || defined (__ARM_ARCH_6ZK__)
>>>>> +#  ifndef __thumb__
>>>>> +#   if defined (__ARM_ARCH_6K__) || defined (__ARM_ARCH_6ZK__)
>>>>> +#   else
>>>>> +#   endif
>>>>> +#  endif
>>>>> +# endif
>>>>> +# if defined (__ARM_ARCH_5TE__) || defined (__ARM_ARCH_5E__)
>>>>> +#  define __ARM_ARCH 5
>>>>> +#  ifdef __ARM_ARCH_5TE__
>>>>> +#  endif
>>>>> +# endif
>>>>> +# if defined (__ARM_ARCH_5T__) || defined (__ARM_ARCH_5__)
>>>>> +#  endif
>>>>> +# endif
>>>>> +# ifdef __ARM_ARCH_4T__
>>>>> +#  define __ARM_ARCH 4
>>>>> +# endif
>>>>> +# ifdef __ARM_ARCH_4__
>>>>> +# endif
>>>>> +# if defined (__ARM_ARCH_3__) || defined (__ARM_ARCH_3M__)
>>>>> +#  define __ARM_ARCH 3
>>>>> +# endif
>>>>> +# ifdef __ARM_ARCH_2__
>>>>> +#  define __ARM_ARCH 2
>>>>> +# endif
>>>>> +# ifdef __ARMEB__
>>>>> +#  define __ARM_BIG_ENDIAN
>>>>> +# endif
>>>>> +/* If we still don't know what the target architecture is, then we're
>>>>> +   probably not using GCC.  */
>>>>> +# ifndef __ARM_ARCH
>>>>> +#  error Unable to determine architecture version.
>>>>> +# endif
>>>>> +#endif /* __ARM_ARCH  */
>>>>> diff --git a/newlib/libc/machine/arm/machine/fenv-mangle.h
>>>>> b/newlib/libc/machine/arm/machine/fenv-mangle.h
>>>>> index 000000000..476f7b20c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libc/machine/arm/machine/fenv-mangle.h
>>>>> @@ -0,0 +1,53 @@
>>>>> + * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS''
>>>>> AND
>>>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>>>>> THE
>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>>> PURPOSE
>>>>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
>>>>> LIABLE
>>>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>>> CONSEQUENTIAL
>>>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
>>>>> GOODS
>>>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>>>>> INTERRUPTION)
>>>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>>>>> CONTRACT, STRICT
>>>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
>>>>> ANY WAY
>>>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#ifdef _FENV_MANGLE_H_
>>>>> +#error Only include fenv-mangle.h once
>>>>> +#endif
>>>>> +#define        _FENV_MANGLE_H_
>>>>> +#ifndef FENV_MANGLE
>>>>> +#error FENV_MANGLE is undefined
>>>>> +#endif
>>>>> +#define        feclearexcept   FENV_MANGLE(feclearexcept)
>>>>> +#define        fegetexceptflag FENV_MANGLE(fegetexceptflag)
>>>>> +#define        fesetexceptflag FENV_MANGLE(fesetexceptflag)
>>>>> +#define        feraiseexcept   FENV_MANGLE(feraiseexcept)
>>>>> +#define        fetestexcept    FENV_MANGLE(fetestexcept)
>>>>> +#define        fegetround      FENV_MANGLE(fegetround)
>>>>> +#define        fesetround      FENV_MANGLE(fesetround)
>>>>> +#define        fegetenv        FENV_MANGLE(fegetenv)
>>>>> +#define        feholdexcept    FENV_MANGLE(feholdexcept)
>>>>> +#define        fesetenv        FENV_MANGLE(fesetenv)
>>>>> +#define        feupdateenv     FENV_MANGLE(feupdateenv)
>>>>> +#define        feenableexcept  FENV_MANGLE(feenableexcept)
>>>>> +#define        fedisableexcept FENV_MANGLE(fedisableexcept)
>>>>> +#define        fegetexcept     FENV_MANGLE(fegetexcept)
>>>>> diff --git a/newlib/libc/machine/arm/machine/fenv-softfloat.h
>>>>> b/newlib/libc/machine/arm/machine/fenv-softfloat.h
>>>>> index 000000000..e53e54f54
>>>>> --- /dev/null
>>>>> +++ b/newlib/libc/machine/arm/machine/fenv-softfloat.h
>>>>> @@ -0,0 +1,187 @@
>>>>> + * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
>>>>> + * Copyright (c) 2004-2011 David Schultz <das at FreeBSD.ORG>
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> AND
>>>>> THE
>>>>> PURPOSE
>>>>> LIABLE
>>>>> CONSEQUENTIAL
>>>>> GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>>>>> ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#ifndef        _SYS_FENV_H_
>>>>> +#error "This file is meant to be included only by <sys/fenv.h>."
>>>>> +#endif
>>>>> +/* the file can be added from architecture specific fenv.h file found
>>>>> in
>>>>> + *libc/sys/arch/sys *
>>>>> + * This file implements the functionality of <fenv.h> on platforms
>>>>> that
>>>>> + * lack an FPU and use softfloat in libc for floating point.  To use
>>>>> it,
>>>>> + * you must write an <fenv.h> that provides the following:
>>>>> + *   - a typedef for fenv_t, which may be an integer or struct type
>>>>> + *   - a typedef for fexcept_t (XXX This file assumes fexcept_t is a
>>>>> + *     simple integer type containing the exception mask.)
>>>>> + *   - definitions of FE_* constants for the five exceptions and four
>>>>> + *     rounding modes in IEEE 754, as described in fenv(3)
>>>>> + *   - a definition, and the corresponding external symbol, for
>>>>> FE_DFL_ENV
>>>>> + *   - a macro __set_env(env, flags, mask, rnd), which sets the given
>>>>> fenv_t
>>>>> + *     from the exception flags, mask, and rounding mode
>>>>> + *   - macros __env_flags(env), __env_mask(env), and
>>>>> __env_round(env), which
>>>>> + *     extract fields from an fenv_t
>>>>> + *   - a definition of __fenv_static
>>>>> + * If the architecture supports an optional FPU, it's recommended
>>>>> that you
>>>>> + * define fenv_t and fexcept_t to match the hardware ABI.  Otherwise,
>>>>> it
>>>>> + * doesn't matter how you define them.
>>>>> +extern int __softfloat_float_exception_flags;
>>>>> +extern int __softfloat_float_exception_mask;
>>>>> +extern int __softfloat_float_rounding_mode;
>>>>> +void __softfloat_float_raise(int);
>>>>> +__fenv_static inline int
>>>>> +feclearexcept(int excepts)
>>>>> +       __softfloat_float_exception_flags &= ~excepts;
>>>>> +       return (0);
>>>>> +fegetexceptflag(fexcept_t *flagp, int excepts)
>>>>> +       *flagp = __softfloat_float_exception_flags & excepts;
>>>>> +       return (0);
>>>>> +fesetexceptflag(const fexcept_t *flagp, int excepts)
>>>>> +       __softfloat_float_exception_flags |= *flagp & excepts;
>>>>> +       return (0);
>>>>> +feraiseexcept(int excepts)
>>>>> +       __softfloat_float_raise(excepts);
>>>>> +       return (0);
>>>>> +fetestexcept(int excepts)
>>>>> +       return (__softfloat_float_exception_flags & excepts);
>>>>> +fegetround(void)
>>>>> +       return (__softfloat_float_rounding_mode);
>>>>> +fesetround(int round)
>>>>> +       __softfloat_float_rounding_mode = round;
>>>>> +       return (0);
>>>>> +fegetenv(fenv_t *envp)
>>>>> +       __set_env(*envp, __softfloat_float_exception_flags,
>>>>> +           __softfloat_float_exception_mask,
>>>>> +       return (0);
>>>>> +feholdexcept(fenv_t *envp)
>>>>> +       fenv_t __env;
>>>>> +       fegetenv(envp);
>>>>> +       __softfloat_float_exception_flags = 0;
>>>>> +       __softfloat_float_exception_mask = 0;
>>>>> +       return (0);
>>>>> +fesetenv(const fenv_t *envp)
>>>>> +       __softfloat_float_exception_flags = __env_flags(*envp);
>>>>> +       __softfloat_float_exception_mask = __env_mask(*envp);
>>>>> +       __softfloat_float_rounding_mode = __env_round(*envp);
>>>>> +       return (0);
>>>>> +feupdateenv(const fenv_t *envp)
>>>>> +       int __oflags = __softfloat_float_exception_flags;
>>>>> +       fesetenv(envp);
>>>>> +       feraiseexcept(__oflags);
>>>>> +       return (0);
>>>>> +#if __BSD_VISIBLE
>>>>> +/* We currently provide no external definitions of the functions
>>>>> below. */
>>>>> +feenableexcept(int __mask)
>>>>> +       int __omask = __softfloat_float_exception_mask;
>>>>> +       __softfloat_float_exception_mask |= __mask;
>>>>> +       return (__omask);
>>>>> +fedisableexcept(int __mask)
>>>>> +       __softfloat_float_exception_mask &= ~__mask;
>>>>> +       return (__omask);
>>>>> +fegetexcept(void)
>>>>> +       return (__softfloat_float_exception_mask);
>>>>> +#endif /* __BSD_VISIBLE */
>>>>> diff --git a/newlib/libc/machine/arm/machine/fenv-vfp.h
>>>>> b/newlib/libc/machine/arm/machine/fenv-vfp.h
>>>>> index 000000000..25d71f3ab
>>>>> --- /dev/null
>>>>> +++ b/newlib/libc/machine/arm/machine/fenv-vfp.h
>>>>> @@ -0,0 +1,187 @@
>>>>> + * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> AND
>>>>> THE
>>>>> PURPOSE
>>>>> LIABLE
>>>>> CONSEQUENTIAL
>>>>> GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>>>>> ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#define        vmrs_fpscr(__r) __asm __volatile("vmrs %0, fpscr" :
>>>>> "=&r"(__r))
>>>>> +#define        vmsr_fpscr(__r) __asm __volatile("vmsr fpscr, %0" : :
>>>>> "r"(__r))
>>>>> +#define _FPU_MASK_SHIFT        8
>>>>> +__fenv_static inline int feclearexcept(int excepts)
>>>>> +       fexcept_t __fpsr;
>>>>> +       vmrs_fpscr(__fpsr);
>>>>> +       __fpsr &= ~excepts;
>>>>> +       vmsr_fpscr(__fpsr);
>>>>> +       return (0);
>>>>> +       fexcept_t __fpsr;
>>>>> +       *flagp = __fpsr & excepts;
>>>>> +       return (0);
>>>>> +       fexcept_t __fpsr;
>>>>> +       __fpsr |= *flagp & excepts;
>>>>> +       return (0);
>>>>> +       fexcept_t __ex = excepts;
>>>>> +       fesetexceptflag(&__ex, excepts);        /* XXX */
>>>>> +       return (0);
>>>>> +       fexcept_t __fpsr;
>>>>> +       return (__fpsr & excepts);
>>>>> +fegetround(void)
>>>>> +       fenv_t __fpsr;
>>>>> +       return (__fpsr & _ROUND_MASK);
>>>>> +       fenv_t __fpsr;
>>>>> +       __fpsr &= ~(_ROUND_MASK);
>>>>> +       __fpsr |= round;
>>>>> +       return (0);
>>>>> +       vmrs_fpscr(*envp);
>>>>> +       return (0);
>>>>> +       fenv_t __env;
>>>>> +       vmrs_fpscr(__env);
>>>>> +       *envp = __env;
>>>>> +       __env &= ~(FE_ALL_EXCEPT);
>>>>> +       vmsr_fpscr(__env);
>>>>> +       return (0);
>>>>> +       vmsr_fpscr(*envp);
>>>>> +       return (0);
>>>>> +       fexcept_t __fpsr;
>>>>> +       feraiseexcept(__fpsr & FE_ALL_EXCEPT);
>>>>> +       return (0);
>>>>> +#if __BSD_VISIBLE
>>>>> below. */
>>>>> +       fenv_t __old_fpsr, __new_fpsr;
>>>>> +       vmrs_fpscr(__old_fpsr);
>>>>> +       __new_fpsr = __old_fpsr |
>>>>> +           ((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
>>>>> +       vmsr_fpscr(__new_fpsr);
>>>>> +       return ((__old_fpsr >> _FPU_MASK_SHIFT) & FE_ALL_EXCEPT);
>>>>> +       __new_fpsr = __old_fpsr &
>>>>> +           ~((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
>>>>> +fegetexcept(void)
>>>>> +       fenv_t __fpsr;
>>>>> +       return (__fpsr & FE_ALL_EXCEPT);
>>>>> diff --git a/newlib/libc/machine/arm/sys/fenv.h
>>>>> b/newlib/libc/machine/arm/sys/fenv.h
>>>>> index 000000000..af74c5f47
>>>>> --- /dev/null
>>>>> +++ b/newlib/libc/machine/arm/sys/fenv.h
>>>>> @@ -0,0 +1,122 @@
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> AND
>>>>> THE
>>>>> PURPOSE
>>>>> LIABLE
>>>>> CONSEQUENTIAL
>>>>> GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>>>>> ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#define _SYS_FENV_H_ 1
>>>>> +#include <sys/_types.h>
>>>>> +#include <sys/cdefs.h>
>>>>> +#ifdef __cplusplus
>>>>> +extern "C" {
>>>>> +#endif
>>>>> +#ifndef        __fenv_static
>>>>> +#define        __fenv_static static
>>>>> +#endif
>>>>> +typedef int fenv_t;
>>>>> +typedef int fexcept_t;
>>>>> +/* Exception flags */
>>>>> +#define        FE_INVALID      0x0001
>>>>> +#define        FE_DIVBYZERO    0x0002
>>>>> +#define        FE_OVERFLOW     0x0004
>>>>> +#define        FE_UNDERFLOW    0x0008
>>>>> +#define        FE_INEXACT      0x0010
>>>>> +#ifdef __ARM_PCS_VFP
>>>>> +#define        FE_DENORMAL     0x0080
>>>>> +#define        FE_ALL_EXCEPT   (FE_DIVBYZERO | FE_INEXACT | \
>>>>> +                        FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW |
>>>>> FE_DENORMAL)
>>>>> +#else
>>>>> +                        FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW)
>>>>> +#endif
>>>>> +/* Rounding modes */
>>>>> +#define        VFP_FE_TONEAREST        0x00000000
>>>>> +#define        VFP_FE_UPWARD           0x00400000
>>>>> +#define        VFP_FE_DOWNWARD         0x00800000
>>>>> +#define        VFP_FE_TOWARDZERO       0x00c00000
>>>>> +#define        FE_TONEAREST    VFP_FE_TONEAREST
>>>>> +#define        FE_UPWARD       VFP_FE_UPWARD
>>>>> +#define        FE_DOWNWARD     VFP_FE_DOWNWARD
>>>>> +#define        FE_TOWARDZERO   VFP_FE_TOWARDZERO
>>>>> +#else
>>>>> +#define        FE_TONEAREST    0x0000
>>>>> +#define        FE_TOWARDZERO   0x0001
>>>>> +#define        FE_UPWARD       0x0002
>>>>> +#define        FE_DOWNWARD     0x0003
>>>>> +#endif
>>>>> +#define        _ROUND_MASK     (FE_TONEAREST | FE_DOWNWARD | \
>>>>> +                        FE_UPWARD | FE_TOWARDZERO)
>>>>> +/* Default floating-point environment */
>>>>> +extern const fenv_t    *_fe_dfl_env;
>>>>> +#define        FE_DFL_ENV      (_fe_dfl_env)
>>>>> +/* We need to be able to map status flag positions to mask flag
>>>>> positions */
>>>>> +#ifndef __ARM_PCS_VFP
>>>>> +#define        _FPUSW_SHIFT    16
>>>>> +#define        _ENABLE_MASK    (FE_ALL_EXCEPT << _FPUSW_SHIFT)
>>>>> +#endif
>>>>> +int feclearexcept(int excepts);
>>>>> +int fegetexceptflag(fexcept_t *flagp, int excepts);
>>>>> +int fesetexceptflag(const fexcept_t *flagp, int excepts);
>>>>> +int feraiseexcept(int excepts);
>>>>> +int fetestexcept(int excepts);
>>>>> +int fegetround(void);
>>>>> +int fesetround(int round);
>>>>> +int fegetenv(fenv_t *envp);
>>>>> +int feholdexcept(fenv_t *envp);
>>>>> +int fesetenv(const fenv_t *envp);
>>>>> +int feupdateenv(const fenv_t *envp);
>>>>> +#if __BSD_VISIBLE
>>>>> +int feenableexcept(int __mask);
>>>>> +int fedisableexcept(int __mask);
>>>>> +int fegetexcept(void);
>>>>> +#endif /* __ARM_PCS_VFP */
>>>>> +#ifdef __cplusplus
>>>>> +#endif
>>>>> +#endif /* _SYS_FENV_H_ */
>>>>> diff --git a/newlib/libm/machine/arm/Makefile.am
>>>>> b/newlib/libm/machine/arm/Makefile.am
>>>>> index 1f10a7a40..a64ee59d5 100644
>>>>> --- a/newlib/libm/machine/arm/Makefile.am
>>>>> +++ b/newlib/libm/machine/arm/Makefile.am
>>>>> @@ -19,7 +19,23 @@ LIB_SOURCES = \
>>>>>         sf_nearbyint.c \
>>>>>         sf_rint.c \
>>>>>         sf_round.c \
>>>>> -       sf_trunc.c
>>>>> +       sf_trunc.c \
>>>>> +       feclearexcept.c \
>>>>> +       fe_dfl_env.c\
>>>>> +       fegetenv.c \
>>>>> +       fegetexceptflag.c \
>>>>> +       fegetround.c \
>>>>> +       feholdexcept.c \
>>>>> +       fenv.c \
>>>>> +       feraiseexcept.c \
>>>>> +       fesetenv.c \
>>>>> +       fesetexceptflag.c \
>>>>> +       fesetround.c \
>>>>> +       fetestexcept.c \
>>>>> +       feupdateenv.c \
>>>>> +       fenv-vfp.c \
>>>>> +       fenv-softfp.c
>>>>>  noinst_LIBRARIES = lib.a
>>>>>  lib_a_SOURCES = $(LIB_SOURCES)
>>>>> diff --git a/newlib/libm/machine/arm/Makefile.in
>>>>> b/newlib/libm/machine/arm/Makefile.in
>>>>> index 0a5a27327..70b03df46 100644
>>>>> --- a/newlib/libm/machine/arm/Makefile.in
>>>>> +++ b/newlib/libm/machine/arm/Makefile.in
>>>>> @@ -1,9 +1,8 @@
>>>>> -# Makefile.in generated by automake 1.11.6 from Makefile.am.
>>>>> +# Makefile.in generated by automake 1.12.6 from Makefile.am.
>>>>>  # @configure_input@
>>>>> -# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
>>>>> -# 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software
>>>>> -# Foundation, Inc.
>>>>> +# Copyright (C) 1994-2012 Free Software Foundation, Inc.
>>>>>  # This Makefile.in is free software; the Free Software Foundation
>>>>>  # gives unlimited permission to copy and/or distribute it,
>>>>>  # with or without modifications, as long as this notice is preserved.
>>>>> @@ -54,7 +53,7 @@ build_triplet = @build@
>>>>>  host_triplet = @host@
>>>>>  DIST_COMMON = $(srcdir)/../../../Makefile.shared
>>>>> $(srcdir)/Makefile.in \
>>>>>         $(srcdir)/Makefile.am $(top_srcdir)/configure \
>>>>> -       $(am__configure_deps) $(srcdir)/../../../../mkinstalldirs
>>>>> +       $(am__configure_deps) $(top_srcdir)/../../../../mkinstalldirs
>>>>>  subdir = .
>>>>>  ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
>>>>>  am__aclocal_m4_deps = $(top_srcdir)/../../../acinclude.m4 \
>>>>> @@ -76,7 +75,15 @@ am__objects_1 = lib_a-e_sqrt.$(OBJEXT)
>>>>> lib_a-ef_sqrt.$(OBJEXT) \
>>>>>         lib_a-s_round.$(OBJEXT) lib_a-s_trunc.$(OBJEXT) \
>>>>>         lib_a-sf_ceil.$(OBJEXT) lib_a-sf_floor.$(OBJEXT) \
>>>>>         lib_a-sf_nearbyint.$(OBJEXT) lib_a-sf_rint.$(OBJEXT) \
>>>>> -       lib_a-sf_round.$(OBJEXT) lib_a-sf_trunc.$(OBJEXT)
>>>>> +       lib_a-sf_round.$(OBJEXT) lib_a-sf_trunc.$(OBJEXT) \
>>>>> +       lib_a-feclearexcept.$(OBJEXT) lib_a-fe_dfl_env.$(OBJEXT) \
>>>>> +       lib_a-fegetenv.$(OBJEXT) lib_a-fegetexceptflag.$(OBJEXT) \
>>>>> +       lib_a-fegetround.$(OBJEXT) lib_a-feholdexcept.$(OBJEXT) \
>>>>> +       lib_a-fenv.$(OBJEXT) lib_a-feraiseexcept.$(OBJEXT) \
>>>>> +       lib_a-fesetenv.$(OBJEXT) lib_a-fesetexceptflag.$(OBJEXT) \
>>>>> +       lib_a-fesetround.$(OBJEXT) lib_a-fetestexcept.$(OBJEXT) \
>>>>> +       lib_a-feupdateenv.$(OBJEXT) lib_a-fenv-vfp.$(OBJEXT) \
>>>>> +       lib_a-fenv-softfp.$(OBJEXT)
>>>>>  am_lib_a_OBJECTS = $(am__objects_1)
>>>>>  lib_a_OBJECTS = $(am_lib_a_OBJECTS)
>>>>>  DEFAULT_INCLUDES = -I. at am__isrc@
>>>>> @@ -95,6 +102,8 @@ am__can_run_installinfo = \
>>>>>  DATA = $(noinst_DATA)
>>>>>  ETAGS = etags
>>>>>  CTAGS = ctags
>>>>> +CSCOPE = cscope
>>>>> +AM_RECURSIVE_TARGETS = cscope
>>>>>  ACLOCAL = @ACLOCAL@
>>>>>  AMTAR = @AMTAR@
>>>>>  AR = @AR@
>>>>> @@ -216,7 +225,22 @@ LIB_SOURCES = \
>>>>>         sf_nearbyint.c \
>>>>>         sf_rint.c \
>>>>>         sf_round.c \
>>>>> -       sf_trunc.c
>>>>> +       sf_trunc.c \
>>>>> +       feclearexcept.c \
>>>>> +       fe_dfl_env.c\
>>>>> +       fegetenv.c \
>>>>> +       fegetround.c \
>>>>> +       feholdexcept.c \
>>>>> +       fenv.c \
>>>>> +       feraiseexcept.c \
>>>>> +       fesetenv.c \
>>>>> +       fesetround.c \
>>>>> +       fetestexcept.c \
>>>>> +       feupdateenv.c \
>>>>> +       fenv-vfp.c \
>>>>> +       fenv-softfp.c
>>>>> @@ -378,6 +402,96 @@ lib_a-sf_trunc.o: sf_trunc.c
>>>>>  lib_a-sf_trunc.obj: sf_trunc.c
>>>>>         $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS)
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-sf_trunc.obj `if test -f
>>>>> 'sf_trunc.c'; then $(CYGPATH_W) 'sf_trunc.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/sf_trunc.c'; fi`
>>>>> +lib_a-feclearexcept.o: feclearexcept.c
>>>>> +       $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS)
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feclearexcept.o `test -f
>>>>> 'feclearexcept.c' || echo '$(srcdir)/'`feclearexcept.c
>>>>> +lib_a-feclearexcept.obj: feclearexcept.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feclearexcept.obj `if
>>>>> test -f 'feclearexcept.c'; then $(CYGPATH_W) 'feclearexcept.c'; else
>>>>> $(CYGPATH_W) '$(srcdir)/feclearexcept.c'; fi`
>>>>> +lib_a-fe_dfl_env.o: fe_dfl_env.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fe_dfl_env.o `test -f
>>>>> 'fe_dfl_env.c' || echo '$(srcdir)/'`fe_dfl_env.c
>>>>> +lib_a-fe_dfl_env.obj: fe_dfl_env.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fe_dfl_env.obj `if test
>>>>> -f 'fe_dfl_env.c'; then $(CYGPATH_W) 'fe_dfl_env.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/fe_dfl_env.c'; fi`
>>>>> +lib_a-fegetenv.o: fegetenv.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetenv.o `test -f
>>>>> 'fegetenv.c' || echo '$(srcdir)/'`fegetenv.c
>>>>> +lib_a-fegetenv.obj: fegetenv.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetenv.obj `if test -f
>>>>> 'fegetenv.c'; then $(CYGPATH_W) 'fegetenv.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/fegetenv.c'; fi`
>>>>> +lib_a-fegetexceptflag.o: fegetexceptflag.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetexceptflag.o `test
>>>>> -f 'fegetexceptflag.c' || echo '$(srcdir)/'`fegetexceptflag.c
>>>>> +lib_a-fegetexceptflag.obj: fegetexceptflag.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetexceptflag.obj `if
>>>>> test -f 'fegetexceptflag.c'; then $(CYGPATH_W) 'fegetexceptflag.c'; else
>>>>> $(CYGPATH_W) '$(srcdir)/fegetexceptflag.c'; fi`
>>>>> +lib_a-fegetround.o: fegetround.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetround.o `test -f
>>>>> 'fegetround.c' || echo '$(srcdir)/'`fegetround.c
>>>>> +lib_a-fegetround.obj: fegetround.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fegetround.obj `if test
>>>>> -f 'fegetround.c'; then $(CYGPATH_W) 'fegetround.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/fegetround.c'; fi`
>>>>> +lib_a-feholdexcept.o: feholdexcept.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feholdexcept.o `test -f
>>>>> 'feholdexcept.c' || echo '$(srcdir)/'`feholdexcept.c
>>>>> +lib_a-feholdexcept.obj: feholdexcept.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feholdexcept.obj `if test
>>>>> -f 'feholdexcept.c'; then $(CYGPATH_W) 'feholdexcept.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/feholdexcept.c'; fi`
>>>>> +lib_a-fenv.o: fenv.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv.o `test -f 'fenv.c'
>>>>> || echo '$(srcdir)/'`fenv.c
>>>>> +lib_a-fenv.obj: fenv.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv.obj `if test -f
>>>>> 'fenv.c'; then $(CYGPATH_W) 'fenv.c'; else $(CYGPATH_W) '$(srcdir)/fenv.c';
>>>>> fi`
>>>>> +lib_a-feraiseexcept.o: feraiseexcept.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feraiseexcept.o `test -f
>>>>> 'feraiseexcept.c' || echo '$(srcdir)/'`feraiseexcept.c
>>>>> +lib_a-feraiseexcept.obj: feraiseexcept.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feraiseexcept.obj `if
>>>>> test -f 'feraiseexcept.c'; then $(CYGPATH_W) 'feraiseexcept.c'; else
>>>>> $(CYGPATH_W) '$(srcdir)/feraiseexcept.c'; fi`
>>>>> +lib_a-fesetenv.o: fesetenv.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetenv.o `test -f
>>>>> 'fesetenv.c' || echo '$(srcdir)/'`fesetenv.c
>>>>> +lib_a-fesetenv.obj: fesetenv.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetenv.obj `if test -f
>>>>> 'fesetenv.c'; then $(CYGPATH_W) 'fesetenv.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/fesetenv.c'; fi`
>>>>> +lib_a-fesetexceptflag.o: fesetexceptflag.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetexceptflag.o `test
>>>>> -f 'fesetexceptflag.c' || echo '$(srcdir)/'`fesetexceptflag.c
>>>>> +lib_a-fesetexceptflag.obj: fesetexceptflag.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetexceptflag.obj `if
>>>>> test -f 'fesetexceptflag.c'; then $(CYGPATH_W) 'fesetexceptflag.c'; else
>>>>> $(CYGPATH_W) '$(srcdir)/fesetexceptflag.c'; fi`
>>>>> +lib_a-fesetround.o: fesetround.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetround.o `test -f
>>>>> 'fesetround.c' || echo '$(srcdir)/'`fesetround.c
>>>>> +lib_a-fesetround.obj: fesetround.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fesetround.obj `if test
>>>>> -f 'fesetround.c'; then $(CYGPATH_W) 'fesetround.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/fesetround.c'; fi`
>>>>> +lib_a-fetestexcept.o: fetestexcept.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fetestexcept.o `test -f
>>>>> 'fetestexcept.c' || echo '$(srcdir)/'`fetestexcept.c
>>>>> +lib_a-fetestexcept.obj: fetestexcept.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fetestexcept.obj `if test
>>>>> -f 'fetestexcept.c'; then $(CYGPATH_W) 'fetestexcept.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/fetestexcept.c'; fi`
>>>>> +lib_a-feupdateenv.o: feupdateenv.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.o `test -f
>>>>> 'feupdateenv.c' || echo '$(srcdir)/'`feupdateenv.c
>>>>> +lib_a-feupdateenv.obj: feupdateenv.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.obj `if test
>>>>> -f 'feupdateenv.c'; then $(CYGPATH_W) 'feupdateenv.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/feupdateenv.c'; fi`
>>>>> +lib_a-fenv-vfp.o: fenv-vfp.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-vfp.o `test -f
>>>>> 'fenv-vfp.c' || echo '$(srcdir)/'`fenv-vfp.c
>>>>> +lib_a-fenv-vfp.obj: fenv-vfp.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-vfp.obj `if test -f
>>>>> 'fenv-vfp.c'; then $(CYGPATH_W) 'fenv-vfp.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/fenv-vfp.c'; fi`
>>>>> +lib_a-fenv-softfp.o: fenv-softfp.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-softfp.o `test -f
>>>>> 'fenv-softfp.c' || echo '$(srcdir)/'`fenv-softfp.c
>>>>> +lib_a-fenv-softfp.obj: fenv-softfp.c
>>>>> $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-softfp.obj `if test
>>>>> -f 'fenv-softfp.c'; then $(CYGPATH_W) 'fenv-softfp.c'; else $(CYGPATH_W)
>>>>> '$(srcdir)/fenv-softfp.c'; fi`
>>>>>  ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
>>>>>         list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
>>>>>         unique=`for i in $$list; do \
>>>>> @@ -427,8 +541,32 @@ GTAGS:
>>>>>           && $(am__cd) $(top_srcdir) \
>>>>>           && gtags -i $(GTAGS_ARGS) "$$here"
>>>>> +cscope: cscope.files
>>>>> +       test ! -s cscope.files \
>>>>> +         || $(CSCOPE) -b -q $(AM_CSCOPEFLAGS) $(CSCOPEFLAGS) -i
>>>>> cscope.files $(CSCOPE_ARGS)
>>>>> +clean-cscope:
>>>>> +       -rm -f cscope.files
>>>>> +cscope.files: clean-cscope  cscopelist
>>>>> +cscopelist:  $(HEADERS) $(SOURCES) $(LISP)
>>>>> +       list='$(SOURCES) $(HEADERS) $(LISP)'; \
>>>>> +       case "$(srcdir)" in \
>>>>> +         [\\/]* | ?:[\\/]*) sdir="$(srcdir)" ;; \
>>>>> +         *) sdir=$(subdir)/$(srcdir) ;; \
>>>>> +       esac; \
>>>>> +       for i in $$list; do \
>>>>> +         if test -f "$$i"; then \
>>>>> +           echo "$(subdir)/$$i"; \
>>>>> +         else \
>>>>> +           echo "$$sdir/$$i"; \
>>>>> +         fi; \
>>>>> +       done >> $(top_builddir)/cscope.files
>>>>>  distclean-tags:
>>>>>         -rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
>>>>> +       -rm -f cscope.out cscope.in.out cscope.po.out cscope.files
>>>>>  check-am:
>>>>>  check: check-am
>>>>>  all-am: Makefile $(LIBRARIES) $(DATA)
>>>>> @@ -537,17 +675,17 @@ uninstall-am:
>>>>>  .MAKE: install-am install-strip
>>>>>  .PHONY: CTAGS GTAGS all all-am am--refresh check check-am clean \
>>>>> -       clean-generic clean-noinstLIBRARIES ctags distclean \
>>>>> -       distclean-compile distclean-generic distclean-tags dvi dvi-am \
>>>>> -       html html-am info info-am install install-am install-data \
>>>>> -       install-data-am install-dvi install-dvi-am install-exec \
>>>>> -       install-exec-am install-html install-html-am install-info \
>>>>> -       install-info-am install-man install-pdf install-pdf-am \
>>>>> -       install-ps install-ps-am install-strip installcheck \
>>>>> -       installcheck-am installdirs maintainer-clean \
>>>>> -       maintainer-clean-generic mostlyclean mostlyclean-compile \
>>>>> -       mostlyclean-generic pdf pdf-am ps ps-am tags uninstall \
>>>>> -       uninstall-am
>>>>> +       clean-cscope clean-generic clean-noinstLIBRARIES cscope \
>>>>> +       cscopelist ctags distclean distclean-compile distclean-generic
>>>>> +       distclean-tags dvi dvi-am html html-am info info-am install \
>>>>> +       install-am install-data install-data-am install-dvi \
>>>>> +       install-dvi-am install-exec install-exec-am install-html \
>>>>> +       install-html-am install-info install-info-am install-man \
>>>>> +       install-pdf install-pdf-am install-ps install-ps-am \
>>>>> +       install-strip installcheck installcheck-am installdirs \
>>>>> +       maintainer-clean maintainer-clean-generic mostlyclean \
>>>>> +       mostlyclean-compile mostlyclean-generic pdf pdf-am ps ps-am \
>>>>> +       tags uninstall uninstall-am
>>>>>  objectlist.awk.in: $(noinst_LTLIBRARIES)
>>>>>         -rm -f objectlist.awk.in
>>>>> diff --git a/newlib/libm/machine/arm/fe_dfl_env.c
>>>>> b/newlib/libm/machine/arm/fe_dfl_env.c
>>>>> index 000000000..8cbee7771
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fe_dfl_env.c
>>>>> @@ -0,0 +1,7 @@
>>>>> + * (c) Copyright 2019 Joel Sherrill <joel at rtems.org>
>>>>> +#include "../../fenv/fenv_stub.c"
>>>>> diff --git a/newlib/libm/machine/arm/feclearexcept.c
>>>>> b/newlib/libm/machine/arm/feclearexcept.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/feclearexcept.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/fegetenv.c
>>>>> b/newlib/libm/machine/arm/fegetenv.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fegetenv.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/fegetexceptflag.c
>>>>> b/newlib/libm/machine/arm/fegetexceptflag.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fegetexceptflag.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/fegetround.c
>>>>> b/newlib/libm/machine/arm/fegetround.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fegetround.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/feholdexcept.c
>>>>> b/newlib/libm/machine/arm/feholdexcept.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/feholdexcept.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/fenv-softfp.c
>>>>> b/newlib/libm/machine/arm/fenv-softfp.c
>>>>> index 000000000..a576cc1b2
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fenv-softfp.c
>>>>> @@ -0,0 +1,32 @@
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> AND
>>>>> THE
>>>>> PURPOSE
>>>>> LIABLE
>>>>> CONSEQUENTIAL
>>>>> GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>>>>> ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#define        FENV_MANGLE(x)  __softfp_ ##x
>>>>> +#include <machine/fenv-mangle.h>
>>>>> +#include "fenv.c"
>>>>> diff --git a/newlib/libm/machine/arm/fenv-vfp.c
>>>>> b/newlib/libm/machine/arm/fenv-vfp.c
>>>>> index 000000000..297e81296
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fenv-vfp.c
>>>>> @@ -0,0 +1,32 @@
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> AND
>>>>> THE
>>>>> PURPOSE
>>>>> LIABLE
>>>>> CONSEQUENTIAL
>>>>> GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>>>>> ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#define        FENV_MANGLE(x)  __vfp_ ##x
>>>>> +#include "fenv.c"
>>>>> diff --git a/newlib/libm/machine/arm/fenv.c
>>>>> b/newlib/libm/machine/arm/fenv.c
>>>>> index 000000000..278de8633
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fenv.c
>>>>> @@ -0,0 +1,328 @@
>>>>> + * Copyright (c) 2004 David Schultz <das at FreeBSD.ORG>
>>>>> + * are met:
>>>>> copyright
>>>>> the
>>>>> distribution.
>>>>> AND
>>>>> THE
>>>>> PURPOSE
>>>>> LIABLE
>>>>> CONSEQUENTIAL
>>>>> GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>>>>> ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#include <fenv.h>
>>>>> +#include <machine/acle-compat.h>
>>>>> +#if __ARM_ARCH >= 6
>>>>> +#define FENV_ARMv6
>>>>> +#endif
>>>>> +/* When SOFTFP_ABI is defined we are using the softfp ABI. */
>>>>> +#if defined(__VFP_FP__) && !defined(__ARM_PCS_VFP)
>>>>> +#define SOFTFP_ABI
>>>>> +#endif
>>>>> + * Hopefully the system ID byte is immutable, so it's valid to use
>>>>> + * this as a default environment.
>>>>> +fenv_t __fe_dfl_env = { 0 };
>>>>> +const fenv_t *_fe_dfl_env = &__fe_dfl_env;
>>>>> +#endif
>>>>> +/* If this is a non-mangled softfp version special processing is
>>>>> required */
>>>>> +#if defined(FENV_MANGLE) || !defined(SOFTFP_ABI) ||
>>>>> !defined(FENV_ARMv6)
>>>>> + * The following macros map between the softfloat emulator's flags and
>>>>> + * the hardware's FPSR.  The hardware this file was written for
>>>>> doesn't
>>>>> + * have rounding control bits, so we stick those in the system ID
>>>>> byte.
>>>>> +#define        __set_env(env, flags, mask, rnd) env = ((flags)
>>>>> (mask)<<_FPUSW_SHIFT  \
>>>>> +                                               | (rnd) << 24)
>>>>> +#define        __env_flags(env)                ((env) & FE_ALL_EXCEPT)
>>>>> +#define        __env_mask(env)                 (((env) >>
>>>>> _FPUSW_SHIFT)        \
>>>>> +                                               & FE_ALL_EXCEPT)
>>>>> +#define        __env_round(env)                (((env) >> 24) &
>>>>> _ROUND_MASK)
>>>>> +#include <machine/fenv-softfloat.h>
>>>>> +#else /* __ARM_PCS_VFP PRESENT */
>>>>> +#include <machine/fenv-vfp.h>
>>>>> +#ifdef __GNUC_GNU_INLINE__
>>>>> +#error "This file must be compiled with C99 'inline' semantics"
>>>>> +#endif
>>>>> +extern inline int feclearexcept(int excepts);
>>>>> +extern inline int fegetexceptflag(fexcept_t *flagp, int excepts);
>>>>> +extern inline int fesetexceptflag(const fexcept_t *flagp, int
>>>>> excepts);
>>>>> +extern inline int feraiseexcept(int excepts);
>>>>> +extern inline int fetestexcept(int excepts);
>>>>> +extern inline int fegetround(void);
>>>>> +extern inline int fesetround(int round);
>>>>> +extern inline int fegetenv(fenv_t *envp);
>>>>> +extern inline int feholdexcept(fenv_t *envp);
>>>>> +extern inline int fesetenv(const fenv_t *envp);
>>>>> +extern inline int feupdateenv(const fenv_t *envp);
>>>>> +extern inline int feenableexcept(int __mask);
>>>>> +extern inline int fedisableexcept(int __mask);
>>>>> +extern inline int fegetexcept(void);
>>>>> +#else /* !FENV_MANGLE && SOFTFP_ABI */
>>>>> +/* Set by libc when the VFP unit is enabled */
>>>>> +extern int _libc_arm_fpu_present;
>>>>> +int __softfp_feclearexcept(int excepts);
>>>>> +int __softfp_fegetexceptflag(fexcept_t *flagp, int excepts);
>>>>> +int __softfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
>>>>> +int __softfp_feraiseexcept(int excepts);
>>>>> +int __softfp_fetestexcept(int excepts);
>>>>> +int __softfp_fegetround(void);
>>>>> +int __softfp_fesetround(int round);
>>>>> +int __softfp_fegetenv(fenv_t *envp);
>>>>> +int __softfp_feholdexcept(fenv_t *envp);
>>>>> +int __softfp_fesetenv(const fenv_t *envp);
>>>>> +int __softfp_feupdateenv(const fenv_t *envp);
>>>>> +int __softfp_feenableexcept(int __mask);
>>>>> +int __softfp_fedisableexcept(int __mask);
>>>>> +int __softfp_fegetexcept(void);
>>>>> +int __vfp_feclearexcept(int excepts);
>>>>> +int __vfp_fegetexceptflag(fexcept_t *flagp, int excepts);
>>>>> +int __vfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
>>>>> +int __vfp_feraiseexcept(int excepts);
>>>>> +int __vfp_fetestexcept(int excepts);
>>>>> +int __vfp_fegetround(void);
>>>>> +int __vfp_fesetround(int round);
>>>>> +int __vfp_fegetenv(fenv_t *envp);
>>>>> +int __vfp_feholdexcept(fenv_t *envp);
>>>>> +int __vfp_fesetenv(const fenv_t *envp);
>>>>> +int __vfp_feupdateenv(const fenv_t *envp);
>>>>> +int __vfp_feenableexcept(int __mask);
>>>>> +int __vfp_fedisableexcept(int __mask);
>>>>> +int __vfp_fegetexcept(void);
>>>>> +static int
>>>>> +__softfp_round_to_vfp(int round)
>>>>> +       switch (round) {
>>>>> +       case FE_TONEAREST:
>>>>> +       default:
>>>>> +               return VFP_FE_TONEAREST;
>>>>> +       case FE_TOWARDZERO:
>>>>> +               return VFP_FE_TOWARDZERO;
>>>>> +       case FE_UPWARD:
>>>>> +               return VFP_FE_UPWARD;
>>>>> +       case FE_DOWNWARD:
>>>>> +               return VFP_FE_DOWNWARD;
>>>>> +static int
>>>>> +__softfp_round_from_vfp(int round)
>>>>> +       switch (round) {
>>>>> +       case VFP_FE_TONEAREST:
>>>>> +       default:
>>>>> +               return FE_TONEAREST;
>>>>> +       case VFP_FE_TOWARDZERO:
>>>>> +               return FE_TOWARDZERO;
>>>>> +       case VFP_FE_UPWARD:
>>>>> +               return FE_UPWARD;
>>>>> +       case VFP_FE_DOWNWARD:
>>>>> +               return FE_DOWNWARD;
>>>>> +       if (_libc_arm_fpu_present)
>>>>> +               __vfp_feclearexcept(excepts);
>>>>> +       __softfp_feclearexcept(excepts);
>>>>> +       return (0);
>>>>> +       fexcept_t __vfp_flagp;
>>>>> +       __vfp_flagp = 0;
>>>>> +               __vfp_fegetexceptflag(&__vfp_flagp, excepts);
>>>>> +       __softfp_fegetexceptflag(flagp, excepts);
>>>>> +       *flagp |= __vfp_flagp;
>>>>> +       return (0);
>>>>> +               __vfp_fesetexceptflag(flagp, excepts);
>>>>> +       __softfp_fesetexceptflag(flagp, excepts);
>>>>> +       return (0);
>>>>> +               __vfp_feraiseexcept(excepts);
>>>>> +       __softfp_feraiseexcept(excepts);
>>>>> +       return (0);
>>>>> +       int __got_excepts;
>>>>> +       __got_excepts = 0;
>>>>> +               __got_excepts = __vfp_fetestexcept(excepts);
>>>>> +       __got_excepts |= __softfp_fetestexcept(excepts);
>>>>> +       return (__got_excepts);
>>>>> +               return __softfp_round_from_vfp(__vfp_fegetround());
>>>>> +       return __softfp_fegetround();
>>>>> +               __vfp_fesetround(__softfp_round_to_vfp(round));
>>>>> +       __softfp_fesetround(round);
>>>>> +       return (0);
>>>>> +       fenv_t __vfp_envp;
>>>>> +       __vfp_envp = 0;
>>>>> +               __vfp_fegetenv(&__vfp_envp);
>>>>> +       __softfp_fegetenv(envp);
>>>>> +       *envp |= __vfp_envp;
>>>>> +       return (0);
>>>>> +       __vfp_envp = 0;
>>>>> +               __vfp_feholdexcept(&__vfp_envp);
>>>>> +       __softfp_feholdexcept(envp);
>>>>> +       return (0);
>>>>> +               __vfp_fesetenv(envp);
>>>>> +       __softfp_fesetenv(envp);
>>>>> +       return (0);
>>>>> +               __vfp_feupdateenv(envp);
>>>>> +       __softfp_feupdateenv(envp);
>>>>> +       return (0);
>>>>> +       int __unmasked;
>>>>> +       __unmasked = 0;
>>>>> +               __unmasked = __vfp_feenableexcept(__mask);
>>>>> +       __unmasked |= __softfp_feenableexcept(__mask);
>>>>> +       return (__unmasked);
>>>>> +       int __unmasked;
>>>>> +       __unmasked = 0;
>>>>> +               __unmasked = __vfp_fedisableexcept(__mask);
>>>>> +       __unmasked |= __softfp_fedisableexcept(__mask);
>>>>> +       int __unmasked;
>>>>> +       __unmasked = 0;
>>>>> +               __unmasked = __vfp_fegetexcept();
>>>>> +       __unmasked |= __softfp_fegetexcept();
>>>>> +#endif
>>>>> diff --git a/newlib/libm/machine/arm/feraiseexcept.c
>>>>> b/newlib/libm/machine/arm/feraiseexcept.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/feraiseexcept.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/fesetenv.c
>>>>> b/newlib/libm/machine/arm/fesetenv.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fesetenv.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/fesetexceptflag.c
>>>>> b/newlib/libm/machine/arm/fesetexceptflag.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fesetexceptflag.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/fesetround.c
>>>>> b/newlib/libm/machine/arm/fesetround.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fesetround.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/fetestexcept.c
>>>>> b/newlib/libm/machine/arm/fetestexcept.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/fetestexcept.c
>>>>> @@ -0,0 +1,7 @@
>>>>> diff --git a/newlib/libm/machine/arm/feupdateenv.c
>>>>> b/newlib/libm/machine/arm/feupdateenv.c
>>>>> --- /dev/null
>>>>> +++ b/newlib/libm/machine/arm/feupdateenv.c
>>>>> @@ -0,0 +1,7 @@
>>>>> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200526/4d7082e2/attachment-0001.html>
