GSoC: Porting OFW to RTEMS
Christian Mauderer oss at c-mauderer.de
Wed May 27 17:55:51 UTC 2020
On 27/05/2020 19:32, Niteesh G. S. wrote:
> On Wed, May 27, 2020 at 12:04 AM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     Hello Niteesh,
>     On 26/05/2020 19:56, Christian Mauderer wrote:
>     > Hello Niteesh,
>     > On 25/05/2020 11:20, Niteesh G. S. wrote:
>     >> Hello,
>     >> I have completed the porting of the OFW code from FreeBSD to RTEMS.
>     >> I do acknowledge the fact that we haven't decided on the
>     directory for files
>     >> to be placed in. The previous conversation had stopped quite a
>     while ago.
>     >> Christian suggested I work on the patch since that would also
>     start the
>     >> conversation again and also refactoring the patch to the correct
>     directory
>     >> will not be much of work.
>     >> cpukit/libfreebsd was suggested as one of the directories to
>     place the
>     >> ported
>     >> FreeBSD files. It is suggested to place all the source files
>     under this
>     >> directory.
>     >> Since this will make the sync part easier. But this causes issues
>     when
>     >> porting
>     >> BSP dependent files. Since RTEMS currently doesn't allow files in
>     cpukit to
>     >> reference bsp headers. I faced a similar issue during my porting
>     process
>     >> also.
>     >> The OFW init function require bsp_fdt_get function to get a
>     reference to
>     >> the fdt
>     >> blob. But I can't include the bsp/fdt.h header file from a source
>     file
>     >> under cpukit.
>     >> We must decide the directory quickly because my project will
>     import other
>     >> FreeBSD sources like the pinmux driver for beaglebone into RTEMS.
>     > Do you have a suggestion for another directory?
>     > If cpukit makes problems (which it clearly does due to the BSP
>     > dependencies) maybe something in bsps/shared?
>     >> https://github.com/gs-niteesh/rtems/commits/ofw_branch
>     > For small patches it would be better to send them to the list
>     using "git
>     > send-email". That allows to comment directly on the patches. But
>     in this
>     > case using a repo is OK because especially the import is quite big.
>     > I'll add comments for small stuff directly on github. I hope that
>     works ;-)
>     Finished adding comments for small stuff. Some bigger questions:
>     - How do you plan to include ofw_if.h in some driver files? RTEMS
>     currently puts every file that can be included with <some.h> into a path
>     called "include".
> Will ofw_if.h be included in driver files? As far as I have searched in the
> FreeBSD sources, other than the OFW implementation none of the driver
> files include this header. So this could be placed in the same directory as
> the OFW sources and need not be added to the global include path.
> If there is a case where it is included in some driver please let me know.
> And also all the references to this header in the OFW implementations are
> relative so in future, if we add other implementations, having it in the
> same
> directory would be the right choice.
You are right. I didn't have a detailed enough look. The functions like
OFW_GETPROP (declared in ofw_if.h) are only used in openfirm.c. So that
location is OK.
>     - You created quite some commits. I would suggest to merge all porting
>     commits so that you have one import commit, one port commit and maybe
>     one commit adding RTEMS specific files
> I have squashed them into a single port commit.
>     - You have at least one completely hand written file (ofw_if.h). Maybe
>     we should think about whether that is located well in the same directory
>     as the imported code or whether a similar structure like used in libbsd
>     would be better. One tree for imported files and one for RTEMS specific
>     hand written ones.
> Do we need a separate directory for RTEMS specific handwritten ones depends
> on what we will be importing in the future? Since we intend only to
> import mostly
> driver related code I don't think there is a need for a separate
> directory. I think
> this way because I assuming we don't need any RTEMS specific file for
> the drivers.
> But if we plan to include some simple subsystem then having a separate
> directory
> will be nice.
Things like that tend to grow. So even if we don't want to import much
for now, it's quite possible that it will be more in the future.
Therefore I would use the future-proof approach even if it is a bit
overkill for now.
> This also makes me think about if having all sources under a single
> directory under
> cpukit a good idea. Since our main import targets are drivers placing
> them in the
> cpukit directory or any other directory other than their respective BSP
> directory is not
> a good idea. This would make writing the sync script harder but this
> will decrease the
> coupling and dependencies between various folders. The other way around
> will be
> to have all headers accessible in the global path i.e. files under
> cpukit should be
> able to access bsp related headers. This would increase the coupling but
> I guess
> it will make writing the script easier since it has to track only a
> single directory.
> I am not really sure which is a better tradeoff. If someone could shed
> some light on
> the complexity of the script it'll help in coming up with a conclusion
> easier.
> But from a logical perspective, Having the drivers in their respective
> directories
> seems to be a better idea to me.
That really depends. I agree that we only want to import low-level drivers.
But also note that it's not always easy to say that driver A belongs
exactly to BSP B. For example take a look at some PowerPC chips and some
ARM chips. PowerPC has been used a lot by Freescale. Freescale now
belongs to NXP. NXP started to use the Freescale peripherals but with an
ARM core. Therefore now there are quite some modules that use the same
driver in ARM chips and in Freescale chips. If you import that driver to
an PowerPC you maybe would have to move it later to some shared section
if you want to use it in an ARM BSP.
So why not just put all the drivers imported from FreeBSD in a shared
section right from the start. Keep the directory structure but move it
to bsps. I think I suggested it earlier already: What about
bsps/shared/freebsd or bsps/shared/bsdports?
Best regards
Christian
>     Please see all comments as advises. Feel free to argue against any of
>     them if you think different ;-)
>     Best regards
>     Christian
>     > Best regards
>     > Christian
>     >> Please have a look at the last 6 patches for the ported work.
>     >> Below is a short summary of the patch.
>     >> * The openfirm.h is the OF interface that will provided to the user.
>     >> * The openfirm.c contains the function definition for openfirm.h. The
>     >> functions
>     >> call the respective OFW_* functions which are responsible for
>     choosing
>     >> the correct implementation for OF interface.
>     >> * ofw_if.h is the replacement for ofw_if.h in FreeBSD. This is an
>     auto
>     >> generated
>     >> header in FreeBSD which choose the correct OF implementation(ofw_fdt,
>     >> ofw_std,
>     >> ofw_32bit, ofw_real). In RTEMS we directly map to the FDT
>     implementation as
>     >> suggested by Sebastian.
>     >> * ofw_fdt.c contains the fdt implementation of OF interface.
>     >> Thanks,
>     >> Niteesh.
>     > _______________________________________________
>     > devel mailing list
>     > devel at rtems.org <mailto:devel at rtems.org>
>     > http://lists.rtems.org/mailman/listinfo/devel
