[PATCH 3/5] bsps/shared/freebsd: RTEMS to FreeBSD porting helper header
G S Niteesh Babu niteesh.gs at gmail.com
Fri May 29 03:21:37 UTC 2020
This file serve the purpose as rtems-bsd-kernel-space.h in the
rtems-libbsd.
This file is intended to be included in every source file that
is to imported from FreeBSD. This is to reduce the number of
redefinitions for commonly used functions like malloc, free
and KASSERT.
 bsps/shared/freebsd/rtems-freebsd-helper.h | 44 ++++++++++++++++++++++
 1 file changed, 44 insertions(+)
 create mode 100644 bsps/shared/freebsd/rtems-freebsd-helper.h
diff --git a/bsps/shared/freebsd/rtems-freebsd-helper.h b/bsps/shared/freebsd/rtems-freebsd-helper.h
new file mode 100644
index 0000000000..8135a1caf5
--- /dev/null
+++ b/bsps/shared/freebsd/rtems-freebsd-helper.h
@@ -0,0 +1,44 @@
+/* SPDX-License-Identifier: BSD-2-Clause
+ * @file
+ * @ingroup LIBFREEBSD
+ * @brief
+ * Copyright (C) <2020> Niteesh Babu <niteesh.gs at gmail.com>
+ * are met:
+#ifndef _LIBFREEBSD_RTEMS_FREEBSD_HELPER_H
+#define _LIBFREEBSD_RTEMS_FREEBSD_HELPER_H
+#define KASSERT(cnd, msg)           assert(cnd)
+#define malloc(size, type, flags)   malloc(size)
+#define free(addr, type)            free(addr)
+#endif /* _LIBFREEBSD_RTEMS_FREEBSD_HELPER_H */
\ No newline at end of file
2.17.1
