Need help in figuring out the flow of RTEMS codes
Richi Dubey
richidubey at gmail.com
Fri May 29 07:59:05 UTC 2020
This makes sense. Thanks a lot!
On Fri, May 29, 2020 at 1:18 PM Sebastian Huber
> Hello Richi,
> On 29/05/2020 09:36, Richi Dubey wrote:
> > Hii,
> > I had a small doubt about all the source code/procedures that a code
> > goes through. Where can I read more about it? For instance, when I am
> > debugging smpschededf02.exe with gdb, It starts with
> > bsps/sparc/shared/start/start.S, line 107(Why did it start with
> > start.s?) and the last line of this file is:
> > mov %g0, %o0 ! command line
> > call SYM(boot_card) ! does not return
> > sub %sp, 0x60, %sp ! room for boot_card to save args
> > After this it starts executing bsps/shared/start/bootcard.c: line 53 .
> > How did this happen? Is it because of call? If yes, why was sub
> > executed(in gdb) before executing code from bootcard.c?
> > I hope I am not trying to going too deep into this. I just want to
> > have a overall picture of how a code gets executed.
> if you want to learn how code executes at processor level, then I would
> recommend to work with an ARM (Qemu) or RISC-V (SIS, Qemu) simulator.
> These are the currently most relevant architectures. SPARC is a dead
> architecture and it has some peculiarities which were a nice idea in the
> 1980s.
> > This is necessary
> > for writing your own code in RTEMS, right?
> It helps, but it is not necessary.
