[PATCH v1 8/9] smpsignal01: Change state before sending the signal
Jan Sommer jan.sommer at dlr.de
Sun May 31 14:22:58 UTC 2020
The signal handler of the consumer might start executing
before rtems_signal_send of the producer returns.
Therefore change the state to SIG_1_SENT before sending the signal.
 testsuites/smptests/smpsignal01/init.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/smpsignal01/init.c
index 36a66bea9b..025e84c6a2 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -81,10 +81,10 @@ static void signal_send(test_context *ctx, test_state new_state)
   rtems_status_code sc;
+  change_state(ctx, new_state);
   sc = rtems_signal_send(ctx->consumer, TEST_SIGNAL);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  change_state(ctx, new_state);
 static void check_consumer_processor(const test_context *ctx)
2.12.3
