[PATCH v3 1/2] Add networking support for griscv bsp
Jiri Gaisler
jiri at gaisler.se
Sun Nov 1 15:46:30 UTC 2020
* Only GRETH device supported for now
* Fix endian problem in GRETH driver
* Remove SPARC assembly from greth.c
* Builds with both autoconf and waf
bsps/riscv/griscv/console/console.c | 2 +-
bsps/riscv/griscv/include/bsp.h | 14 +++++
bsps/riscv/griscv/net/griscv_greth.c | 59 ++++++++++++++++++++
bsps/shared/grlib/net/greth.c | 24 ++++----
bsps/shared/net/greth2.c | 6 +-
c/src/lib/libbsp/riscv/griscv/Makefile.am | 6 ++
spec/build/bsps/riscv/griscv/grp.yml | 2 +
spec/build/bsps/riscv/griscv/objnetnosmp.yml | 18 ++++++
8 files changed, 117 insertions(+), 14 deletions(-)
create mode 100644 bsps/riscv/griscv/net/griscv_greth.c
create mode 100644 spec/build/bsps/riscv/griscv/objnetnosmp.yml
diff --git a/bsps/riscv/griscv/console/console.c b/bsps/riscv/griscv/console/console.c
index 582b4c81b8..c92be99fdb 100644
--- a/bsps/riscv/griscv/console/console.c
+++ b/bsps/riscv/griscv/console/console.c
@@ -64,7 +64,7 @@ static int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
/* Extract needed information of one APBUART */
apbuarts[uarts].regs = (struct apbuart_regs *)apb->start;
- apbuarts[uarts].irq = apb->irq;
+ apbuarts[uarts].irq = apb->common.irq;
/* Get APBUART core frequency, it is assumed that it is the same
* as Bus frequency where the UART is situated
diff --git a/bsps/riscv/griscv/include/bsp.h b/bsps/riscv/griscv/include/bsp.h
index 95cccd3d0a..9d6fb2a16f 100644
--- a/bsps/riscv/griscv/include/bsp.h
+++ b/bsps/riscv/griscv/include/bsp.h
@@ -75,6 +75,20 @@ extern void BSP_shared_interrupt_mask(int irq);
extern void BSP_shared_interrupt_clear(int irq);
extern void BSP_shared_interrupt_unmask(int irq);
+ * Network driver configuration for greth
+struct rtems_bsdnet_ifconfig;
+extern int rtems_griscv_greth_driver_attach(
+ struct rtems_bsdnet_ifconfig *config,
+ int attach
+#define RTEMS_BSP_NETWORK_DRIVER_NAME "gr_eth1"
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_griscv_greth_driver_attach
+#define GRETH_SUPPORTED
+#define CPU_U32_FIX
#ifdef __cplusplus
#endif
diff --git a/bsps/riscv/griscv/net/griscv_greth.c b/bsps/riscv/griscv/net/griscv_greth.c
new file mode 100644
index 0000000000..e5c05fd060
--- /dev/null
+++ b/bsps/riscv/griscv/net/griscv_greth.c
@@ -0,0 +1,59 @@
+ * LEON3 Opencores Ethernet MAC Configuration Information
+ * COPYRIGHT (c) 2004.
+ * Gaisler Research
+#include <machine/rtems-bsd-kernel-space.h>
+#include <bsp.h>
+#include <amba.h>
+#include <grlib/ambapp.h>
+#include <libchip/greth.h>
+/*#if (GRETH_DEBUG & GRETH_DEBUG_PRINT_REGISTERS)*/
+#include <stdio.h>
+/*#endif*/
+ * Default sizes of transmit and receive descriptor areas
+#define RDA_COUNT 32
+#define TDA_COUNT 32
+greth_configuration_t griscv_greth_configuration;
+int rtems_griscv_greth_driver_attach(
+ int attach
+ unsigned int base_addr = 0; /* avoid warnings */
+ unsigned int eth_irq = 0; /* avoid warnings */
+ struct ambapp_dev *adev;
+ struct ambapp_apb_info *apb;
+ /* Scan for MAC AHB slave interface */
+ adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
+ VENDOR_GAISLER, GAISLER_ETHMAC,
+ ambapp_find_by_idx, NULL);
+ if (adev) {
+ apb = DEV_TO_APB(adev);
+ base_addr = apb->start;
+ eth_irq = apb->common.irq;
+ /* clear control register and reset NIC */
+ *(volatile int *) base_addr = 0;
+ *(volatile int *) base_addr = GRETH_CTRL_RST;
+ griscv_greth_configuration.base_address = (void*)base_addr;
+ griscv_greth_configuration.vector = eth_irq; /* on LEON vector is IRQ no. */
+ griscv_greth_configuration.txd_count = TDA_COUNT;
+ griscv_greth_configuration.rxd_count = RDA_COUNT;
+ rtems_greth_driver_attach(config, &griscv_greth_configuration);
+ return 0;
diff --git a/bsps/shared/grlib/net/greth.c b/bsps/shared/grlib/net/greth.c
index bc4d3cc40f..8b19b48211 100644
--- a/bsps/shared/grlib/net/greth.c
+++ b/bsps/shared/grlib/net/greth.c
@@ -25,6 +25,7 @@
#include <rtems/bspIo.h>
+#include <string.h>
#include <stdarg.h>
#include <rtems/error.h>
@@ -721,10 +722,13 @@ void ipalign(struct mbuf *m)
unsigned int tmp = 0;
if ((((int) m->m_data) & 2) && (m->m_len)) {
+#if CPU_LITTLE_ENDIAN == TRUE
+ memmove((caddr_t)(((int) m->m_data) + 2), m->m_data, m->m_len);
+#else
last = (unsigned int *) ((((int) m->m_data) + m->m_len + 8) & ~3);
first = (unsigned int *) (((int) m->m_data) & ~3);
/* tmp = *first << 16; */
- asm volatile (" lda [%1] 1, %0\n" : "=r"(tmp) : "r"(first) );
+ tmp = GRETH_MEM_LOAD(first);
tmp = tmp << 16;
first++;
do {
@@ -733,12 +737,12 @@ void ipalign(struct mbuf *m)
** Load with forced cache miss
* data = *first;
- asm volatile (" lda [%1] 1, %0\n" : "=r"(data) : "r"(first) );
+ data = GRETH_MEM_LOAD(first);
*first = tmp | (data >> 16);
tmp = data << 16;
first++;
} while (first <= last);
+#endif
m->m_data = (caddr_t)(((int) m->m_data) + 2);
@@ -756,7 +760,6 @@ greth_Daemon (void *arg)
SPIN_IRQFLAGS(flags);
int first;
int tmp;
- unsigned int addr;
for (;;)
@@ -836,14 +839,11 @@ again:
#ifdef CPU_U32_FIX
if(!dp->gbit_mac) {
/* OVERRIDE CACHED ETHERNET HEADER FOR NON-SNOOPING SYSTEMS */
- addr = (unsigned int)eh;
- asm volatile (" lda [%1] 1, %0\n" : "=r"(tmp) : "r"(addr) );
- addr+=4;
- addr+=4;
- addr+=4;
+ tmp = GRETH_MEM_LOAD((uintptr_t)eh);
+ tmp = GRETH_MEM_LOAD(4+(uintptr_t)eh);
+ tmp = GRETH_MEM_LOAD(8+(uintptr_t)eh);
+ tmp = GRETH_MEM_LOAD(12+(uintptr_t)eh);
+ (void)tmp;
ipalign(m); /* Align packet on 32-bit boundary */
diff --git a/bsps/shared/net/greth2.c b/bsps/shared/net/greth2.c
index 2fc35a5471..13bf7b8884 100644
--- a/bsps/shared/net/greth2.c
+++ b/bsps/shared/net/greth2.c
@@ -21,6 +21,7 @@
#include <stdarg.h>
@@ -514,6 +515,9 @@ void ipalign(struct mbuf *m)
unsigned int tmp;
+#else
@@ -529,7 +533,7 @@ void ipalign(struct mbuf *m)
tmp = data << 16;
first++;
+#endif
diff --git a/c/src/lib/libbsp/riscv/griscv/Makefile.am b/c/src/lib/libbsp/riscv/griscv/Makefile.am
index e04598e4bf..07f5cc03ca 100644
--- a/c/src/lib/libbsp/riscv/griscv/Makefile.am
+++ b/c/src/lib/libbsp/riscv/griscv/Makefile.am
@@ -64,6 +64,12 @@ if HAS_SMP
librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/griscv/start/bspsmp.c
endif
+if HAS_NETWORKING
+if !HAS_SMP
+librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/griscv/net/griscv_greth.c
+endif
+endif
include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
include $(srcdir)/../../../../../../bsps/shared/grlib-sources.am
include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
diff --git a/spec/build/bsps/riscv/griscv/grp.yml b/spec/build/bsps/riscv/griscv/grp.yml
index 1945d984f5..056af047b6 100644
--- a/spec/build/bsps/riscv/griscv/grp.yml
+++ b/spec/build/bsps/riscv/griscv/grp.yml
@@ -23,6 +23,8 @@ links:
uid: abi
- role: build-dependency
uid: obj
+- role: build-dependency
+ uid: objnetnosmp
uid: objsmp
diff --git a/spec/build/bsps/riscv/griscv/objnetnosmp.yml b/spec/build/bsps/riscv/griscv/objnetnosmp.yml
index 0000000000..105a23351d
--- /dev/null
+++ b/spec/build/bsps/riscv/griscv/objnetnosmp.yml
@@ -0,0 +1,18 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by:
+- and:
+ - RTEMS_NETWORKING
+ - not: RTEMS_SMP
+includes:
+- cpukit/libnetworking
+install: []
+links: []
+source:
+- bsps/riscv/griscv/net/griscv_greth.c
+type: build
2.17.1
