[PATCH v1 1/2] bsps/shared/ofw: Implement RTEMS OFW interface
Niteesh G. S.
niteesh.gs at gmail.com
Mon Nov 2 17:06:12 UTC 2020
ping.
On Thu, Sep 24, 2020 at 9:00 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> Hello,
> On Sat, Sep 19, 2020 at 4:13 PM Christian Mauderer <oss at c-mauderer.de>
> wrote:
>> Hello Niteesh,
>> sorry for adding another delay: I think the new build system needs a bit
>> of time to settle. As soon as there are some more PASS in the table that
>> Sebastian created [1] (especially for beagle) we should try to get these
>> patches merged. Before that I would like to avoid big changes because it
>> might get hard to distinguish new bugs from build system bugs.
> No problem. Currently, I have my university exams going on and also I am
> waiting for my logic analyzer. As soon as it arrives I'll start verifying
> the previous
> drivers and finish refactoring the other ones.
> Thanks,
> Niteesh.
>> Best regards
>> Christian
>> [1] https://devel.rtems.org/wiki/Release/6/Waf%20BSP%20Checklist
>> On 16/09/2020 19:05, Niteesh G. S. wrote:
>> > Hello,
>> > Sorry for the delay, I was a bit occupied with my university work.
>> > Now since the new build system is merged I would like to get my
>> > GSoC work merged too.
>> > The goal of this series patches is to implement the OFW API into RTEMS
>> > and modify libBSD to use this RTEMS API instead of its own.
>> > Thanks,
>> > Niteesh.
>> > On Wed, Sep 16, 2020 at 10:33 PM G S Niteesh Babu <niteesh.gs at gmail.com
>> > <mailto:niteesh.gs at gmail.com>> wrote:
>> > RTEMS OFW is a FDT only implementation of the OpenFirmWare
>> > interface. This API is created to be compatible with FreeBSD
>> > OpenFirmWare interface. The main intention is to make
>> > porting of FreeBSD drivers to RTEMS easier.
>> > Most functions implemented have an direct one-one mapping
>> > with the original OFW API and some extra auxiliary functions
>> > were implemented to make working with device trees easier in
>> > RTEMS.
>> > Update #3784
>> > bsps/include/ofw/ofw.h | 548 +++++++++++++++++++++++++++
>> > bsps/include/ofw/ofw_compat.h | 74 ++++
>> > bsps/shared/ofw/ofw.c | 682
>> > spec/build/bsps/obj.yml | 5 +
>> > 4 files changed, 1309 insertions(+)
>> > create mode 100644 bsps/include/ofw/ofw.h
>> > create mode 100644 bsps/include/ofw/ofw_compat.h
>> > create mode 100644 bsps/shared/ofw/ofw.c
>> > diff --git a/bsps/include/ofw/ofw.h b/bsps/include/ofw/ofw.h
>> > new file mode 100644
>> > index 0000000000..411010be89
>> > --- /dev/null
>> > +++ b/bsps/include/ofw/ofw.h
>> > @@ -0,0 +1,548 @@
>> > +/* SPDX-License-Identifier: BSD-2-Clause */
>> > + * @file
>> > + * @ingroup ofw
>> > + * RTEMS FDT implementation of OpenFirmWare Interface.
>> > + * RTEMS OFW is a FDT only implementation of the OpenFirmWare
>> > interface.
>> > + * This API is created to be compatible with FreeBSD OpenFirmWare
>> > interface.
>> > + * The main intention is to make porting of FreeBSD drivers to
>> > RTEMS easier.
>> > + * Copyright (C) 2020 Niteesh Babu G S <niteesh.gs at gmail.com
>> > + * Redistribution and use in source and binary forms, with or
>> without
>> > + * modification, are permitted provided that the following
>> conditions
>> > + * are met:
>> > + * 1. Redistributions of source code must retain the above
>> copyright
>> > + * notice, this list of conditions and the following disclaimer.
>> > + * 2. Redistributions in binary form must reproduce the above
>> copyright
>> > in the
>> > + * documentation and/or other materials provided with the
>> > distribution.
>> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>> > CONTRIBUTORS "AS IS"
>> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>> > LIMITED TO, THE
>> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>> > PARTICULAR PURPOSE
>> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>> > CONTRIBUTORS BE
>> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>> EXEMPLARY, OR
>> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>> PROCUREMENT OF
>> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> > BUSINESS
>> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>> > WHETHER IN
>> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> > OTHERWISE)
>> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>> > ADVISED OF THE
>> > + * POSSIBILITY OF SUCH DAMAGE.
>> > +#ifndef _OFW_H
>> > +#define _OFW_H
>> > +#ifdef __cplusplus
>> > +extern "C" {
>> > +#endif
>> > +#include <rtems.h>
>> > +#include <stdint.h>
>> > +#include <sys/types.h>
>> > + * Represents a node in the device tree. The offset from fdtp to
>> > node is used
>> > + * instead of fdt offset to make sure this is compatible with OF
>> > interface in
>> > + * FreeBSD.
>> > +typedef uint32_t phandle_t;
>> > + * Represents the effective phandle of the node.
>> > +typedef uint32_t ihandle_t;
>> > + * Represents the data type of the buffer.
>> > +typedef uint32_t pcell_t;
>> > + * @struct rtems_ofw_memory_area
>> > + * This is used to represent elements(FDT properties) that define
>> > + * region of memory address.
>> > +typedef struct {
>> > + /** The start address of the memory region. */
>> > + uint32_t start;
>> > + /** The size of the memory region. */
>> > + uint32_t size;
>> > +} rtems_ofw_memory_area;
>> > + * @struct rtems_ofw_ranges
>> > + * This is used to represent the ranges property in the device
>> tree.
>> > +typedef struct {
>> > + /** The physical address within the child bus address space */
>> > + uint32_t child_bus;
>> > + /** The physical address within the parent bus address space */
>> > + uint32_t parent_bus;
>> > + /** The size of the range in the child’s address space */
>> > + uint32_t size;
>> > +} rtems_ofw_ranges;
>> > + * @brief Gets the node that is next to @a node.
>> > + * @param[in] node Node offset
>> > + * @retval Peer node offset Successful operation.
>> > + * @retval 0 No peer node or invalid node handle
>> > +phandle_t rtems_ofw_peer(
>> > + phandle_t node
>> > + * @brief Gets the node that is the child of @a node.
>> > + * @retval child node offset Successful operation.
>> > + * @retval 0 No child node or invalid node handle
>> > +phandle_t rtems_ofw_child(
>> > + phandle_t node
>> > + * @brief Gets the node that is the parent of @a node.
>> > +phandle_t rtems_ofw_parent(
>> > + phandle_t node
>> > + * @brief Gets the length of the property mentioned in @a propname.
>> > + * @param[in] prop Property name
>> > + * @retval -1 Invalid node or property
>> > + * @retval Length of property on successful operation
>> > +ssize_t rtems_ofw_get_prop_len(
>> > + phandle_t node,
>> > + const char *propname
>> > + * @brief Gets the value of property mentioned in @a propname.
>> > + * @param[out] buf The property value gets stored in this buffer
>> > (Pre-allocated)
>> > + * @param[in] len Length of the buffer
>> > +ssize_t rtems_ofw_get_prop(
>> > + phandle_t node,
>> > + const char *propname,
>> > + void *buf,
>> > + size_t len
>> > + * @brief Gets the value of property mentioned in @a prop.
>> > + * Gets the value of property of @a node and converts the value
>> > into the host's
>> > + * endianness.
>> > buffer(Pre-allocated)
>> > + * after converted to the host's endianness
>> > +ssize_t rtems_ofw_get_enc_prop(
>> > + phandle_t node,
>> > + const char *prop,
>> > + pcell_t *buf,
>> > + size_t len
>> > + * @brief Checks if the property @a propname is present in @a node.
>> > + * @param[in] propname Property name
>> > + * @retval 0 Property not present.
>> > + * @retval 1 Property is present.
>> > +int rtems_ofw_has_prop(
>> > + phandle_t node,
>> > + * @brief Searches for property @a propname in @a node.
>> > + * Searches the node and its parent recursively for the property
>> > and fills the
>> > + * buffer with the first found value.
>> > (Pre-allocated)
>> > + * @retval Length of the property if property is found.
>> > + * @retval -1 Property is not found.
>> > +ssize_t rtems_ofw_search_prop(
>> > + phandle_t node,
>> > + void *buf,
>> > + size_t len
>> > and fills the
>> > + * buffer with the first value found after converting it to the
>> > endianness of
>> > + * the host.
>> > +ssize_t rtems_ofw_search_enc_prop(
>> > + phandle_t node,
>> > + pcell_t *buf,
>> > + size_t len
>> > + * Same as rtems_ofw_getprop, but the @a buf is allocated in this
>> > routine and
>> > + * the user is responsible for freeing it.
>> > + * @param[out] buf The buffer is allocated in this routine and
>> user is
>> > + * responsible for freeing.
>> > +ssize_t rtems_ofw_get_prop_alloc(
>> > + phandle_t node,
>> > + void **buf
>> > + * @brief Gets multiple values of the property @a propname.
>> > + * Same as rtems_ofw_getprop_alloc but it can read properties with
>> > multiple
>> > + * values.
>> > + * For eg: reg = <0x1000 0x10 0x2000 0x20>
>> > + * @param[in] elsz Size of the single value
>> user is
>> > + * @retval Number of values read.
>> > +ssize_t rtems_ofw_get_prop_alloc_multi(
>> > + phandle_t node,
>> > + int elsz,
>> > + void **buf
>> > + * Same as rtems_ofw_getprop_alloc but the value stored in the
>> > buffer is
>> > + * converted into the host's endianness.
>> user is
>> > +ssize_t rtems_ofw_get_enc_prop_alloc(
>> > + phandle_t node,
>> > + void **buf
>> > + * Same as rtems_ofw_getprop_alloc_multi but the values stored in
>> > the buffer
>> > + * are converted to the host's endianness.
>> user is
>> > +ssize_t rtems_ofw_get_enc_prop_alloc_multi(
>> > + phandle_t node,
>> > + int elsz,
>> > + void **buf
>> > + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc
>> > functions.
>> > + * @param[in] buf Buffer to be freed
>> > +void rtems_ofw_free(
>> > + void *buf
>> > + * @brief Finds the next property of @a node.
>> > + * Finds the next property of the node and when @a propname is NULL
>> > it returns
>> > + * the value in the first property.
>> > + * @param[in] previous Previous property name
>> > + * @param[out] buf The value of the next property gets stored in
>> > this buffer
>> > + * (Pre-allocated)
>> > + * @retval -1 node or previous property does not exist
>> > + * @retval 0 no more properties
>> > + * @retval 1 success
>> > +int rtems_ofw_next_prop(
>> > + phandle_t node,
>> > + const char *previous,
>> > + char *buf,
>> > + size_t len
>> > + * @brief Sets the property @name of @a node to @a buf.
>> > + * @param[in] name Property name
>> > + * @param[in] buf Buffer contains the value to be set.
>> > + * @retval -1 node does not exist
>> > + * @retval 0 on success
>> > + * @retval libFDT error codes on unsuccessful setting operation
>> > +int rtems_ofw_set_prop(
>> > + phandle_t node,
>> > + const char *name,
>> > + const void *buf,
>> > + size_t len
>> > + * @brief Converts a device specifier to a fully qualified path
>> name.
>> > + * @param[in] dev device specifier
>> > + * @param[out] buf The path is filled into the
>> > + * @param[in] length of the buffer
>> > + * @retval -1 always. Unimplemented.
>> > +ssize_t rtems_ofw_canon(
>> > + const char *dev,
>> > + char *buf,
>> > + size_t len
>> > + * @brief Finds the node at the given path
>> > + * @param[in] path to the node from root
>> > + * @retval node handle on success
>> > +phandle_t rtems_ofw_find_device(
>> > + const char *path
>> > + * @brief This routine converts effective phandle @a xref to node
>> > offset.
>> > + * @param[in] xref Node phandle
>> > + * @retval Node offset on success
>> > + * @retval Node phandle on failure
>> > +phandle_t rtems_ofw_node_from_xref(
>> > + phandle_t xref
>> > + * @brief This routine converts node offset to effective phandle of
>> > @a node.
>> > + * @retval Node phandle on success
>> > + * @retval Node offset on failure
>> > +phandle_t rtems_ofw_xref_from_node(
>> > + phandle_t node
>> > + * instance handles(ihandle_t) as same as phandles in the FDT
>> > implementation
>> > + * of OF interface.
>> > + * @brief Converts @a instance handle to phandle.
>> > + * instance are same as node offsets in FDT.
>> > + * @param[in] instance Node offset
>> > + * @retval phandle of node on success.
>> > + * @retval instance of node on failure.
>> > +phandle_t rtems_ofw_instance_to_package(
>> > + ihandle_t instance
>> > + * @brief Find the node's path from phandle.
>> > + * @param[out] buf Path is filled into this buffer(Pre-allocated).
>> > + * @param[in] len Length of the buffer.
>> > +ssize_t rtems_ofw_package_to_path(
>> > + phandle_t node,
>> > + char *buf,
>> > + size_t len
>> > + * @brief Find the node's path from ihandle.
>> > +ssize_t rtems_ofw_instance_to_path(
>> > + ihandle_t instance,
>> > + char *buf,
>> > + size_t len
>> > + * @brief Queries the node's reg value.
>> > + * This routine fills the buffer @a buf with the values in reg
>> > property of node
>> > + * @a node. It reads all the values of the property and fills the
>> > buffer to max
>> > + * size.
>> > + * This routine is local to RTEMS OFW and does not have an
>> > corresponding
>> > + * FreeBSD OFW pair.
>> > + * @param[out] buf Register values are stored in this
>> > + * @param[in] size Length of the buffer.
>> > + * @retval -1 If reg property is missing.
>> > + * @retval Length of the reg property in bytes.
>> > +int rtems_ofw_get_reg(
>> > + phandle_t node,
>> > + rtems_ofw_memory_area *buf,
>> > + size_t size
>> > + * @brief Queries the node's interrupt value.
>> > + * This routine fills the buffer @a buf with the interrupt number.
>> > In case of
>> > + * multiple numbers it fills the buffer to its full extent.
>> > corresponding
>> > + * @param[out] buf Interrupt values are stored in this
>> > + * @retval -1 If interrupts property is missing.
>> > + * @retval The number of interrupt numbers read.
>> > +int rtems_ofw_get_interrupts(
>> > + phandle_t node,
>> > + rtems_vector_number *buf,
>> > + size_t size
>> > + * @brief Queries the node's status.
>> > corresponding
>> > + * @retval true Status is OK or empty.
>> > + * @retval false Status is not OK or missing.
>> > +bool rtems_ofw_node_status( phandle_t node );
>> > + * @brief Gets node phandle from compatible property.
>> > corresponding
>> > + * @param[in] compat Compatible string
>> > + * @retval 0 Node with @a compat as compatible string not found
>> > + * @retval Node phandle on success.
>> > +phandle_t rtems_ofw_find_device_by_compat( const char *compat );
>> > +#ifdef __cplusplus
>> > +#endif
>> > +#endif /* _OFW_H */
>> > diff --git a/bsps/include/ofw/ofw_compat.h
>> > b/bsps/include/ofw/ofw_compat.h
>> > index 0000000000..be4a5ea3ce
>> > --- /dev/null
>> > +++ b/bsps/include/ofw/ofw_compat.h
>> > @@ -0,0 +1,74 @@
>> > + * @file
>> > + * @ingroup ofw
>> > + * This file defines necessary symbols to make the RTEMS OFW API
>> > compatible
>> > + * with FreeBSD OFW.
>> without
>> conditions
>> > + * are met:
>> copyright
>> copyright
>> > in the
>> > distribution.
>> > LIMITED TO, THE
>> > PARTICULAR PURPOSE
>> > CONTRIBUTORS BE
>> EXEMPLARY, OR
>> PROCUREMENT OF
>> > BUSINESS
>> > WHETHER IN
>> > OTHERWISE)
>> > ADVISED OF THE
>> > +#ifndef _OFW_COMPAT_H
>> > +#define _OFW_COMPAT_H
>> > +#ifdef __cplusplus
>> > +extern "C" {
>> > +#endif
>> > +#include <ofw/ofw.h>
>> > +#define OF_peer rtems_ofw_peer
>> > +#define OF_child rtems_ofw_child
>> > +#define OF_parent rtems_ofw_parent
>> > +#define OF_getproplen rtems_ofw_get_prop_len
>> > +#define OF_getprop rtems_ofw_get_prop
>> > +#define OF_getencprop rtems_ofw_get_enc_prop
>> > +#define OF_hasprop rtems_ofw_has_prop
>> > +#define OF_searchprop rtems_ofw_search_prop
>> > +#define OF_searchencprop rtems_ofw_search_enc_prop
>> > +#define OF_getprop_alloc rtems_ofw_get_prop_alloc
>> > +#define OF_getprop_alloc_multi rtems_ofw_get_prop_alloc_multi
>> > +#define OF_getencprop_alloc_multi
>> > +#define OF_getencprop_alloc rtems_ofw_get_enc_prop_alloc
>> > +#define OF_prop_free rtems_ofw_free
>> > +#define OF_nextprop rtems_ofw_next_prop
>> > +#define OF_setprop rtems_ofw_set_prop
>> > +#define OF_canon rtems_ofw_canon
>> > +#define OF_finddevice rtems_ofw_find_device
>> > +#define OF_package_to_path rtems_ofw_package_to_path
>> > +#define OF_node_from_xref rtems_ofw_node_from_xref
>> > +#define OF_xref_from_node rtems_ofw_xref_from_node
>> > +#define OF_instance_to_package rtems_ofw_instance_to_package
>> > +#define OF_instance_to_path rtems_ofw_instance_to_path
>> > +#ifdef __cplusplus
>> > +#endif
>> > +#endif /* _OFW_COMPAT_H */
>> > diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
>> > index 0000000000..2b1dff8bf8
>> > --- /dev/null
>> > +++ b/bsps/shared/ofw/ofw.c
>> > @@ -0,0 +1,682 @@
>> > + * @file
>> > + * @ingroup ofw
>> without
>> conditions
>> > + * are met:
>> copyright
>> copyright
>> > in the
>> > distribution.
>> > LIMITED TO, THE
>> > PARTICULAR PURPOSE
>> > CONTRIBUTORS BE
>> EXEMPLARY, OR
>> PROCUREMENT OF
>> > BUSINESS
>> > WHETHER IN
>> > OTHERWISE)
>> > ADVISED OF THE
>> > +#ifdef HAVE_CONFIG_H
>> > +#include "config.h"
>> > +#endif
>> > +#include <bsp/fdt.h>
>> > +#include <sys/param.h>
>> > +#include <libfdt.h>
>> > +#include <assert.h>
>> > +#include <rtems/sysinit.h>
>> > +const void *fdtp = NULL;
>> > +static phandle_t rtems_fdt_offset_to_phandle( int offset )
>> > + if (offset < 0) {
>> > + return 0;
>> > + return (phandle_t)offset + fdt_off_dt_struct(fdtp);
>> > +static int rtems_fdt_phandle_to_offset( phandle_t handle )
>> > + int off;
>> > + int fdt_off;
>> > + off = (int) handle;
>> > + fdt_off = fdt_off_dt_struct(fdtp);
>> > + if (off < fdt_off) {
>> > + return -1;
>> > + return off - fdt_off;
>> > +static void rtems_ofw_init( void ) {
>> > + int rv;
>> > + const void *fdt;
>> > + fdt = bsp_fdt_get();
>> > + rv = fdt_check_header(fdt);
>> > + * If the FDT is invalid exit through fatal.
>> > + if (rv != 0) {
>> > + rtems_fatal_error_occurred(RTEMS_NOT_CONFIGURED);
>> > + fdtp = fdt;
>> > +RTEMS_SYSINIT_ITEM(
>> > + rtems_ofw_init,
>> > + RTEMS_SYSINIT_BSP_PRE_DRIVERS,
>> > + RTEMS_SYSINIT_ORDER_FIRST
>> > +phandle_t rtems_ofw_peer( phandle_t node )
>> > + int offset;
>> > + if (node == 0) {
>> > + int root = fdt_path_offset(fdtp, "/");
>> > + return rtems_fdt_offset_to_phandle(root);
>> > + offset = rtems_fdt_phandle_to_offset(node);
>> > + if (offset < 0) {
>> > + return 0;
>> > + offset = fdt_next_subnode(fdtp, offset);
>> > + return rtems_fdt_offset_to_phandle(offset);
>> > +phandle_t rtems_ofw_child( phandle_t node )
>> > + int offset;
>> > + if (offset < 0) {
>> > + return 0;
>> > + offset = fdt_first_subnode(fdtp, offset);
>> > +phandle_t rtems_ofw_parent( phandle_t node )
>> > + int offset;
>> > + if (offset < 0) {
>> > + return 0;
>> > + offset = fdt_parent_offset(fdtp, offset);
>> > + phandle_t node,
>> > + int offset;
>> > + int len;
>> > + const void *prop;
>> > + if (offset < 0) {
>> > + return -1;
>> > + prop = fdt_getprop(fdtp, offset, propname, &len);
>> > + if (prop == NULL && strcmp(propname, "name") == 0) {
>> > + fdt_get_name(fdtp, offset, &len);
>> > + return len + 1;
>> > + if (prop == NULL && strcmp(propname, "/chosen") == 0) {
>> > + if (strcmp(propname, "fdtbootcpu") == 0)
>> > + return sizeof(pcell_t);
>> > + if (strcmp(propname, "fdtmemreserv") == 0)
>> > + return 2 * sizeof(uint64_t) * fdt_num_mem_rsv(fdtp);
>> > + if (prop == NULL) {
>> > + return -1;
>> > + return len;
>> > + phandle_t node,
>> > + void *buf,
>> > + size_t bufsize
>> > + const void *prop;
>> > + int offset;
>> > + int len;
>> > + uint32_t cpuid;
>> > + if (offset < 0) {
>> > + return -1;
>> > + prop = fdt_get_name(fdtp, offset, &len);
>> > + strncpy(buf, prop, bufsize);
>> > + return len + 1;
>> > + if (strcmp(propname, "fdtbootcpu") == 0) {
>> > + cpuid = cpu_to_fdt32(fdt_boot_cpuid_phys(fdtp));
>> > + len = sizeof(cpuid);
>> > + prop = &cpuid;
>> > + if (strcmp(propname, "fdtmemreserv") == 0) {
>> > + prop = (char *)fdtp + fdt_off_mem_rsvmap(fdtp);
>> > + len = sizeof(uint64_t)*2*fdt_num_mem_rsv(fdtp);
>> > + return -1;
>> > + bcopy(prop, buf, MIN(len, bufsize));
>> > + return len;
>> > + phandle_t node,
>> > + const char *prop,
>> > + pcell_t *buf,
>> > + size_t len
>> > + ssize_t rv;
>> > + assert(len % 4 == 0);
>> > + rv = rtems_ofw_get_prop(node, prop, buf, len);
>> > + if (rv < 0) {
>> > + return rv;
>> > + for (int i = 0; i < (len / 4); i++) {
>> > + buf[i] = fdt32_to_cpu(buf[i]);
>> > + return rv;
>> > + phandle_t node,
>> > + ssize_t rv;
>> > + rv = rtems_ofw_get_prop_len(node, propname);
>> > + return rv >= 0 ? 1 : 0;
>> > + phandle_t node,
>> > + void *buf,
>> > + size_t len
>> > + ssize_t rv;
>> > + for (; node != 0; node = rtems_ofw_parent(node)) {
>> > + if ((rv = rtems_ofw_get_prop(node, propname, buf, len) != -1))
>> > + return rv;
>> > + return -1;
>> > + phandle_t node,
>> > + pcell_t *buf,
>> > + size_t len
>> > + ssize_t rv;
>> > + if ((rv = rtems_ofw_get_enc_prop(node, propname, buf, len) !=
>> > -1)) {
>> > + return rv;
>> > + return -1;
>> > + phandle_t node,
>> > + void **buf
>> > + ssize_t len;
>> > + *buf = NULL;
>> > + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1) {
>> > + return -1;
>> > + if (len > 0) {
>> > + *buf = malloc(len);
>> > + if (*buf == NULL) {
>> > + return -1;
>> > + if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
>> > + rtems_ofw_free(buf);
>> > + *buf = NULL;
>> > + return -1;
>> > + return len;
>> > + phandle_t node,
>> > + int elsz,
>> > + void **buf
>> > + ssize_t len;
>> > + *buf = NULL;
>> > + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1 ||
>> > + (len % elsz != 0)) {
>> > + return -1;
>> > + if (len > 0) {
>> > + return -1;
>> > + *buf = NULL;
>> > + return -1;
>> > + return (len / elsz);
>> > + phandle_t node,
>> > + void **buf
>> > + ssize_t len;
>> > + *buf = NULL;
>> > + return -1;
>> > + if (len > 0) {
>> > + return -1;
>> > + if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
>> > + *buf = NULL;
>> > + return -1;
>> > + return len;
>> > + phandle_t node,
>> > + int elsz,
>> > + void **buf
>> > + ssize_t len;
>> > + *buf = NULL;
>> > + return -1;
>> > + if (len > 0) {
>> > + return -1;
>> > + *buf = NULL;
>> > + return -1;
>> > +void rtems_ofw_free( void *buf )
>> > + free(buf);
>> > + phandle_t node,
>> > + char *buf,
>> > + size_t len
>> > + const void *name;
>> > + const void *prop;
>> > + int offset;
>> > + if (offset < 0) {
>> > + return -1;
>> > + if (previous == NULL) {
>> > + offset = fdt_first_property_offset(fdtp, offset);
>> > + } else {
>> > + fdt_for_each_property_offset(offset, fdtp, offset) {
>> > + prop = fdt_getprop_by_offset(fdtp, offset, (const char
>> > **)&name, NULL);
>> > + if (prop == NULL)
>> > + return -1;
>> > + if (strcmp(previous, name) != 0)
>> > + continue;
>> > + offset = fdt_next_property_offset(fdtp, offset);
>> > + break;
>> > + if (offset < 0)
>> > + return 0;
>> > + prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name,
>> > &offset);
>> > + if (prop == NULL)
>> > + return -1;
>> > + strncpy(buf, name, len);
>> > + return 1;
>> > + phandle_t node,
>> > + const char *name,
>> > + const void *buf,
>> > + size_t len
>> > + int offset;
>> > + if (offset < 0)
>> > + return -1;
>> > + if (fdt_setprop_inplace(fdtp, offset, name, buf, len) != 0)
>> > + return (fdt_setprop(fdtp, offset, name, buf, len));
>> > + return 0;
>> > +phandle_t rtems_ofw_find_device( const char *path )
>> > + int offset;
>> > + offset = fdt_path_offset(fdtp, path);
>> > + if (offset < 0)
>> > + return -1;
>> > +static phandle_t rtems_ofw_get_effective_phandle(
>> > + phandle_t node,
>> > + phandle_t xref
>> > + phandle_t child;
>> > + phandle_t ref;
>> > + for (child = rtems_ofw_child(node); child != 0; child =
>> > rtems_ofw_peer(child)) {
>> > + ref = rtems_ofw_get_effective_phandle(child, xref);
>> > + if (ref != -1)
>> > + return ref;
>> > + if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref))
>> > == -1 &&
>> > + rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref,
>> > sizeof(ref)) == -1 &&
>> > + rtems_ofw_get_enc_prop(child, "linux,phandle", &ref,
>> > sizeof(ref)) == -1
>> > + continue;
>> > + if (ref == xref)
>> > + return child;
>> > + return -1;
>> > +phandle_t rtems_ofw_node_from_xref( phandle_t xref )
>> > + phandle_t node;
>> > + if ((node = rtems_ofw_get_effective_phandle(rtems_ofw_peer(0),
>> > xref)) == -1)
>> > + return xref;
>> > + return node;
>> > +phandle_t rtems_ofw_xref_from_node( phandle_t node )
>> > + phandle_t ref;
>> > + if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref))
>> > == -1 &&
>> > + rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref,
>> > + rtems_ofw_get_enc_prop(node, "linux,phandle", &ref,
>> > sizeof(ref)) == -1)
>> > + return node;
>> > + return ref;
>> > +phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
>> > + return rtems_ofw_node_from_xref(instance);
>> > + phandle_t node,
>> > + char *buf,
>> > + size_t len
>> > + int offset;
>> > + int rv;
>> > + rv = fdt_get_path(fdtp, offset, buf, len);
>> > + if (rv != 0)
>> > + return -1;
>> > + return rv;
>> > + char *buf,
>> > + size_t len
>> > + int offset;
>> > + int rv;
>> > + offset = rtems_ofw_instance_to_package(instance);
>> > + offset = rtems_fdt_phandle_to_offset(offset);
>> > + if (rv != 0)
>> > + return -1;
>> > + return rv;
>> > + phandle_t node,
>> > + size_t size
>> > + int len;
>> > + int offset;
>> > + int nranges;
>> > + int nregs;
>> > + phandle_t parent;
>> > + rtems_ofw_ranges range;
>> > + const rtems_ofw_ranges *ptr;
>> > + len = rtems_ofw_get_enc_prop(node, "reg", (pcell_t *)buf, size);
>> > + if (len <= 0) {
>> > + return len;
>> > + nregs = MIN(len, size) / sizeof(rtems_ofw_memory_area);
>> > + for (parent = rtems_ofw_parent(node); parent > 0;
>> > + parent = rtems_ofw_parent(parent)) {
>> > + offset = rtems_fdt_phandle_to_offset(parent);
>> > + ptr = fdt_getprop(fdtp, offset, "ranges", &len);
>> > + if (len < 0) {
>> > + break;
>> > + nranges = len / sizeof(rtems_ofw_ranges);
>> > + offset = 0;
>> > + for (int i=0; i < nregs; i++) {
>> > + for (int j=0; j < nranges; j++) {
>> > + range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
>> > + range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
>> > + range.size = fdt32_to_cpu(ptr[j].size);
>> > + if (buf[i].start >= range.child_bus &&
>> > + buf[i].start < range.child_bus + range.size) {
>> > + offset = range.parent_bus - range.child_bus;
>> > + break;
>> > + buf[i].start += offset;
>> > + return nregs;
>> > + phandle_t node,
>> > + size_t size
>> > + int rv;
>> > + rv = rtems_ofw_get_enc_prop(node, "interrupts", buf, size);
>> > + if (rv <= 0) {
>> > + return rv;
>> > + return MIN(size, rv) / sizeof(rtems_vector_number);
>> > + int len;
>> > + const char buf[10];
>> > + len = rtems_ofw_get_prop(node, "status", &buf[0], sizeof(buf));
>> > + if ((len == -1) ||
>> > + (strncmp(buf, "okay", MIN(5, len)) == 0) ||
>> > + (strncmp(buf, "ok", MIN(3, len)) == 0)) {
>> > + return true;
>> > + return false;
>> > + int offset;
>> > + offset = fdt_node_offset_by_compatible(fdtp, -1, compat);
>> > diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
>> > index 8809238057..0ea07fc83d 100644
>> > --- a/spec/build/bsps/obj.yml
>> > +++ b/spec/build/bsps/obj.yml
>> > @@ -24,6 +24,10 @@ install:
>> > - bsps/include/bsp/u-boot.h
>> > - bsps/include/bsp/uart-output-char.h
>> > - bsps/include/bsp/utility.h
>> > +- destination: ${BSP_INCLUDEDIR}/ofw
>> > + source:
>> > + - bsps/include/ofw/ofw.h
>> > + - bsps/include/ofw/ofw_compat.h
>> > - destination: ${BSP_INCLUDEDIR}/libchip
>> > source:
>> > - bsps/include/libchip/am29lv160.h
>> > @@ -104,4 +108,5 @@ source:
>> > - bsps/shared/dev/serial/z85c30_reg.c
>> > - bsps/shared/start/bootcard.c
>> > - bsps/shared/rtems-version.c
>> > +- bsps/shared/ofw/ofw.c
>> > type: build
>> > 2.17.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201102/21f69fae/attachment-0001.html>
