[PATCH v2 2/2] libtests/ofw01: Added a test for RTEMS OFW
G S Niteesh Babu niteesh.gs at gmail.com
Tue Nov 3 18:18:54 UTC 2020
Added a basic test for the implemented RTEMS OFW
API.
 spec/build/testsuites/libtests/grp.yml   |   2 +
 spec/build/testsuites/libtests/ofw01.yml |  21 +++
 testsuites/libtests/ofw01/init.c         | 187 +++++++++++++++++++++++
 testsuites/libtests/ofw01/ofw01.doc      |  29 ++++
 testsuites/libtests/ofw01/ofw01.scn      |   2 +
 testsuites/libtests/ofw01/some.c         |  72 +++++++++
 testsuites/libtests/ofw01/some.dts       |  76 +++++++++
 testsuites/libtests/ofw01/some.h         |  15 ++
 8 files changed, 404 insertions(+)
 create mode 100644 spec/build/testsuites/libtests/ofw01.yml
 create mode 100644 testsuites/libtests/ofw01/init.c
 create mode 100644 testsuites/libtests/ofw01/ofw01.doc
 create mode 100644 testsuites/libtests/ofw01/ofw01.scn
 create mode 100644 testsuites/libtests/ofw01/some.c
 create mode 100644 testsuites/libtests/ofw01/some.dts
 create mode 100644 testsuites/libtests/ofw01/some.h
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index b9ca014b0d..1aa136854a 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -316,6 +316,8 @@ links:
   uid: write
 - role: build-dependency
   uid: writev
+- role: build-dependency
+  uid: ofw01
 type: build
 use-after:
 - rtemstest
diff --git a/spec/build/testsuites/libtests/ofw01.yml b/spec/build/testsuites/libtests/ofw01.yml
new file mode 100644
index 0000000000..8517c58bad
--- /dev/null
+++ b/spec/build/testsuites/libtests/ofw01.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 Niteesh G S
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags:
+- -Wl,--wrap=bsp_fdt_get
+links: []
+source:
+- testsuites/libtests/ofw01/init.c
+- testsuites/libtests/ofw01/some.c
+stlib: []
+target: testsuites/libtests/ofw01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/libtests/ofw01/init.c b/testsuites/libtests/ofw01/init.c
index 0000000000..82ee5eb11f
--- /dev/null
+++ b/testsuites/libtests/ofw01/init.c
@@ -0,0 +1,187 @@
+ * Copyright (C) <2020> Niteesh G S <niteesh.gs at gmail.com>
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <tmacros.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <libfdt.h>
+#include <sys/endian.h>
+#include <ofw/ofw.h>
+#include <bsp/fdt.h>
+#include "some.h"
+#define BUF_SIZE 100
+const char rtems_test_name[] = "OFW 01";
+const void *__wrap_bsp_fdt_get(void);
+const void *__real_bsp_fdt_get(void);
+  if (some_bin != NULL) {
+    return &some_bin[0];
+  return __real_bsp_fdt_get();
+static void Init(rtems_task_argument arg)
+  int rv;
+  phandle_t d;
+  phandle_t l;
+  phandle_t t;
+  phandle_t c;
+  phandle_t a;
+  phandle_t b;
+  phandle_t q;
+  phandle_t root;
+  phandle_t temp;
+  uint32_t *arr;
+  char buf[BUF_SIZE];
+  char *bufp;
+  ssize_t buf_len;
+  rtems_ofw_memory_area reg;
+  rtems_ofw_memory_area regs[2];
+  rtems_vector_number intr;
+  rtems_vector_number intrs[2];
+  TEST_BEGIN();
+  buf_len = sizeof(buf);
+   * Cannot use fdt_path_offset to compare because
+   * the OF interface uses the offset from the ftdp
+   * to the node as phandle.
+  root = rtems_ofw_find_device("/");
+  rtems_test_assert(root == 56);
+  root = rtems_ofw_peer(0);
+  d = rtems_ofw_child(root);
+  temp = rtems_ofw_find_device("/d");
+  rtems_test_assert(d == temp);
+  temp = rtems_ofw_parent(d);
+  rtems_test_assert(root == temp);
+  rv = rtems_ofw_get_prop(d, "e", buf, buf_len);
+  rtems_test_assert(rv != -1);
+  rtems_test_assert(strcmp(buf, "f") == 0);
+  rv = rtems_ofw_has_prop(d, "g");
+  rtems_test_assert(rv == 1);
+  rv = rtems_ofw_get_prop_len(root, "model");
+  rtems_test_assert(rv == 2);
+  rv = rtems_ofw_next_prop(d, "e", buf, buf_len);
+  rtems_test_assert(strcmp(buf, "g") == 0);
+  l = rtems_ofw_find_device("/m at 1248");
+  rv = rtems_ofw_search_prop(l, "model", buf, buf_len);
+  rtems_test_assert(strcmp(buf, "c") == 0);
+  rv = rtems_ofw_get_prop_alloc(root, "compatible", (void **)&bufp);
+  rtems_test_assert(strcmp(bufp, "a,b") == 0);
+  rtems_ofw_free(bufp);
+  rv = rtems_ofw_get_prop_alloc_multi(l, "n", sizeof(*arr), (void **)&arr);
+  rtems_test_assert(arr[0] == htobe32(0xdeadbeef));
+  rtems_test_assert(arr[1] == htobe32(0x12345678));
+  rv = rtems_ofw_get_enc_prop_alloc_multi(l, "n", sizeof(*arr), (void **)&arr);
+  rtems_test_assert(arr[0] == 0xdeadbeef);
+  rtems_test_assert(arr[1] == 0x12345678);
+  t = rtems_ofw_find_device("/t");
+  rv = rtems_ofw_next_prop(t, "u", buf, buf_len);
+  rtems_test_assert(rv == 0);
+  a = rtems_ofw_find_device("/a");
+  rv = rtems_ofw_get_reg(a, &reg, sizeof(reg));
+  rtems_test_assert(reg.start == 0x1234);
+  rtems_test_assert(reg.size == 0x10);
+  b = rtems_ofw_find_device("/a/b");
+  rv = rtems_ofw_get_reg(b, &regs[0], sizeof(regs));
+  rtems_test_assert(regs[0].start == 0x8234);
+  rtems_test_assert(regs[0].size == 0x10);
+  rtems_test_assert(regs[1].start == 0xf468);
+  rtems_test_assert(regs[1].size == 0x10);
+  c = rtems_ofw_find_device("/c");
+  rv = rtems_ofw_get_reg(c, &reg, sizeof(reg));
+  rtems_test_assert(rv == -1);
+  rv = rtems_ofw_get_interrupts(a, &intr, sizeof(intr));
+  rtems_test_assert(intr == 0x1);
+  rv = rtems_ofw_get_interrupts(c, &intrs[0], sizeof(intrs));
+  rtems_test_assert(intrs[0] == 0x1);
+  rtems_test_assert(intrs[1] == 0x2);
+  q = rtems_ofw_find_device("/c/q");
+  rv = rtems_ofw_node_status(q);
+  rtems_test_assert(rv == true);
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/ofw01/ofw01.doc b/testsuites/libtests/ofw01/ofw01.doc
index 0000000000..6a28c847d8
--- /dev/null
+++ b/testsuites/libtests/ofw01/ofw01.doc
@@ -0,0 +1,29 @@
+This file describes the directives and concepts tested by this test set.
+test set name: openfirmware01
+directives:
+  - rtems_ofw_peer
+  - rtems_ofw_child
+  - rtems_ofw_parent
+  - rtems_ofw_get_prop_len
+  - rtems_ofw_get_enc_prop
+  - rtems_ofw_has_prop
+  - rtems_ofw_search_prop
+  - rtems_ofw_search_enc_prop
+  - rtems_ofw_get_prop_alloc
+  - rtems_ofw_get_prop_alloc_multi
+  - rtems_ofw_get_enc_prop_alloc
+  - rtems_ofw_get_enc_prop_alloc_multi
+  - rtems_ofw_free
+  - rtems_ofw_next_prop
+  - rtems_ofw_set_prop
+  - rtems_ofw_canon
+  - rtems_ofw_find_device
+  - rtems_ofw_package_to_path
+concepts:
+  - Ensure that some openfimware functions work as expected.
diff --git a/testsuites/libtests/ofw01/ofw01.scn b/testsuites/libtests/ofw01/ofw01.scn
index 0000000000..007675e374
--- /dev/null
+++ b/testsuites/libtests/ofw01/ofw01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST OFW 1 ***
+*** END OF TEST OFW 1 ***
\ No newline at end of file
diff --git a/testsuites/libtests/ofw01/some.c b/testsuites/libtests/ofw01/some.c
index 0000000000..91251e71b0
--- /dev/null
+++ b/testsuites/libtests/ofw01/some.c
@@ -0,0 +1,72 @@
+ *  Declarations for C structure representing binary file some.bin
+ *  WARNING: Automatically generated -- do not edit!
+#include <sys/types.h>
+const unsigned char some_bin[] = {
+  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x02, 0xcf, 0x00, 0x00, 0x00, 0x38,
+  0x00, 0x00, 0x02, 0x70, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5f,
+  0x00, 0x00, 0x02, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x00, 0x61, 0x2c, 0x62, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1a,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x26, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x09, 0x66, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x01,
+  0x68, 0x40, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x68, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61,
+  0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x30, 0x2f, 0x6d, 0x40, 0x31, 0x32, 0x34, 0x38, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6d, 0x40, 0x31, 0x32,
+  0x34, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x32, 0xde, 0xad, 0xbe, 0xef, 0x12, 0x34, 0x56, 0x78,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x34,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x6f, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x71, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x3e,
+  0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00,
+  0x61, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x12, 0x34, 0x00, 0x00, 0x00, 0x10,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x46,
+  0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x04, 0x00,
+  0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0xf0, 0x00, 0x00, 0x00, 0x10, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x4d,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x62, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x42,
+  0x00, 0x00, 0x12, 0x34, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x24, 0x68,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x46, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x4d, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x01,
+  0x71, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, 0x02, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x58,
+  0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09,
+  0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00, 0x23,
+  0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c, 0x6c,
+  0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c, 0x6c,
+  0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65, 0x6c, 0x00, 0x67, 0x00, 0x77, 0x00,
+  0x6b, 0x00, 0x6e, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00,
+  0x70, 0x00, 0x72, 0x00, 0x75, 0x00, 0x72, 0x65, 0x67, 0x00, 0x72, 0x61,
+  0x6e, 0x67, 0x65, 0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75,
+  0x70, 0x74, 0x73, 0x00, 0x73, 0x74, 0x61, 0x74, 0x75, 0x73, 0x00,
+const size_t some_bin_size = sizeof(some_bin);
diff --git a/testsuites/libtests/ofw01/some.dts b/testsuites/libtests/ofw01/some.dts
index 0000000000..6ed8aeb069
--- /dev/null
+++ b/testsuites/libtests/ofw01/some.dts
@@ -0,0 +1,76 @@
+ * Copyright (c) 2020 Niteesh G S <niteesh.gs at gmail.com>.  All rights reserved.
+ * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+/dts-v1/;
+	compatible = "a,b";
+	#address-cells = <1>;
+	#size-cells = <2>;
+	model = "c";
+	d {
+		e = "f";
+		g;
+		h at 0 {
+		h at 1 {
+			w = <123>;
+	aliases {
+		k = "/m at 1248";
+	l: m at 1248 {
+		n = <0xdeadbeef 0x12345678>;
+		o {
+			p;
+		q {
+			r = "s";
+	t {
+		u = <&l>;
+	a {
+		compatible = "a";
+		reg = <0x1234 0x10>;
+		ranges = <0x1000 0x8000 0x400 0x2000 0xF000 0x1000>;
+		interrupts = <0x1>;
+		b {
+			reg = <0x1234 0x10 0x2468 0x10>;
+	c {
+		ranges;
+		interrupts = <0x1 0x2 0x3>;
+		q {
+			reg = <0x4800 0x200>;
+			status = "okay";
diff --git a/testsuites/libtests/ofw01/some.h b/testsuites/libtests/ofw01/some.h
index 0000000000..e2e0135e68
--- /dev/null
+++ b/testsuites/libtests/ofw01/some.h
@@ -0,0 +1,15 @@
+ *  Extern declarations for C structure representing binary file some.bin
+#ifndef __some_h
+#define __some_h
+extern const unsigned char some_bin[];
+extern const size_t some_bin_size;
+#endif
2.17.1
