Out of tree builds with waf?
Sebastian Huber
Thu Nov 5 16:45:39 UTC 2020
On 05/11/2020 17:09, Joel Sherrill wrote:
> On Thu, Nov 5, 2020 at 10:04 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello,
> I tried to do an out of tree build with waf:
> ~/src/rtems/waf configure --rtems-config $PWD/config.ini --out
> $PWD/build --top $HOME/src/rtems
> This seems to work, however, I get a message like this (CWD /home
> ~/src/rtems/waf --out $PWD/build --top $HOME/src/rtems
> Waf: Entering directory
> `/home/EB/sebastian_h/src/rtems-source-builder/tmp/build'
> Waf: Leaving directory
> 'build' finished successfully (0.332s)
> `/home/EB/sebastian_h/src/rtems-source-builder/tmp/build/sparc/erc32'
> CWD /home/EB/sebastian_h/src/rtems-source-builder/tmp is not under
> /home/EB/sebastian_h/src/rtems, forcing --targets=* (run distclean?)
> 'build_sparc/erc32' finished successfully (0.438s)
> I this something to worry about? Are out of tree builds supported
> by waf?
> I hope they can be. Or at least the build directory name changed based
> on user input.
> For automated testing, I have been building multiple BSPs in parallel
> completely independently. I don't know a way to do this with waf.
If out of tree builds and a read-only source tree should be supported by
the build system, then this should be added to the goals in
eng/build-system.rst.
I need some support from a waf expert to add proper support for this to
the wscript.
Another open issue is the --target option which currently doesn't work.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
