[PATCH] build: Place cache file in build directory
Thu Nov 5 17:15:17 UTC 2020
On Thu, Nov 5, 2020 at 10:13 AM Sebastian Huber
> On 05/11/2020 18:00, Gedare Bloom wrote:
> > ok I think. the commit message confused me since the c4che was in the
> > 'build/' directory already, now you move to the directory in which the
> > build happens.
> > I guess this means if one builds in the source tree and doesn't
> > specify --out, they will get c4che in rtems.git source? This directory
> > should be added to gitignore then
> Previously, the cache file was placed in the source directory under
> "build/...". Now, it is placed in the build directory, which is "build"
> by default. So, if you don't use the --out option nothing changes.
Aha! Ok then, thanks
> embedded brains GmbH
> Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> Phone: +49-89-18 94 741 - 16
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
