Out of tree builds with waf?
Sebastian Huber
Thu Nov 5 17:27:59 UTC 2020
On 05/11/2020 18:22, Sebastian Huber wrote:
> On 05/11/2020 18:16, Andrew Butterfield wrote:
>> I'm not a waf expert, but might this section in their book help?
>> https://waf.io/book/#_fundamental_waf_commands
>> <https://waf.io/book/#_fundamental_waf_commands>
>> Can variables `top` and `out` in the example there be manipulated to
>> do want you want?
> Yes, the --top and --out options works somehow, but I get a warning
> like this:
> Waf: Entering directory
> `/home/EB/sebastian_h/src/rtems-source-builder/tmp/build/sparc/erc32'
> CWD /home/EB/sebastian_h/src/rtems-source-builder/tmp is not under
> /home/EB/sebastian_h/src/rtems, forcing --targets=* (run distclean?)
> Also the documentation says "Though Waf may be called from any folder
> containing a /wscript/ file,", so I am not sure if this is really
> supported what I am doing.
What works is something like this:
./waf configure --out $PWD/tmp/xxx/build
called from the source tree. However, this has some side-effects.
1. A .waf* directory is created in the source tree (this is an issue
with a read-only source tree).
2. Waf somehow remembers this configuration. You can call "./waf" to
build it. So, there must be some hidden state in the source tree. This
is not really an out of tree build. You cannot have multiple independent
build trees.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
