Out of tree builds with waf?
    Sebastian Huber
    Thu Nov  5 18:02:44 UTC 2020
On 05/11/2020 18:27, Sebastian Huber wrote:
> On 05/11/2020 18:22, Sebastian Huber wrote:
>> On 05/11/2020 18:16, Andrew Butterfield wrote:
>>>  I'm not a waf expert, but might this section in their book help?
>>> https://waf.io/book/#_fundamental_waf_commands
>>> <https://waf.io/book/#_fundamental_waf_commands>
>>> Can variables `top` and `out` in the example there be manipulated to
>>> do want you want?
>> Yes, the --top and --out options works somehow, but I get a warning
>> like this:
>> Waf: Entering directory
>> `/home/EB/sebastian_h/src/rtems-source-builder/tmp/build/sparc/erc32'
>> CWD /home/EB/sebastian_h/src/rtems-source-builder/tmp is not under
>> /home/EB/sebastian_h/src/rtems, forcing --targets=* (run distclean?)
>> Also the documentation says "Though Waf may be called from any folder
>> containing a /wscript/ file,", so I am not sure if this is really
>> supported what I am doing.
> What works is something like this:
> ./waf configure --out $PWD/tmp/xxx/build
> called from the source tree. However, this has some side-effects.
> 1. A .waf* directory is created in the source tree (this is an issue
> with a read-only source tree).
> 2. Waf somehow remembers this configuration. You can call "./waf" to
> build it. So, there must be some hidden state in the source tree. This
> is not really an out of tree build. You cannot have multiple
> independent build trees.
This happens if I use a read-only source tree:
~/tmp/out-of-tree > pwd
/home/EB/sebastian_h/tmp/out-of-tree
~/tmp/out-of-tree > ~/src/rtems/waf --top $HOME/src/rtems-read-only
--out $PWD/build configure --rtems-config $PWD/config.ini
Setting top to                           :
/home/EB/sebastian_h/src/rtems-read-only
Setting out to                           :
/home/EB/sebastian_h/tmp/out-of-tree/build
Configure board support package (BSP)    : sparc/erc32
Checking for program 'sparc-rtems6-gcc'  :
/opt/rtems/6/bin/sparc-rtems6-gcc
Checking for program 'sparc-rtems6-g++'  :
/opt/rtems/6/bin/sparc-rtems6-g++
Checking for program 'sparc-rtems6-ar'   : /opt/rtems/6/bin/sparc-rtems6-ar
Checking for program 'sparc-rtems6-ld'   : /opt/rtems/6/bin/sparc-rtems6-ld
Checking for program 'ar'                : /opt/rtems/6/bin/sparc-rtems6-ar
Checking for program 'g++, c++'          :
Checking for program 'gas, gcc'          :
Checking for program 'gcc, cc'           :
Checking for asm flags '-MMD'            : yes
Checking for c flags '-MMD'              : yes
Checking for cxx flags '-MMD'            : yes
Traceback (most recent call last):
   File
"/home/EB/sebastian_h/src/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Scripting.py",
line 119, in waf_entry_point
     run_commands()
   File
line 182, in run_commands
     ctx=run_command(cmd_name)
   File
line 173, in run_command
     ctx.execute()
   File
"/home/EB/sebastian_h/src/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Configure.py",
line 101, in execute
     env.store(os.path.join(Context.run_dir,Options.lockfile))
   File
"/home/EB/sebastian_h/src/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/ConfigSet.py",
line 146, in store
     Utils.writef(filename,''.join(buf))
   File
"/home/EB/sebastian_h/src/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Utils.py",
line 160, in writef
     with open(fname,m)as f:
IOError: [Errno 13] Permission denied:
'/home/EB/sebastian_h/src/rtems-read-only/.lock-waf_linux2_build'
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
