80 or 79 characters limit?
Christian Mauderer
oss at c-mauderer.de
Thu Nov 5 19:12:35 UTC 2020
Hello Joel and Sebastian,
On 05/11/2020 16:44, Joel Sherrill wrote:
> On Thu, Nov 5, 2020, 9:26 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello,
> I review currently the Coding Conventions. Should the 80 characters
> limit be really a 79 characters limit with the \n as the invisible 80th
> character?
> Yes.
> As old as this makes me feel, I remember printers which did an automatic
> linefeed and then the newline one if you hit column 80. So it really is
> 79 unfortunately.
I don't think printers with an automatic linefeed are a common use case
for reading the RTEMS source code nowadays. So that maybe isn't the best
reason for using 79 characters.
I would suggest to use the same convention that most coding styles use
which seems to be 80 characters:
https://en.wikipedia.org/wiki/Characters_per_line#In_programming
At least if there are no more recent examples for tools or editors where
79 is a benefit. 80 seems just feels a bit more natural.
By the way: If we count '\n': Should we count a tab '\t' as a single
character, as 2, as 4 or as 8 ones? What about the few Unicode
characters that slipped in over the years?
Best regards
Christian
> embedded brains GmbH
> Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> Phone: +49-89-18 94 741 - 16
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> devel mailing list
> devel at rtems.org
