[PATCH] eng: Move code formatting rules into one section
Sebastian Huber
Fri Nov 6 08:24:23 UTC 2020
Clarify the 80 character limit. Change the line continuation indent
level.
eng/coding-80cols.rst | 154 -----------------------------
eng/coding-conventions.rst | 26 -----
eng/coding-formatting.rst | 196 +++++++++++++++++++++++++++++++++++++
eng/coding.rst | 2 +-
4 files changed, 197 insertions(+), 181 deletions(-)
delete mode 100644 eng/coding-80cols.rst
create mode 100644 eng/coding-formatting.rst
diff --git a/eng/coding-80cols.rst b/eng/coding-80cols.rst
deleted file mode 100644
index 85b838a..0000000
--- a/eng/coding-80cols.rst
+++ /dev/null
@@ -1,154 +0,0 @@
-.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2018.
-.. COMMENT: RTEMS Foundation, The RTEMS Documentation Project
-Eighty Character Line Limit
-.. COMMENT: TBD - Convert the following to Rest and insert into this file
-.. COMMENT: TBD - https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line
- Code should look good for everyone under some standard width assumptions.
- Where a line wraps should be the same for anyone reading the code. For
- historical reasons, RTEMS uses 80 characters as the maximum width for each
- line of code.
-If you find yourself with code longer than 80 characters, first ask yourself
-whether the nesting level is too deep, names too long, compound expressions too
-complicated, or if some other guideline for improving readability can help to
-shrink the line length. Refactoring nested blocks into functions can help to
-alleviate code width problems while improving code readability. Making names
-descriptive yet terse can also improve readability. If absolutely necessary
-to have a long line, follow the rules on this page to break the line up to adhere
-to the 80 characters per line rule.
-Breaking long lines
-``if``, ``while``, and ``for`` loops have their condition expressions aligned
-and broken on separate lines. When the conditions have to be broken, none go on
-the first line with the ``if``, ``while``, or ``for`` statement, and none go on
-the last line with the closing parenthesis and (optional) curly brace. Long
-statements are broken up and indented at operators, with an operator always
-being the last token on a line. No blank spaces should be left at the end of
-any line. Here is an example with a ``for`` loop.
-.. code-block:: c
- for ( initialization = statement; a + really + long + statement + that + evaluates + to < a + boolean; another + statement++ ) {
- z = a + really + long + statement + that + needs + two + lines + gets + indented + four + more + spaces + on + the + second + and + subsequent + lines + and + broken + up + at + operators;
-Should be replaced with
-.. code-block:: c
- for (
- initialization = statement;
- a + really + long + statement + that + evaluates + to <
- a + boolean;
- another + statement++
- two + lines + gets + indented + four + more +
- spaces + on + the + second + and + subsequent +
- lines + and + broken + up + at + operators;
-Note that indentations should add 2 nesting levels (4 space characters, not tabs).
-Similarly,
-.. code-block:: c
- if ( this + that < those && this + these < that && this + those < these && this < those && those < that ) {
-should be broken up like
-.. code-block:: c
- if (
- this + that < those &&
- this + these < that &&
- this + those < these &&
- this < those &&
- those < that
-Note that each expression that resolves to a boolean goes on its own line.
-Where you place the boolean operator is a matter of choice.
-When a line is long because of a comment at the end, move the comment to
-just before the line, for example
-.. code-block:: c
- #define A_LONG_MACRO_NAME (AND + EXPANSION) /* Plus + a + really + long + comment */
-can be replaced with
-.. code-block:: c
- /* Plus + a + really + long + comment */
-C Preprocessor macros need to be broken up with some care, because the
-preprocessor does not understand that it should eat newline characters. So
-.. code-block:: c
- #define A_LONG_MACRO_NAME (AND + EXCESSIVELY + LONG + EXPANSION + WITH + LOTS + OF + EXTRA + STUFF + DEFINED)
-would become
-.. code-block:: c
- #define A_LONG_MACRO_NAME ( \
- AND + EXCESSIVELY + LONG + EXPANSION + WITH + LOTS + OF + EXTRA + STUFF + \
- DEFINED \
-Notice that each line is terminated by a backslash then the carriage return.
-The backslash tells the preprocessor to eat the newline. Of course, if you have
-such a long macro, you should consider not using a macro.
-Function declarations can be broken up at each argument, for example
-.. code-block:: c
- int this_is_a_function( int arg1, int arg2, int arg3, int arg4, int arg5, int arg6, int arg7, int arg8, int arg9 );
-would be broken up as
-.. code-block:: c
- int arg1,
- int arg2,
- int arg3,
- int arg4,
- int arg5,
- int arg6,
- int arg7,
- int arg8,
- int arg9
-Excessively long comments should be broken up at a word boundary or somewhere
-that makes sense, for example
-.. code-block:: c
- /* Excessively long comments should be broken up at a word boundary or somewhere that makes sense, for example */
-would be
-.. code-block:: c
- * somewhere that makes sense, for example */
-Note that multiline comments have a single asterisk aligned with the asterisk
-in the opening ``/*``. The closing ``*/`` should go at the end of the last
-line.
diff --git a/eng/coding-conventions.rst b/eng/coding-conventions.rst
index e34cd74..668a917 100644
--- a/eng/coding-conventions.rst
+++ b/eng/coding-conventions.rst
@@ -131,32 +131,6 @@ Language and Compiler
* Do not use the register keyword. It is deprecated since C++14.
-Formatting
-* Use spaces instead of tabs.
-* Use two spaces for indentation, four spaces for
- hanging indentation.
-* Adhere to a limit of `80 characters per line <https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line>`_..
-* Put function return types and names on one line if they fit.
-* Put function calls on one line if they fit.
-* No space between a function name or function-like macro and
- the opening parens.
-* Put braces on the same line as and one space after the
- conditional expression ends.
-* Put the opening brace of a function definition one line after
- the closing parenthesis of its prototype.
-* Put a single space inside and outside of each parenthesis
- of a conditional expression.
- * Exception: never put a space before a closing semi-colon.
-* Put a single space before and after ternary operators.
-* Put a single space before and after binary operators.
-* Put no space between unary operators (e.g. *, &, !, ~, ++, --)
- and their operands.
-* No spaces around dereferencing operators (-> and .).
-* Do not use more than one blank line in a row.
-* Do not use trailing whitespace at the end of a line.
Readability
diff --git a/eng/coding-formatting.rst b/eng/coding-formatting.rst
new file mode 100644
index 0000000..f606a60
--- /dev/null
+++ b/eng/coding-formatting.rst
@@ -0,0 +1,196 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2018.
+.. COMMENT: RTEMS Foundation, The RTEMS Documentation Project
+Formatting
+Rules
+* Adhere to the :ref:`EightyCharacterLineLimit`.
+* Use spaces instead of tabs.
+* Use two spaces for one indentation level.
+* Put function return types and names on one line if they fit.
+* Put function calls on one line if they fit.
+* No space between a function name or function-like macro and
+ the opening parenthesis.
+* Put braces on the same line as and one space after the
+ conditional expression ends.
+* Put the opening brace of a function definition one line after the closing
+ parenthesis of its prototype.
+* Put a single space inside and outside of each parenthesis of a conditional
+ expression. Exception: never put a space before a closing semi-colon.
+* Put a single space before and after ternary operators.
+* Put a single space before and after binary operators.
+* Put no space between unary operators (e.g. ``*``, ``&``, ``!``, ``~``, ``++``, ``--``)
+ and their operands.
+* No spaces around dereferencing operators (``->`` and ``.``).
+* Do not use more than one blank line in a row.
+* Do not use trailing white space at the end of a line.
+.. _EightyCharacterLineLimit:
+Eighty Character Line Limit
+Code should look good for everyone under some standard width assumptions.
+Where a line wraps should be the same for anyone reading the code. For
+historical reasons, RTEMS uses 80 characters as the maximum width for each line
+of code. The newline (``\n``) character terminating the line does not count
+for the 80 character limit.
+If you find yourself with code longer than 80 characters, first ask yourself
+whether the nesting level is too deep, names too long, compound expressions too
+complicated, or if some other guideline for improving readability can help to
+shrink the line length. Refactoring nested blocks into functions can help to
+alleviate code width problems while improving code readability. Making names
+descriptive yet terse can also improve readability. If absolutely necessary to
+have a long line, follow the rules on this page to break the line up to adhere
+to the 80 characters per line rule.
+Breaking Long Lines
+The ``if``, ``while``, and ``for`` control statements have their condition
+expressions aligned and broken on separate lines. When the conditions have to
+be broken, none go on the first line with the ``if``, ``while``, or ``for``
+statement, and none go on the last line with the closing parenthesis and the
+curly brace. Long statements are broken up and indented at operators, with an
+operator always being the last token on a line. No blank spaces should be left
+at the end of any line. The continuation of a broken line is indented by one
+level. Here is an example with a ``for`` loop.
+.. code-block:: c
+ for ( initialization = statement; a + really + longish + statement + that + evaluates + to < a + boolean; another + statement ) {
+ some_variable = a + really + longish + statement + that + needs + two + lines + gets + indented + four + more + spaces + on + the + second + and + subsequent + lines + and + broken + up + at + operators;
+Should be replaced with
+.. code-block:: c
+ for (
+ initialization = statement;
+ a + really + longish + statement + that + evaluates + to <
+ a + boolean;
+ another + statement
+Similarly,
+.. code-block:: c
+ if ( this + that < those && this + these < that && this + those < these && this < those && those < that ) {
+should be broken up like
+.. code-block:: c
+ if (
+ this + that < those &&
+ this + these < that &&
+ this + those < these &&
+ this < those &&
+ those < that
+Note that each expression that resolves to a boolean goes on its own line.
+Where you place the boolean operator is a matter of choice.
+When a line is long because of a comment at the end, move the comment to
+just before the line, for example
+.. code-block:: c
+ #define A_LONG_MACRO_NAME (AND + EXPANSION) /* Plus + a + really + long + comment */
+can be replaced with
+.. code-block:: c
+ /* Plus + a + really + long + comment */
+C Preprocessor macros need to be broken up with some care, because the
+preprocessor does not understand that it should eat newline characters. So
+.. code-block:: c
+ #define A_LONG_MACRO_NAME (AND + EXCESSIVELY + LONG + EXPANSION + WITH + LOTS + OF + EXTRA + STUFF + DEFINED)
+would become
+.. code-block:: c
+ #define A_LONG_MACRO_NAME ( \
+ AND + EXCESSIVELY + LONG + EXPANSION + WITH + LOTS + OF + EXTRA + STUFF + \
+ DEFINED \
+Notice that each line is terminated by a backslash.
+The backslash tells the preprocessor to eat the newline. Of course, if you have
+such a long macro, you should consider not using a macro.
+Function declarations can be broken up at each argument, for example
+.. code-block:: c
+ int this_is_a_function( int arg1, int arg2, int arg3, int arg4, int arg5, int arg6, int arg7, int arg8, int arg9 );
+would be broken up as
+.. code-block:: c
+ int arg1,
+ int arg2,
+ int arg3,
+ int arg4,
+ int arg5,
+ int arg6,
+ int arg7,
+ int arg8,
+ int arg9
+Excessively long comments should be broken up at a word boundary or somewhere
+that makes sense, for example
+.. code-block:: c
+ /* Excessively long comments should be broken up at a word boundary or somewhere that makes sense, for example */
+would be
+.. code-block:: c
+ * Excessively long comments should be broken up at a word boundary or
+ * somewhere that makes sense, for example.
+Note that multiline comments have a single asterisk aligned with the asterisk
+in the opening ``/*``. The closing ``*/`` should go at the end of the last
+line.
diff --git a/eng/coding.rst b/eng/coding.rst
index 6cba22a..692f9aa 100644
--- a/eng/coding.rst
+++ b/eng/coding.rst
@@ -12,7 +12,7 @@ TBD - Write introduction, re-order, identify missing content
.. toctree::
coding-conventions
- coding-80cols
+ coding-formatting
coding-deprecating
coding-doxygen
coding-file-hdr
2.26.2
