[PATCH rtems 7/8] bsp/atsam: Replace non-ASCII characters
Christian Mauderer
oss at c-mauderer.de
Sat Nov 7 13:23:52 UTC 2020
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
Note that this replacement is pure guess. It has been done using a
unicode converter tool that spit out the pTq. That is most likely a math
notation for some vector operation.
bsps/arm/atsam/contrib/libraries/libchip/source/aes.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsps/arm/atsam/contrib/libraries/libchip/source/aes.c b/bsps/arm/atsam/contrib/libraries/libchip/source/aes.c
index 010e7cf8d1..27f543218f 100644
--- a/bsps/arm/atsam/contrib/libraries/libchip/source/aes.c
+++ b/bsps/arm/atsam/contrib/libraries/libchip/source/aes.c
@@ -249,7 +249,7 @@ void AES_SetGcmHash(uint32_t *hash)
* \brief Get The four 32-bit Tag which contain the final 128-bit GCM
- * Authentication tag ¡°T¡± when GCM processing is complete.
+ * Authentication tag pTq when GCM processing is complete.
* \param tag point to the word of the tag.
void AES_GetGcmTag(uint32_t *tag)
2.29.2
