[PATCH rtems 3/8] bsps: Replace non-ASCII bullet points
Christian Mauderer
oss at c-mauderer.de
Sat Nov 7 13:23:48 UTC 2020
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
bsps/shared/grlib/can/occan.c | 4 ++--
bsps/shared/grlib/spw/grspw.c | 8 ++++----
2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/bsps/shared/grlib/can/occan.c b/bsps/shared/grlib/can/occan.c
index 59b4f234f6..84402b8809 100644
--- a/bsps/shared/grlib/can/occan.c
+++ b/bsps/shared/grlib/can/occan.c
@@ -855,8 +855,8 @@ static int pelican_start(occan_priv *priv){
#endif
/* core already in reset mode,
- * ¤ Exit reset mode
- * ¤ Enter Single/Dual mode filtering.
+ * * Exit reset mode
+ * * Enter Single/Dual mode filtering.
WRITE_REG(priv, &priv->regs->mode, (priv->single_mode << 3));
diff --git a/bsps/shared/grlib/spw/grspw.c b/bsps/shared/grlib/spw/grspw.c
index 2e1e8e90e9..1b50cc642f 100644
--- a/bsps/shared/grlib/spw/grspw.c
+++ b/bsps/shared/grlib/spw/grspw.c
@@ -1475,10 +1475,10 @@ static rtems_device_driver grspw_control(
/* Get timeout from userspace
* timeout:
- * ¤ -1 = Default timeout
- * ¤ less than -1 = forever
- * ¤ 0 = no wait, proceed if link is up
- * ¤ positive = specifies number of system clock ticks that
+ * * -1 = Default timeout
+ * * less than -1 = forever
+ * * 0 = no wait, proceed if link is up
+ * * positive = specifies number of system clock ticks that
* startup will wait for link to enter ready mode.
timeout = (int)ioarg->buffer;
2.29.2
