[PATCH rtems 2/8] bsps: Replace non-ASCII trademark symbol
Christian Mauderer oss at c-mauderer.de
Sat Nov 7 13:23:47 UTC 2020
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
 bsps/arm/atsam/contrib/libraries/libboard/include/gmii.h | 2 +-
 bsps/arm/lm3s69xx/start/bspstart.c                       | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/bsps/arm/atsam/contrib/libraries/libboard/include/gmii.h b/bsps/arm/atsam/contrib/libraries/libboard/include/gmii.h
index e346143452..e9dc31e1e4 100644
--- a/bsps/arm/atsam/contrib/libraries/libboard/include/gmii.h
+++ b/bsps/arm/atsam/contrib/libraries/libboard/include/gmii.h
@@ -52,7 +52,7 @@
 #define GMII_ECR         0x18  // Expanded Control Register
 #define GMII_ICSR        0x1B  // Interrupt Control/Status Register
 #define GMII_FC          0x1C  // Function Control
-#define GMII_LCSR        0x1D  // LinkMD® Control/Status Register
+#define GMII_LCSR        0x1D  // LinkMD(R) Control/Status Register
 #define GMII_PC1R        0x1E  // PHY Control 1 Register
 #define GMII_PC2R        0x1F  // PHY Control 2 Register
diff --git a/bsps/arm/lm3s69xx/start/bspstart.c b/bsps/arm/lm3s69xx/start/bspstart.c
index ea73b1e1c2..43b7b826bf 100644
--- a/bsps/arm/lm3s69xx/start/bspstart.c
+++ b/bsps/arm/lm3s69xx/start/bspstart.c
@@ -39,7 +39,7 @@ static void init_main_osc(void)
   syscon->rcc2 = rcc2;
-   As per a note in Stellaris® LM4F120H5QR Microcontroller Data
+   As per a note in Stellaris(R) LM4F120H5QR Microcontroller Data
    Sheet on page 219: "When transitioning the system clock
    configuration to use the MOSC as the fundamental clock source, the
    MOSCDIS bit must be set prior to reselecting the MOSC or an
2.29.2
