[PATCH] libtests/dl06: Add -lm
Sebastian Huber
Mon Nov 9 07:24:28 UTC 2020
On 09/11/2020 02:23, Chris Johns wrote:
> On 3/11/20 3:39 am, Sebastian Huber wrote:
>> There is probably something wrong with this test program. If it is compiled
>> without function/data sections, no optimization, and no linker garbage
>> collection, then there is an undefined reference to atan2() and tan().
> These symbols are referenced in the loaded module ...
> https://git.rtems.org/rtems/tree/testsuites/libtests/dl06/dl06-o2.c
> This test gets rtems-ld with the RAP format to collect the atan1 and tan code
> into the loaded module. They should not be present in the base image. The libm
> library is used because it is _not_ part of the standard libraries linked and is
> available everywhere.
>> Fix this issue by adding -lm.
> Is the error linking the base kernel image or the RAP loadable module?
> If it is the loadable module and this is how you add the libraries to be
> searched to the rtems-ld command then the fix is needed and there is no problem.
> If the error was in the base kernel image then I suggest something else is wrong
> because those symbols should not be present in the base image. If the build
> system can support options for just rtems-ld then adding it there would be good.
The error is in this command:
[4044/4050] Processing link:
build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-o1.o
build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-o2.o
build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-tar.o
build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/init.o
build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl-load.o
build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-sym.o ->
build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06.exe
08:21:03 runner ['/build/rtems/6/bin/arm-rtems6-gcc', '-qnolinkcmds',
'-T', 'linkcmds.realview_pbx_a9_qemu',
'/home/EB/sebastian_h/git-rtems-6/build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-o1.o',
'/home/EB/sebastian_h/git-rtems-6/build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-o2.o',
'/home/EB/sebastian_h/git-rtems-6/build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-tar.o',
'/home/EB/sebastian_h/git-rtems-6/build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/init.o',
'/home/EB/sebastian_h/git-rtems-6/build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl-load.o',
'/home/EB/sebastian_h/git-rtems-6/build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-sym.o',
'-o/home/EB/sebastian_h/git-rtems-6/build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06.exe',
'-Wl,--wrap=printf', '-Wl,--wrap=puts', '-L.', '-lrtemscpu',
'-lrtemsbsp', '-lrtemstest', '-qrtems', '-march=armv7-a', '-mthumb',
'-mfpu=neon', '-mfloat-abi=hard', '-mtune=cortex-a9',
'-L/home/EB/sebastian_h/git-rtems-6/bsps/arm/shared/start',
'-L/home/EB/sebastian_h/git-rtems-6/bsps/arm/realview-pbx-a9/start']
/build/rtems/6/lib/gcc/arm-rtems6/10.2.1/../../../../arm-rtems6/bin/ld:
/home/EB/sebastian_h/git-rtems-6/build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl06/dl06-o2.o:
in function `dl_o2_func2':
/home/EB/sebastian_h/git-rtems-6/testsuites/libtests/dl06/dl06-o2.c:31:
undefined reference to `atan2'
in function `dl_o2_func3':
/home/EB/sebastian_h/git-rtems-6/testsuites/libtests/dl06/dl06-o2.c:37:
undefined reference to `tan'
I used the following config.ini:
[arm/realview_pbx_a9_qemu]
BUILD_LIBTESTS = True
OPTIMIZATION_FLAGS = -O0 -g
LDFLAGS =
> More of a concern is no error. I wonder if the code is being inlined when there
> is FPU support. Maybe the test needs to create a library linking to it to be
> more robust?
Using these functions without -fno-builtin is not really robust.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
