[PATCH 03/11] rtems: Generate <rtems/rtems/config.h>
Sebastian Huber
Mon Nov 9 14:49:31 UTC 2020
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
cpukit/include/rtems/rtems/config.h | 305 +++++++++++++++++++++-------
1 file changed, 237 insertions(+), 68 deletions(-)
diff --git a/cpukit/include/rtems/rtems/config.h b/cpukit/include/rtems/rtems/config.h
index bd6b38a532..82102fb713 100644
--- a/cpukit/include/rtems/rtems/config.h
+++ b/cpukit/include/rtems/rtems/config.h
@@ -1,152 +1,321 @@
* @file
- * @ingroup ClassicConfig
+ * @brief This header file provides parts of the application configuration
+ * information API.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
- * This include file contains the table of user defined configuration
- * parameters specific for the RTEMS API.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
-/* COPYRIGHT (c) 1989-2013.
- * On-Line Applications Research Corporation (OAR).
+ * Do not manually edit this file. It is part of the RTEMS quality process
+ * and was automatically generated.
+ * If you find something that needs to be fixed or worded better please
+ * post a report to an RTEMS mailing list or raise a bug report:
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+/* Generated from spec:/rtems/config/if/header-2 */
#ifndef _RTEMS_RTEMS_CONFIG_H
#define _RTEMS_RTEMS_CONFIG_H
-#include <rtems/rtems/types.h>
+#include <stdbool.h>
+#include <stdint.h>
#ifdef __cplusplus
extern "C" {
#endif
- * @defgroup ClassicConfig Configuration
- * @ingroup RTEMSAPIClassic
- * This encapsulates functionality related to the application's configuration
- * of the Classic API including the maximum number of each class of objects.
+/* Generated from spec:/rtems/config/if/api-table */
- * The following records define the Configuration Table. The
- * information contained in this table is required in all
- * RTEMS systems, whether single or multiprocessor. This
- * table primarily defines the following:
+ * @ingroup RTEMSAPIConfig
+ * @brief This structure contains a summary of the Classic API configuration.
- * + required number of each object type
+ * Use rtems_configuration_get_rtems_api_configuration() to get the
+ * configuration table.
typedef struct {
- * This field contains the maximum number of Classic API
- * Tasks which are configured for this application.
+ * @brief This member contains the maximum number of Classic API Tasks
+ * configured for this application.
+ * See #CONFIGURE_MAXIMUM_TASKS.
- uint32_t maximum_tasks;
+ uint32_t maximum_tasks;
- * This field indicates whether Classic API notepads are
- * enabled or disabled.
+ * @brief This member is true, if the Classic API Notepads are enabled,
+ * otherwise it is false.
- bool notepads_enabled;
+ bool notepads_enabled;
- * Timers which are configured for this application.
+ * @brief This member contains the maximum number of Classic API Timers
+ * See #CONFIGURE_MAXIMUM_TIMERS.
- uint32_t maximum_timers;
+ uint32_t maximum_timers;
- * Semaphores which are configured for this application.
+ * @brief This member contains the maximum number of Classic API Semaphores
+ * See #CONFIGURE_MAXIMUM_SEMAPHORES.
- uint32_t maximum_semaphores;
+ uint32_t maximum_semaphores;
- * Message Queues which are configured for this application.
+ * @brief This member contains the maximum number of Classic API Message Queues
+ * See #CONFIGURE_MAXIMUM_MESSAGE_QUEUES.
- uint32_t maximum_message_queues;
+ uint32_t maximum_message_queues;
- * Partitions which are configured for this application.
+ * @brief This member contains the maximum number of Classic API Partitions
+ * See #CONFIGURE_MAXIMUM_PARTITIONS.
- uint32_t maximum_partitions;
+ uint32_t maximum_partitions;
- * Regions which are configured for this application.
+ * @brief This member contains the maximum number of Classic API Regions
+ * See #CONFIGURE_MAXIMUM_REGIONS.
- uint32_t maximum_regions;
+ uint32_t maximum_regions;
- * Dual Ported Memory Areas which are configured for this
- * application.
+ * @brief This member contains the maximum number of Classic API Dual-Ported
+ * Memories configured for this application.
+ * See #CONFIGURE_MAXIMUM_PORTS.
- uint32_t maximum_ports;
+ uint32_t maximum_ports;
- * Rate Monotonic Periods which are configured for this
- * application.
+ * @brief This member contains the maximum number of Classic API Rate Monotonic
+ * Periods configured for this application.
+ * See #CONFIGURE_MAXIMUM_PERIODS.
- uint32_t maximum_periods;
+ uint32_t maximum_periods;
- * Barriers which are configured for this application.
+ * @brief This member contains the maximum number of Classic API Barriers
+ * See #CONFIGURE_MAXIMUM_BARRIERS.
- uint32_t maximum_barriers;
+ uint32_t maximum_barriers;
- * This field contains the number of Classic API Initialization
+ * @brief This member contains the number of Classic API Initialization Tasks
+ * See #CONFIGURE_RTEMS_INIT_TASKS_TABLE.
- uint32_t number_of_initialization_tasks;
+ uint32_t number_of_initialization_tasks;
- * This field is the set of Classic API Initialization
+ * @brief This member contains the pointer to Classic API Initialization Tasks
+ * Table of this application.
const rtems_initialization_tasks_table *User_initialization_tasks_table;
} rtems_api_configuration_table;
+/* Generated from spec:/rtems/config/if/get-api-configuration */
+ * @brief Gets the Classic API Configuration Table of this application.
+ * @return Returns the pointer to the Classic API Configuration Table of this
+ * application.
+const rtems_api_configuration_table *
+rtems_configuration_get_rtems_api_configuration( void );
+/* Generated from spec:/rtems/config/if/get-maximum-barriers */
+ * @brief Gets the maximum number of Classic API Barriers configured for this
+ * application.
+ * @return Returns the maximum number of Classic API Barriers configured for
+ * this application.
uint32_t rtems_configuration_get_maximum_barriers( void );
+/* Generated from spec:/rtems/config/if/get-maximum-message-queues */
+ * @brief Gets the maximum number of Classic API Message Queues configured for
+ * @return Returns the maximum number of Classic API Message Queues configured
+ * for this application.
uint32_t rtems_configuration_get_maximum_message_queues( void );
+/* Generated from spec:/rtems/config/if/get-maximum-partitions */
+ * @brief Gets the maximum number of Classic API Partitions configured for this
+ * application.
+ * @return Returns the maximum number of Classic API Partitions configured for
uint32_t rtems_configuration_get_maximum_partitions( void );
+/* Generated from spec:/rtems/config/if/get-maximum-periods */
+ * @brief Gets the maximum number of Classic API Rate Monotonic Periods
+ * @return Returns the maximum number of Classic API Rate Monotonic Periods
uint32_t rtems_configuration_get_maximum_periods( void );
+/* Generated from spec:/rtems/config/if/get-maximum-ports */
+ * @brief Gets the maximum number of Classic API Dual-Ported Memories
+ * @return Returns the maximum number of Classic API Dual-Ported Memories
uint32_t rtems_configuration_get_maximum_ports( void );
+/* Generated from spec:/rtems/config/if/get-maximum-regions */
+ * @brief Gets the maximum number of Classic API Regions configured for this
+ * application.
+ * @return Returns the maximum number of Classic API Regions configured for
uint32_t rtems_configuration_get_maximum_regions( void );
+/* Generated from spec:/rtems/config/if/get-maximum-semaphores */
+ * @brief Gets the maximum number of Classic API Semaphores configured for this
+ * application.
+ * @return Returns the maximum number of Classic API Semaphores configured for
uint32_t rtems_configuration_get_maximum_semaphores( void );
-uint32_t rtems_configuration_get_maximum_timers( void );
+/* Generated from spec:/rtems/config/if/get-maximum-tasks */
+ * @brief Gets the maximum number of Classic API Tasks configured for this
+ * application.
+ * @return Returns the maximum number of Classic API Tasks configured for this
+ * application.
uint32_t rtems_configuration_get_maximum_tasks( void );
-const rtems_api_configuration_table *
-rtems_configuration_get_rtems_api_configuration( void );
+/* Generated from spec:/rtems/config/if/get-maximum-timers */
+ * @brief Gets the maximum number of Classic API Timers configured for this
+ * application.
+ * @return Returns the maximum number of Classic API Timers configured for this
+ * application.
+uint32_t rtems_configuration_get_maximum_timers( void );
#ifdef __cplusplus
#endif
-#endif
-/* end of include file */
+#endif /* _RTEMS_RTEMS_CONFIG_H */
2.26.2
