[PATCH 08/11] rtems: Generate <rtems/rtems/attr.h>
Mon Nov 9 14:49:36 UTC 2020
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
 cpukit/include/rtems/rtems/attr.h | 312 +++++++++++++++++++++---------
 1 file changed, 223 insertions(+), 89 deletions(-)
diff --git a/cpukit/include/rtems/rtems/attr.h b/cpukit/include/rtems/rtems/attr.h
index 74ed96fdba..c0bc990c45 100644
--- a/cpukit/include/rtems/rtems/attr.h
+++ b/cpukit/include/rtems/rtems/attr.h
@@ -1,188 +1,322 @@
  * @file
- * @ingroup ClassicAttributes
+ * @brief This header file provides Classic API directive attributes.
+ * Copyright (C) 2014, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2008 On-Line Applications Research Corporation (OAR)
+ * are met:
- * This include file contains all information about the Object Attributes
- * Handler.
-/* COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
+ * Do not manually edit this file.  It is part of the RTEMS quality process
+ * and was automatically generated.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * If you find something that needs to be fixed or worded better please
+ * post a report to an RTEMS mailing list or raise a bug report:
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+/* Generated from spec:/rtems/attr/if/header */
 #ifndef _RTEMS_RTEMS_ATTR_H
 #define _RTEMS_RTEMS_ATTR_H
-#include <rtems/score/basedefs.h>
+#include <stdint.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
+/* Generated from spec:/rtems/attr/if/group */
- *  @defgroup ClassicAttributes Attributes
+ * @defgroup RTEMSAPIClassicAttr Directive Attributes
- *  @ingroup RTEMSAPIClassic
+ * @ingroup RTEMSAPIClassic
- *  This encapsulates functionality which defines and manages the
- *  set of Classic API object attributes.
+ * @brief This group contains the Classic API directive attributes.
+/* Generated from spec:/rtems/attr/if/application-task */
- *  This defines the type used to contain Classic API attributes.  These
- *  are primarily used when creating objects.
+ * @ingroup RTEMSAPIClassicAttr
+ * @brief This attribute constant indicates that the Classic API task created
+ *   by rtems_task_create() or rtems_task_construct() shall be an application
+ *   task.
-typedef uint32_t   rtems_attribute;
-/** This is the default value for an attribute set. */
+#define RTEMS_APPLICATION_TASK 0x00000000
-#define RTEMS_DEFAULT_ATTRIBUTES  0x00000000
+/* Generated from spec:/rtems/attr/if/attribute */
- *  This is the attribute constant to indicate local resource.
+ * @brief This type represents Classic API attributes.
+ * Attributes are primarily used when creating objects.
-#define RTEMS_LOCAL               0x00000000
+typedef uint32_t rtems_attribute;
+/* Generated from spec:/rtems/attr/if/barrier-automatic-release */
- *  This is the attribute constant to indicate global resource.
+ * @brief This attribute constant indicates that the Classic API barrier
+ *   created by rtems_barrier_create() shall use the automatic release
+ *   protocol.
-#define RTEMS_GLOBAL              0x00000002
+#define RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000200
+/* Generated from spec:/rtems/attr/if/barrier-manual-release */
- *  This is the attribute constant which reflects that blocking
- *  tasks will be managed using FIFO discipline.
+ *   created by rtems_barrier_create() shall use the manual release protocol.
-#define RTEMS_FIFO                0x00000000
+#define RTEMS_BARRIER_MANUAL_RELEASE 0x00000000
+/* Generated from spec:/rtems/attr/if/binary-semaphore */
- *  tasks will be managed using task priority discipline.
+ * @brief This attribute constant indicates that the Classic API semaphore
+ *   created by rtems_semaphore_create() shall be a proper binary semaphore or
+ *   mutex.
-#define RTEMS_PRIORITY            0x00000004
+#define RTEMS_BINARY_SEMAPHORE 0x00000010
-/******************** RTEMS Task Specific Attributes *********************/
+/* Generated from spec:/rtems/attr/if/counting-semaphore */
- *  This attribute constant indicates that the task will not use the
- *  floating point hardware.  If the architecture permits it, then
- *  the FPU will be disabled when the task is executing.
+ *   created by rtems_semaphore_create() shall be a counting semaphore.
-#define RTEMS_NO_FLOATING_POINT   0x00000000
+#define RTEMS_COUNTING_SEMAPHORE 0x00000000
+/* Generated from spec:/rtems/attr/if/default */
- *  This attribute constant indicates that the task will use the
- *  floating point hardware.  There will be a floating point
- *  context associated with this task.
+ * @brief This attribute constant represents the default attribute set.
-#define RTEMS_FLOATING_POINT      0x00000001
+#define RTEMS_DEFAULT_ATTRIBUTES 0x00000000
-/***************** RTEMS Semaphore Specific Attributes ********************/
+/* Generated from spec:/rtems/attr/if/fifo */
- *  This is the mask for the attribute bits associated with the
- *  Classic API Semaphore Manager.
+ * @brief This attribute constant indicates that the Classic API object shall
+ *   manage blocking tasks using the FIFO discipline.
-#define RTEMS_SEMAPHORE_CLASS         0x00000030
+#define RTEMS_FIFO 0x00000000
+/* Generated from spec:/rtems/attr/if/floating-point */
- *  This attribute constant indicates that the Classic API Semaphore
- *  instance created will be a counting semaphore.
+ *   by rtems_task_create() or rtems_task_construct() shall be able to use the
+ *   floating point hardware.
+ * On some architectures, there will be a floating point context associated
+ * with this task.
-#define RTEMS_COUNTING_SEMAPHORE      0x00000000
+#define RTEMS_FLOATING_POINT 0x00000001
+/* Generated from spec:/rtems/attr/if/global */
- *  instance created will be a proper binary semaphore or mutex.
+ *   be a global resource in a multiprocessing network.
+ * This attribute does not refer to SMP systems.
-#define RTEMS_BINARY_SEMAPHORE        0x00000010
+#define RTEMS_GLOBAL 0x00000002
+/* Generated from spec:/rtems/attr/if/inherit-priority */
- *  instance created will be a simple binary semaphore.
+ *   created by rtems_semaphore_create() shall use the Priority Inheritance
+ *   Protocol.
+ * The semaphore shall be a binary semaphore (#RTEMS_BINARY_SEMAPHORE).
-#define RTEMS_SIMPLE_BINARY_SEMAPHORE 0x00000020
+#define RTEMS_INHERIT_PRIORITY 0x00000040
+/* Generated from spec:/rtems/attr/if/local */
- *  instance created will NOT use the Priority Inheritance Protocol.
+ *   be a local resource in a multiprocessing network.
-#define RTEMS_NO_INHERIT_PRIORITY     0x00000000
+#define RTEMS_LOCAL 0x00000000
+/* Generated from spec:/rtems/attr/if/multiprocessor-resource-sharing */
- *  instance created will use the Priority Inheritance Protocol.
+ *   created by rtems_semaphore_create() shall use the Multiprocessor Resource
+ *   Sharing Protocol.
- *  @note The semaphore instance must be a binary semaphore.
-#define RTEMS_INHERIT_PRIORITY        0x00000040
+#define RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100
+/* Generated from spec:/rtems/attr/if/no-floating-point */
- *  instance created will NOT use the Priority Ceiling Protocol.
+ *   by rtems_task_create() or rtems_task_construct() will not use the floating
+ *   point hardware.
+ * If the architecture permits it, then the FPU will be disabled when the task
+ * is executing.
-#define RTEMS_NO_PRIORITY_CEILING     0x00000000
+#define RTEMS_NO_FLOATING_POINT 0x00000000
+/* Generated from spec:/rtems/attr/if/no-inherit-priority */
- *  instance created will use the Priority Ceiling Protocol.
+ *   created by rtems_semaphore_create() will not use the Priority Inheritance
+ *   Protocol.
-#define RTEMS_PRIORITY_CEILING        0x00000080
+#define RTEMS_NO_INHERIT_PRIORITY 0x00000000
+/* Generated from spec:/rtems/attr/if/no-multiprocessor-resource-sharing */
- *  This attribute constant indicates that the Classic API Semaphore instance
- *  created will NOT use the Multiprocessor Resource Sharing Protocol.
+ *   created by rtems_semaphore_create() will not use the Multiprocessor
+ *   Resource Sharing Protocol.
 #define RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING 0x00000000
+/* Generated from spec:/rtems/attr/if/no-priority-ceiling */
- *  created will use the Multiprocessor Resource Sharing Protocol.
+ *   created by rtems_semaphore_create() will not use the Priority Ceiling
+ *   Protocol.
-#define RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100
+#define RTEMS_NO_PRIORITY_CEILING 0x00000000
-/******************** RTEMS Barrier Specific Attributes ********************/
+/* Generated from spec:/rtems/attr/if/priority */
- *  This attribute constant indicates that the Classic API Barrier
- *  instance created will use an automatic release protocol.
+ *   manage blocking tasks using the task priority discipline.
-#define RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000200
+#define RTEMS_PRIORITY 0x00000004
+/* Generated from spec:/rtems/attr/if/priority-ceiling */
- *  instance created will use the manual release protocol.
+ *   created by rtems_semaphore_create() shall use the Priority Ceiling
+ *   Protocol.
-#define RTEMS_BARRIER_MANUAL_RELEASE    0x00000000
+#define RTEMS_PRIORITY_CEILING 0x00000080
-/**************** RTEMS Internal Task Specific Attributes ****************/
+/* Generated from spec:/rtems/attr/if/semaphore-class */
- *  This attribute constant indicates that the task was created
- *  by the application using normal Classic API methods.
+ * @brief This attribute constant represents the mask of bits associated with
+ *   the Classic API semaphore classes #RTEMS_BINARY_SEMAPHORE,
+ *   #RTEMS_COUNTING_SEMAPHORE, and #RTEMS_SIMPLE_BINARY_SEMAPHORE.
-#define RTEMS_APPLICATION_TASK        0x00000000
+#define RTEMS_SEMAPHORE_CLASS 0x00000030
+/* Generated from spec:/rtems/attr/if/simple-binary-semaphore */
- *  by RTEMS as a support task.
+ *   created by rtems_semaphore_create() shall be a simple binary semaphore.
-#define RTEMS_SYSTEM_TASK             0x00008000
+#define RTEMS_SIMPLE_BINARY_SEMAPHORE 0x00000020
+/* Generated from spec:/rtems/attr/if/system-task */
+ *   by rtems_task_create() or rtems_task_construct() shall be a system task.
+#define RTEMS_SYSTEM_TASK 0x00008000
 #ifdef __cplusplus
 #endif
-#endif
-/* end of include file */
+#endif /* _RTEMS_RTEMS_ATTR_H */
2.26.2
