[PATCH 10/11] rtems: Generate <rtems/rtems/part.h>
Sebastian Huber
Mon Nov 9 14:49:38 UTC 2020
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
cpukit/include/rtems/rtems/part.h | 397 ++++++++++++++++++++++++------
1 file changed, 317 insertions(+), 80 deletions(-)
diff --git a/cpukit/include/rtems/rtems/part.h b/cpukit/include/rtems/rtems/part.h
index a3c3128a00..b7f9b944a6 100644
--- a/cpukit/include/rtems/rtems/part.h
+++ b/cpukit/include/rtems/rtems/part.h
@@ -1,41 +1,85 @@
* @file
- * @ingroup ClassicPart
+ * @ingroup RTEMSAPIClassicPart
+ * @brief This header file provides the Partition Manager API.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * @brief Classic Partition Manager API
-/* COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
+ * Do not manually edit this file. It is part of the RTEMS quality process
+ * and was automatically generated.
+ * If you find something that needs to be fixed or worded better please
+ * post a report to an RTEMS mailing list or raise a bug report:
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+/* Generated from spec:/rtems/part/if/header */
#ifndef _RTEMS_RTEMS_PART_H
#define _RTEMS_RTEMS_PART_H
+#include <stddef.h>
+#include <stdint.h>
#include <rtems/rtems/attr.h>
+#include <rtems/score/cpu.h>
#ifdef __cplusplus
extern "C" {
#endif
+/* Generated from spec:/rtems/part/if/group */
- * @defgroup ClassicPart Partitions
+ * @defgroup RTEMSAPIClassicPart Partition Manager
- * @ingroup RTEMSAPIClassic
- * This encapsulates functionality related to the
- * Classic API Partition Manager.
+ * @brief The Partition Manager provides facilities to dynamically allocate
+ * memory in fixed-size units.
+/* Generated from spec:/rtems/part/if/alignment */
* @brief This constant defines the minimum alignment of a partition buffer in
* bytes.
@@ -44,103 +88,296 @@ extern "C" {
#define RTEMS_PARTITION_ALIGNMENT CPU_SIZEOF_POINTER
+/* Generated from spec:/rtems/part/if/create */
- * @brief RTEMS Partition Create
+ * @brief Creates a partition.
+ * This directive creates a partition of fixed size buffers from a physically
+ * contiguous memory space which starts at ``starting_address`` and is
+ * ``length`` bytes in size. Each allocated buffer is to be of ``buffer_size``
+ * in bytes. The assigned partition identifier is returned in ``id``. This
+ * partition identifier is used to access the partition with other partition
+ * related directives.
+ * The **attribute set** specified in ``attribute_set`` is built through a
+ * *bitwise or* of the attribute constants described below. Attributes not
+ * mentioned below are not evaluated by this directive and have no effect.
+ * The partition can have **local** or **global** scope in a multiprocessing
+ * network (this attribute does not refer to SMP systems).
+ * * A **local** scope is the default and can be emphasized through the use of
+ * the #RTEMS_LOCAL attribute. A local partition can be only used by the
+ * node which created it.
+ * * A **global** scope is established if the #RTEMS_GLOBAL attribute is set.
+ * The memory space used for the partition must reside in shared memory.
+ * Setting the global attribute in a single node system has no effect.
+ * This directive may cause the calling task to be preempted due to an obtain
+ * and release of the object allocator mutex.
+ * The partition buffer area specified by the ``starting_address`` must be
+ * properly aligned. It must be possible to directly store target architecture
+ * pointers and also the user data. For example, if the user data contains
+ * some long double or vector data types, the partition buffer area and the
+ * buffer size must take the alignment of these types into account which is
+ * usually larger than the pointer alignment. A cache line alignment may be
+ * also a factor. Use #RTEMS_PARTITION_ALIGNMENT to specify the minimum
+ * alignment of a partition buffer type.
+ * The ``buffer_size`` parameter must be an integral multiple of the pointer
+ * size on the target architecture. Additionally, ``buffer_size`` must be
+ * large enough to hold two pointers on the target architecture. This is
+ * required for RTEMS to manage the buffers when they are free.
+ * For control and maintenance of the partition, RTEMS allocates a PTCB from
+ * the local PTCB free pool and initializes it. Memory from the partition
+ * buffer area is not used by RTEMS to store the PTCB.
+ * The PTCB for a global partition is allocated on the local node. Partitions
+ * should not be made global unless remote tasks must interact with the
+ * partition. This is to avoid the overhead incurred by the creation of a
+ * global partition. When a global partition is created, the partition's name
+ * and identifier must be transmitted to every node in the system for insertion
+ * in the local copy of the global object table.
- * Partition Manager
+ * The total number of global objects, including partitions, is limited by the
+ * value of the #CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS application configuration
+ * option.
- * This routine implements the rtems_partition_create directive. The
- * partition will have the name name. The memory area managed by
- * the partition is of length bytes and starts at starting_address.
- * The memory area will be divided into as many buffers of
- * buffer_size bytes as possible. The attribute_set determines if
- * the partition is global or local. It returns the id of the
- * created partition in ID.
+ * @param name is the name of the partition.
+ * @param starting_address is the starting address of the buffer area used by
+ * the partition.
+ * @param length is the length in bytes of the buffer area used by the
+ * partition.
+ * @param buffer_size is the size in bytes of a buffer managed by the
+ * partition.
+ * @param attribute_set is the attribute set of the partition.
+ * @param id is the pointer to an object identifier variable. The identifier
+ * of the created partition object will be stored in this variable, in case
+ * of a successful operation.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_INVALID_NAME The partition name was invalid.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``id`` parameter was NULL.
+ * @retval ::RTEMS_INVALID_SIZE The ``length`` parameter was 0.
+ * @retval ::RTEMS_INVALID_SIZE The ``buffer_size`` parameter was 0.
+ * @retval ::RTEMS_INVALID_SIZE The ``length`` parameter was less than the
+ * ``buffer_size`` parameter.
+ * @retval ::RTEMS_INVALID_SIZE The ``buffer_size`` parameter was not an
+ * integral multiple of the pointer size.
+ * @retval ::RTEMS_INVALID_SIZE The ``buffer_size`` parameter was less than two
+ * times the pointer size.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``starting_address`` parameter was not
+ * on a pointer size boundary.
+ * @retval ::RTEMS_TOO_MANY There was no inactive object available to create a
+ * new partition. The number of partitions available to the application is
+ * configured through the #CONFIGURE_MAXIMUM_PARTITIONS configuration option.
rtems_status_code rtems_partition_create(
- rtems_name name,
- void *starting_address,
- uintptr_t length,
- size_t buffer_size,
- rtems_attribute attribute_set,
- rtems_id *id
+ rtems_name name,
+ void *starting_address,
+ uintptr_t length,
+ size_t buffer_size,
+ rtems_attribute attribute_set,
+ rtems_id *id
+/* Generated from spec:/rtems/part/if/ident */
- * @brief RTEMS Partition Ident
- * This routine implements the rtems_partition_ident directive.
- * This directive returns the partition ID associated with name.
- * If more than one partition is named name, then the partition
- * to which the ID belongs is arbitrary. node indicates the
- * extent of the search for the ID of the partition named name.
- * The search can be limited to a particular node or allowed to
- * encompass all nodes.
- * @param[in] name is the user defined partition name
- * @param[in] node is(are) the node(s) to be searched
- * @param[in] id is the pointer to partition id
- * @retval RTEMS_SUCCESSFUL if successful or error code if unsuccessful and
- * *id filled in with the partition id
+ * @brief Identifies a partition by the object name.
+ * This directive obtains a partition identifier associated with the partition
+ * name specified in ``name``.
+ * The node to search is specified in ``node``. It shall be
+ * * a valid node number,
+ * * the constant #RTEMS_SEARCH_ALL_NODES to search in all nodes,
+ * * the constant #RTEMS_SEARCH_LOCAL_NODE to search in the local node only, or
+ * * the constant #RTEMS_SEARCH_OTHER_NODES to search in all nodes except the
+ * local node.
+ * If the partition name is not unique, then the partition identifier will
+ * match the first partition with that name in the search order. However, this
+ * partition identifier is not guaranteed to correspond to the desired
+ * partition. The partition identifier is used with other partition related
+ * directives to access the partition.
+ * If node is #RTEMS_SEARCH_ALL_NODES, all nodes are searched with the local
+ * node being searched first. All other nodes are searched with the lowest
+ * numbered node searched first.
+ * If node is a valid node number which does not represent the local node, then
+ * only the partitions exported by the designated node are searched.
+ * This directive does not generate activity on remote nodes. It accesses only
+ * the local copy of the global object table.
+ * @param name is the object name to look up.
+ * @param node is the node or node set to search for a matching object.
+ * @param[out] id is the pointer to an object identifier variable. The object
+ * identifier of an object with the specified name will be stored in this
+ * variable, in case of a successful operation.
+ * @retval ::RTEMS_INVALID_ADDRESS The id parameter was NULL.
+ * @retval ::RTEMS_INVALID_NAME The name parameter was 0.
+ * @retval ::RTEMS_INVALID_NAME There was no object with the specified name on
+ * the specified nodes.
+ * @retval ::RTEMS_INVALID_NODE In multiprocessing configurations, the
+ * specified node was invalid.
rtems_status_code rtems_partition_ident(
- rtems_name name,
- uint32_t node,
- rtems_id *id
+ rtems_name name,
+ uint32_t node,
+ rtems_id *id
+/* Generated from spec:/rtems/part/if/delete */
- * @brief RTEMS Delete Partition
+ * @brief Deletes the partition.
+ * This directive deletes the partition specified by the id parameter. The
+ * partition cannot be deleted if any of its buffers are still allocated. The
+ * PTCB for the deleted partition is reclaimed by RTEMS.
+ * The calling task does not have to be the task that created the partition.
+ * Any local task that knows the partition identifier can delete the partition.
+ * When a global partition is deleted, the partition identifier must be
+ * transmitted to every node in the system for deletion from the local copy of
+ * the global object table.
- * This routine implements the rtems_partition_delete directive. The
- * partition indicated by ID is deleted, provided that none of its buffers
- * are still allocated.
+ * The partition must reside on the local node, even if the partition was
+ * created with the #RTEMS_GLOBAL attribute.
- * @param[in] id is the partition id
+ * @param id is the partition identifier.
- * @retval This method returns RTEMS_SUCCESSFUL if there was not an
- * error. Otherwise, a status code is returned indicating the
- * source of the error.
+ * @retval ::RTEMS_INVALID_ID There was no partition with the specified
+ * identifier.
+ * @retval ::RTEMS_ILLEGAL_ON_REMOTE_OBJECT The partition resided on a remote
+ * node.
+ * @retval ::RTEMS_RESOURCE_IN_USE There were buffers of the partition still in
+ * use.
-rtems_status_code rtems_partition_delete(
- rtems_id id
+rtems_status_code rtems_partition_delete( rtems_id id );
+/* Generated from spec:/rtems/part/if/get-buffer */
- * @brief RTEMS Get Partition Buffer
- * This routine implements the rtems_partition_get_buffer directive. It
- * attempts to allocate a buffer from the partition associated with ID.
- * If a buffer is allocated, its address is returned in buffer.
+ * @brief Tries to get a buffer from the partition.
- * @param[out] buffer is the pointer to buffer address
+ * This directive allows a buffer to be obtained from the partition specified
+ * in the ``id`` parameter. The address of the allocated buffer is returned
+ * through the ``buffer`` parameter.
+ * This directive will not cause the running task to be preempted.
+ * The buffer start alignment is determined by the memory area and buffer size
+ * used to create the partition.
+ * A task cannot wait on a buffer to become available.
+ * Getting a buffer from a global partition which does not reside on the local
+ * node will generate a request telling the remote node to allocate a buffer
+ * from the partition.
+ * @param[out] buffer is the pointer to a buffer pointer variable. The pointer
+ * to the allocated buffer will be stored in this variable, in case of a
+ * successful operation.
+ * identifier.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``buffer`` parameter was NULL.
+ * @retval ::RTEMS_UNSATISFIED There was no free buffer available to allocate
+ * and return.
-rtems_status_code rtems_partition_get_buffer(
- rtems_id id,
- void **buffer
+rtems_status_code rtems_partition_get_buffer( rtems_id id, void **buffer );
+/* Generated from spec:/rtems/part/if/return-buffer */
- * @brief rtems_partition_return_buffer
+ * @brief Returns the buffer to the partition.
- * This routine implements the rtems_partition_return_buffer directive. It
- * frees the buffer to the partition associated with ID. The buffer must
- * have been previously allocated from the same partition.
+ * This directive returns the buffer specified by ``buffer`` to the partition
+ * specified by ``id``.
+ * Returning a buffer to a global partition which does not reside on the local
+ * node will generate a request telling the remote node to return the buffer to
+ * the partition.
+ * Returning a buffer multiple times is an error. It will corrupt the internal
+ * state of the partition.
+ * @param buffer is the pointer to the buffer to return.
+ * identifier.
+ * @retval ::RTEMS_INVALID_ADDRESS The buffer referenced by ``buffer`` was not
+ * in the partition.
-rtems_status_code rtems_partition_return_buffer(
- rtems_id id,
- void *buffer
+rtems_status_code rtems_partition_return_buffer( rtems_id id, void *buffer );
#ifdef __cplusplus
#endif
-#endif
-/* end of include file */
+#endif /* _RTEMS_RTEMS_PART_H */
2.26.2
