[PATCH 00/11] Generate some header files
Chris Johns
chrisj at rtems.org
Mon Nov 9 23:05:54 UTC 2020
On 10/11/20 1:49 am, Sebastian Huber wrote:
> This patch set replaces some hand written header files of the Classic
> API with header files generated from specification items. The main
> parts are the Event Manager and the Partition Manager. The patches for
> the RTEMS Classic API Guide of these two managers is available here:
> https://lists.rtems.org/pipermail/devel/2020-November/063122.html
> I tried to follow the updated Doxygen guidelines:
> https://lists.rtems.org/pipermail/devel/2020-November/063119.html
> Sebastian Huber (11):
> rtems: Include missing header file
> rtems: Generate <rtems/config.h>
> rtems: Generate <rtems/rtems/config.h>
> rtems: Generate <rtems/rtems/status.h>
> rtems: Generate <rtems/rtems/modes.h>
> rtems: Generate <rtems/rtems/options.h>
> rtems: Generate <rtems/rtems/types.h>
> rtems: Generate <rtems/rtems/attr.h>
> rtems: Generate <rtems/rtems/event.h>
> rtems: Generate <rtems/rtems/part.h>
> rtems: Generate <rtems/score/basedefs.h>
Do these files need something that indicates they are generated and part of the
RTEMS Quality Process (RQP?)?
I could not see anything.
