[PATCH] build: Fix cache file placement
Tue Nov 10 07:18:37 UTC 2020
The "bsp_list" and "bsp_defaults" commands get a waflib.Context object
which has no build node.  Use a hard coded build path for these
commands.
 wscript | 8 +++++---
 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/wscript b/wscript
index 5f6958dbf3..5ad93de453 100755
--- a/wscript
+++ b/wscript
@@ -1135,9 +1135,11 @@ def load_from_yaml(load, ctx, data_by_uid, base, path):
 def load_items_in_directory(ctx, ctors, path):
-    f = ctx.bldnode.make_node(
-        "c4che/" + re.sub(r"[^\w]", "_", path) + ".pickle"
+    p = "c4che/" + re.sub(r"[^\w]", "_", path) + ".pickle"
+    try:
+        f = ctx.bldnode.make_node(p)
+    except AttributeError:
+        f = ctx.path.make_node("build/" + p)
     f.parent.mkdir()
     cache_file = f.abspath()
     data_by_uid = {}
2.26.2
