Fatal exceptions on context-switching for more than two isolated threads
Utkarsh Rai
utkarsh.rai60 at gmail.com
Tue Nov 10 15:53:18 UTC 2020
On Thu, Nov 5, 2020 at 11:45 AM Sebastian Huber <
> On 04/11/2020 19:38, Gedare Bloom wrote:
> >> Based on the above suggestions I tried to move the
> User_extensions_Iterator storage to the TCB by adding a new field to the
> structure, but that did not compile(userextimpl.h is not included with
> thread.h because of cyclic dependency).
> >> This made me try out a naive hack, I defined a structure similar to the
> User_extensions_Iterator and then added the field to the TCB. The next
> problem that I faced was during the creation of the idle thread. Since an
> idle thread is created during system
> >> initialization, the 'executing' pointer pointing the TCB is null, and
> hence referencing to the iterator placed in the TCB for the idle thread
> fails. This was resolved by separating the cases for an idle thread and
> other threads. After that I was able to successfully isolate more than two
> thread stacks.
> >> Can you please suggest a more acceptable approach for resolving this
> issue?
> > At a high level the approach you took makes sense. You have moved the
> > user extensions to the TCB, and then avoid accessing it in case the
> > TCB is null (i.e., the initial context switch). I'd need to see the
> > code to make any further critical analysis. But it sounds acceptable
> > to me.
> The executing thread pointer can be NULL and there is already a check
> for this in _User_extensions_Iterate(). In this case you can use a
> member in the _Per_CPU_Information[].
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Based on your comments I have made the following changes in the user
extension iterator scheme. Some of the code is still hackish( if-else
conditional for handling TCB pointer when it is NULL ) and I would request
your suggestions on the same.
diff --git a/cpukit/include/rtems/score/percpu.h
b/cpukit/include/rtems/score/percpu.h
index 31bc2b0bff..6e15f4b1ba 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -25,7 +25,7 @@
#include <rtems/asm.h>
#else
- #include <rtems/score/chain.h>
+ #include <rtems/score/chainimpl.h>
#include <rtems/score/isrlock.h>
#include <rtems/score/smp.h>
#include <rtems/score/timestamp.h>
@@ -339,6 +339,20 @@ typedef enum {
PER_CPU_WATCHDOG_COUNT
} Per_CPU_Watchdog_index;
+#if defined ( RTEMS_THREAD_STACK_PROTECTION )
+ * @brief Per CPU user extensions iterator structure
+ * This structure is used to refer to the user extensions iterator when
+ * thread stack protection is configured.
+typedef struct Per_CPU_User_extensions_Iterator {
+ Chain_Iterator Iterator;
+ struct Per_CPU_User_extensions_Iterator *previous;
+} Per_CPU_User_extensions_Iterator;
+#endif
* @brief Per CPU Core Structure
@@ -595,6 +609,10 @@ typedef struct Per_CPU_Control {
bool boot;
#endif
+ #if defined (RTEMS_THREAD_STACK_PROTECTION)
+ Per_CPU_User_extensions_Iterator iter;
+ #endif
struct Record_Control *record;
Per_CPU_Stats Stats;
diff --git a/cpukit/include/rtems/score/thread.h
b/cpukit/include/rtems/score/thread.h
index ee0aee5b79..98b85a66af 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -636,6 +636,13 @@ struct Thread_Action {
Thread_Action_handler handler;
+#if defined (RTEMS_THREAD_STACK_PROTECTION)
+ typedef struct Thread_User_extensions_Iterator {
+ struct Thread_User_extensions_Iterator *previous;
+ } Thread_User_extensions_Iterator;
+#endif
* @brief Per-thread information for POSIX Keys.
@@ -864,6 +871,10 @@ struct _Thread_Control {
struct _pthread_cleanup_context *last_cleanup_context;
+ Thread_User_extensions_Iterator iter;
+#endif
* @brief LIFO list of user extensions iterators.
diff --git a/cpukit/score/src/userextiterate.c
b/cpukit/score/src/userextiterate.c
index 06665a2d7a..814e695018 100644
--- a/cpukit/score/src/userextiterate.c
+++ b/cpukit/score/src/userextiterate.c
@@ -181,22 +181,47 @@ void _User_extensions_Iterate(
_User_extensions_Acquire( &lock_context );
- _Chain_Iterator_initialize(
+ if ( executing != NULL ) {
+ executing->iter.previous = executing->last_user_extensions_iterator;
+ executing->last_user_extensions_iterator = &executing->iter;
+ _Chain_Iterator_initialize(
&_User_extensions_List.Active,
&_User_extensions_List.Iterators,
- &iter.Iterator,
+ &executing->iter.Iterator,
direction
- if ( executing != NULL ) {
- iter.previous = executing->last_user_extensions_iterator;
- executing->last_user_extensions_iterator = &iter;
+ while ( ( node = _Chain_Iterator_next( &executing->iter.Iterator ) )
!= end ) {
+ const User_extensions_Control *extension;
+ _Chain_Iterator_set_position( &executing->iter.Iterator, node );
+ _User_extensions_Release( &lock_context );
+ extension = (const User_extensions_Control *) node;
+ ( *visitor )( executing, arg, &extension->Callouts );
+ _User_extensions_Acquire( &lock_context );
- while ( ( node = _Chain_Iterator_next( &iter.Iterator ) ) != end ) {
+ executing->last_user_extensions_iterator = executing->iter.previous;
+ _Chain_Iterator_destroy( &executing->iter.Iterator );
+ } else {
+ &_User_extensions_List.Active,
+ &_User_extensions_List.Iterators,
+ &_Per_CPU_Information[0].per_cpu.iter.Iterator,
+ direction
&_Per_CPU_Information[0].per_cpu.iter.Iterator ) ) != end ) {
- _Chain_Iterator_set_position( &iter.Iterator, node );
&_Per_CPU_Information[0].per_cpu.iter.Iterator, node );
@@ -206,11 +231,9 @@ void _User_extensions_Iterate(
- executing->last_user_extensions_iterator = iter.previous;
+ _Chain_Iterator_destroy( &_Per_CPU_Information->per_cpu.iter.Iterator );
- _Chain_Iterator_destroy( &iter.Iterator );
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201110/0c038b9d/attachment-0001.html>
