[PATCH 4/4] eng: Clarify "Coding Conventions" introduction
Gedare Bloom
gedare at rtems.org
Tue Nov 10 23:22:50 UTC 2020
all 4 look good to me.
On Thu, Nov 5, 2020 at 11:43 AM Sebastian Huber
> eng/coding-conventions.rst | 10 +++++-----
> 1 file changed, 5 insertions(+), 5 deletions(-)
> diff --git a/eng/coding-conventions.rst b/eng/coding-conventions.rst
> index 5dd8df5..e34cd74 100644
> --- a/eng/coding-conventions.rst
> +++ b/eng/coding-conventions.rst
> @@ -9,11 +9,11 @@
> Coding Conventions
> -The style of RTEMS is generally consistent in the core areas.
> -This page attempts to capture generally accepted practices.
> -When in doubt, consult the code around you or look in cpukit/rtems.
> -See the sister page `Doxygen Recommendations <https://devel.rtems.org/wiki/Developer/Coding/Doxygen>`_.
> -for examples that illustrate style rules and Doxygen usage.
> +The style of RTEMS is generally consistent in the core areas. This section
> +attempts to capture generally accepted practices. When in doubt, consult the
> +code around you, look in the RTEMS sources in the directories
> +:file:`cpukit/include/rtems/score` and :file:`cpukit/score`, or ask on the
> +:r:list:`devel`.
> Source Documentation
> 2.26.2
> devel mailing list
> devel at rtems.org
