Proposal: Add BSP documentation to BSP build specification
Sebastian Huber
Wed Nov 11 09:25:30 UTC 2020
Hello,
currently, we have a hand crafted chapter with the BSPs and some
documentation in the User Manual:
https://docs.rtems.org/branches/master/user/bsps/index.html
I would like to generate this chapter using the BSP build specification
items, for example:
https://git.rtems.org/rtems/tree/spec/build/bsps/sparc/erc32/bsperc32.yml
For this I would introduce a BSP family item which includes the name of
the family and a description in Sphinx format with sections related to
all BSPs of the family. For example:
documentation-introduction: |
This BSP offers only one variant, the `altcycv_devkit`. This variant
supports
the Intel Cyclone V system on chip. The basic hardware
initialization is not
performed by the BSP. A boot loader with device tree support must be
used to
start the BSP, e.g. U-Boot.
The BSP is known to run on these boards:
* `Cyclone V SoC Development Kit
<https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-soc.html>`_
* `Enclustra Mars MA3 SoC Module
<https://www.enclustra.com/en/products/system-on-chip-modules/mars-ma3/>`_
* `Terasic DE10-Standard Development Kit
<https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1081>`_
documentation-sections:
- header: Boot via U-Boot
section: |
The application executable file (ELF file) must be converted to an
U-Boot
image. Use the following commands:
.. code-block:: none
arm-rtems5-objcopy -O binary app.exe app.bin
gzip -9 -f -c app.bin > app.bin.gz
mkimage -A arm -O linux -T kernel -a 0x00300000 -e 0x00300000
-n RTEMS -d app.bin.gz app.img
Use the following U-Boot commands to boot an application via TFTP
download:
tftpboot ${loadaddr} app.img && run loadfdt && bootm
${loadaddr} - ${fdt_addr} ; reset
The ``loadfdt`` command may be not defined in your U-Boot
environment. Just
replace it with the appropriate commands to load the device tree at
``${fdt_addr}``.
- header: Clock Driver
section: |
The clock driver uses the `Cortex-A9 MPCore Global Timer`.
The BSP items would link to the family item using the new role
"build-family". This replaces the "family" attribute of the BSP items.
The BSP items would get a "description" attribute with an optional
documentation section for this variant.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
