[PATCH 2/2] c-user: Generate Partition Manager documentation
Wed Nov 11 17:16:09 UTC 2020
These will be fine, with the manually edited warning fixed
On Mon, Nov 9, 2020 at 7:47 AM Sebastian Huber
> The manager documentation is a consolidation of the comments in Doxygen
> markup and the documentation sources in Sphinx markup.  The
> documentation was transfered to interface specification items.  This
> header file was generated from the items by a script.
> Update #3993.
>  c-user/partition/directives.rst   | 647 +++++++++++++++++-------------
>  c-user/partition/introduction.rst |  41 +-
>  2 files changed, 408 insertions(+), 280 deletions(-)
> diff --git a/c-user/partition/directives.rst b/c-user/partition/directives.rst
> index f81c37f..cd50671 100644
> --- a/c-user/partition/directives.rst
> +++ b/c-user/partition/directives.rst
> @@ -1,349 +1,450 @@
>  .. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>  .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
> +.. Do not manually edit this file.  It is part of the RTEMS quality process
> +.. and was automatically generated.
> +.. If you find something that needs to be fixed or worded better please
> +.. post a report to an RTEMS mailing list or raise a bug report:
> +.. https://docs.rtems.org/branches/master/user/support/bugs.html
> +.. For information on updating and regenerating please refer to:
> +.. https://docs.rtems.org/branches/master/eng/req/howto.html
> +.. _PartitionManagerDirectives:
>  Directives
> -This section details the partition manager's directives.  A subsection is
> -dedicated to each of this manager's directives and describes the calling
> -sequence, related constants, usage, and status codes.
> +This section details the directives of the Partition Manager. A subsection is
> +dedicated to each of this manager's directives and lists the calling sequence,
> +parameters, description, return values, and notes of the directive.
> +.. Generated from spec:/rtems/part/if/create
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_partition_create()
>  .. index:: create a partition
> -.. index:: rtems_partition_create
> -.. _rtems_partition_create:
> -PARTITION_CREATE - Create a partition
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_partition_create(
> -            rtems_name       name,
> -            void            *starting_address,
> -            uintptr_t        length,
> -            size_t           buffer_size,
> -            rtems_attribute  attribute_set,
> -            rtems_id        *id
> -DIRECTIVE STATUS CODES:
> -    .. list-table::
> -     :class: rtems-table
> -     * - ``RTEMS_SUCCESSFUL``
> -       - partition created successfully
> -     * - ``RTEMS_INVALID_NAME``
> -       - invalid partition ``name``
> -     * - ``RTEMS_TOO_MANY``
> -       - too many partitions created
> -     * - ``RTEMS_INVALID_ADDRESS``
> -       - ``starting_address`` is not on a pointer size boundary
> -       - ``starting_address`` is NULL
> -       - ``id`` is NULL
> -     * - ``RTEMS_INVALID_SIZE``
> -       - ``length`` or ``buffer_size`` is 0
> -       - ``length`` is less than the ``buffer_size``
> -       - ``buffer_size`` is not an integral multiple of the pointer size
> -       - ``buffer_size`` is less than two times the pointer size
> -       - too many global objects
> -DESCRIPTION:
> -    This directive creates a partition of fixed size buffers from a physically
> -    contiguous memory space which starts at starting_address and is length
> -    bytes in size.  Each allocated buffer is to be of ``buffer_size`` in bytes.
> -    The assigned partition id is returned in ``id``.  This partition id is used
> -    to access the partition with other partition related directives.  For
> -    control and maintenance of the partition, RTEMS allocates a PTCB from the
> -    local PTCB free pool and initializes it.
> -NOTES:
> -    This directive may cause the calling task to be preempted due to an
> -    obtain and release of the object allocator mutex.
> -    The partition buffer area specified by the ``starting_address`` must be
> -    properly aligned.  It must be possible to directly store target
> -    architecture pointers and the also the user data.  For example, if the user
> -    data contains some long double or vector data types, the partition buffer
> -    area and the buffer size must take the alignment of these types into
> -    account which is usually larger than the pointer alignment.  A cache line
> -    alignment may be also a factor.
> -    The ``buffer_size`` parameter must be an integral multiple of the pointer
> -    size on the target architecture.  Additionally, ``buffer_size`` must be
> -    large enough to hold two pointers on the target architecture.  This is
> -    required for RTEMS to manage the buffers when they are free.
> -    Memory from the partition is not used by RTEMS to store the Partition
> -    Control Block.
> -    The following partition attribute constants are defined by RTEMS:
> -    .. list-table::
> -     * - ``RTEMS_LOCAL``
> -       - local partition (default)
> -     * - ``RTEMS_GLOBAL``
> -       - global partition
> -    The PTCB for a global partition is allocated on the local node.  The memory
> -    space used for the partition must reside in shared memory. Partitions
> -    should not be made global unless remote tasks must interact with the
> -    partition.  This is to avoid the overhead incurred by the creation of a
> -    global partition.  When a global partition is created, the partition's name
> -    and id must be transmitted to every node in the system for insertion in the
> -    local copy of the global object table.
> -    The total number of global objects, including partitions, is limited by the
> -    maximum_global_objects field in the Configuration Table.
> -EXAMPLE:
> -    .. code-block:: c
> -        #include <rtems.h>
> -        #include <rtems/chain.h>
> -        #include <assert.h>
> -        typedef struct {
> -          char  less;
> -          short more;
> -        } item;
> -        union {
> -          item             data;
> -          rtems_chain_node node;
> -        } items[ 13 ];
> -        rtems_id create_partition(void)
> -          rtems_id          id;
> -          rtems_status_code sc;
> -          sc = rtems_partition_create(
> -            rtems_build_name( 'P', 'A', 'R', 'T' ),
> -            items,
> -            sizeof( items ),
> -            sizeof( items[ 0 ] ),
> -            RTEMS_DEFAULT_ATTRIBUTES,
> -            &id
> -          assert(sc == RTEMS_SUCCESSFUL);
> -          return id;
> +.. _InterfaceRtemsPartitionCreate:
> +rtems_partition_create()
> +Creates a partition.
> +.. rubric:: CALLING SEQUENCE:
> +.. code-block:: c
> +    rtems_status_code rtems_partition_create(
> +      rtems_name      name,
> +      void           *starting_address,
> +      uintptr_t       length,
> +      size_t          buffer_size,
> +      rtems_attribute attribute_set,
> +      rtems_id       *id
> +.. rubric:: PARAMETERS:
> +``name``
> +    This parameter is the name of the partition.
> +``starting_address``
> +    This parameter is the starting address of the buffer area used by the
> +    partition.
> +``length``
> +    This parameter is the length in bytes of the buffer area used by the
> +    partition.
> +``buffer_size``
> +    This parameter is the size in bytes of a buffer managed by the partition.
> +``attribute_set``
> +    This parameter is the attribute set of the partition.
> +``id``
> +    This parameter is the pointer to an object identifier variable.  The
> +    identifier of the created partition object will be stored in this variable,
> +    in case of a successful operation.
> +.. rubric:: DESCRIPTION:
> +This directive creates a partition of fixed size buffers from a physically
> +contiguous memory space which starts at ``starting_address`` and is ``length``
> +bytes in size.  Each allocated buffer is to be of ``buffer_size`` in bytes.
> +The assigned partition identifier is returned in ``id``.  This partition
> +identifier is used to access the partition with other partition related
> +directives.
> +The **attribute set** specified in ``attribute_set`` is built through a
> +*bitwise or* of the attribute constants described below.  Attributes not
> +mentioned below are not evaluated by this directive and have no effect.
> +The partition can have **local** or **global** scope in a multiprocessing
> +network (this attribute does not refer to SMP systems).
> +* A **local** scope is the default and can be emphasized through the use of the
> +  :c:macro:`RTEMS_LOCAL` attribute.  A local partition can be only used by the
> +  node which created it.
> +* A **global** scope is established if the :c:macro:`RTEMS_GLOBAL` attribute is
> +  set.  The memory space used for the partition must reside in shared memory.
> +  Setting the global attribute in a single node system has no effect.
> +.. rubric:: RETURN VALUES:
> +:c:macro:`RTEMS_SUCCESSFUL`
> +    The requested operation was successful.
> +:c:macro:`RTEMS_INVALID_NAME`
> +    The partition name was invalid.
> +:c:macro:`RTEMS_INVALID_ADDRESS`
> +    The ``id`` parameter was `NULL
> +    <https://en.cppreference.com/w/c/types/NULL>`_.
> +:c:macro:`RTEMS_INVALID_SIZE`
> +    The ``length`` parameter was 0.
> +    The ``buffer_size`` parameter was 0.
> +    The ``length`` parameter was less than the ``buffer_size`` parameter.
> +    The ``buffer_size`` parameter was not an integral multiple of the pointer
> +    size.
> +    The ``buffer_size`` parameter was less than two times the pointer size.
> +    The ``starting_address`` parameter was not on a pointer size boundary.
> +:c:macro:`RTEMS_TOO_MANY`
> +    There was no inactive object available to create a new partition.  The
> +    number of partitions available to the application is configured through the
> +    :ref:`CONFIGURE_MAXIMUM_PARTITIONS` configuration option.
> +.. rubric:: NOTES:
> +This directive may cause the calling task to be preempted due to an obtain and
> +release of the object allocator mutex.
> +The partition buffer area specified by the ``starting_address`` must be
> +properly aligned.  It must be possible to directly store target architecture
> +pointers and also the user data.  For example, if the user data contains some
> +long double or vector data types, the partition buffer area and the buffer size
> +must take the alignment of these types into account which is usually larger
> +than the pointer alignment.  A cache line alignment may be also a factor.  Use
> +:c:macro:`RTEMS_PARTITION_ALIGNMENT` to specify the minimum alignment of a
> +partition buffer type.
> +The ``buffer_size`` parameter must be an integral multiple of the pointer size
> +on the target architecture.  Additionally, ``buffer_size`` must be large enough
> +to hold two pointers on the target architecture.  This is required for RTEMS to
> +manage the buffers when they are free.
> +For control and maintenance of the partition, RTEMS allocates a :term:`PTCB`
> +from the local PTCB free pool and initializes it. Memory from the partition
> +buffer area is not used by RTEMS to store the PTCB.
> +The PTCB for a global partition is allocated on the local node.  Partitions
> +should not be made global unless remote tasks must interact with the partition.
> +This is to avoid the overhead incurred by the creation of a global partition.
> +When a global partition is created, the partition's name and identifier must be
> +transmitted to every node in the system for insertion in the local copy of the
> +global object table.
> +The total number of global objects, including partitions, is limited by the
> +value of the :ref:`CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS` application
> +configuration option.
> +.. Generated from spec:/rtems/part/if/ident
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_partition_ident()
>  .. index:: get ID of a partition
>  .. index:: obtain ID of a partition
> -.. index:: rtems_partition_ident
> -.. _rtems_partition_ident:
> +.. _InterfaceRtemsPartitionIdent:
> +rtems_partition_ident()
> +Identifies a partition by the object name.
> +.. code-block:: c
> -PARTITION_IDENT - Get ID of a partition
> +    rtems_status_code rtems_partition_ident(
> +      rtems_name name,
> +      uint32_t   node,
> +      rtems_id  *id
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_partition_ident(
> -            rtems_name  name,
> -            uint32_t    node,
> -            rtems_id   *id
> +``name``
> +    This parameter is the object name to look up.
> -    .. list-table::
> +``node``
> +    This parameter is the node or node set to search for a matching object.
> -       - partition identified successfully
> -       - ``id`` is NULL
> -       - partition name not found
> -     * - ``RTEMS_INVALID_NODE``
> -       - invalid node id
> +``id``
> +    This parameter is the pointer to an object identifier variable.  The object
> +    identifier of an object with the specified name will be stored in this
> +    variable, in case of a successful operation.
> -DESCRIPTION:
> -    This directive obtains the partition id associated with the partition name.
> -    If the partition name is not unique, then the partition id will match one
> -    of the partitions with that name.  However, this partition id is not
> -    guaranteed to correspond to the desired partition.  The partition id is
> -    used with other partition related directives to access the partition.
> -NOTES:
> -    This directive will not cause the running task to be preempted.
> +This directive obtains a partition identifier associated with the partition
> +name specified in ``name``.
> -    If node is ``RTEMS_SEARCH_ALL_NODES``, all nodes are searched with the
> -    local node being searched first.  All other nodes are searched with the
> -    lowest numbered node searched first.
> +The node to search is specified in ``node``.  It shall be
> -    If node is a valid node number which does not represent the local node,
> -    then only the partitions exported by the designated node are searched.
> +* a valid node number,
> -    This directive does not generate activity on remote nodes.  It accesses
> -    only the local copy of the global object table.
> +* the constant :c:macro:`RTEMS_SEARCH_ALL_NODES` to search in all nodes,
> +* the constant :c:macro:`RTEMS_SEARCH_LOCAL_NODE` to search in the local node
> +  only, or
> +* the constant :c:macro:`RTEMS_SEARCH_OTHER_NODES` to search in all nodes
> +  except the local node.
> +    The id parameter was `NULL <https://en.cppreference.com/w/c/types/NULL>`_.
> +    The name parameter was 0.
> +    There was no object with the specified name on the specified nodes.
> +:c:macro:`RTEMS_INVALID_NODE`
> +    In multiprocessing configurations, the specified node was invalid.
> +.. rubric:: NOTES:
> +If the partition name is not unique, then the partition identifier will match
> +the first partition with that name in the search order.  However, this
> +partition identifier is not guaranteed to correspond to the desired partition.
> +The partition identifier is used with other partition related directives to
> +access the partition.
> +If node is :c:macro:`RTEMS_SEARCH_ALL_NODES`, all nodes are searched with the
> +local node being searched first.  All other nodes are searched with the lowest
> +numbered node searched first.
> +If node is a valid node number which does not represent the local node, then
> +only the partitions exported by the designated node are searched.
> +This directive does not generate activity on remote nodes.  It accesses only
> +the local copy of the global object table.
> +.. Generated from spec:/rtems/part/if/delete
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_partition_delete()
>  .. index:: delete a partition
> -.. index:: rtems_partition_delete
> -.. _rtems_partition_delete:
> +.. _InterfaceRtemsPartitionDelete:
> +rtems_partition_delete()
> +Deletes the partition.
> +.. code-block:: c
> +    rtems_status_code rtems_partition_delete( rtems_id id );
> +``id``
> +    This parameter is the partition identifier.
> -PARTITION_DELETE - Delete a partition
> +This directive deletes the partition specified by the id parameter.  The
> +partition cannot be deleted if any of its buffers are still allocated.  The
> +:term:`PTCB` for the deleted partition is reclaimed by RTEMS.
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_partition_delete(
> -            rtems_id id
> -    .. list-table::
> +:c:macro:`RTEMS_INVALID_ID`
> +    There was no partition with the specified identifier.
> -       - partition deleted successfully
> -     * - ``RTEMS_INVALID_ID``
> -       - invalid partition id
> -     * - ``RTEMS_RESOURCE_IN_USE``
> -       - buffers still in use
> -     * - ``RTEMS_ILLEGAL_ON_REMOTE_OBJECT``
> -       - cannot delete remote partition
> +:c:macro:`RTEMS_ILLEGAL_ON_REMOTE_OBJECT`
> +    The partition resided on a remote node.
> -DESCRIPTION:
> -    This directive deletes the partition specified by id.  The partition cannot
> -    be deleted if any of its buffers are still allocated.  The PTCB for the
> -    deleted partition is reclaimed by RTEMS.
> +:c:macro:`RTEMS_RESOURCE_IN_USE`
> +    There were buffers of the partition still in use.
> -NOTES:
> +.. rubric:: NOTES:
> -    The calling task does not have to be the task that created the partition.
> -    Any local task that knows the partition id can delete the partition.
> -    When a global partition is deleted, the partition id must be transmitted to
> -    every node in the system for deletion from the local copy of the global
> -    object table.
> +The calling task does not have to be the task that created the partition. Any
> +local task that knows the partition identifier can delete the partition.
> -    The partition must reside on the local node, even if the partition was
> -    created with the ``RTEMS_GLOBAL`` option.
> +When a global partition is deleted, the partition identifier must be
> +transmitted to every node in the system for deletion from the local copy of the
> +The partition must reside on the local node, even if the partition was created
> +with the :c:macro:`RTEMS_GLOBAL` attribute.
> +.. Generated from spec:/rtems/part/if/get-buffer
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_partition_get_buffer()
>  .. index:: get buffer from partition
>  .. index:: obtain buffer from partition
> -.. index:: rtems_partition_get_buffer
> -.. _rtems_partition_get_buffer:
> +.. _InterfaceRtemsPartitionGetBuffer:
> +rtems_partition_get_buffer()
> +Tries to get a buffer from the partition.
> +.. code-block:: c
> +    rtems_status_code rtems_partition_get_buffer( rtems_id id, void **buffer );
> +``id``
> +``buffer``
> +    This parameter is the pointer to a buffer pointer variable.  The pointer to
> +    the allocated buffer will be stored in this variable, in case of a
> +    successful operation.
> -PARTITION_GET_BUFFER - Get buffer from a partition
> +This directive allows a buffer to be obtained from the partition specified in
> +the ``id`` parameter.  The address of the allocated buffer is returned through
> +the ``buffer`` parameter.
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_partition_get_buffer(
> -            rtems_id   id,
> -            void     **buffer
> -    .. list-table::
> -       - buffer obtained successfully
> -       - ``buffer`` is NULL
> -     * - ``RTEMS_UNSATISFIED``
> -       - all buffers are allocated
> +    The ``buffer`` parameter was `NULL
> -DESCRIPTION:
> -    This directive allows a buffer to be obtained from the partition specified
> -    in id.  The address of the allocated buffer is returned in buffer.
> +:c:macro:`RTEMS_UNSATISFIED`
> +    There was no free buffer available to allocate and return.
> -NOTES:
> +.. rubric:: NOTES:
> -    All buffers begin on a four byte boundary.
> +This directive will not cause the running task to be preempted.
> -    A task cannot wait on a buffer to become available.
> +The buffer start alignment is determined by the memory area and buffer size
> +used to create the partition.
> -    Getting a buffer from a global partition which does not reside on the local
> -    node will generate a request telling the remote node to allocate a buffer
> -    from the specified partition.
> +A task cannot wait on a buffer to become available.
> +Getting a buffer from a global partition which does not reside on the local
> +node will generate a request telling the remote node to allocate a buffer from
> +the partition.
> +.. Generated from spec:/rtems/part/if/return-buffer
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_partition_return_buffer()
> +.. index:: return buffer to partition
> +.. _InterfaceRtemsPartitionReturnBuffer:
> +rtems_partition_return_buffer()
> +Returns the buffer to the partition.
> +.. code-block:: c
> +    rtems_status_code rtems_partition_return_buffer( rtems_id id, void *buffer );
> +``id``
> -.. index:: return buffer to partitition
> -.. index:: rtems_partition_return_buffer
> +``buffer``
> +    This parameter is the pointer to the buffer to return.
> -.. _rtems_partition_return_buffer:
> -PARTITION_RETURN_BUFFER - Return buffer to a partition
> +This directive returns the buffer specified by ``buffer`` to the partition
> +specified by ``id``.
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_partition_return_buffer(
> -            rtems_id  id,
> -            void     *buffer
> -    .. list-table::
> -       - buffer returned successfully
> -       - buffer address not in partition
> +    The buffer referenced by ``buffer`` was not in the partition.
> -DESCRIPTION:
> -    This directive returns the buffer specified by buffer to the partition
> -    specified by id.
> +.. rubric:: NOTES:
> -NOTES:
> -    Returning a buffer to a global partition which does not reside on the local
> -    node will generate a request telling the remote node to return the buffer
> -    to the specified partition.
> +Returning a buffer to a global partition which does not reside on the local
> +node will generate a request telling the remote node to return the buffer to
> +the partition.
> -    Returning a buffer multiple times is an error.  It will corrupt the
> -    internal state of the partition.
> +Returning a buffer multiple times is an error.  It will corrupt the internal
> +state of the partition.
> diff --git a/c-user/partition/introduction.rst b/c-user/partition/introduction.rst
> index dd51d30..4cfa9ac 100644
> --- a/c-user/partition/introduction.rst
> +++ b/c-user/partition/introduction.rst
> @@ -1,19 +1,46 @@
> +.. Generated from spec:/rtems/part/if/group
> +.. _PartitionManagerIntroduction:
>  Introduction
> -The partition manager provides facilities to dynamically allocate memory in
> -fixed-size units.  The directives provided by the partition manager are:
> +.. The following list was generated from:
> +.. spec:/rtems/part/if/create
> +.. spec:/rtems/part/if/ident
> +.. spec:/rtems/part/if/delete
> +.. spec:/rtems/part/if/get-buffer
> +.. spec:/rtems/part/if/return-buffer
> +The Partition Manager provides facilities to dynamically allocate memory in
> +fixed-size units. The directives provided by the Partition Manager are:
> -- :ref:`rtems_partition_create`
> +* :ref:`InterfaceRtemsPartitionCreate` - Creates a partition.
> -- :ref:`rtems_partition_ident`
> +* :ref:`InterfaceRtemsPartitionIdent` - Identifies a partition by the object
> +  name.
> -- :ref:`rtems_partition_delete`
> +* :ref:`InterfaceRtemsPartitionDelete` - Deletes the partition.
> -- :ref:`rtems_partition_get_buffer`
> +* :ref:`InterfaceRtemsPartitionGetBuffer` - Tries to get a buffer from the
> +  partition.
> -- :ref:`rtems_partition_return_buffer`
> +* :ref:`InterfaceRtemsPartitionReturnBuffer` - Returns the buffer to the
> +  partition.
> 2.26.2
> devel mailing list
> devel at rtems.org
