[PATCH 2/2] eng: Simplify "Load" environment reporting
Sebastian Huber
Thu Nov 12 09:39:02 UTC 2020
Report all runtime measurement environments with a name only and encode
the worker count of the "Load" environment in the name.
Update #3199.
eng/test-framework.rst | 21 +++++++--------------
1 file changed, 7 insertions(+), 14 deletions(-)
diff --git a/eng/test-framework.rst b/eng/test-framework.rst
index 94d2f35..589caf7 100644
--- a/eng/test-framework.rst
+++ b/eng/test-framework.rst
@@ -1303,14 +1303,14 @@ DirtyCache
You can disable this variant with the
`T_MEASURE_RUNTIME_DISABLE_DIRTY_CACHE` request flag.
-Load
+Load/<WorkerCount>
This variant tries to get close to worst-case conditions. The cache is set
up according to the `DirtyCache` variant. In addition, other processors
try to fully load the memory system. The load is produced through writes
to a memory area with twice the size of the outer-most data cache. The
load variant is performed multiple times with a different set of active
- load worker threads (`M:L`). The active workers range from one up to the
- processor count.
+ load worker threads. The <WorkerCount> value is the count of active
+ workers which ranges from one to the processor count.
You can disable these variants with the
`T_MEASURE_RUNTIME_DISABLE_MINOR_LOAD` and
@@ -1393,8 +1393,7 @@ reported.
M:D:0.000033244
M:E:Empty:D:1.887834875
M:B:Empty
- M:V:Load
- M:L:1
+ M:V:Load/1
M:N:1024
M:MI:0.000000000
M:Q1:0.000000002
@@ -1407,8 +1406,7 @@ reported.
[... 22 more load variants ...]
M:E:Empty:D:0.021252583
M:B:Empty
- M:V:Load
- M:L:24
+ M:V:Load/24
M:N:1024
M:MI:0.000000001
M:Q1:0.000000002
@@ -1907,8 +1905,6 @@ M
**M:V:<Variant>**
- **M:L:<Load>**
**M:N:<SampleCount>**
**M:S:<Count>:<Value>**
@@ -1937,11 +1933,8 @@ M
<Variant>
The execution variant which is one of **FullCache**, **HotCache**,
- **DirtyCache**, or **Load**.
- <Load>
- The active load workers count which ranges from one to the processor
- count.
+ **DirtyCache**, or **Load/<WorkerCount>**. The <WorkerCount> is the
+ count of active workers which ranges from one to the processor count.
<SampleCount>
The sample count as defined by the runtime measurement configuration.
2.26.2
