[PATCH rtems-libbsd] Update arm64/aarch64 support
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Nov 12 19:31:42 UTC 2020
freebsd/sys/arm64/arm64/in_cksum.c | 243 +++++++
freebsd/sys/arm64/include/machine/armreg.h | 665 ++++++++++++++++++
freebsd/sys/arm64/include/machine/cpu.h | 203 ++++++
freebsd/sys/arm64/include/machine/cpufunc.h | 153 ++++
freebsd/sys/arm64/include/machine/in_cksum.h | 83 +++
.../ck/include/gcc/aarch64/ck_pr_llsc.h | 352 +++++++++
.../ck/include/gcc/aarch64/ck_pr_lse.h | 298 ++++++++
libbsd.py | 21 +
rtemsbsd/include/machine/frame.h | 1 +
9 files changed, 2019 insertions(+)
create mode 100644 freebsd/sys/arm64/arm64/in_cksum.c
create mode 100644 freebsd/sys/arm64/include/machine/armreg.h
create mode 100644 freebsd/sys/arm64/include/machine/cpu.h
create mode 100644 freebsd/sys/arm64/include/machine/cpufunc.h
create mode 100644 freebsd/sys/arm64/include/machine/in_cksum.h
create mode 100644 freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_llsc.h
create mode 100644 freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_lse.h
create mode 100644 rtemsbsd/include/machine/frame.h
diff --git a/freebsd/sys/arm64/arm64/in_cksum.c b/freebsd/sys/arm64/arm64/in_cksum.c
new file mode 100644
index 00000000..9f92f2ff
--- /dev/null
+++ b/freebsd/sys/arm64/arm64/in_cksum.c
@@ -0,0 +1,243 @@
+#include <machine/rtems-bsd-kernel-space.h>
+/* $NetBSD: in_cksum.c,v 1.7 1997/09/02 13:18:15 thorpej Exp $ */
+ * Copyright (c) 1988, 1992, 1993
+ * The Regents of the University of California. All rights reserved.
+ * Copyright (c) 1996
+ * Matt Thomas <matt at 3am-software.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 3. All advertising materials mentioning features or use of this software
+ * must display the following acknowledgement:
+ * This product includes software developed by the University of
+ * California, Berkeley and its contributors.
+ * 4. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * @(#)in_cksum.c 8.1 (Berkeley) 6/10/93
+#include <sys/cdefs.h> /* RCS ID & Copyright macro defns */
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/mbuf.h>
+#include <sys/systm.h>
+#include <netinet/in_systm.h>
+#include <netinet/in.h>
+#include <netinet/ip.h>
+#include <machine/in_cksum.h>
+ * Checksum routine for Internet Protocol family headers
+ * (Portable Alpha version).
+ * This routine is very heavily used in the network
+ * code and should be modified for each CPU to be as fast as possible.
+#define ADDCARRY(x) (x > 65535 ? x -= 65535 : x)
+#define REDUCE32 \
+ q_util.q = sum; \
+ sum = q_util.s[0] + q_util.s[1] + q_util.s[2] + q_util.s[3]; \
+#define REDUCE16 \
+ q_util.q = sum; \
+ l_util.l = q_util.s[0] + q_util.s[1] + q_util.s[2] + q_util.s[3]; \
+ sum = l_util.s[0] + l_util.s[1]; \
+ ADDCARRY(sum); \
+static const u_int32_t in_masks[] = {
+ /*0 bytes*/ /*1 byte*/ /*2 bytes*/ /*3 bytes*/
+ 0x00000000, 0x000000FF, 0x0000FFFF, 0x00FFFFFF, /* offset 0 */
+ 0x00000000, 0x0000FF00, 0x00FFFF00, 0xFFFFFF00, /* offset 1 */
+ 0x00000000, 0x00FF0000, 0xFFFF0000, 0xFFFF0000, /* offset 2 */
+ 0x00000000, 0xFF000000, 0xFF000000, 0xFF000000, /* offset 3 */
+union l_util {
+ u_int16_t s[2];
+ u_int32_t l;
+union q_util {
+ u_int16_t s[4];
+ u_int32_t l[2];
+ u_int64_t q;
+static u_int64_t
+in_cksumdata(const void *buf, int len)
+ const u_int32_t *lw = (const u_int32_t *) buf;
+ u_int64_t sum = 0;
+ u_int64_t prefilled;
+ int offset;
+ union q_util q_util;
+ if ((3 & (long) lw) == 0 && len == 20) {
+ sum = (u_int64_t) lw[0] + lw[1] + lw[2] + lw[3] + lw[4];
+ REDUCE32;
+ return sum;
+ if ((offset = 3 & (long) lw) != 0) {
+ const u_int32_t *masks = in_masks + (offset << 2);
+ lw = (u_int32_t *) (((long) lw) - offset);
+ sum = *lw++ & masks[len >= 3 ? 3 : len];
+ len -= 4 - offset;
+ if (len <= 0) {
+ REDUCE32;
+ return sum;
+#if 0
+ * Force to cache line boundary.
+ offset = 32 - (0x1f & (long) lw);
+ if (offset < 32 && len > offset) {
+ len -= offset;
+ if (4 & offset) {
+ sum += (u_int64_t) lw[0];
+ lw += 1;
+ if (8 & offset) {
+ sum += (u_int64_t) lw[0] + lw[1];
+ lw += 2;
+ if (16 & offset) {
+ sum += (u_int64_t) lw[0] + lw[1] + lw[2] + lw[3];
+ lw += 4;
+#endif
+ * access prefilling to start load of next cache line.
+ * then add current cache line
+ * save result of prefilling for loop iteration.
+ prefilled = lw[0];
+ while ((len -= 32) >= 4) {
+ u_int64_t prefilling = lw[8];
+ sum += prefilled + lw[1] + lw[2] + lw[3]
+ + lw[4] + lw[5] + lw[6] + lw[7];
+ lw += 8;
+ prefilled = prefilling;
+ if (len >= 0) {
+ lw += 8;
+ } else {
+ len += 32;
+ while ((len -= 16) >= 0) {
+ lw += 4;
+ len += 16;
+ while ((len -= 4) >= 0) {
+ sum += (u_int64_t) *lw++;
+ len += 4;
+ if (len > 0)
+ sum += (u_int64_t) (in_masks[len] & *lw);
+ REDUCE32;
+ return sum;
+u_short
+in_addword(u_short a, u_short b)
+ u_int64_t sum = a + b;
+ ADDCARRY(sum);
+ return (sum);
+u_short
+in_pseudo(u_int32_t a, u_int32_t b, u_int32_t c)
+ u_int64_t sum;
+ union l_util l_util;
+ sum = (u_int64_t) a + b + c;
+ REDUCE16;
+ return (sum);
+u_short
+in_cksum_skip(struct mbuf *m, int len, int skip)
+ int mlen = 0;
+ int clen = 0;
+ caddr_t addr;
+ len -= skip;
+ for (; skip && m; m = m->m_next) {
+ if (m->m_len > skip) {
+ mlen = m->m_len - skip;
+ addr = mtod(m, caddr_t) + skip;
+ goto skip_start;
+ } else {
+ skip -= m->m_len;
+ for (; m && len; m = m->m_next) {
+ if (m->m_len == 0)
+ continue;
+ mlen = m->m_len;
+ addr = mtod(m, caddr_t);
+skip_start:
+ if (len < mlen)
+ mlen = len;
+ if ((clen ^ (long) addr) & 1)
+ sum += in_cksumdata(addr, mlen) << 8;
+ else
+ sum += in_cksumdata(addr, mlen);
+ clen += mlen;
+ len -= mlen;
+ REDUCE16;
+ return (~sum & 0xffff);
+u_int in_cksum_hdr(const struct ip *ip)
+ u_int64_t sum = in_cksumdata(ip, sizeof(struct ip));
+ REDUCE16;
diff --git a/freebsd/sys/arm64/include/machine/armreg.h b/freebsd/sys/arm64/include/machine/armreg.h
index 00000000..d528f1af
--- /dev/null
+++ b/freebsd/sys/arm64/include/machine/armreg.h
@@ -0,0 +1,665 @@
+ * Copyright (c) 2013, 2014 Andrew Turner
+ * Copyright (c) 2015 The FreeBSD Foundation
+ * All rights reserved.
+ * This software was developed by Andrew Turner under
+ * sponsorship from the FreeBSD Foundation.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _MACHINE_ARMREG_H_
+#define _MACHINE_ARMREG_H_
+#define INSN_SIZE 4
+#define READ_SPECIALREG(reg) \
+({ uint64_t val; \
+ __asm __volatile("mrs %0, " __STRING(reg) : "=&r" (val)); \
+ val; \
+#define WRITE_SPECIALREG(reg, val) \
+ __asm __volatile("msr " __STRING(reg) ", %0" : : "r"((uint64_t)val))
+#define UL(x) UINT64_C(x)
+/* CNTHCTL_EL2 - Counter-timer Hypervisor Control register */
+#define CNTHCTL_EVNTI_MASK (0xf << 4) /* Bit to trigger event stream */
+#define CNTHCTL_EVNTDIR (1 << 3) /* Control transition trigger bit */
+#define CNTHCTL_EVNTEN (1 << 2) /* Enable event stream */
+#define CNTHCTL_EL1PCEN (1 << 1) /* Allow EL0/1 physical timer access */
+#define CNTHCTL_EL1PCTEN (1 << 0) /*Allow EL0/1 physical counter access*/
+/* CPACR_EL1 */
+#define CPACR_FPEN_MASK (0x3 << 20)
+#define CPACR_FPEN_TRAP_ALL1 (0x0 << 20) /* Traps from EL0 and EL1 */
+#define CPACR_FPEN_TRAP_EL0 (0x1 << 20) /* Traps from EL0 */
+#define CPACR_FPEN_TRAP_ALL2 (0x2 << 20) /* Traps from EL0 and EL1 */
+#define CPACR_FPEN_TRAP_NONE (0x3 << 20) /* No traps */
+#define CPACR_TTA (0x1 << 28)
+/* CTR_EL0 - Cache Type Register */
+#define CTR_DLINE_SHIFT 16
+#define CTR_DLINE_MASK (0xf << CTR_DLINE_SHIFT)
+#define CTR_DLINE_SIZE(reg) (((reg) & CTR_DLINE_MASK) >> CTR_DLINE_SHIFT)
+#define CTR_ILINE_SHIFT 0
+#define CTR_ILINE_MASK (0xf << CTR_ILINE_SHIFT)
+#define CTR_ILINE_SIZE(reg) (((reg) & CTR_ILINE_MASK) >> CTR_ILINE_SHIFT)
+/* DAIF - Interrupt Mask Bits */
+#define DAIF_D_MASKED (1 << 9)
+#define DAIF_A_MASKED (1 << 8)
+#define DAIF_I_MASKED (1 << 7)
+#define DAIF_F_MASKED (1 << 6)
+/* DCZID_EL0 - Data Cache Zero ID register */
+#define DCZID_DZP (1 << 4) /* DC ZVA prohibited if non-0 */
+#define DCZID_BS_SHIFT 0
+#define DCZID_BS_MASK (0xf << DCZID_BS_SHIFT)
+#define DCZID_BS_SIZE(reg) (((reg) & DCZID_BS_MASK) >> DCZID_BS_SHIFT)
+/* ESR_ELx */
+#define ESR_ELx_ISS_MASK 0x00ffffff
+#define ISS_INSN_FnV (0x01 << 10)
+#define ISS_INSN_EA (0x01 << 9)
+#define ISS_INSN_S1PTW (0x01 << 7)
+#define ISS_INSN_IFSC_MASK (0x1f << 0)
+#define ISS_DATA_ISV (0x01 << 24)
+#define ISS_DATA_SAS_MASK (0x03 << 22)
+#define ISS_DATA_SSE (0x01 << 21)
+#define ISS_DATA_SRT_MASK (0x1f << 16)
+#define ISS_DATA_SF (0x01 << 15)
+#define ISS_DATA_AR (0x01 << 14)
+#define ISS_DATA_FnV (0x01 << 10)
+#define ISS_DATA_EA (0x01 << 9)
+#define ISS_DATA_CM (0x01 << 8)
+#define ISS_DATA_S1PTW (0x01 << 7)
+#define ISS_DATA_WnR (0x01 << 6)
+#define ISS_DATA_DFSC_MASK (0x3f << 0)
+#define ISS_DATA_DFSC_ASF_L0 (0x00 << 0)
+#define ISS_DATA_DFSC_ASF_L1 (0x01 << 0)
+#define ISS_DATA_DFSC_ASF_L2 (0x02 << 0)
+#define ISS_DATA_DFSC_ASF_L3 (0x03 << 0)
+#define ISS_DATA_DFSC_TF_L0 (0x04 << 0)
+#define ISS_DATA_DFSC_TF_L1 (0x05 << 0)
+#define ISS_DATA_DFSC_TF_L2 (0x06 << 0)
+#define ISS_DATA_DFSC_TF_L3 (0x07 << 0)
+#define ISS_DATA_DFSC_AFF_L1 (0x09 << 0)
+#define ISS_DATA_DFSC_AFF_L2 (0x0a << 0)
+#define ISS_DATA_DFSC_AFF_L3 (0x0b << 0)
+#define ISS_DATA_DFSC_PF_L1 (0x0d << 0)
+#define ISS_DATA_DFSC_PF_L2 (0x0e << 0)
+#define ISS_DATA_DFSC_PF_L3 (0x0f << 0)
+#define ISS_DATA_DFSC_EXT (0x10 << 0)
+#define ISS_DATA_DFSC_EXT_L0 (0x14 << 0)
+#define ISS_DATA_DFSC_EXT_L1 (0x15 << 0)
+#define ISS_DATA_DFSC_EXT_L2 (0x16 << 0)
+#define ISS_DATA_DFSC_EXT_L3 (0x17 << 0)
+#define ISS_DATA_DFSC_ECC (0x18 << 0)
+#define ISS_DATA_DFSC_ECC_L0 (0x1c << 0)
+#define ISS_DATA_DFSC_ECC_L1 (0x1d << 0)
+#define ISS_DATA_DFSC_ECC_L2 (0x1e << 0)
+#define ISS_DATA_DFSC_ECC_L3 (0x1f << 0)
+#define ISS_DATA_DFSC_ALIGN (0x21 << 0)
+#define ISS_DATA_DFSC_TLB_CONFLICT (0x30 << 0)
+#define ESR_ELx_IL (0x01 << 25)
+#define ESR_ELx_EC_SHIFT 26
+#define ESR_ELx_EC_MASK (0x3f << 26)
+#define ESR_ELx_EXCEPTION(esr) (((esr) & ESR_ELx_EC_MASK) >> ESR_ELx_EC_SHIFT)
+#define EXCP_UNKNOWN 0x00 /* Unkwn exception */
+#define EXCP_FP_SIMD 0x07 /* VFP/SIMD trap */
+#define EXCP_ILL_STATE 0x0e /* Illegal execution state */
+#define EXCP_SVC32 0x11 /* SVC trap for AArch32 */
+#define EXCP_SVC64 0x15 /* SVC trap for AArch64 */
+#define EXCP_MSR 0x18 /* MSR/MRS trap */
+#define EXCP_INSN_ABORT_L 0x20 /* Instruction abort, from lower EL */
+#define EXCP_INSN_ABORT 0x21 /* Instruction abort, from same EL */
+#define EXCP_PC_ALIGN 0x22 /* PC alignment fault */
+#define EXCP_DATA_ABORT_L 0x24 /* Data abort, from lower EL */
+#define EXCP_DATA_ABORT 0x25 /* Data abort, from same EL */
+#define EXCP_SP_ALIGN 0x26 /* SP slignment fault */
+#define EXCP_TRAP_FP 0x2c /* Trapped FP exception */
+#define EXCP_SERROR 0x2f /* SError interrupt */
+#define EXCP_SOFTSTP_EL0 0x32 /* Software Step, from lower EL */
+#define EXCP_SOFTSTP_EL1 0x33 /* Software Step, from same EL */
+#define EXCP_WATCHPT_EL1 0x35 /* Watchpoint, from same EL */
+#define EXCP_BRK 0x3c /* Breakpoint */
+/* ICC_CTLR_EL1 */
+#define ICC_CTLR_EL1_EOIMODE (1U << 1)
+/* ICC_IAR1_EL1 */
+#define ICC_IAR1_EL1_SPUR (0x03ff)
+/* ICC_IGRPEN0_EL1 */
+#define ICC_IGRPEN0_EL1_EN (1U << 0)
+/* ICC_PMR_EL1 */
+#define ICC_PMR_EL1_PRIO_MASK (0xFFUL)
+/* ICC_SGI1R_EL1 */
+#define ICC_SGI1R_EL1_TL_MASK 0xffffUL
+#define ICC_SGI1R_EL1_AFF1_SHIFT 16
+#define ICC_SGI1R_EL1_SGIID_SHIFT 24
+#define ICC_SGI1R_EL1_AFF2_SHIFT 32
+#define ICC_SGI1R_EL1_AFF3_SHIFT 48
+#define ICC_SGI1R_EL1_SGIID_MASK 0xfUL
+#define ICC_SGI1R_EL1_IRM (0x1UL << 40)
+/* ICC_SRE_EL1 */
+#define ICC_SRE_EL1_SRE (1U << 0)
+/* ICC_SRE_EL2 */
+#define ICC_SRE_EL2_SRE (1U << 0)
+#define ICC_SRE_EL2_EN (1U << 3)
+/* ID_AA64DFR0_EL1 */
+#define ID_AA64DFR0_MASK UL(0x0000000ff0f0ffff)
+#define ID_AA64DFR0_DebugVer_SHIFT 0
+#define ID_AA64DFR0_DebugVer_MASK (UL(0xf) << ID_AA64DFR0_DebugVer_SHIFT)
+#define ID_AA64DFR0_DebugVer(x) ((x) & ID_AA64DFR0_DebugVer_MASK)
+#define ID_AA64DFR0_DebugVer_8 (UL(0x6) << ID_AA64DFR0_DebugVer_SHIFT)
+#define ID_AA64DFR0_DebugVer_8_VHE (UL(0x7) << ID_AA64DFR0_DebugVer_SHIFT)
+#define ID_AA64DFR0_DebugVer_8_2 (UL(0x8) << ID_AA64DFR0_DebugVer_SHIFT)
+#define ID_AA64DFR0_TraceVer_SHIFT 4
+#define ID_AA64DFR0_TraceVer_MASK (UL(0xf) << ID_AA64DFR0_TraceVer_SHIFT)
+#define ID_AA64DFR0_TraceVer(x) ((x) & ID_AA64DFR0_TraceVer_MASK)
+#define ID_AA64DFR0_TraceVer_NONE (UL(0x0) << ID_AA64DFR0_TraceVer_SHIFT)
+#define ID_AA64DFR0_TraceVer_IMPL (UL(0x1) << ID_AA64DFR0_TraceVer_SHIFT)
+#define ID_AA64DFR0_PMUVer_SHIFT 8
+#define ID_AA64DFR0_PMUVer_MASK (UL(0xf) << ID_AA64DFR0_PMUVer_SHIFT)
+#define ID_AA64DFR0_PMUVer(x) ((x) & ID_AA64DFR0_PMUVer_MASK)
+#define ID_AA64DFR0_PMUVer_NONE (UL(0x0) << ID_AA64DFR0_PMUVer_SHIFT)
+#define ID_AA64DFR0_PMUVer_3 (UL(0x1) << ID_AA64DFR0_PMUVer_SHIFT)
+#define ID_AA64DFR0_PMUVer_3_1 (UL(0x4) << ID_AA64DFR0_PMUVer_SHIFT)
+#define ID_AA64DFR0_PMUVer_IMPL (UL(0xf) << ID_AA64DFR0_PMUVer_SHIFT)
+#define ID_AA64DFR0_BRPs_SHIFT 12
+#define ID_AA64DFR0_BRPs_MASK (UL(0xf) << ID_AA64DFR0_BRPs_SHIFT)
+#define ID_AA64DFR0_BRPs(x) \
+ ((((x) >> ID_AA64DFR0_BRPs_SHIFT) & 0xf) + 1)
+#define ID_AA64DFR0_WRPs_SHIFT 20
+#define ID_AA64DFR0_WRPs_MASK (UL(0xf) << ID_AA64DFR0_WRPs_SHIFT)
+#define ID_AA64DFR0_WRPs(x) \
+ ((((x) >> ID_AA64DFR0_WRPs_SHIFT) & 0xf) + 1)
+#define ID_AA64DFR0_CTX_CMPs_SHIFT 28
+#define ID_AA64DFR0_CTX_CMPs_MASK (UL(0xf) << ID_AA64DFR0_CTX_CMPs_SHIFT)
+#define ID_AA64DFR0_CTX_CMPs(x) \
+ ((((x) >> ID_AA64DFR0_CTX_CMPs_SHIFT) & 0xf) + 1)
+#define ID_AA64DFR0_PMSVer_SHIFT 32
+#define ID_AA64DFR0_PMSVer_MASK (UL(0xf) << ID_AA64DFR0_PMSVer_SHIFT)
+#define ID_AA64DFR0_PMSVer(x) ((x) & ID_AA64DFR0_PMSVer_MASK)
+#define ID_AA64DFR0_PMSVer_NONE (UL(0x0) << ID_AA64DFR0_PMSVer_SHIFT)
+#define ID_AA64DFR0_PMSVer_V1 (UL(0x1) << ID_AA64DFR0_PMSVer_SHIFT)
+/* ID_AA64ISAR0_EL1 */
+#define ID_AA64ISAR0_MASK UL(0x0000fffff0fffff0)
+#define ID_AA64ISAR0_AES_SHIFT 4
+#define ID_AA64ISAR0_AES_MASK (UL(0xf) << ID_AA64ISAR0_AES_SHIFT)
+#define ID_AA64ISAR0_AES(x) ((x) & ID_AA64ISAR0_AES_MASK)
+#define ID_AA64ISAR0_AES_NONE (UL(0x0) << ID_AA64ISAR0_AES_SHIFT)
+#define ID_AA64ISAR0_AES_BASE (UL(0x1) << ID_AA64ISAR0_AES_SHIFT)
+#define ID_AA64ISAR0_AES_PMULL (UL(0x2) << ID_AA64ISAR0_AES_SHIFT)
+#define ID_AA64ISAR0_SHA1_SHIFT 8
+#define ID_AA64ISAR0_SHA1_MASK (UL(0xf) << ID_AA64ISAR0_SHA1_SHIFT)
+#define ID_AA64ISAR0_SHA1(x) ((x) & ID_AA64ISAR0_SHA1_MASK)
+#define ID_AA64ISAR0_SHA1_NONE (UL(0x0) << ID_AA64ISAR0_SHA1_SHIFT)
+#define ID_AA64ISAR0_SHA1_BASE (UL(0x1) << ID_AA64ISAR0_SHA1_SHIFT)
+#define ID_AA64ISAR0_SHA2_SHIFT 12
+#define ID_AA64ISAR0_SHA2_MASK (UL(0xf) << ID_AA64ISAR0_SHA2_SHIFT)
+#define ID_AA64ISAR0_SHA2(x) ((x) & ID_AA64ISAR0_SHA2_MASK)
+#define ID_AA64ISAR0_SHA2_NONE (UL(0x0) << ID_AA64ISAR0_SHA2_SHIFT)
+#define ID_AA64ISAR0_SHA2_BASE (UL(0x1) << ID_AA64ISAR0_SHA2_SHIFT)
+#define ID_AA64ISAR0_SHA2_512 (UL(0x2) << ID_AA64ISAR0_SHA2_SHIFT)
+#define ID_AA64ISAR0_CRC32_SHIFT 16
+#define ID_AA64ISAR0_CRC32_MASK (UL(0xf) << ID_AA64ISAR0_CRC32_SHIFT)
+#define ID_AA64ISAR0_CRC32(x) ((x) & ID_AA64ISAR0_CRC32_MASK)
+#define ID_AA64ISAR0_CRC32_NONE (UL(0x0) << ID_AA64ISAR0_CRC32_SHIFT)
+#define ID_AA64ISAR0_CRC32_BASE (UL(0x1) << ID_AA64ISAR0_CRC32_SHIFT)
+#define ID_AA64ISAR0_Atomic_SHIFT 20
+#define ID_AA64ISAR0_Atomic_MASK (UL(0xf) << ID_AA64ISAR0_Atomic_SHIFT)
+#define ID_AA64ISAR0_Atomic(x) ((x) & ID_AA64ISAR0_Atomic_MASK)
+#define ID_AA64ISAR0_Atomic_NONE (UL(0x0) << ID_AA64ISAR0_Atomic_SHIFT)
+#define ID_AA64ISAR0_Atomic_IMPL (UL(0x2) << ID_AA64ISAR0_Atomic_SHIFT)
+#define ID_AA64ISAR0_RDM_SHIFT 28
+#define ID_AA64ISAR0_RDM_MASK (UL(0xf) << ID_AA64ISAR0_RDM_SHIFT)
+#define ID_AA64ISAR0_RDM(x) ((x) & ID_AA64ISAR0_RDM_MASK)
+#define ID_AA64ISAR0_RDM_NONE (UL(0x0) << ID_AA64ISAR0_RDM_SHIFT)
+#define ID_AA64ISAR0_RDM_IMPL (UL(0x1) << ID_AA64ISAR0_RDM_SHIFT)
+#define ID_AA64ISAR0_SHA3_SHIFT 32
+#define ID_AA64ISAR0_SHA3_MASK (UL(0xf) << ID_AA64ISAR0_SHA3_SHIFT)
+#define ID_AA64ISAR0_SHA3(x) ((x) & ID_AA64ISAR0_SHA3_MASK)
+#define ID_AA64ISAR0_SHA3_NONE (UL(0x0) << ID_AA64ISAR0_SHA3_SHIFT)
+#define ID_AA64ISAR0_SHA3_IMPL (UL(0x1) << ID_AA64ISAR0_SHA3_SHIFT)
+#define ID_AA64ISAR0_SM3_SHIFT 36
+#define ID_AA64ISAR0_SM3_MASK (UL(0xf) << ID_AA64ISAR0_SM3_SHIFT)
+#define ID_AA64ISAR0_SM3(x) ((x) & ID_AA64ISAR0_SM3_MASK)
+#define ID_AA64ISAR0_SM3_NONE (UL(0x0) << ID_AA64ISAR0_SM3_SHIFT)
+#define ID_AA64ISAR0_SM3_IMPL (UL(0x1) << ID_AA64ISAR0_SM3_SHIFT)
+#define ID_AA64ISAR0_SM4_SHIFT 40
+#define ID_AA64ISAR0_SM4_MASK (UL(0xf) << ID_AA64ISAR0_SM4_SHIFT)
+#define ID_AA64ISAR0_SM4(x) ((x) & ID_AA64ISAR0_SM4_MASK)
+#define ID_AA64ISAR0_SM4_NONE (UL(0x0) << ID_AA64ISAR0_SM4_SHIFT)
+#define ID_AA64ISAR0_SM4_IMPL (UL(0x1) << ID_AA64ISAR0_SM4_SHIFT)
+#define ID_AA64ISAR0_DP_SHIFT 44
+#define ID_AA64ISAR0_DP_MASK (UL(0xf) << ID_AA64ISAR0_DP_SHIFT)
+#define ID_AA64ISAR0_DP(x) ((x) & ID_AA64ISAR0_DP_MASK)
+#define ID_AA64ISAR0_DP_NONE (UL(0x0) << ID_AA64ISAR0_DP_SHIFT)
+#define ID_AA64ISAR0_DP_IMPL (UL(0x1) << ID_AA64ISAR0_DP_SHIFT)
+/* ID_AA64ISAR1_EL1 */
+#define ID_AA64ISAR1_MASK UL(0x00000000ffffffff)
+#define ID_AA64ISAR1_DPB_SHIFT 0
+#define ID_AA64ISAR1_DPB_MASK (UL(0xf) << ID_AA64ISAR1_DPB_SHIFT)
+#define ID_AA64ISAR1_DPB(x) ((x) & ID_AA64ISAR1_DPB_MASK)
+#define ID_AA64ISAR1_DPB_NONE (UL(0x0) << ID_AA64ISAR1_DPB_SHIFT)
+#define ID_AA64ISAR1_DPB_IMPL (UL(0x1) << ID_AA64ISAR1_DPB_SHIFT)
+#define ID_AA64ISAR1_APA_SHIFT 4
+#define ID_AA64ISAR1_APA_MASK (UL(0xf) << ID_AA64ISAR1_APA_SHIFT)
+#define ID_AA64ISAR1_APA(x) ((x) & ID_AA64ISAR1_APA_MASK)
+#define ID_AA64ISAR1_APA_NONE (UL(0x0) << ID_AA64ISAR1_APA_SHIFT)
+#define ID_AA64ISAR1_APA_IMPL (UL(0x1) << ID_AA64ISAR1_APA_SHIFT)
+#define ID_AA64ISAR1_API_SHIFT 8
+#define ID_AA64ISAR1_API_MASK (UL(0xf) << ID_AA64ISAR1_API_SHIFT)
+#define ID_AA64ISAR1_API(x) ((x) & ID_AA64ISAR1_API_MASK)
+#define ID_AA64ISAR1_API_NONE (UL(0x0) << ID_AA64ISAR1_API_SHIFT)
+#define ID_AA64ISAR1_API_IMPL (UL(0x1) << ID_AA64ISAR1_API_SHIFT)
+#define ID_AA64ISAR1_JSCVT_SHIFT 12
+#define ID_AA64ISAR1_JSCVT_MASK (UL(0xf) << ID_AA64ISAR1_JSCVT_SHIFT)
+#define ID_AA64ISAR1_JSCVT(x) ((x) & ID_AA64ISAR1_JSCVT_MASK)
+#define ID_AA64ISAR1_JSCVT_NONE (UL(0x0) << ID_AA64ISAR1_JSCVT_SHIFT)
+#define ID_AA64ISAR1_JSCVT_IMPL (UL(0x1) << ID_AA64ISAR1_JSCVT_SHIFT)
+#define ID_AA64ISAR1_FCMA_SHIFT 16
+#define ID_AA64ISAR1_FCMA_MASK (UL(0xf) << ID_AA64ISAR1_FCMA_SHIFT)
+#define ID_AA64ISAR1_FCMA(x) ((x) & ID_AA64ISAR1_FCMA_MASK)
+#define ID_AA64ISAR1_FCMA_NONE (UL(0x0) << ID_AA64ISAR1_FCMA_SHIFT)
+#define ID_AA64ISAR1_FCMA_IMPL (UL(0x1) << ID_AA64ISAR1_FCMA_SHIFT)
+#define ID_AA64ISAR1_LRCPC_SHIFT 20
+#define ID_AA64ISAR1_LRCPC_MASK (UL(0xf) << ID_AA64ISAR1_LRCPC_SHIFT)
+#define ID_AA64ISAR1_LRCPC(x) ((x) & ID_AA64ISAR1_LRCPC_MASK)
+#define ID_AA64ISAR1_LRCPC_NONE (UL(0x0) << ID_AA64ISAR1_LRCPC_SHIFT)
+#define ID_AA64ISAR1_LRCPC_IMPL (UL(0x1) << ID_AA64ISAR1_LRCPC_SHIFT)
+#define ID_AA64ISAR1_GPA_SHIFT 24
+#define ID_AA64ISAR1_GPA_MASK (UL(0xf) << ID_AA64ISAR1_GPA_SHIFT)
+#define ID_AA64ISAR1_GPA(x) ((x) & ID_AA64ISAR1_GPA_MASK)
+#define ID_AA64ISAR1_GPA_NONE (UL(0x0) << ID_AA64ISAR1_GPA_SHIFT)
+#define ID_AA64ISAR1_GPA_IMPL (UL(0x1) << ID_AA64ISAR1_GPA_SHIFT)
+#define ID_AA64ISAR1_GPI_SHIFT 28
+#define ID_AA64ISAR1_GPI_MASK (UL(0xf) << ID_AA64ISAR1_GPI_SHIFT)
+#define ID_AA64ISAR1_GPI(x) ((x) & ID_AA64ISAR1_GPI_MASK)
+#define ID_AA64ISAR1_GPI_NONE (UL(0x0) << ID_AA64ISAR1_GPI_SHIFT)
+#define ID_AA64ISAR1_GPI_IMPL (UL(0x1) << ID_AA64ISAR1_GPI_SHIFT)
+/* ID_AA64MMFR0_EL1 */
+#define ID_AA64MMFR0_MASK UL(0x00000000ffffffff)
+#define ID_AA64MMFR0_PARange_SHIFT 0
+#define ID_AA64MMFR0_PARange_MASK (UL(0xf) << ID_AA64MMFR0_PARange_SHIFT)
+#define ID_AA64MMFR0_PARange(x) ((x) & ID_AA64MMFR0_PARange_MASK)
+#define ID_AA64MMFR0_PARange_4G (UL(0x0) << ID_AA64MMFR0_PARange_SHIFT)
+#define ID_AA64MMFR0_PARange_64G (UL(0x1) << ID_AA64MMFR0_PARange_SHIFT)
+#define ID_AA64MMFR0_PARange_1T (UL(0x2) << ID_AA64MMFR0_PARange_SHIFT)
+#define ID_AA64MMFR0_PARange_4T (UL(0x3) << ID_AA64MMFR0_PARange_SHIFT)
+#define ID_AA64MMFR0_PARange_16T (UL(0x4) << ID_AA64MMFR0_PARange_SHIFT)
+#define ID_AA64MMFR0_PARange_256T (UL(0x5) << ID_AA64MMFR0_PARange_SHIFT)
+#define ID_AA64MMFR0_PARange_4P (UL(0x6) << ID_AA64MMFR0_PARange_SHIFT)
+#define ID_AA64MMFR0_ASIDBits_SHIFT 4
+#define ID_AA64MMFR0_ASIDBits_MASK (UL(0xf) << ID_AA64MMFR0_ASIDBits_SHIFT)
+#define ID_AA64MMFR0_ASIDBits(x) ((x) & ID_AA64MMFR0_ASIDBits_MASK)
+#define ID_AA64MMFR0_ASIDBits_8 (UL(0x0) << ID_AA64MMFR0_ASIDBits_SHIFT)
+#define ID_AA64MMFR0_ASIDBits_16 (UL(0x2) << ID_AA64MMFR0_ASIDBits_SHIFT)
+#define ID_AA64MMFR0_BigEnd_SHIFT 8
+#define ID_AA64MMFR0_BigEnd_MASK (UL(0xf) << ID_AA64MMFR0_BigEnd_SHIFT)
+#define ID_AA64MMFR0_BigEnd(x) ((x) & ID_AA64MMFR0_BigEnd_MASK)
+#define ID_AA64MMFR0_BigEnd_FIXED (UL(0x0) << ID_AA64MMFR0_BigEnd_SHIFT)
+#define ID_AA64MMFR0_BigEnd_MIXED (UL(0x1) << ID_AA64MMFR0_BigEnd_SHIFT)
+#define ID_AA64MMFR0_SNSMem_SHIFT 12
+#define ID_AA64MMFR0_SNSMem_MASK (UL(0xf) << ID_AA64MMFR0_SNSMem_SHIFT)
+#define ID_AA64MMFR0_SNSMem(x) ((x) & ID_AA64MMFR0_SNSMem_MASK)
+#define ID_AA64MMFR0_SNSMem_NONE (UL(0x0) << ID_AA64MMFR0_SNSMem_SHIFT)
+#define ID_AA64MMFR0_SNSMem_DISTINCT (UL(0x1) << ID_AA64MMFR0_SNSMem_SHIFT)
+#define ID_AA64MMFR0_BigEndEL0_SHIFT 16
+#define ID_AA64MMFR0_BigEndEL0_MASK (UL(0xf) << ID_AA64MMFR0_BigEndEL0_SHIFT)
+#define ID_AA64MMFR0_BigEndEL0(x) ((x) & ID_AA64MMFR0_BigEndEL0_MASK)
+#define ID_AA64MMFR0_BigEndEL0_FIXED (UL(0x0) << ID_AA64MMFR0_BigEndEL0_SHIFT)
+#define ID_AA64MMFR0_BigEndEL0_MIXED (UL(0x1) << ID_AA64MMFR0_BigEndEL0_SHIFT)
+#define ID_AA64MMFR0_TGran16_SHIFT 20
+#define ID_AA64MMFR0_TGran16_MASK (UL(0xf) << ID_AA64MMFR0_TGran16_SHIFT)
+#define ID_AA64MMFR0_TGran16(x) ((x) & ID_AA64MMFR0_TGran16_MASK)
+#define ID_AA64MMFR0_TGran16_NONE (UL(0x0) << ID_AA64MMFR0_TGran16_SHIFT)
+#define ID_AA64MMFR0_TGran16_IMPL (UL(0x1) << ID_AA64MMFR0_TGran16_SHIFT)
+#define ID_AA64MMFR0_TGran64_SHIFT 24
+#define ID_AA64MMFR0_TGran64_MASK (UL(0xf) << ID_AA64MMFR0_TGran64_SHIFT)
+#define ID_AA64MMFR0_TGran64(x) ((x) & ID_AA64MMFR0_TGran64_MASK)
+#define ID_AA64MMFR0_TGran64_IMPL (UL(0x0) << ID_AA64MMFR0_TGran64_SHIFT)
+#define ID_AA64MMFR0_TGran64_NONE (UL(0xf) << ID_AA64MMFR0_TGran64_SHIFT)
+#define ID_AA64MMFR0_TGran4_SHIFT 28
+#define ID_AA64MMFR0_TGran4_MASK (UL(0xf) << ID_AA64MMFR0_TGran4_SHIFT)
+#define ID_AA64MMFR0_TGran4(x) ((x) & ID_AA64MMFR0_TGran4_MASK)
+#define ID_AA64MMFR0_TGran4_IMPL (UL(0x0) << ID_AA64MMFR0_TGran4_SHIFT)
+#define ID_AA64MMFR0_TGran4_NONE (UL(0xf) << ID_AA64MMFR0_TGran4_SHIFT)
+/* ID_AA64MMFR1_EL1 */
+#define ID_AA64MMFR1_MASK UL(0x00000000ffffffff)
+#define ID_AA64MMFR1_HAFDBS_SHIFT 0
+#define ID_AA64MMFR1_HAFDBS_MASK (UL(0xf) << ID_AA64MMFR1_HAFDBS_SHIFT)
+#define ID_AA64MMFR1_HAFDBS(x) ((x) & ID_AA64MMFR1_HAFDBS_MASK)
+#define ID_AA64MMFR1_HAFDBS_NONE (UL(0x0) << ID_AA64MMFR1_HAFDBS_SHIFT)
+#define ID_AA64MMFR1_HAFDBS_AF (UL(0x1) << ID_AA64MMFR1_HAFDBS_SHIFT)
+#define ID_AA64MMFR1_HAFDBS_AF_DBS (UL(0x2) << ID_AA64MMFR1_HAFDBS_SHIFT)
+#define ID_AA64MMFR1_VMIDBits_SHIFT 4
+#define ID_AA64MMFR1_VMIDBits_MASK (UL(0xf) << ID_AA64MMFR1_VMIDBits_SHIFT)
+#define ID_AA64MMFR1_VMIDBits(x) ((x) & ID_AA64MMFR1_VMIDBits_MASK)
+#define ID_AA64MMFR1_VMIDBits_8 (UL(0x0) << ID_AA64MMFR1_VMIDBits_SHIFT)
+#define ID_AA64MMFR1_VMIDBits_16 (UL(0x2) << ID_AA64MMFR1_VMIDBits_SHIFT)
+#define ID_AA64MMFR1_VH_SHIFT 8
+#define ID_AA64MMFR1_VH_MASK (UL(0xf) << ID_AA64MMFR1_VH_SHIFT)
+#define ID_AA64MMFR1_VH(x) ((x) & ID_AA64MMFR1_VH_MASK)
+#define ID_AA64MMFR1_VH_NONE (UL(0x0) << ID_AA64MMFR1_VH_SHIFT)
+#define ID_AA64MMFR1_VH_IMPL (UL(0x1) << ID_AA64MMFR1_VH_SHIFT)
+#define ID_AA64MMFR1_HPDS_SHIFT 12
+#define ID_AA64MMFR1_HPDS_MASK (UL(0xf) << ID_AA64MMFR1_HPDS_SHIFT)
+#define ID_AA64MMFR1_HPDS(x) ((x) & ID_AA64MMFR1_HPDS_MASK)
+#define ID_AA64MMFR1_HPDS_NONE (UL(0x0) << ID_AA64MMFR1_HPDS_SHIFT)
+#define ID_AA64MMFR1_HPDS_HPD (UL(0x1) << ID_AA64MMFR1_HPDS_SHIFT)
+#define ID_AA64MMFR1_HPDS_TTPBHA (UL(0x2) << ID_AA64MMFR1_HPDS_SHIFT)
+#define ID_AA64MMFR1_LO_SHIFT 16
+#define ID_AA64MMFR1_LO_MASK (UL(0xf) << ID_AA64MMFR1_LO_SHIFT)
+#define ID_AA64MMFR1_LO(x) ((x) & ID_AA64MMFR1_LO_MASK)
+#define ID_AA64MMFR1_LO_NONE (UL(0x0) << ID_AA64MMFR1_LO_SHIFT)
+#define ID_AA64MMFR1_LO_IMPL (UL(0x1) << ID_AA64MMFR1_LO_SHIFT)
+#define ID_AA64MMFR1_PAN_SHIFT 20
+#define ID_AA64MMFR1_PAN_MASK (UL(0xf) << ID_AA64MMFR1_PAN_SHIFT)
+#define ID_AA64MMFR1_PAN(x) ((x) & ID_AA64MMFR1_PAN_MASK)
+#define ID_AA64MMFR1_PAN_NONE (UL(0x0) << ID_AA64MMFR1_PAN_SHIFT)
+#define ID_AA64MMFR1_PAN_IMPL (UL(0x1) << ID_AA64MMFR1_PAN_SHIFT)
+#define ID_AA64MMFR1_PAN_ATS1E1 (UL(0x2) << ID_AA64MMFR1_PAN_SHIFT)
+#define ID_AA64MMFR1_SpecSEI_SHIFT 24
+#define ID_AA64MMFR1_SpecSEI_MASK (UL(0xf) << ID_AA64MMFR1_SpecSEI_SHIFT)
+#define ID_AA64MMFR1_SpecSEI(x) ((x) & ID_AA64MMFR1_SpecSEI_MASK)
+#define ID_AA64MMFR1_SpecSEI_NONE (UL(0x0) << ID_AA64MMFR1_SpecSEI_SHIFT)
+#define ID_AA64MMFR1_SpecSEI_IMPL (UL(0x1) << ID_AA64MMFR1_SpecSEI_SHIFT)
+#define ID_AA64MMFR1_XNX_SHIFT 28
+#define ID_AA64MMFR1_XNX_MASK (UL(0xf) << ID_AA64MMFR1_XNX_SHIFT)
+#define ID_AA64MMFR1_XNX(x) ((x) & ID_AA64MMFR1_XNX_MASK)
+#define ID_AA64MMFR1_XNX_NONE (UL(0x0) << ID_AA64MMFR1_XNX_SHIFT)
+#define ID_AA64MMFR1_XNX_IMPL (UL(0x1) << ID_AA64MMFR1_XNX_SHIFT)
+/* ID_AA64MMFR2_EL1 */
+#define ID_AA64MMFR2_EL1 S3_0_C0_C7_2
+#define ID_AA64MMFR2_MASK UL(0x000000000fffffff)
+#define ID_AA64MMFR2_CnP_SHIFT 0
+#define ID_AA64MMFR2_CnP_MASK (UL(0xf) << ID_AA64MMFR2_CnP_SHIFT)
+#define ID_AA64MMFR2_CnP(x) ((x) & ID_AA64MMFR2_CnP_MASK)
+#define ID_AA64MMFR2_CnP_NONE (UL(0x0) << ID_AA64MMFR2_CnP_SHIFT)
+#define ID_AA64MMFR2_CnP_IMPL (UL(0x1) << ID_AA64MMFR2_CnP_SHIFT)
+#define ID_AA64MMFR2_UAO_SHIFT 4
+#define ID_AA64MMFR2_UAO_MASK (UL(0xf) << ID_AA64MMFR2_UAO_SHIFT)
+#define ID_AA64MMFR2_UAO(x) ((x) & ID_AA64MMFR2_UAO_MASK)
+#define ID_AA64MMFR2_UAO_NONE (UL(0x0) << ID_AA64MMFR2_UAO_SHIFT)
+#define ID_AA64MMFR2_UAO_IMPL (UL(0x1) << ID_AA64MMFR2_UAO_SHIFT)
+#define ID_AA64MMFR2_LSM_SHIFT 8
+#define ID_AA64MMFR2_LSM_MASK (UL(0xf) << ID_AA64MMFR2_LSM_SHIFT)
+#define ID_AA64MMFR2_LSM(x) ((x) & ID_AA64MMFR2_LSM_MASK)
+#define ID_AA64MMFR2_LSM_NONE (UL(0x0) << ID_AA64MMFR2_LSM_SHIFT)
+#define ID_AA64MMFR2_LSM_IMPL (UL(0x1) << ID_AA64MMFR2_LSM_SHIFT)
+#define ID_AA64MMFR2_IESB_SHIFT 12
+#define ID_AA64MMFR2_IESB_MASK (UL(0xf) << ID_AA64MMFR2_IESB_SHIFT)
+#define ID_AA64MMFR2_IESB(x) ((x) & ID_AA64MMFR2_IESB_MASK)
+#define ID_AA64MMFR2_IESB_NONE (UL(0x0) << ID_AA64MMFR2_IESB_SHIFT)
+#define ID_AA64MMFR2_IESB_IMPL (UL(0x1) << ID_AA64MMFR2_IESB_SHIFT)
+#define ID_AA64MMFR2_VARange_SHIFT 16
+#define ID_AA64MMFR2_VARange_MASK (UL(0xf) << ID_AA64MMFR2_VARange_SHIFT)
+#define ID_AA64MMFR2_VARange(x) ((x) & ID_AA64MMFR2_VARange_MASK)
+#define ID_AA64MMFR2_VARange_48 (UL(0x0) << ID_AA64MMFR2_VARange_SHIFT)
+#define ID_AA64MMFR2_VARange_52 (UL(0x1) << ID_AA64MMFR2_VARange_SHIFT)
+#define ID_AA64MMFR2_CCIDX_SHIFT 20
+#define ID_AA64MMFR2_CCIDX_MASK (UL(0xf) << ID_AA64MMFR2_CCIDX_SHIFT)
+#define ID_AA64MMFR2_CCIDX(x) ((x) & ID_AA64MMFR2_CCIDX_MASK)
+#define ID_AA64MMFR2_CCIDX_32 (UL(0x0) << ID_AA64MMFR2_CCIDX_SHIFT)
+#define ID_AA64MMFR2_CCIDX_64 (UL(0x1) << ID_AA64MMFR2_CCIDX_SHIFT)
+#define ID_AA64MMFR2_NV_SHIFT 24
+#define ID_AA64MMFR2_NV_MASK (UL(0xf) << ID_AA64MMFR2_NV_SHIFT)
+#define ID_AA64MMFR2_NV(x) ((x) & ID_AA64MMFR2_NV_MASK)
+#define ID_AA64MMFR2_NV_NONE (UL(0x0) << ID_AA64MMFR2_NV_SHIFT)
+#define ID_AA64MMFR2_NV_IMPL (UL(0x1) << ID_AA64MMFR2_NV_SHIFT)
+/* ID_AA64PFR0_EL1 */
+#define ID_AA64PFR0_MASK UL(0x0000000fffffffff)
+#define ID_AA64PFR0_EL0_SHIFT 0
+#define ID_AA64PFR0_EL0_MASK (UL(0xf) << ID_AA64PFR0_EL0_SHIFT)
+#define ID_AA64PFR0_EL0(x) ((x) & ID_AA64PFR0_EL0_MASK)
+#define ID_AA64PFR0_EL0_64 (UL(0x1) << ID_AA64PFR0_EL0_SHIFT)
+#define ID_AA64PFR0_EL0_64_32 (UL(0x2) << ID_AA64PFR0_EL0_SHIFT)
+#define ID_AA64PFR0_EL1_SHIFT 4
+#define ID_AA64PFR0_EL1_MASK (UL(0xf) << ID_AA64PFR0_EL1_SHIFT)
+#define ID_AA64PFR0_EL1(x) ((x) & ID_AA64PFR0_EL1_MASK)
+#define ID_AA64PFR0_EL1_64 (UL(0x1) << ID_AA64PFR0_EL1_SHIFT)
+#define ID_AA64PFR0_EL1_64_32 (UL(0x2) << ID_AA64PFR0_EL1_SHIFT)
+#define ID_AA64PFR0_EL2_SHIFT 8
+#define ID_AA64PFR0_EL2_MASK (UL(0xf) << ID_AA64PFR0_EL2_SHIFT)
+#define ID_AA64PFR0_EL2(x) ((x) & ID_AA64PFR0_EL2_MASK)
+#define ID_AA64PFR0_EL2_NONE (UL(0x0) << ID_AA64PFR0_EL2_SHIFT)
+#define ID_AA64PFR0_EL2_64 (UL(0x1) << ID_AA64PFR0_EL2_SHIFT)
+#define ID_AA64PFR0_EL2_64_32 (UL(0x2) << ID_AA64PFR0_EL2_SHIFT)
+#define ID_AA64PFR0_EL3_SHIFT 12
+#define ID_AA64PFR0_EL3_MASK (UL(0xf) << ID_AA64PFR0_EL3_SHIFT)
+#define ID_AA64PFR0_EL3(x) ((x) & ID_AA64PFR0_EL3_MASK)
+#define ID_AA64PFR0_EL3_NONE (UL(0x0) << ID_AA64PFR0_EL3_SHIFT)
+#define ID_AA64PFR0_EL3_64 (UL(0x1) << ID_AA64PFR0_EL3_SHIFT)
+#define ID_AA64PFR0_EL3_64_32 (UL(0x2) << ID_AA64PFR0_EL3_SHIFT)
+#define ID_AA64PFR0_FP_SHIFT 16
+#define ID_AA64PFR0_FP_MASK (UL(0xf) << ID_AA64PFR0_FP_SHIFT)
+#define ID_AA64PFR0_FP(x) ((x) & ID_AA64PFR0_FP_MASK)
+#define ID_AA64PFR0_FP_IMPL (UL(0x0) << ID_AA64PFR0_FP_SHIFT)
+#define ID_AA64PFR0_FP_HP (UL(0x1) << ID_AA64PFR0_FP_SHIFT)
+#define ID_AA64PFR0_FP_NONE (UL(0xf) << ID_AA64PFR0_FP_SHIFT)
+#define ID_AA64PFR0_AdvSIMD_SHIFT 20
+#define ID_AA64PFR0_AdvSIMD_MASK (UL(0xf) << ID_AA64PFR0_AdvSIMD_SHIFT)
+#define ID_AA64PFR0_AdvSIMD(x) ((x) & ID_AA64PFR0_AdvSIMD_MASK)
+#define ID_AA64PFR0_AdvSIMD_IMPL (UL(0x0) << ID_AA64PFR0_AdvSIMD_SHIFT)
+#define ID_AA64PFR0_AdvSIMD_HP (UL(0x1) << ID_AA64PFR0_AdvSIMD_SHIFT)
+#define ID_AA64PFR0_AdvSIMD_NONE (UL(0xf) << ID_AA64PFR0_AdvSIMD_SHIFT)
+#define ID_AA64PFR0_GIC_BITS 0x4 /* Number of bits in GIC field */
+#define ID_AA64PFR0_GIC_SHIFT 24
+#define ID_AA64PFR0_GIC_MASK (UL(0xf) << ID_AA64PFR0_GIC_SHIFT)
+#define ID_AA64PFR0_GIC(x) ((x) & ID_AA64PFR0_GIC_MASK)
+#define ID_AA64PFR0_GIC_CPUIF_NONE (UL(0x0) << ID_AA64PFR0_GIC_SHIFT)
+#define ID_AA64PFR0_GIC_CPUIF_EN (UL(0x1) << ID_AA64PFR0_GIC_SHIFT)
+#define ID_AA64PFR0_RAS_SHIFT 28
+#define ID_AA64PFR0_RAS_MASK (UL(0xf) << ID_AA64PFR0_RAS_SHIFT)
+#define ID_AA64PFR0_RAS(x) ((x) & ID_AA64PFR0_RAS_MASK)
+#define ID_AA64PFR0_RAS_NONE (UL(0x0) << ID_AA64PFR0_RAS_SHIFT)
+#define ID_AA64PFR0_RAS_V1 (UL(0x1) << ID_AA64PFR0_RAS_SHIFT)
+#define ID_AA64PFR0_SVE_SHIFT 32
+#define ID_AA64PFR0_SVE_MASK (UL(0xf) << ID_AA64PFR0_SVE_SHIFT)
+#define ID_AA64PFR0_SVE(x) ((x) & ID_AA64PFR0_SVE_MASK)
+#define ID_AA64PFR0_SVE_NONE (UL(0x0) << ID_AA64PFR0_SVE_SHIFT)
+#define ID_AA64PFR0_SVE_IMPL (UL(0x1) << ID_AA64PFR0_SVE_SHIFT)
+/* MAIR_EL1 - Memory Attribute Indirection Register */
+#define MAIR_ATTR_MASK(idx) (0xff << ((n)* 8))
+#define MAIR_ATTR(attr, idx) ((attr) << ((idx) * 8))
+#define MAIR_DEVICE_nGnRnE 0x00
+#define MAIR_NORMAL_NC 0x44
+#define MAIR_NORMAL_WT 0xbb
+#define MAIR_NORMAL_WB 0xff
+/* PAR_EL1 - Physical Address Register */
+#define PAR_F_SHIFT 0
+#define PAR_F (0x1 << PAR_F_SHIFT)
+#define PAR_SUCCESS(x) (((x) & PAR_F) == 0)
+/* When PAR_F == 0 (success) */
+#define PAR_SH_SHIFT 7
+#define PAR_SH_MASK (0x3 << PAR_SH_SHIFT)
+#define PAR_NS_SHIFT 9
+#define PAR_NS_MASK (0x3 << PAR_NS_SHIFT)
+#define PAR_PA_SHIFT 12
+#define PAR_PA_MASK 0x0000fffffffff000
+#define PAR_ATTR_SHIFT 56
+#define PAR_ATTR_MASK (0xff << PAR_ATTR_SHIFT)
+/* When PAR_F == 1 (aborted) */
+#define PAR_FST_SHIFT 1
+#define PAR_FST_MASK (0x3f << PAR_FST_SHIFT)
+#define PAR_PTW_SHIFT 8
+#define PAR_PTW_MASK (0x1 << PAR_PTW_SHIFT)
+#define PAR_S_SHIFT 9
+#define PAR_S_MASK (0x1 << PAR_S_SHIFT)
+/* SCTLR_EL1 - System Control Register */
+#define SCTLR_RES0 0xc8222440 /* Reserved ARMv8.0, write 0 */
+#define SCTLR_RES1 0x30d00800 /* Reserved ARMv8.0, write 1 */
+#define SCTLR_M 0x00000001
+#define SCTLR_A 0x00000002
+#define SCTLR_C 0x00000004
+#define SCTLR_SA 0x00000008
+#define SCTLR_SA0 0x00000010
+#define SCTLR_CP15BEN 0x00000020
+/* Bit 6 is reserved */
+#define SCTLR_ITD 0x00000080
+#define SCTLR_SED 0x00000100
+#define SCTLR_UMA 0x00000200
+/* Bit 10 is reserved */
+/* Bit 11 is reserved */
+#define SCTLR_I 0x00001000
+#define SCTLR_EnDB 0x00002000 /* ARMv8.3 */
+#define SCTLR_DZE 0x00004000
+#define SCTLR_UCT 0x00008000
+#define SCTLR_nTWI 0x00010000
+/* Bit 17 is reserved */
+#define SCTLR_nTWE 0x00040000
+#define SCTLR_WXN 0x00080000
+/* Bit 20 is reserved */
+#define SCTLR_IESB 0x00200000 /* ARMv8.2 */
+/* Bit 22 is reserved */
+#define SCTLR_SPAN 0x00800000 /* ARMv8.1 */
+#define SCTLR_EOE 0x01000000
+#define SCTLR_EE 0x02000000
+#define SCTLR_UCI 0x04000000
+#define SCTLR_EnDA 0x08000000 /* ARMv8.3 */
+#define SCTLR_nTLSMD 0x10000000 /* ARMv8.2 */
+#define SCTLR_LSMAOE 0x20000000 /* ARMv8.2 */
+#define SCTLR_EnIB 0x40000000 /* ARMv8.3 */
+#define SCTLR_EnIA 0x80000000 /* ARMv8.3 */
+/* SPSR_EL1 */
+ * When the exception is taken in AArch64:
+ * M[3:2] is the exception level
+ * M[1] is unused
+ * M[0] is the SP select:
+ * 0: always SP0
+ * 1: current ELs SP
+#define PSR_M_EL0t 0x00000000
+#define PSR_M_EL1t 0x00000004
+#define PSR_M_EL1h 0x00000005
+#define PSR_M_EL2t 0x00000008
+#define PSR_M_EL2h 0x00000009
+#define PSR_M_MASK 0x0000000f
+#define PSR_AARCH32 0x00000010
+#define PSR_F 0x00000040
+#define PSR_I 0x00000080
+#define PSR_A 0x00000100
+#define PSR_D 0x00000200
+#define PSR_IL 0x00100000
+#define PSR_SS 0x00200000
+#define PSR_V 0x10000000
+#define PSR_C 0x20000000
+#define PSR_Z 0x40000000
+#define PSR_N 0x80000000
+#define PSR_FLAGS 0xf0000000
+/* TCR_EL1 - Translation Control Register */
+#define TCR_ASID_16 (1 << 36)
+#define TCR_IPS_SHIFT 32
+#define TCR_IPS_32BIT (0 << TCR_IPS_SHIFT)
+#define TCR_IPS_36BIT (1 << TCR_IPS_SHIFT)
+#define TCR_IPS_40BIT (2 << TCR_IPS_SHIFT)
+#define TCR_IPS_42BIT (3 << TCR_IPS_SHIFT)
+#define TCR_IPS_44BIT (4 << TCR_IPS_SHIFT)
+#define TCR_IPS_48BIT (5 << TCR_IPS_SHIFT)
+#define TCR_TG1_SHIFT 30
+#define TCR_TG1_16K (1 << TCR_TG1_SHIFT)
+#define TCR_TG1_4K (2 << TCR_TG1_SHIFT)
+#define TCR_TG1_64K (3 << TCR_TG1_SHIFT)
+#define TCR_SH1_SHIFT 28
+#define TCR_SH1_IS (0x3UL << TCR_SH1_SHIFT)
+#define TCR_ORGN1_SHIFT 26
+#define TCR_ORGN1_WBWA (0x1UL << TCR_ORGN1_SHIFT)
+#define TCR_IRGN1_SHIFT 24
+#define TCR_IRGN1_WBWA (0x1UL << TCR_IRGN1_SHIFT)
+#define TCR_SH0_SHIFT 12
+#define TCR_SH0_IS (0x3UL << TCR_SH0_SHIFT)
+#define TCR_ORGN0_SHIFT 10
+#define TCR_ORGN0_WBWA (0x1UL << TCR_ORGN0_SHIFT)
+#define TCR_IRGN0_SHIFT 8
+#define TCR_IRGN0_WBWA (0x1UL << TCR_IRGN0_SHIFT)
+#define TCR_CACHE_ATTRS ((TCR_IRGN0_WBWA | TCR_IRGN1_WBWA) |\
+ (TCR_ORGN0_WBWA | TCR_ORGN1_WBWA))
+#ifdef SMP
+#define TCR_SMP_ATTRS (TCR_SH0_IS | TCR_SH1_IS)
+#else
+#define TCR_SMP_ATTRS 0
+#endif
+#define TCR_T1SZ_SHIFT 16
+#define TCR_T0SZ_SHIFT 0
+#define TCR_T1SZ(x) ((x) << TCR_T1SZ_SHIFT)
+#define TCR_T0SZ(x) ((x) << TCR_T0SZ_SHIFT)
+#define TCR_TxSZ(x) (TCR_T1SZ(x) | TCR_T0SZ(x))
+/* Saved Program Status Register */
+#define DBG_SPSR_SS (0x1 << 21)
+/* Monitor Debug System Control Register */
+#define DBG_MDSCR_SS (0x1 << 0)
+#define DBG_MDSCR_KDE (0x1 << 13)
+#define DBG_MDSCR_MDE (0x1 << 15)
+/* Perfomance Monitoring Counters */
+#define PMCR_E (1 << 0) /* Enable all counters */
+#define PMCR_P (1 << 1) /* Reset all counters */
+#define PMCR_C (1 << 2) /* Clock counter reset */
+#define PMCR_D (1 << 3) /* CNTR counts every 64 clk cycles */
+#define PMCR_X (1 << 4) /* Export to ext. monitoring (ETM) */
+#define PMCR_DP (1 << 5) /* Disable CCNT if non-invasive debug*/
+#define PMCR_LC (1 << 6) /* Long cycle count enable */
+#define PMCR_IMP_SHIFT 24 /* Implementer code */
+#define PMCR_IMP_MASK (0xff << PMCR_IMP_SHIFT)
+#define PMCR_IDCODE_SHIFT 16 /* Identification code */
+#define PMCR_IDCODE_MASK (0xff << PMCR_IDCODE_SHIFT)
+#define PMCR_IDCODE_CORTEX_A57 0x01
+#define PMCR_IDCODE_CORTEX_A72 0x02
+#define PMCR_IDCODE_CORTEX_A53 0x03
+#define PMCR_N_SHIFT 11 /* Number of counters implemented */
+#define PMCR_N_MASK (0x1f << PMCR_N_SHIFT)
+#endif /* !_MACHINE_ARMREG_H_ */
diff --git a/freebsd/sys/arm64/include/machine/cpu.h b/freebsd/sys/arm64/include/machine/cpu.h
index 00000000..5663e50e
--- /dev/null
+++ b/freebsd/sys/arm64/include/machine/cpu.h
@@ -0,0 +1,203 @@
+ * Copyright (c) 1990 The Regents of the University of California.
+ * Copyright (c) 2014-2016 The FreeBSD Foundation
+ * This code is derived from software contributed to Berkeley by
+ * William Jolitz.
+ * Portions of this software were developed by Andrew Turner
+ * under sponsorship from the FreeBSD Foundation
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ * SUCH DAMAGE.
+ * from: @(#)cpu.h 5.4 (Berkeley) 5/9/91
+ * from: FreeBSD: src/sys/i386/include/cpu.h,v 1.62 2001/06/29
+ * $FreeBSD$
+#ifndef _MACHINE_CPU_H_
+#define _MACHINE_CPU_H_
+#include <machine/atomic.h>
+#include <machine/frame.h>
+#include <machine/armreg.h>
+#define TRAPF_PC(tfp) ((tfp)->tf_lr)
+#define TRAPF_USERMODE(tfp) (((tfp)->tf_spsr & PSR_M_MASK) == PSR_M_EL0t)
+#define cpu_getstack(td) ((td)->td_frame->tf_sp)
+#define cpu_setstack(td, sp) ((td)->td_frame->tf_sp = (sp))
+#define cpu_spinwait() __asm __volatile("yield" ::: "memory")
+#define cpu_lock_delay() DELAY(1)
+/* Extract CPU affinity levels 0-3 */
+#define CPU_AFF0(mpidr) (u_int)(((mpidr) >> 0) & 0xff)
+#define CPU_AFF1(mpidr) (u_int)(((mpidr) >> 8) & 0xff)
+#define CPU_AFF2(mpidr) (u_int)(((mpidr) >> 16) & 0xff)
+#define CPU_AFF3(mpidr) (u_int)(((mpidr) >> 32) & 0xff)
+#define CPU_AFF0_MASK 0xffUL
+#define CPU_AFF1_MASK 0xff00UL
+#define CPU_AFF2_MASK 0xff0000UL
+#define CPU_AFF3_MASK 0xff00000000UL
+#define CPU_AFF_MASK (CPU_AFF0_MASK | CPU_AFF1_MASK | \
+ CPU_AFF2_MASK| CPU_AFF3_MASK) /* Mask affinity fields in MPIDR_EL1 */
+#ifdef _KERNEL
+#define CPU_IMPL_ARM 0x41
+#define CPU_IMPL_BROADCOM 0x42
+#define CPU_IMPL_CAVIUM 0x43
+#define CPU_IMPL_DEC 0x44
+#define CPU_IMPL_INFINEON 0x49
+#define CPU_IMPL_FREESCALE 0x4D
+#define CPU_IMPL_NVIDIA 0x4E
+#define CPU_IMPL_APM 0x50
+#define CPU_IMPL_QUALCOMM 0x51
+#define CPU_IMPL_MARVELL 0x56
+#define CPU_IMPL_INTEL 0x69
+/* ARM Part numbers */
+#define CPU_PART_FOUNDATION 0xD00
+#define CPU_PART_CORTEX_A35 0xD04
+#define CPU_PART_CORTEX_A53 0xD03
+#define CPU_PART_CORTEX_A55 0xD05
+#define CPU_PART_CORTEX_A57 0xD07
+#define CPU_PART_CORTEX_A72 0xD08
+#define CPU_PART_CORTEX_A73 0xD09
+#define CPU_PART_CORTEX_A75 0xD0A
+/* Cavium Part numbers */
+#define CPU_PART_THUNDERX 0x0A1
+#define CPU_PART_THUNDERX_81XX 0x0A2
+#define CPU_PART_THUNDERX_83XX 0x0A3
+#define CPU_PART_THUNDERX2 0x0AF
+#define CPU_REV_THUNDERX_1_0 0x00
+#define CPU_REV_THUNDERX_1_1 0x01
+#define CPU_REV_THUNDERX2_0 0x00
+/* APM / Ampere Part Number */
+#define CPU_PART_EMAG8180 0x000
+#define CPU_IMPL(midr) (((midr) >> 24) & 0xff)
+#define CPU_PART(midr) (((midr) >> 4) & 0xfff)
+#define CPU_VAR(midr) (((midr) >> 20) & 0xf)
+#define CPU_REV(midr) (((midr) >> 0) & 0xf)
+#define CPU_IMPL_TO_MIDR(val) (((val) & 0xff) << 24)
+#define CPU_PART_TO_MIDR(val) (((val) & 0xfff) << 4)
+#define CPU_VAR_TO_MIDR(val) (((val) & 0xf) << 20)
+#define CPU_REV_TO_MIDR(val) (((val) & 0xf) << 0)
+#define CPU_IMPL_MASK (0xff << 24)
+#define CPU_PART_MASK (0xfff << 4)
+#define CPU_VAR_MASK (0xf << 20)
+#define CPU_REV_MASK (0xf << 0)
+#define CPU_ID_RAW(impl, part, var, rev) \
+ (CPU_IMPL_TO_MIDR((impl)) | \
+ CPU_PART_TO_MIDR((part)) | CPU_VAR_TO_MIDR((var)) | \
+ CPU_REV_TO_MIDR((rev)))
+#define CPU_MATCH(mask, impl, part, var, rev) \
+ (((mask) & PCPU_GET(midr)) == \
+ ((mask) & CPU_ID_RAW((impl), (part), (var), (rev))))
+#define CPU_MATCH_RAW(mask, devid) \
+ (((mask) & PCPU_GET(midr)) == ((mask) & (devid)))
+ * Chip-specific errata. This defines are intended to be
+ * booleans used within if statements. When an appropriate
+ * kernel option is disabled, these defines must be defined
+ * as 0 to allow the compiler to remove a dead code thus
+ * produce better optimized kernel image.
+ * Vendor: Cavium
+ * Chip: ThunderX
+ * Revision(s): Pass 1.0, Pass 1.1
+#ifdef THUNDERX_PASS_1_1_ERRATA
+#define CPU_MATCH_ERRATA_CAVIUM_THUNDERX_1_1 \
+ (CPU_MATCH(CPU_IMPL_MASK | CPU_PART_MASK | CPU_REV_MASK, \
+ CPU_IMPL_CAVIUM, CPU_PART_THUNDERX, 0, CPU_REV_THUNDERX_1_0) || \
+ CPU_MATCH(CPU_IMPL_MASK | CPU_PART_MASK | CPU_REV_MASK, \
+ CPU_IMPL_CAVIUM, CPU_PART_THUNDERX, 0, CPU_REV_THUNDERX_1_1))
+#else
+#define CPU_MATCH_ERRATA_CAVIUM_THUNDERX_1_1 0
+#endif
+extern char btext[];
+extern char etext[];
+extern uint64_t __cpu_affinity[];
+void cpu_halt(void) __dead2;
+void cpu_reset(void) __dead2;
+void fork_trampoline(void);
+void identify_cpu(void);
+void install_cpu_errata(void);
+void print_cpu_features(u_int);
+void swi_vm(void *v);
+#define CPU_AFFINITY(cpu) __cpu_affinity[(cpu)]
+#define CPU_CURRENT_SOCKET \
+ (CPU_AFF2(CPU_AFFINITY(PCPU_GET(cpuid))))
+static __inline uint64_t
+get_cyclecount(void)
+ uint64_t ret;
+ ret = READ_SPECIALREG(cntvct_el0);
+ return (ret);
+#define ADDRESS_TRANSLATE_FUNC(stage) \
+static inline uint64_t \
+arm64_address_translate_ ##stage (uint64_t addr) \
+ uint64_t ret; \
+ __asm __volatile( \
+ "at " __STRING(stage) ", %1 \n" \
+ "mrs %0, par_el1" : "=r"(ret) : "r"(addr)); \
+ return (ret); \
+ADDRESS_TRANSLATE_FUNC(s1e0r)
+ADDRESS_TRANSLATE_FUNC(s1e0w)
+ADDRESS_TRANSLATE_FUNC(s1e1r)
+ADDRESS_TRANSLATE_FUNC(s1e1w)
+#endif
+#endif /* !_MACHINE_CPU_H_ */
diff --git a/freebsd/sys/arm64/include/machine/cpufunc.h b/freebsd/sys/arm64/include/machine/cpufunc.h
index 00000000..c3e2a36e
--- /dev/null
+++ b/freebsd/sys/arm64/include/machine/cpufunc.h
@@ -0,0 +1,153 @@
+ * Copyright (c) 2014 Andrew Turner
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _MACHINE_CPUFUNC_H_
+#define _MACHINE_CPUFUNC_H_
+static __inline void
+breakpoint(void)
+ __asm("brk #0");
+#ifdef _KERNEL
+void pan_enable(void);
+static __inline register_t
+dbg_disable(void)
+ uint32_t ret;
+ __asm __volatile(
+ "mrs %x0, daif \n"
+ "msr daifset, #8 \n"
+ : "=&r" (ret));
+ return (ret);
+dbg_enable(void)
+ __asm __volatile("msr daifclr, #8");
+intr_disable(void)
+ /* DAIF is a 32-bit register */
+ uint32_t ret;
+ __asm __volatile(
+ "msr daifset, #2 \n"
+ : "=&r" (ret));
+ return (ret);
+intr_restore(register_t s)
+ WRITE_SPECIALREG(daif, s);
+intr_enable(void)
+ __asm __volatile("msr daifclr, #2");
+get_midr(void)
+ uint64_t midr;
+ midr = READ_SPECIALREG(midr_el1);
+ return (midr);
+get_mpidr(void)
+ uint64_t mpidr;
+ mpidr = READ_SPECIALREG(mpidr_el1);
+ return (mpidr);
+clrex(void)
+ * Ensure compiler barrier, otherwise the monitor clear might
+ * occur too late for us ?
+ __asm __volatile("clrex" : : : "memory");
+extern int64_t dcache_line_size;
+extern int64_t icache_line_size;
+extern int64_t idcache_line_size;
+extern int64_t dczva_line_size;
+#define cpu_nullop() arm64_nullop()
+#define cpufunc_nullop() arm64_nullop()
+#define cpu_setttb(a) arm64_setttb(a)
+#define cpu_tlb_flushID() arm64_tlb_flushID()
+#define cpu_dcache_wbinv_range(a, s) arm64_dcache_wbinv_range((a), (s))
+#define cpu_dcache_inv_range(a, s) arm64_dcache_inv_range((a), (s))
+#define cpu_dcache_wb_range(a, s) arm64_dcache_wb_range((a), (s))
+#define cpu_idcache_wbinv_range(a, s) arm64_idcache_wbinv_range((a), (s))
+#define cpu_icache_sync_range(a, s) arm64_icache_sync_range((a), (s))
+void arm64_nullop(void);
+void arm64_setttb(vm_offset_t);
+void arm64_tlb_flushID(void);
+void arm64_tlb_flushID_SE(vm_offset_t);
+void arm64_icache_sync_range(vm_offset_t, vm_size_t);
+void arm64_idcache_wbinv_range(vm_offset_t, vm_size_t);
+void arm64_dcache_wbinv_range(vm_offset_t, vm_size_t);
+void arm64_dcache_inv_range(vm_offset_t, vm_size_t);
+void arm64_dcache_wb_range(vm_offset_t, vm_size_t);
+#endif /* _KERNEL */
+#endif /* _MACHINE_CPUFUNC_H_ */
diff --git a/freebsd/sys/arm64/include/machine/in_cksum.h b/freebsd/sys/arm64/include/machine/in_cksum.h
index 00000000..d55b838b
--- /dev/null
+++ b/freebsd/sys/arm64/include/machine/in_cksum.h
@@ -0,0 +1,83 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * are met:
+ * SUCH DAMAGE.
+ * from tahoe: in_cksum.c 1.2 86/01/05
+ * from: @(#)in_cksum.c 1.3 (Berkeley) 1/19/91
+ * from: Id: in_cksum.c,v 1.8 1995/12/03 18:35:19 bde Exp
+ * from: src/sys/alpha/include/in_cksum.h,v 1.7 2005/03/02 21:33:20 joerg
+ * $FreeBSD$
+#ifndef _MACHINE_IN_CKSUM_H_
+#define _MACHINE_IN_CKSUM_H_ 1
+#define in_cksum(m, len) in_cksum_skip(m, len, 0)
+#if defined(IPVERSION) && (IPVERSION == 4)
+ * It it useful to have an Internet checksum routine which is inlineable
+ * and optimized specifically for the task of computing IP header checksums
+ * in the normal case (where there are no options and the header length is
+ * therefore always exactly five 32-bit words.
+#ifdef __CC_SUPPORTS___INLINE
+in_cksum_update(struct ip *ip)
+ int __tmpsum;
+ __tmpsum = (int)ntohs(ip->ip_sum) + 256;
+ ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16));
+#else
+#define in_cksum_update(ip) \
+ do { \
+ int __tmpsum; \
+ __tmpsum = (int)ntohs(ip->ip_sum) + 256; \
+ ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16)); \
+ } while(0)
+#endif
+#endif
+#ifdef _KERNEL
+u_int in_cksum_hdr(const struct ip *ip);
+#endif
+u_short in_addword(u_short sum, u_short b);
+u_short in_pseudo(u_int sum, u_int b, u_int c);
+u_short in_cksum_skip(struct mbuf *m, int len, int skip);
+#endif
+#endif /* _MACHINE_IN_CKSUM_H_ */
diff --git a/freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_llsc.h b/freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_llsc.h
index 00000000..aa4e3090
--- /dev/null
+++ b/freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_llsc.h
@@ -0,0 +1,352 @@
+ * Copyright 2009-2016 Samy Al Bahra.
+ * Copyright 2013-2016 Olivier Houchard.
+ * are met:
+ * SUCH DAMAGE.
+#ifndef CK_PR_AARCH64_LLSC_H
+#define CK_PR_AARCH64_LLSC_H
+#ifndef CK_PR_H
+#error Do not include this file directly, use ck_pr.h
+#endif
+CK_CC_INLINE static bool
+ck_pr_cas_64_2_value(uint64_t target[2], uint64_t compare[2], uint64_t set[2], uint64_t value[2])
+ uint64_t tmp1, tmp2;
+ __asm__ __volatile__("1:"
+ "ldxp %0, %1, [%4];"
+ "mov %2, %0;"
+ "mov %3, %1;"
+ "eor %0, %0, %5;"
+ "eor %1, %1, %6;"
+ "orr %1, %0, %1;"
+ "mov %w0, #0;"
+ "cbnz %1, 2f;"
+ "stxp %w0, %7, %8, [%4];"
+ "cbnz %w0, 1b;"
+ "mov %w0, #1;"
+ "2:"
+ : "=&r" (tmp1), "=&r" (tmp2), "=&r" (value[0]), "=&r" (value[1])
+ : "r" (target), "r" (compare[0]), "r" (compare[1]), "r" (set[0]), "r" (set[1])
+ : "cc", "memory");
+ return (tmp1);
+ck_pr_cas_ptr_2_value(void *target, void *compare, void *set, void *value)
+ return (ck_pr_cas_64_2_value(CK_CPP_CAST(uint64_t *, target),
+ CK_CPP_CAST(uint64_t *, compare),
+ CK_CPP_CAST(uint64_t *, set),
+ CK_CPP_CAST(uint64_t *, value)));
+ck_pr_cas_64_2(uint64_t target[2], uint64_t compare[2], uint64_t set[2])
+ "ldxp %0, %1, [%2];"
+ "eor %0, %0, %3;"
+ "eor %1, %1, %4;"
+ "orr %1, %0, %1;"
+ "mov %w0, #0;"
+ "cbnz %1, 2f;"
+ "stxp %w0, %5, %6, [%2];"
+ "cbnz %w0, 1b;"
+ "mov %w0, #1;"
+ "2:"
+ return (tmp1);
+ck_pr_cas_ptr_2(void *target, void *compare, void *set)
+ return (ck_pr_cas_64_2(CK_CPP_CAST(uint64_t *, target),
+ CK_CPP_CAST(uint64_t *, set)));
+#define CK_PR_CAS(N, M, T, W, R) \
+ CK_CC_INLINE static bool \
+ ck_pr_cas_##N##_value(M *target, T compare, T set, M *value) \
+ T previous; \
+ T tmp; \
+ __asm__ __volatile__("1:" \
+ "ldxr" W " %" R "0, [%2];" \
+ "cmp %" R "0, %" R "4;" \
+ "b.ne 2f;" \
+ "stxr" W " %w1, %" R "3, [%2];" \
+ "cbnz %w1, 1b;" \
+ "2:" \
+ : "=&r" (previous), \
+ "=&r" (tmp) \
+ : "r" (target), \
+ "r" (set), \
+ "r" (compare) \
+ : "memory", "cc"); \
+ *(T *)value = previous; \
+ return (previous == compare); \
+ ck_pr_cas_##N(M *target, T compare, T set) \
+ T previous; \
+ T tmp; \
+ __asm__ __volatile__( \
+ "1:" \
+ "b.ne 2f;" \
+ "cbnz %w1, 1b;" \
+ "2:" \
+ "=&r" (tmp) \
+ : "r" (target), \
+ "r" (set), \
+ "r" (compare) \
+CK_PR_CAS(ptr, void, void *, "", "")
+#define CK_PR_CAS_S(N, M, W, R) CK_PR_CAS(N, M, M, W, R)
+CK_PR_CAS_S(64, uint64_t, "", "")
+#ifndef CK_PR_DISABLE_DOUBLE
+CK_PR_CAS_S(double, double, "", "")
+#endif
+CK_PR_CAS_S(32, uint32_t, "", "w")
+CK_PR_CAS_S(uint, unsigned int, "", "w")
+CK_PR_CAS_S(int, int, "", "w")
+CK_PR_CAS_S(16, uint16_t, "h", "w")
+CK_PR_CAS_S(8, uint8_t, "b", "w")
+CK_PR_CAS_S(short, short, "h", "w")
+CK_PR_CAS_S(char, char, "b", "w")
+#undef CK_PR_CAS_S
+#undef CK_PR_CAS
+#define CK_PR_FAS(N, M, T, W, R) \
+ CK_CC_INLINE static T \
+ ck_pr_fas_##N(M *target, T v) \
+ T previous; \
+ T tmp; \
+ "stxr" W " %w1, %" R "3, [%2];"\
+ "cbnz %w1, 1b;" \
+ "=&r" (tmp) \
+ : "r" (target), \
+ "r" (v) \
+ return (previous); \
+CK_PR_FAS(64, uint64_t, uint64_t, "", "")
+CK_PR_FAS(32, uint32_t, uint32_t, "", "w")
+CK_PR_FAS(ptr, void, void *, "", "")
+CK_PR_FAS(int, int, int, "", "w")
+CK_PR_FAS(uint, unsigned int, unsigned int, "", "w")
+CK_PR_FAS(16, uint16_t, uint16_t, "h", "w")
+CK_PR_FAS(8, uint8_t, uint8_t, "b", "w")
+CK_PR_FAS(short, short, short, "h", "w")
+CK_PR_FAS(char, char, char, "b", "w")
+#undef CK_PR_FAS
+#define CK_PR_UNARY(O, N, M, T, I, W, R) \
+ CK_CC_INLINE static void \
+ ck_pr_##O##_##N(M *target) \
+ T previous = 0; \
+ T tmp = 0; \
+ I ";" \
+ "stxr" W " %w1, %" R "0, [%2];" \
+ "cbnz %w1, 1b;" \
+ "=&r" (tmp) \
+ : "r" (target) \
+ return; \
+CK_PR_UNARY(inc, ptr, void, void *, "add %0, %0, #1", "", "")
+CK_PR_UNARY(dec, ptr, void, void *, "sub %0, %0, #1", "", "")
+CK_PR_UNARY(not, ptr, void, void *, "mvn %0, %0", "", "")
+CK_PR_UNARY(inc, 64, uint64_t, uint64_t, "add %0, %0, #1", "", "")
+CK_PR_UNARY(dec, 64, uint64_t, uint64_t, "sub %0, %0, #1", "", "")
+CK_PR_UNARY(not, 64, uint64_t, uint64_t, "mvn %0, %0", "", "")
+#define CK_PR_UNARY_S(S, T, W) \
+ CK_PR_UNARY(inc, S, T, T, "add %w0, %w0, #1", W, "w") \
+ CK_PR_UNARY(dec, S, T, T, "sub %w0, %w0, #1", W, "w") \
+ CK_PR_UNARY(not, S, T, T, "mvn %w0, %w0", W, "w") \
+CK_PR_UNARY_S(32, uint32_t, "")
+CK_PR_UNARY_S(uint, unsigned int, "")
+CK_PR_UNARY_S(int, int, "")
+CK_PR_UNARY_S(16, uint16_t, "h")
+CK_PR_UNARY_S(8, uint8_t, "b")
+CK_PR_UNARY_S(short, short, "h")
+CK_PR_UNARY_S(char, char, "b")
+#undef CK_PR_UNARY_S
+#undef CK_PR_UNARY
+#define CK_PR_BINARY(O, N, M, T, I, W, R) \
+ ck_pr_##O##_##N(M *target, T delta) \
+ T previous; \
+ T tmp; \
+ "ldxr" W " %" R "0, [%2];"\
+ I " %" R "0, %" R "0, %" R "3;" \
+ "cbnz %w1, 1b;" \
+ "=&r" (tmp) \
+ : "r" (target), \
+ "r" (delta) \
+ return; \
+CK_PR_BINARY(and, ptr, void, uintptr_t, "and", "", "")
+CK_PR_BINARY(add, ptr, void, uintptr_t, "add", "", "")
+CK_PR_BINARY(or, ptr, void, uintptr_t, "orr", "", "")
+CK_PR_BINARY(sub, ptr, void, uintptr_t, "sub", "", "")
+CK_PR_BINARY(xor, ptr, void, uintptr_t, "eor", "", "")
+CK_PR_BINARY(and, 64, uint64_t, uint64_t, "and", "", "")
+CK_PR_BINARY(add, 64, uint64_t, uint64_t, "add", "", "")
+CK_PR_BINARY(or, 64, uint64_t, uint64_t, "orr", "", "")
+CK_PR_BINARY(sub, 64, uint64_t, uint64_t, "sub", "", "")
+CK_PR_BINARY(xor, 64, uint64_t, uint64_t, "eor", "", "")
+#define CK_PR_BINARY_S(S, T, W) \
+ CK_PR_BINARY(and, S, T, T, "and", W, "w") \
+ CK_PR_BINARY(add, S, T, T, "add", W, "w") \
+ CK_PR_BINARY(or, S, T, T, "orr", W, "w") \
+ CK_PR_BINARY(sub, S, T, T, "sub", W, "w") \
+ CK_PR_BINARY(xor, S, T, T, "eor", W, "w")
+CK_PR_BINARY_S(32, uint32_t, "")
+CK_PR_BINARY_S(uint, unsigned int, "")
+CK_PR_BINARY_S(int, int, "")
+CK_PR_BINARY_S(16, uint16_t, "h")
+CK_PR_BINARY_S(8, uint8_t, "b")
+CK_PR_BINARY_S(short, short, "h")
+CK_PR_BINARY_S(char, char, "b")
+#undef CK_PR_BINARY_S
+CK_CC_INLINE static void *
+ck_pr_faa_ptr(void *target, uintptr_t delta)
+ uintptr_t previous, r, tmp;
+ "ldxr %0, [%3];"
+ "add %1, %4, %0;"
+ "stxr %w2, %1, [%3];"
+ "cbnz %w2, 1b;"
+ "=&r" (r),
+ "=&r" (tmp)
+ : "r" (target),
+ "r" (delta)
+ return (void *)(previous);
+CK_CC_INLINE static uint64_t
+ck_pr_faa_64(uint64_t *target, uint64_t delta)
+ uint64_t previous, r, tmp;
+ "ldxr %0, [%3];"
+ "add %1, %4, %0;"
+ "cbnz %w2, 1b;"
+ "=&r" (r),
+ "=&r" (tmp)
+ : "r" (target),
+ "r" (delta)
+#define CK_PR_FAA(S, T, W) \
+ ck_pr_faa_##S(T *target, T delta) \
+ T previous, r, tmp; \
+ "ldxr" W " %w0, [%3];" \
+ "add %w1, %w4, %w0;" \
+ "stxr" W " %w2, %w1, [%3];" \
+ "cbnz %w2, 1b;" \
+ "=&r" (r), \
+ "=&r" (tmp) \
+ : "r" (target), \
+ "r" (delta) \
+CK_PR_FAA(32, uint32_t, "")
+CK_PR_FAA(uint, unsigned int, "")
+CK_PR_FAA(int, int, "")
+CK_PR_FAA(16, uint16_t, "h")
+CK_PR_FAA(8, uint8_t, "b")
+CK_PR_FAA(short, short, "h")
+CK_PR_FAA(char, char, "b")
+#undef CK_PR_FAA
+#endif /* CK_PR_AARCH64_LLSC_H */
diff --git a/freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_lse.h b/freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_lse.h
index 00000000..e2c9554c
--- /dev/null
+++ b/freebsd/sys/contrib/ck/include/gcc/aarch64/ck_pr_lse.h
@@ -0,0 +1,298 @@
+ * Copyright 2016 Alexey Kopytov.
+ * are met:
+ * SUCH DAMAGE.
+#ifndef CK_PR_AARCH64_LSE_H
+#define CK_PR_AARCH64_LSE_H
+#ifndef CK_PR_H
+#endif
+ uint64_t tmp1;
+ uint64_t tmp2;
+ register uint64_t x0 __asm__ ("x0") = compare[0];
+ register uint64_t x1 __asm__ ("x1") = compare[1];
+ register uint64_t x2 __asm__ ("x2") = set[0];
+ register uint64_t x3 __asm__ ("x3") = set[1];
+ __asm__ __volatile__("casp %0, %1, %4, %5, [%6];"
+ "eor %2, %0, %7;"
+ "eor %3, %1, %8;"
+ "orr %2, %2, %3;"
+ : "+&r" (x0), "+&r" (x1), "=&r" (tmp1), "=&r" (tmp2)
+ : "r" (x2), "r" (x3), "r" (target), "r" (compare[0]), "r" (compare[1])
+ : "memory");
+ value[0] = x0;
+ value[1] = x1;
+ return (!!tmp1);
+ __asm__ __volatile__("casp %0, %1, %2, %3, [%4];"
+ "eor %0, %0, %5;"
+ "eor %1, %1, %6;"
+ "orr %0, %0, %1;"
+ : "memory");
+ return (!!x0);
+ *(T *)value = compare; \
+ "cas" W " %" R "0, %" R "2, [%1];" \
+ : "+&r" (*(T *)value) \
+ : "r" (target), \
+ "r" (set) \
+ : "memory"); \
+ return (*(T *)value == compare); \
+ T previous = compare; \
+ : "+&r" (previous) \
+ : "r" (target), \
+ "r" (set) \
+ : "memory"); \
+#endif
+#undef CK_PR_CAS_S
+#undef CK_PR_CAS
+ T previous; \
+ "swp" W " %" R "2, %" R "0, [%1];" \
+ : "=&r" (previous) \
+ : "r" (target), \
+ "r" (v) \
+ : "memory"); \
+#undef CK_PR_FAS
+#define CK_PR_UNARY(O, N, M, T, I, W, R, S) \
+ __asm__ __volatile__(I ";" \
+ "st" S W " " R "0, [%0];" \
+ : "r" (target) \
+ : "x0", "memory"); \
+ return; \
+CK_PR_UNARY(inc, ptr, void, void *, "mov x0, 1", "", "x", "add")
+CK_PR_UNARY(dec, ptr, void, void *, "mov x0, -1", "", "x", "add")
+CK_PR_UNARY(not, ptr, void, void *, "mov x0, -1", "", "x", "eor")
+CK_PR_UNARY(inc, 64, uint64_t, uint64_t, "mov x0, 1", "", "x", "add")
+CK_PR_UNARY(dec, 64, uint64_t, uint64_t, "mov x0, -1", "", "x", "add")
+CK_PR_UNARY(not, 64, uint64_t, uint64_t, "mov x0, -1", "", "x", "eor")
+ CK_PR_UNARY(inc, S, T, T, "mov w0, 1", W, "w", "add") \
+ CK_PR_UNARY(dec, S, T, T, "mov w0, -1", W, "w", "add") \
+ CK_PR_UNARY(not, S, T, T, "mov w0, -1", W, "w", "eor") \
+#undef CK_PR_UNARY
+#define CK_PR_BINARY(O, N, M, T, S, W, R, I) \
+ "st" S W " %" R "0, [%1];" \
+ : "+&r" (delta) \
+ : "r" (target) \
+ : "memory"); \
+ return; \
+CK_PR_BINARY(and, ptr, void, uintptr_t, "clr", "", "", "mvn %0, %0")
+CK_PR_BINARY(add, ptr, void, uintptr_t, "add", "", "", "")
+CK_PR_BINARY(or, ptr, void, uintptr_t, "set", "", "", "")
+CK_PR_BINARY(sub, ptr, void, uintptr_t, "add", "", "", "neg %0, %0")
+CK_PR_BINARY(xor, ptr, void, uintptr_t, "eor", "", "", "")
+CK_PR_BINARY(and, 64, uint64_t, uint64_t, "clr", "", "", "mvn %0, %0")
+CK_PR_BINARY(add, 64, uint64_t, uint64_t, "add", "", "", "")
+CK_PR_BINARY(or, 64, uint64_t, uint64_t, "set", "", "", "")
+CK_PR_BINARY(sub, 64, uint64_t, uint64_t, "add", "", "", "neg %0, %0")
+CK_PR_BINARY(xor, 64, uint64_t, uint64_t, "eor", "", "", "")
+ CK_PR_BINARY(and, S, T, T, "clr", W, "w", "mvn %w0, %w0") \
+ CK_PR_BINARY(add, S, T, T, "add", W, "w", "") \
+ CK_PR_BINARY(or, S, T, T, "set", W, "w", "") \
+ CK_PR_BINARY(sub, S, T, T, "add", W, "w", "neg %w0, %w0") \
+ CK_PR_BINARY(xor, S, T, T, "eor", W, "w", "")
+ uintptr_t previous;
+ "ldadd %2, %0, [%1];"
+ : "=r" (previous)
+ : "r" (target),
+ "r" (delta)
+ : "memory");
+ uint64_t previous;
+ : "=r" (previous)
+ : "r" (target),
+ "r" (delta)
+ : "memory");
+ T previous; \
+ "ldadd" W " %w2, %w0, [%1];" \
+ : "=r" (previous) \
+ : "r" (target), \
+ "r" (delta) \
+ : "memory"); \
+#undef CK_PR_FAA
+#endif /* CK_PR_AARCH64_LSE_H */
diff --git a/libbsd.py b/libbsd.py
index 99877a2f..909c0037 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -104,6 +104,8 @@ _defaults = {
# (source, [targets..])
# i386
('freebsd/sys/i386/include', ['freebsd/sys/x86/include', 'freebsd/sys/i386/include']),
+ # arm64
+ ('freebsd/sys/aarch64/include', ['freebsd/sys/aarch64/include', 'freebsd/sys/arm64/include']),
@@ -340,6 +342,8 @@ class base(builder.Module):
'sys/contrib/ck/include/ck_string.h',
'sys/contrib/ck/include/gcc/aarch64/ck_f_pr.h',
'sys/contrib/ck/include/gcc/aarch64/ck_pr.h',
+ 'sys/contrib/ck/include/gcc/aarch64/ck_pr_lse.h',
+ 'sys/contrib/ck/include/gcc/aarch64/ck_pr_llsc.h',
'sys/contrib/ck/include/gcc/arm/ck_f_pr.h',
'sys/contrib/ck/include/gcc/arm/ck_pr.h',
'sys/contrib/ck/include/gcc/ck_cc.h',
@@ -1444,6 +1448,9 @@ class dev_nic(builder.Module):
self.addCPUDependentFreeBSDHeaderFiles(
+ 'sys/arm64/include/armreg.h',
+ 'sys/arm64/include/cpufunc.h',
+ 'sys/arm64/include/cpu.h',
'sys/arm/include/cpufunc.h',
'sys/i386/include/md_var.h',
'sys/i386/include/intr_machdep.h',
@@ -4913,6 +4920,13 @@ class in_cksum(builder.Module):
'sys/sparc64/include/in_cksum.h',
+ self.addTargetSourceCPUDependentHeaderFiles(
+ [ 'arm64' ],
+ 'arm64',
+ 'sys/arm64/include/in_cksum.h',
[ 'arm', 'avr', 'bfin', 'h8300', 'lm32', 'm32c', 'm32r', 'm68k',
'nios2', 'sh', 'sparc', 'v850' ],
@@ -4921,6 +4935,13 @@ class in_cksum(builder.Module):
'sys/mips/include/in_cksum.h',
+ self.addCPUDependentFreeBSDSourceFiles(
+ [ 'aarch64', 'arm64' ],
+ 'sys/arm64/arm64/in_cksum.c',
+ mm.generator['source']()
[ 'i386' ],
diff --git a/rtemsbsd/include/machine/frame.h b/rtemsbsd/include/machine/frame.h
index 00000000..936ffd88
--- /dev/null
+++ b/rtemsbsd/include/machine/frame.h
@@ -0,0 +1 @@
+/* EMPTY */
2.20.1
