[PATCH v2] devel/qemu: Update QEMU to 5.2.0-rc1
chrisj at rtems.org chrisj at rtems.org
Thu Nov 12 22:27:14 UTC 2020
- This version of qemu uses meson and ninja to build. You will need
  to install ninja to build. No checks are made until meson run
 .../{qemu4-git-1.cfg => qemu-5.2.0-1.cfg}     |  18 +--
 bare/config/devel/qemu.bset                   |   2 +-
 bare/config/devel/qemu4.bset                  |  25 ---
 source-builder/config/qemu-5-1.cfg            |   9 ++
 source-builder/config/qemu-common-2.cfg       | 145 ++++++++++++++++++
 5 files changed, 164 insertions(+), 35 deletions(-)
 rename bare/config/devel/{qemu4-git-1.cfg => qemu-5.2.0-1.cfg} (58%)
 delete mode 100644 bare/config/devel/qemu4.bset
 create mode 100644 source-builder/config/qemu-5-1.cfg
 create mode 100644 source-builder/config/qemu-common-2.cfg
diff --git a/bare/config/devel/qemu4-git-1.cfg b/bare/config/devel/qemu-5.2.0-1.cfg
similarity index 58%
rename from bare/config/devel/qemu4-git-1.cfg
rename to bare/config/devel/qemu-5.2.0-1.cfg
index ff241bb..8c80ffc 100644
--- a/bare/config/devel/qemu4-git-1.cfg
+++ b/bare/config/devel/qemu-5.2.0-1.cfg
@@ -13,14 +13,14 @@
 # Stable version. Qemu is fast moving.
-%define qemu_version 4.1.0
+%define qemu_version 5.2.0-rc1
 # Use release sources.
 %source set qemu https://download.qemu.org/qemu-%{qemu_version}.tar.xz
-%hash sha512 qemu-%{qemu_version}.tar.xz \
-        gv1RcCp7mxsAsvG9O0qDK4AkkBjbuhrdCwpz59S+5FKv1FV0tNjffORHfYcR872kygcqGm3iWJXJPrIc94/Esg==
+#%hash sha512 qemu-%{qemu_version}.tar.xz \
+#        gv1RcCp7mxsAsvG9O0qDK4AkkBjbuhrdCwpz59S+5FKv1FV0tNjffORHfYcR872kygcqGm3iWJXJPrIc94/Esg==
 # Patches from Qemu's patchworks site.
@@ -30,13 +30,13 @@
          40399fcedb44b2c1bfa1a95af482f7f335f42d713967ed2f34980a7a940c3740
-# Patches to build qemu-4.1.0-sparc with Leon3 support
+# Patches to build qemu sparc with Leon3 support
-%patch add qemu https://gaisler.se/qemu/qemu-4.1.0-leon3.patch
-%hash sha256 qemu-4.1.0-leon3.patch \
-         d62ff3418903f1c5eb7f6d727af0400caeb250e23cc120111930601c9ecce02a
+%patch add qemu https://gaisler.se/qemu/qemu-5.2.0-leon3.patch
+%hash sha512 qemu-5.2.0-leon3.patch \
+       cQju/ja5SAM+gsXEkzSteeR+7PjG9g2w+yUb4kg1eZoOSm2MmZDjA/auINVdRax8wgtIEWnzq5/hdY7/THnowg==
-# The Qemu build instructions. We use 4.x.x Release 1.
+# The Qemu build instructions. We use 5.x.x Release 1.
-%include %{_configdir}/qemu-4-1.cfg
+%include %{_configdir}/qemu-5-1.cfg
diff --git a/bare/config/devel/qemu.bset b/bare/config/devel/qemu.bset
index a8b1ebf..3a9b0d5 100644
--- a/bare/config/devel/qemu.bset
+++ b/bare/config/devel/qemu.bset
@@ -21,4 +21,4 @@ devel/gettext-0.18.3.1-1
 devel/libffi-3.0.13-1
 devel/pixman-0.40.0-1
 devel/glib-2.48.2-1
-devel/qemu-git-1
+devel/qemu-5.2.0-1
diff --git a/bare/config/devel/qemu4.bset b/bare/config/devel/qemu4.bset
deleted file mode 100644
index fa52084..0000000
--- a/bare/config/devel/qemu4.bset
+++ /dev/null
@@ -1,25 +0,0 @@
-# Build set for QEMU
-%define release 1
-# Name of the package.
-package: qemu-%{qemu_version}-%{_host}-%{release}
-# A magic internal path that would break if changes in the defaults.mc
-# macro file are made.
-%define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
-# I don't think these are needed anymore ...?
-#devel/autotools-internal
-devel/libiconv-1.14-1
-devel/gettext-0.18.3.1-1
-devel/libffi-3.0.13-1
-devel/pixman-0.40.0-1
-devel/glib-2.46.2-1
-devel/qemu4-git-1
diff --git a/source-builder/config/qemu-5-1.cfg b/source-builder/config/qemu-5-1.cfg
new file mode 100644
index 0000000..7ca58b8
--- /dev/null
+++ b/source-builder/config/qemu-5-1.cfg
@@ -0,0 +1,9 @@
+# QEMU 5 Version 1.
+# This configuration file configure's, make's and install's QEMU.
+%define qemu_disables --disable-nettle
+%include %{_configdir}/qemu-common-2.cfg
diff --git a/source-builder/config/qemu-common-2.cfg b/source-builder/config/qemu-common-2.cfg
index 0000000..1dbaf05
--- /dev/null
+++ b/source-builder/config/qemu-common-2.cfg
@@ -0,0 +1,145 @@
+# QEMU Common Version 1.
+%if %{release} == %{nil}
+%define release 1
+%endif
+# Select Snapshot Macro Maps
+%select qemu-snapshot
+# The description.
+Name:      qemu-%{qemu_version}-%{_host}-%{release}
+Summary:   Qemu is a simulator of various processors.
+Version:   %{qemu_version}
+Release:   %{release}
+URL: 	   http://www.qemu.org/
+# Source
+%source set qemu http://wiki.qemu-project.org/download/qemu-%{qemu_version}.tar.bz2
+# QEMU Disable component list.
+# We are not interested in the VM use case for qemu and most of that
+# functionality carries host platform baggage which complicates building on a
+# range of host platforms.
+# You can specialise before including this config file.
+%define qemu_std_disables --disable-werror
+%define qemu_std_disables %{qemu_std_disables} --disable-tools
+%define qemu_std_disables %{qemu_std_disables} --disable-pie
+%define qemu_std_disables %{qemu_std_disables} --disable-vnc
+%define qemu_std_disables %{qemu_std_disables} --disable-sdl
+%define qemu_std_disables %{qemu_std_disables} --disable-gtk
+%define qemu_std_disables %{qemu_std_disables} --disable-opengl
+%define qemu_std_disables %{qemu_std_disables} --disable-netmap
+%ifn %{defined qemu_disables}
+ %define qemu_disables %{nil}
+%endif
+%define qemu_disables %{qemu_std_disables} %{qemu_disables}
+# QEMU Targets to build.
+%if %{!defined qemu_archs} && %{!defined with_qemu_archs}
+ %define qemu_target_list %{nil}
+%else
+ %if %{defined with_qemu_archs}
+  %define qemu_target_list --target-list=%{with_qemu_archs}
+ %else
+  %define qemu_target_list --target-list=%{qemu_archs}
+ %endif
+%endif
+# Clear the path to SB, meson does not like the python pkg-config
+%define _extra_path %{nil}
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_qemu="qemu-%{qemu_version}"
+  %source setup qemu -q -n qemu-%{qemu_version}
+  %patch setup qemu -p1
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %if %{pkgconfig check vdeplug}
+    VDE_CONFIG="--enable-vde"
+    VDE_CFLAGS="%{pkgconfig cflags vdeplug}"
+    VDE_LDFLAGS="%{pkgconfig ldflags vdeplug} %{pkgconfig libs vdeplug}"
+  %endif
+  %{host_build_flags}
+  if test "%{_build}" != "%{_host}" ; then
+    CROSS_PREFIX_OPTION="--cross-prefix=%{_host}-"
+  fi
+  SYSROOT=$SB_TMPPREFIX
+  STAGED_GLIB="-I${SB_TMPPREFIX}/include/glib-2.0 -I${SB_TMPPREFIX}/lib/glib-2.0/include"
+  STAGED_PIXMAN=" -I${SB_TMPPREFIX}/include/pixman-1"
+  STAGED_INCLUDES="${STAGED_GLIB} ${STAGED_PIXMAN}"
+  CC="${CC} ${STAGED_INCLUDES}"
+  CXX="${CXX} ${STAGED_INCLUDES}"
+  # Hack warning: MSYS2 does not seem to convert the path to
+  #               a shell path from Windows so we keep them
+  #               separate and handle it in the pkgconfig tool.
+  PKG_CONFIG_DEFAULT_PATH=${PKG_CONFIG_PATH} \
+  PKG_CONFIG_PATH=$SYSROOT/lib/pkgconfig \
+  PKG_CONFIG_BUILD_TOP_DIR=$SB_TMPROOT \
+  %{_ld_library_path}=$SYSROOT/lib \
+  LDFLAGS="-Wl,-rpath -Wl,/$SB_PREFIX_CLEAN/lib -L$SYSROOT/lib ${VDE_LDFLAGS}" \
+  CFLAGS="${CFLAGS} ${VDE_CFLAGS}" \
+  ../${source_dir_qemu}/configure \
+    --prefix=%{_prefix} \
+    ${CROSS_PREFIX_OPTION} \
+    --make=%{__make} \
+    %{qemu_target_list} \
+    ${VDE_CONFIG} \
+    %{qemu_disables}
+  %{__make} %{?_smp_mflags} all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  cd ${build_dir}
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
2.24.1
