[PATCH] eng: Add performance specification items
Fri Nov 13 09:47:03 UTC 2020
Add items to specify runtime performance requirements.
Update #3715.
You find an updated document here:
https://ftp.rtems.org/pub/rtems/people/sebh/eng.pdf
 eng/req/items.rst | 616 +++++++++++++++++++++++++++++++++++++---------
 1 file changed, 503 insertions(+), 113 deletions(-)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 9d3822b..e811213 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -109,8 +109,14 @@ The specification item types have the following hierarchy:
     * :ref:`SpecTypeNonFunctionalRequirementItemType`
+      * :ref:`SpecTypeGenericNonFunctionalRequirementItemType`
+      * :ref:`SpecTypeRuntimePerformanceRequirementItemType`
   * :ref:`SpecTypeRequirementValidationItemType`
+  * :ref:`SpecTypeRuntimeMeasurementTestItemType`
   * :ref:`SpecTypeSpecificationItemType`
   * :ref:`SpecTypeTestCaseItemType`
@@ -183,6 +189,8 @@ This type is refined by the following types:
+* :ref:`SpecTypeRuntimeMeasurementTestItemType`
@@ -1729,8 +1737,8 @@ test-cleanup
     action loop body after the test post-condition checks.
 test-context
-    The attribute value shall be a list. Each list element shall be an
-    :ref:`SpecTypeActionRequirementTestContextMember`.
+    The attribute value shall be a list. Each list element shall be a
+    :ref:`SpecTypeTestContextMember`.
 test-context-support
     The attribute value shall be an optional string. If the value is present,
@@ -1758,12 +1766,10 @@ test-prepare
     the test action loop body before the test pre-condition preparations.
 test-setup
-    The attribute value shall be an
-    :ref:`SpecTypeActionRequirementTestFixtureMethod`.
+    The attribute value shall be a :ref:`SpecTypeTestSupportMethod`.
 test-stop
 test-support
@@ -1775,8 +1781,7 @@ test-target
     generated test case source file.
 test-teardown
 transition-map
@@ -1943,8 +1948,213 @@ attributes specifies a non-functional requirement. All explicit attributes
 shall be specified. The explicit attributes for this type are:
 non-functional-type
-    The attribute value shall be a :ref:`SpecTypeRequirementNonFunctionalType`.
-    It shall be the non-functional type of the requirement.
+    The attribute value shall be a :ref:`SpecTypeName`. It shall be the
+    non-functional type of the requirement.
+This type is refined by the following types:
+* :ref:`SpecTypeGenericNonFunctionalRequirementItemType`
+* :ref:`SpecTypeRuntimePerformanceRequirementItemType`
+.. _SpecTypeGenericNonFunctionalRequirementItemType:
+Generic Non-Functional Requirement Item Type
+This type refines the following types:
+* :ref:`SpecTypeNonFunctionalRequirementItemType` though the
+  ``non-functional-type`` attribute if the value is ``build-configuration``
+  ``non-functional-type`` attribute if the value is ``constraint``
+  ``non-functional-type`` attribute if the value is ``design``
+  ``non-functional-type`` attribute if the value is ``documentation``
+  ``non-functional-type`` attribute if the value is ``interface``
+  ``non-functional-type`` attribute if the value is ``interface-requirement``
+  ``non-functional-type`` attribute if the value is ``maintainability``
+  ``non-functional-type`` attribute if the value is ``performance``
+  ``non-functional-type`` attribute if the value is ``portability``
+  ``non-functional-type`` attribute if the value is ``quality``
+  ``non-functional-type`` attribute if the value is ``reliability``
+  ``non-functional-type`` attribute if the value is ``resource``
+  ``non-functional-type`` attribute if the value is ``safety``
+Items of this type state a non-functional requirement with the non-functional
+type defined by the specification type refinement.
+.. _SpecTypeRuntimePerformanceRequirementItemType:
+Runtime Performance Requirement Item Type
+This type refines the :ref:`SpecTypeNonFunctionalRequirementItemType` though
+the ``non-functional-type`` attribute if the value is ``performance-runtime``.
+The item shall have exactly one link with the
+:ref:`SpecTypeRuntimeMeasurementRequestLinkRole`.  A requirement text processor
+shall support a substitution of ${.:/limit-kind}:
+* For a :ref:`SpecTypeRuntimeMeasurementValueKind` of ``min-lower-bound`` or
+  ``min-upper-bound``, the substitution of ${.:/limit-kind} shall be
+  ``"minimum"``.
+* For a :ref:`SpecTypeRuntimeMeasurementValueKind` of ``mean-lower-bound`` or
+  ``mean-upper-bound``, the substitution of ${.:/limit-kind} shall be
+  ``"mean"``.
+* For a :ref:`SpecTypeRuntimeMeasurementValueKind` of ``max-lower-bound`` or
+  ``max-upper-bound``, the substitution of ${.:/limit-kind} shall be
+  ``"maximum"``.
+A requirement text processor shall support a substitution of
+${.:/limit-condition}:
+* For a :ref:`SpecTypeRuntimeMeasurementValueKind` of ``min-lower-bound``,
+  ``mean-lower-bound``, or ``max-lower-bound``, the substitution of
+  ${.:/limit-condition} shall be ``"greater than or equal to <value>"`` with
+  <value> being the value of the corresponding entry in the
+  :ref:`SpecTypeRuntimeMeasurementValueTable`.
+* For a :ref:`SpecTypeRuntimeMeasurementValueKind` of ``min-upper-bound``,
+  ``mean-upper-bound``, or ``max-upper-bound``, the substitution of
+  ${.:/limit-condition} shall be ``"less than or equal to <value>"`` with
+A requirement text processor shall support a substitution of ${.:/environment}.
+The value of the substitution shall be ``"<environment> environment"`` with
+<environment> being the environment of the corresponding entry in the
+:ref:`SpecTypeRuntimeMeasurementEnvironmentTable`.
+This set of attributes specifies non-functional runtime performance
+requirements and the corresponding validation test code.  Along with the
+requirement, the test code to execute a measure runtime request is specified.
+All explicit attributes shall be specified. The explicit attributes for this
+type are:
+limits
+    The attribute value shall be a :ref:`SpecTypeRuntimePerformanceLimitTable`.
+params
+    :ref:`SpecTypeRuntimePerformanceParameterSet`.
+test-body
+    The attribute value shall be a :ref:`SpecTypeTestSupportMethod`. It shall
+    provide the code of the measure runtime body handler.  In contrast to other
+    methods, this method is mandatory.
+test-cleanup
+    The attribute value shall be a :ref:`SpecTypeTestSupportMethod`. It may
+    provide the code to clean up the measure runtime request. This method is
+    called before the cleanup method of the corresponding
+    :ref:`SpecTypeRuntimeMeasurementTestItemType` item and after the request.
+test-prepare
+    provide the code to prepare the measure runtime request.  This method is
+    called after the prepare method of the corresponding
+    :ref:`SpecTypeRuntimeMeasurementTestItemType` item and before the request.
+test-setup
+    provide the code of the measure runtime setup handler.
+test-teardown
+    provide the code of the measure runtime teardown handler.
+Please have a look at the following example:
+.. code-block:: yaml
+    SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+    copyrights:
+    - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+    enabled-by: true
+    links:
+    - role: runtime-measurement-request
+      uid: ../val/performance
+    limits:
+      sparc/leon3:
+        DirtyCache:
+          max-upper-bound: 0.000005
+          mean-upper-bound: 0.000005
+        FullCache:
+        HotCache:
+        Load/1:
+          max-upper-bound: 0.00001
+          mean-upper-bound: 0.00001
+        Load/2:
+        Load/3:
+        Load/4:
+    params: {}
+    rationale: null
+    references: []
+    test-body:
+      brief: |
+        Get a buffer.
+      code: |
+        ctx->status = rtems_partition_get_buffer( ctx->part_many, &ctx->buffer );
+      description: null
+    test-cleanup: null
+    test-prepare: null
+    test-setup: null
+    test-teardown:
+      brief: |
+        Return the buffer.
+      code: |
+        rtems_status_code sc;
+        T_quiet_rsc_success( ctx->status );
+        sc = rtems_partition_return_buffer( ctx->part_many, ctx->buffer );
+        T_quiet_rsc_success( sc );
+        return tic == toc;
+      description: null
+    text: |
+      When a partition has exactly ${../val/performance:/params/buffer-count} free
+      buffers, the ${.:limit-kind} runtime of exactly
+      ${../val/performance:/params/sample-count} successful calls to
+      ${../if/get-buffer:/name} in the ${.:/environment} shall be
+      ${.:limit-condition}.
+    non-functional-type: performance-runtime
+    requirement-type: non-functional
+    type: requirement
 .. _SpecTypeRequirementValidationItemType:
@@ -1974,6 +2184,76 @@ text
     * *By review of design*: A rationale shall be provided to demonstrate how
       the requirement is satisfied implicitly by the software design.
+.. _SpecTypeRuntimeMeasurementTestItemType:
+Runtime Measurement Test Item Type
+This type refines the :ref:`SpecTypeRootItemType` though the ``type`` attribute
+if the value is ``runtime-measurement-test``. This set of attributes specifies
+a runtime measurement test case. All explicit attributes shall be specified.
+The explicit attributes for this type are:
+params
+    :ref:`SpecTypeRuntimeMeasurementParameterSet`.
+test-brief
+    The attribute value shall be an optional string. If the value is present,
+    then it shall be the test case brief description.
+test-cleanup
+    The attribute value shall be a :ref:`SpecTypeTestSupportMethod`. If the
+    value is present, then it shall be the measure runtime request cleanup
+    method.  The method is called after each measure runtime request.
+test-context
+test-context-support
+    then it shall be the test context support code.  The context support code
+    is placed at file scope before the test context definition.
+test-description
+    then it shall be the test case description.
+test-includes
+    The attribute value shall be a list of strings. It shall be a list of
+    header files included via ``#include <...>``.
+test-local-includes
+    header files included via ``#include "..."``.
+test-prepare
+    value is present, then it shall be the measure runtime request prepare
+    method.  The method is called before each measure runtime request.
+test-setup
+    value is present, then it shall be the test case setup fixture method.
+test-stop
+    value is present, then it shall be the test case stop fixture method.
+test-support
+    then it shall be the test case support code. The support code is placed at
+    file scope before the test case code.
+test-target
+    The attribute value shall be a string. It shall be the path to the
+    generated test case source file.
+test-teardown
+    value is present, then it shall be the test case teardown fixture method.
 .. _SpecTypeSpecificationItemType:
 Specification Item Type
@@ -2207,14 +2487,14 @@ test-epilogue
     then it shall be the test epilogue code. The epilogue code is placed in the
     test condition preparation or check before the state-specific code.  The
     code may use a local variable ``ctx`` which points to the test context, see
 test-prologue
     then it shall be the test prologue code. The prologue code is placed in the
     test condition preparation or check after the state-specific code.  The
 This type is used by the following types:
@@ -2283,7 +2563,7 @@ test-code
     The attribute value shall be a string. It shall be the test code to prepare
     or check the state of the condition.  The code may use a local variable
 text
     The attribute value shall be a :ref:`SpecTypeRequirementText`. It shall
@@ -2293,66 +2573,6 @@ This type is used by the following types:
 * :ref:`SpecTypeActionRequirementCondition`
-.. _SpecTypeActionRequirementTestContextMember:
-Action Requirement Test Context Member
-A value of this type shall be of one of the following variants:
-* The value may be a set of attributes. This set of attributes defines an
-  action requirement test context member. All explicit attributes shall be
-  specified. The explicit attributes for this type are:
-  brief
-      The attribute value shall be an optional string. It shall be the test
-      context member brief description.
-  description
-      context member description.
-  member
-      The attribute value shall be a string. It shall be the test context
-      member definition.  It shall be a valid C structure member definition
-      without a trailing ``;``.
-* There may by be no value (null).
-This type is used by the following types:
-* :ref:`SpecTypeActionRequirementItemType`
-.. _SpecTypeActionRequirementTestFixtureMethod:
-Action Requirement Test Fixture Method
-  action requirement test fixture method. All explicit attributes shall be
-  brief
-      fixture method brief description.
-  code
-      The attribute value shall be a string. It shall be the test fixture
-      method code.  The code may use a local variable ``ctx`` which points to
-      the test context, see :ref:`SpecTypeActionRequirementTestContextMember`.
-  description
-      fixture method description.
 .. _SpecTypeActionRequirementTransition:
 Action Requirement Transition
@@ -3977,6 +4197,8 @@ This type is refined by the following types:
 * :ref:`SpecTypeRequirementValidationLinkRole`
+* :ref:`SpecTypeRuntimeMeasurementRequestLinkRole`
 * :ref:`SpecTypeSpecificationMemberLinkRole`
 * :ref:`SpecTypeSpecificationRefinementLinkRole`
@@ -4013,10 +4235,16 @@ This type is used by the following types:
 * :ref:`SpecTypeLink`
 * :ref:`SpecTypeRequirementItemType`
 * :ref:`SpecTypeRootItemType`
+* :ref:`SpecTypeRuntimeMeasurementParameterSet`
+* :ref:`SpecTypeRuntimePerformanceParameterSet`
 * :ref:`SpecTypeSpecificationAttributeValue`
 * :ref:`SpecTypeSpecificationExplicitAttributes`
@@ -4050,44 +4278,6 @@ value is ``placement-order``. This link role defines the placement order of
 items in a container item (for example an interface function in a header file
 or a documentation section).
-.. _SpecTypeRequirementNonFunctionalType:
-Requirement Non-Functional Type
-The value shall be a string. This type shall be used for non-functional
-requirement types. The value shall be an element of
-* "``build-configuration``",
-* "``constraint``",
-* "``design``",
-* "``documentation``",
-* "``interface``",
-* "``interface-requirement``",
-* "``maintainability``",
-* "``performance``",
-* "``portability``",
-* "``quality``",
-* "``reliability``",
-* "``resource``", and
-* "``safety``".
-* :ref:`SpecTypeNonFunctionalRequirementItemType`
 .. _SpecTypeRequirementReference:
 Requirement Reference
@@ -4313,6 +4503,140 @@ This type is used by the following types:
+.. _SpecTypeRuntimeMeasurementEnvironment:
+Runtime Measurement Environment
+The value shall be a string. It specifies the runtime measurement environment.
+The value
+* shall be an element of
+  * "``FullCache``",
+  * "``HotCache``", and
+  * "``DirtyCache``",
+* or, shall match with the regular expression "``^Load/[1-9][0-9]*$``".
+This type is used by the following types:
+* :ref:`SpecTypeRuntimeMeasurementEnvironmentTable`
+.. _SpecTypeRuntimeMeasurementEnvironmentTable:
+Runtime Measurement Environment Table
+This set of attributes provides runtime performance limits for a set of runtime
+measurement environments. Generic attributes may be specified. Each generic
+attribute key shall be a :ref:`SpecTypeRuntimeMeasurementEnvironment`. Each
+generic attribute value shall be a :ref:`SpecTypeRuntimeMeasurementValueTable`.
+* :ref:`SpecTypeRuntimePerformanceLimitTable`
+.. _SpecTypeRuntimeMeasurementParameterSet:
+Runtime Measurement Parameter Set
+This set of attributes defines parameters of the runtime measurement test case.
+type are:
+sample-count
+    The attribute value shall be an integer number. It shall be the sample
+    count of the runtime measurement context.
+In addition to the explicit attributes, generic attributes may be specified.
+Each generic attribute key shall be a :ref:`SpecTypeName`. The attribute value
+may have any type.
+.. _SpecTypeRuntimeMeasurementRequestLinkRole:
+Runtime Measurement Request Link Role
+This type refines the :ref:`SpecTypeLink` though the ``role`` attribute if the
+value is ``runtime-measurement-request``. It defines the runtime measurement
+request role of links.  The link target shall be a
+:ref:`SpecTypeRuntimeMeasurementTestItemType` item.
+.. _SpecTypeRuntimeMeasurementValueKind:
+Runtime Measurement Value Kind
+The value shall be a string. It specifies the kind of a runtime measurement
+value. The value shall be an element of
+* "``max-lower-bound``",
+* "``max-upper-bound``",
+* "``mean-lower-bound``",
+* "``mean-upper-bound``",
+* "``min-lower-bound``", and
+* "``min-upper-bound``".
+* :ref:`SpecTypeRuntimeMeasurementValueTable`
+.. _SpecTypeRuntimeMeasurementValueTable:
+Runtime Measurement Value Table
+This set of attributes provides a set of runtime measurement values each of a
+specified kind.  The unit of the values shall be one second. Generic attributes
+may be specified. Each generic attribute key shall be a
+:ref:`SpecTypeRuntimeMeasurementValueKind`. Each generic attribute value shall
+be a floating-point number.
+.. _SpecTypeRuntimePerformanceLimitTable:
+Runtime Performance Limit Table
+This set of attributes provides runtime performance limits for BSP variants
+specified by ``"<arch>/<bsp>"`` with <arch> being the architecture of the BSP
+and <bsp> being the base name of the BSP. Generic attributes may be specified.
+Each generic attribute key shall be a string. Each generic attribute value
+shall be a :ref:`SpecTypeRuntimeMeasurementEnvironmentTable`.
+.. _SpecTypeRuntimePerformanceParameterSet:
+Runtime Performance Parameter Set
+This set of attributes defines parameters of the runtime performance
+requirement. Generic attributes may be specified. Each generic attribute key
+shall be a :ref:`SpecTypeName`. The attribute value may have any type.
 .. _SpecTypeSPDXLicenseIdentifier:
 SPDX License Identifier
@@ -4932,6 +5256,38 @@ This type is used by the following types:
 * :ref:`SpecTypeTestCaseAction`
+.. _SpecTypeTestContextMember:
+Test Context Member
+A value of this type shall be of one of the following variants:
+* The value may be a set of attributes. This set of attributes defines an
+  action requirement test context member. All explicit attributes shall be
+  specified. The explicit attributes for this type are:
+  brief
+      The attribute value shall be an optional string. It shall be the test
+      context member brief description.
+  description
+      context member description.
+  member
+      The attribute value shall be a string. It shall be the test context
+      member definition.  It shall be a valid C structure member definition
+      without a trailing ``;``.
+* There may by be no value (null).
+* :ref:`SpecTypeActionRequirementItemType`
 .. _SpecTypeTestHeader:
 Test Header
@@ -4986,8 +5342,8 @@ Test Run Parameter
 This set of attributes specifies a parameter for the test run function. In case
 this parameter is used in an :ref:`SpecTypeActionRequirementItemType` item,
 then the parameter is also added as a member to the test context, see
-:ref:`SpecTypeActionRequirementTestContextMember`. All explicit attributes
-shall be specified. The explicit attributes for this type are:
+:ref:`SpecTypeTestContextMember`. All explicit attributes shall be specified.
 description
     The attribute value shall be a string. It shall be the description of the
@@ -5008,6 +5364,40 @@ This type is used by the following types:
 * :ref:`SpecTypeTestHeader`
+.. _SpecTypeTestSupportMethod:
+Test Support Method
+  action requirement test support method. All explicit attributes shall be
+  brief
+      support method brief description.
+  code
+      The attribute value shall be a string. It shall be the test support
+      method code.  The code may use a local variable ``ctx`` which points to
+      the test context, see :ref:`SpecTypeTestContextMember`.
+  description
+      support method description.
 .. _SpecTypeUID:
 UID
2.26.2
