[PATCH 8/8] validation/ts-performance-0: Add partition tests
Sebastian Huber
Fri Nov 13 10:07:57 UTC 2020
.../testsuites/validation/performance-0.yml | 1 +
testsuites/validation/tc-part-performance.c | 437 ++++++++++++++++++
2 files changed, 438 insertions(+)
create mode 100644 testsuites/validation/tc-part-performance.c
diff --git a/spec/build/testsuites/validation/performance-0.yml b/spec/build/testsuites/validation/performance-0.yml
index ba14066dd3..711edb0c75 100644
--- a/spec/build/testsuites/validation/performance-0.yml
+++ b/spec/build/testsuites/validation/performance-0.yml
@@ -11,6 +11,7 @@ includes: []
ldflags: []
links: []
source:
+- testsuites/validation/tc-part-performance.c
- testsuites/validation/ts-performance-0.c
stlib: []
target: testsuites/validation/ts-performance-0.exe
diff --git a/testsuites/validation/tc-part-performance.c b/testsuites/validation/tc-part-performance.c
new file mode 100644
index 0000000000..46f48c7bf5
--- /dev/null
+++ b/testsuites/validation/tc-part-performance.c
@@ -0,0 +1,437 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsPartValPerformance
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/chain.h>
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsPartValPerformance \
+ * spec:/rtems/part/val/performance
+ * @ingroup RTEMSTestSuiteTestsuitesPerformance0
+ * @brief This test case provides a context to run Partition Manager
+ * performance tests.
+ * @brief Test context for spec:/rtems/part/val/performance test case.
+typedef struct {
+ * @brief This member provides a partition with exactly one free buffer.
+ rtems_id part_one;
+ * ${.:/params/buffer-count} free buffers.
+ rtems_id part_many;
+ * @brief This member provides a status code.
+ rtems_status_code status;
+ * @brief This member provides a buffer pointer.
+ void *buffer;
+ * @brief This member provides a second buffer pointer.
+ void *buffer_2;
+ * @brief This member references the measure runtime context.
+ T_measure_runtime_context *context;
+ * @brief This member provides the measure runtime request.
+ T_measure_runtime_request request;
+} RtemsPartValPerformance_Context;
+static RtemsPartValPerformance_Context
+ RtemsPartValPerformance_Instance;
+static void RtemsPartValPerformance_Setup_Context(
+ RtemsPartValPerformance_Context *ctx
+ T_measure_runtime_config config;
+ memset( &config, 0, sizeof( config ) );
+ config.sample_count = 1000;
+ ctx->request.arg = ctx;
+ ctx->context = T_measure_runtime_create( &config );
+ T_assert_not_null( ctx->context );
+ * @brief Creates the test partition.
+static void RtemsPartValPerformance_Setup(
+ rtems_status_code sc;
+ size_t size;
+ void *area;
+ uintptr_t length;
+ size = sizeof( rtems_chain_node );
+ area = T_malloc( size );
+ sc = rtems_partition_create(
+ rtems_build_name( ' ', 'O', 'N', 'E' ),
+ area,
+ size,
+ size,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->part_one
+ T_assert_rsc_success( sc );
+ length = 100 * size;
+ area = T_malloc( length );
+ rtems_build_name( 'M', 'A', 'N', 'Y' ),
+ area,
+ length,
+ size,
+ &ctx->part_many
+static void RtemsPartValPerformance_Setup_Wrap( void *arg )
+ RtemsPartValPerformance_Context *ctx;
+ ctx = arg;
+ RtemsPartValPerformance_Setup_Context( ctx );
+ RtemsPartValPerformance_Setup( ctx );
+ * @brief Deletes the test partition.
+static void RtemsPartValPerformance_Teardown(
+ if ( ctx->part_one != 0 ) {
+ sc = rtems_partition_delete( ctx->part_one );
+ T_rsc_success( sc );
+ if ( ctx->part_many != 0 ) {
+ sc = rtems_partition_delete( ctx->part_many );
+static void RtemsPartValPerformance_Teardown_Wrap( void *arg )
+ ctx = arg;
+ RtemsPartValPerformance_Teardown( ctx );
+static T_fixture RtemsPartValPerformance_Fixture = {
+ .setup = RtemsPartValPerformance_Setup_Wrap,
+ .stop = NULL,
+ .teardown = RtemsPartValPerformance_Teardown_Wrap,
+ .scope = NULL,
+ .initial_context = &RtemsPartValPerformance_Instance
+ * @brief Get a buffer.
+static void RtemsPartReqPerfGetBuffer_Body(
+ ctx->status = rtems_partition_get_buffer( ctx->part_many, &ctx->buffer );
+static void RtemsPartReqPerfGetBuffer_Body_Wrap( void *arg )
+ ctx = arg;
+ RtemsPartReqPerfGetBuffer_Body( ctx );
+ * @brief Return the buffer.
+static bool RtemsPartReqPerfGetBuffer_Teardown(
+ RtemsPartValPerformance_Context *ctx,
+ T_ticks *delta,
+ uint32_t tic,
+ uint32_t toc,
+ unsigned int retry
+ T_quiet_rsc_success( ctx->status );
+ sc = rtems_partition_return_buffer( ctx->part_many, ctx->buffer );
+ T_quiet_rsc_success( sc );
+ return tic == toc;
+static bool RtemsPartReqPerfGetBuffer_Teardown_Wrap(
+ void *arg,
+ T_ticks *delta,
+ uint32_t tic,
+ uint32_t toc,
+ ctx = arg;
+ return RtemsPartReqPerfGetBuffer_Teardown( ctx, delta, tic, toc, retry );
+ * @brief Get the buffer.
+static void RtemsPartReqPerfGetNoBuffer_Prepare(
+ sc = rtems_partition_get_buffer( ctx->part_one, &ctx->buffer_2 );
+ * @brief Try to get a buffer.
+static void RtemsPartReqPerfGetNoBuffer_Body(
+ ctx->status = rtems_partition_get_buffer( ctx->part_one, &ctx->buffer );
+static void RtemsPartReqPerfGetNoBuffer_Body_Wrap( void *arg )
+ ctx = arg;
+ RtemsPartReqPerfGetNoBuffer_Body( ctx );
+ * @brief Check the status code.
+static bool RtemsPartReqPerfGetNoBuffer_Teardown(
+ T_ticks *delta,
+ uint32_t tic,
+ uint32_t toc,
+ T_quiet_rsc( ctx->status, RTEMS_UNSATISFIED );
+static bool RtemsPartReqPerfGetNoBuffer_Teardown_Wrap(
+ void *arg,
+ T_ticks *delta,
+ uint32_t tic,
+ uint32_t toc,
+ ctx = arg;
+ return RtemsPartReqPerfGetNoBuffer_Teardown( ctx, delta, tic, toc, retry );
+static void RtemsPartReqPerfGetNoBuffer_Cleanup(
+ sc = rtems_partition_return_buffer( ctx->part_one, ctx->buffer_2 );
+static void RtemsPartReqPerfReturnBuffer_Setup(
+ sc = rtems_partition_get_buffer( ctx->part_many, &ctx->buffer );
+static void RtemsPartReqPerfReturnBuffer_Setup_Wrap( void *arg )
+ ctx = arg;
+ RtemsPartReqPerfReturnBuffer_Setup( ctx );
+static void RtemsPartReqPerfReturnBuffer_Body(
+ ctx->status = rtems_partition_return_buffer( ctx->part_many, ctx->buffer );
+static void RtemsPartReqPerfReturnBuffer_Body_Wrap( void *arg )
+ ctx = arg;
+ RtemsPartReqPerfReturnBuffer_Body( ctx );
+static bool RtemsPartReqPerfReturnBuffer_Teardown(
+ T_ticks *delta,
+ uint32_t tic,
+ uint32_t toc,
+ T_quiet_rsc( ctx->status, RTEMS_SUCCESSFUL );
+static bool RtemsPartReqPerfReturnBuffer_Teardown_Wrap(
+ void *arg,
+ T_ticks *delta,
+ uint32_t tic,
+ uint32_t toc,
+ ctx = arg;
+ return RtemsPartReqPerfReturnBuffer_Teardown( ctx, delta, tic, toc, retry );
+ * @fn void T_case_body_RtemsPartValPerformance( void )
+T_TEST_CASE_FIXTURE(
+ RtemsPartValPerformance,
+ &RtemsPartValPerformance_Fixture
+ ctx = T_fixture_context();
+ ctx->request.name = "RtemsPartReqPerfGetBuffer";
+ ctx->request.setup = NULL;
+ ctx->request.body = RtemsPartReqPerfGetBuffer_Body_Wrap;
+ ctx->request.teardown = RtemsPartReqPerfGetBuffer_Teardown_Wrap;
+ T_measure_runtime( ctx->context, &ctx->request );
+ RtemsPartReqPerfGetNoBuffer_Prepare( ctx );
+ ctx->request.name = "RtemsPartReqPerfGetNoBuffer";
+ ctx->request.body = RtemsPartReqPerfGetNoBuffer_Body_Wrap;
+ ctx->request.teardown = RtemsPartReqPerfGetNoBuffer_Teardown_Wrap;
+ RtemsPartReqPerfGetNoBuffer_Cleanup( ctx );
+ ctx->request.name = "RtemsPartReqPerfReturnBuffer";
+ ctx->request.setup = RtemsPartReqPerfReturnBuffer_Setup_Wrap;
+ ctx->request.body = RtemsPartReqPerfReturnBuffer_Body_Wrap;
+ ctx->request.teardown = RtemsPartReqPerfReturnBuffer_Teardown_Wrap;
2.26.2
