[PATCH 3/8] libtest: Add primitive test case memory allocator
Sebastian Huber
Fri Nov 13 10:07:52 UTC 2020
This primitive test case memory allocator uses memory from the low-level
memory information provided by the BSP. At the beginning of each test
case, the memory available to the test case is reinitialized. This
allows the use of a simple allocate only allocator.
cpukit/include/rtems/test.h | 6 ++
cpukit/libtest/t-test-rtems-memory.c | 86 ++++++++++++++++++++++++++++
spec/build/cpukit/librtemstest.yml | 1 +
3 files changed, 93 insertions(+)
create mode 100644 cpukit/libtest/t-test-rtems-memory.c
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index 7d8b131286..ae81aac4d0 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -2463,6 +2463,12 @@ void T_report_hash_sha256(T_event, const char *);
void T_check_heap(T_event, const char *);
#ifdef __rtems__
+void T_memory_action(T_event, const char *);
+void *T_memory_allocate(size_t);
+void T_memory_deallocate(void *);
void T_check_task_context(T_event, const char *);
void T_check_file_descriptors(T_event, const char *);
diff --git a/cpukit/libtest/t-test-rtems-memory.c b/cpukit/libtest/t-test-rtems-memory.c
new file mode 100644
index 0000000000..92d21a7ccd
--- /dev/null
+++ b/cpukit/libtest/t-test-rtems-memory.c
@@ -0,0 +1,86 @@
+ * Copyright (C) 2020 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/test.h>
+#include <rtems/score/memory.h>
+#include <rtems/sysinit.h>
+static Memory_Area T_memory_areas[1];
+static Memory_Information T_memory_information =
+ MEMORY_INFORMATION_INITIALIZER(T_memory_areas);
+static void
+T_memory_initialize(void)
+ const Memory_Information *mem;
+ Memory_Area *area;
+ void *begin;
+ uintptr_t size;
+ mem = _Memory_Get();
+ area = _Memory_Get_area(mem, 0);
+ begin = _Memory_Get_free_begin(area);
+ size = _Memory_Get_free_size(area) / 2;
+ _Memory_Consume(area, size);
+ _Memory_Initialize_by_size(&T_memory_areas[0], begin, size);
+RTEMS_SYSINIT_ITEM(T_memory_initialize, RTEMS_SYSINIT_WORKSPACE,
+ RTEMS_SYSINIT_ORDER_FIRST);
+void *
+T_memory_allocate(size_t size)
+ return _Memory_Allocate(&T_memory_information, size,
+ CPU_HEAP_ALIGNMENT);
+void
+T_memory_deallocate(void *ptr)
+ (void)ptr;
+void
+T_memory_action(T_event event, const char *name)
+ (void)name;
+ switch (event) {
+ case T_EVENT_CASE_BEGIN:
+ area = &T_memory_areas[0];
+ _Memory_Set_free_begin(area,
+ RTEMS_DECONST(void *, _Memory_Get_begin(area)));
+ break;
+ default:
+ break;
diff --git a/spec/build/cpukit/librtemstest.yml b/spec/build/cpukit/librtemstest.yml
index ee116fba49..ae5ffeeb9b 100644
--- a/spec/build/cpukit/librtemstest.yml
+++ b/spec/build/cpukit/librtemstest.yml
@@ -30,6 +30,7 @@ source:
- cpukit/libtest/t-test-rtems-fds.c
- cpukit/libtest/t-test-rtems-heap.c
- cpukit/libtest/t-test-rtems-measure.c
+- cpukit/libtest/t-test-rtems-memory.c
- cpukit/libtest/t-test-rtems-posix-keys.c
- cpukit/libtest/t-test-rtems-objs.c
- cpukit/libtest/t-test-time.c
2.26.2
