[PATCH v2 1/2] bsps/shared/ofw: Implement RTEMS OFW interface
Niteesh G. S. niteesh.gs at gmail.com
Tue Nov 17 06:41:03 UTC 2020
Hello Christian,
On Tue, Nov 17, 2020 at 12:10 AM Christian Mauderer <contact at c-mauderer.de>
wrote:
> Hello,
> sorry for the long delay. I tested it on xilinx-zynq-a9-qemu (which
> doesn't have a FDT) and the test seems to run fine. So I'm OK with the
> patches. If no one objects in the next two days, I'll commit them.
Thanks for testing the patches.
Thanks,
Niteesh.
> Best regards
> Christian
> On 03/11/2020 19:18, G S Niteesh Babu wrote:
> > RTEMS OFW is a FDT only implementation of the OpenFirmWare
> > interface. This API is created to be compatible with FreeBSD
> > OpenFirmWare interface. The main intention is to make
> > porting of FreeBSD drivers to RTEMS easier.
> > Most functions implemented have an direct one-one mapping
> > with the original OFW API and some extra auxiliary functions
> > were implemented to make working with device trees easier in
> > RTEMS.
> > Update #3784
> >  bsps/include/ofw/ofw.h        | 548 +++++++++++++++++++++++++++
> >  bsps/include/ofw/ofw_compat.h |  74 ++++
> >  bsps/shared/ofw/ofw.c         | 682 ++++++++++++++++++++++++++++++++++
> >  spec/build/bsps/obj.yml       |   5 +
> >  4 files changed, 1309 insertions(+)
> >  create mode 100644 bsps/include/ofw/ofw.h
> >  create mode 100644 bsps/include/ofw/ofw_compat.h
> >  create mode 100644 bsps/shared/ofw/ofw.c
> > diff --git a/bsps/include/ofw/ofw.h b/bsps/include/ofw/ofw.h
> > new file mode 100644
> > index 0000000000..4c402671a4
> > --- /dev/null
> > +++ b/bsps/include/ofw/ofw.h
> > @@ -0,0 +1,548 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + * @file
> > + * @ingroup ofw
> > + * RTEMS FDT implementation of OpenFirmWare Interface.
> > + * RTEMS OFW is a FDT only implementation of the OpenFirmWare interface.
> > + * This API is created to be compatible with FreeBSD OpenFirmWare
> interface.
> > + * The main intention is to make porting of FreeBSD drivers to RTEMS
> easier.
> > + * Copyright (C) 2020 Niteesh Babu G S <niteesh.gs at gmail.com>
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifndef _OFW_H
> > +#define _OFW_H
> > +#ifdef __cplusplus
> > +extern "C" {
> > +#endif
> > +#include <rtems.h>
> > +#include <stdint.h>
> > +#include <sys/types.h>
> > + * Represents a node in the device tree. The offset from fdtp to node
> is used
> > + * instead of fdt offset to make sure this is compatible with OF
> interface in
> > + * FreeBSD.
> > +typedef uint32_t  phandle_t;
> > + * Represents the effective phandle of the node.
> > +typedef uint32_t  ihandle_t;
> > + * Represents the data type of the buffer.
> > +typedef uint32_t  pcell_t;
> > + * @struct rtems_ofw_memory_area
> > + * This is used to represent elements(FDT properties) that define
> > + * region of memory address.
> > +typedef struct {
> > +  /** The start address of the memory region. */
> > +  uint32_t start;
> > +  /** The size of the memory region. */
> > +  uint32_t size;
> > +} rtems_ofw_memory_area;
> > + * @struct rtems_ofw_ranges
> > + * This is used to represent the ranges property in the device tree.
> > +typedef struct {
> > +  /** The physical address within the child bus address space */
> > +  uint32_t child_bus;
> > +  /** The physical address within the parent bus address space */
> > +  uint32_t parent_bus;
> > +  /** The size of the range in the child’s address space */
> > +  uint32_t size;
> > +} rtems_ofw_ranges;
> > + * @brief Gets the node that is next to @a node.
> > + * @param[in] node Node offset
> > + * @retval Peer node offset Successful operation.
> > + * @retval 0 No peer node or invalid node handle
> > +phandle_t rtems_ofw_peer(
> > +  phandle_t   node
> > + * @brief Gets the node that is the child of @a node.
> > + * @retval child node offset Successful operation.
> > + * @retval 0 No child node or invalid node handle
> > +phandle_t rtems_ofw_child(
> > +  phandle_t   node
> > + * @brief Gets the node that is the parent of @a node.
> > +phandle_t rtems_ofw_parent(
> > +  phandle_t   node
> > + * @brief Gets the length of the property mentioned in @a propname.
> > + * @param[in] prop Property name
> > + * @retval -1 Invalid node or property
> > + * @retval  Length of property on successful operation
> > +ssize_t rtems_ofw_get_prop_len(
> > +  phandle_t   node,
> > +  const char *propname
> > + * @brief Gets the value of property mentioned in @a propname.
> > + * @param[out] buf The property value gets stored in this buffer
> (Pre-allocated)
> > + * @param[in] len Length of the buffer
> > +ssize_t rtems_ofw_get_prop(
> > +  phandle_t    node,
> > +  const char  *propname,
> > +  void        *buf,
> > +  size_t       len
> > + * @brief Gets the value of property mentioned in @a prop.
> > + * Gets the value of property of @a node and converts the value into
> the host's
> > + * endianness.
> buffer(Pre-allocated)
> > + * after converted to the host's endianness
> > +ssize_t rtems_ofw_get_enc_prop(
> > +  phandle_t    node,
> > +  const char  *prop,
> > +  pcell_t     *buf,
> > +  size_t       len
> > + * @brief Checks if the property @a propname is present in @a node.
> > + * @param[in] propname Property name
> > + *  @retval  0 Property not present.
> > + *  @retval  1 Property is present.
> > +int rtems_ofw_has_prop(
> > +  phandle_t    node,
> > + * @brief Searches for property @a propname in @a node.
> > + * Searches the node and its parent recursively for the property and
> fills the
> > + * buffer with the first found value.
> (Pre-allocated)
> > + * @retval  Length of the property if property is found.
> > + * @retval  -1 Property is not found.
> > +ssize_t rtems_ofw_search_prop(
> > +  phandle_t    node,
> > +  void        *buf,
> > +  size_t       len
> fills the
> > + * buffer with the first value found after converting it to the
> endianness of
> > + * the host.
> > +ssize_t rtems_ofw_search_enc_prop(
> > +  phandle_t    node,
> > +  pcell_t     *buf,
> > +  size_t       len
> > + * Same as rtems_ofw_getprop, but the @a buf is allocated in this
> routine and
> > + * the user is responsible for freeing it.
> > + * @param[out] buf The buffer is allocated in this routine and user is
> > + * responsible for freeing.
> > +ssize_t rtems_ofw_get_prop_alloc(
> > +  phandle_t    node,
> > +  void       **buf
> > + * @brief Gets multiple values of the property @a propname.
> > + * Same as rtems_ofw_getprop_alloc but it can read properties with
> multiple
> > + * values.
> > + * For eg: reg = <0x1000 0x10 0x2000 0x20>
> > + * @param[in] elsz Size of the single value
> > + * @retval   Number of values read.
> > +ssize_t rtems_ofw_get_prop_alloc_multi(
> > +  phandle_t    node,
> > +  int          elsz,
> > +  void       **buf
> > + * Same as rtems_ofw_getprop_alloc but the value stored in the buffer is
> > + * converted into the host's endianness.
> > +ssize_t rtems_ofw_get_enc_prop_alloc(
> > +  phandle_t    node,
> > +  void       **buf
> > + * Same as rtems_ofw_getprop_alloc_multi but the values stored in the
> buffer
> > + * are converted to the host's endianness.
> > +ssize_t rtems_ofw_get_enc_prop_alloc_multi(
> > +  phandle_t     node,
> > +  int           elsz,
> > +  void        **buf
> > + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc
> functions.
> > + * @param[in] buf Buffer to be freed
> > +void rtems_ofw_free(
> > +  void   *buf
> > + * @brief Finds the next property of @a node.
> > + * Finds the next property of the node and when @a propname is NULL it
> returns
> > + * the value in the first property.
> > + * @param[in] previous Previous property name
> > + * @param[out] buf The value of the next property gets stored in this
> buffer
> > + * (Pre-allocated)
> > + * @retval  -1 node or previous property does not exist
> > + * @retval   0 no more properties
> > + * @retval   1 success
> > +int rtems_ofw_next_prop(
> > +  phandle_t    node,
> > +  const char  *previous,
> > +  char        *buf,
> > +  size_t       len
> > + * @brief Sets the property @name of @a node to @a buf.
> > + * @param[in] name Property name
> > + * @param[in] buf Buffer contains the value to be set.
> > + * @retval  -1 node does not exist
> > + * @retval   0 on success
> > + * @retval   libFDT error codes on unsuccessful setting operation
> > +int rtems_ofw_set_prop(
> > +  phandle_t    node,
> > +  const char  *name,
> > +  const void  *buf,
> > +  size_t       len
> > + * @brief Converts a device specifier to a fully qualified path name.
> > + * @param[in] dev device specifier
> > + * @param[out] buf The path is filled into the buffer(Pre-allocated)
> > + * @param[in] length of the buffer
> > + * @retval  -1 always. Unimplemented.
> > +ssize_t rtems_ofw_canon(
> > +  const char  *dev,
> > +  char        *buf,
> > +  size_t       len
> > + * @brief Finds the node at the given path
> > + * @param[in] path to the node from root
> > + * @retval   node handle on success
> > +phandle_t rtems_ofw_find_device(
> > +  const char  *path
> > + * @brief This routine converts effective phandle @a xref to node
> offset.
> > + * @param[in] xref Node phandle
> > + * @retval Node offset on success
> > + * @retval Node phandle on failure
> > +phandle_t rtems_ofw_node_from_xref(
> > +  phandle_t   xref
> > + * @brief This routine converts node offset to effective phandle of @a
> node.
> > + * @retval Node phandle on success
> > + * @retval Node offset on failure
> > +phandle_t rtems_ofw_xref_from_node(
> > +  phandle_t   node
> > + * instance handles(ihandle_t) as same as phandles in the FDT
> implementation
> > + * of OF interface.
> > + * @brief Converts @a instance handle to phandle.
> > + * instance are same as node offsets in FDT.
> > + * @param[in] instance Node offset
> > + * @retval phandle of node on success.
> > + * @retval instance of node on failure.
> > +phandle_t rtems_ofw_instance_to_package(
> > +  ihandle_t   instance
> > + * @brief Find the node's path from phandle.
> > + * @param[out] buf Path is filled into this buffer(Pre-allocated).
> > + * @param[in] len Length of the buffer.
> > +ssize_t rtems_ofw_package_to_path(
> > +  phandle_t   node,
> > +  char       *buf,
> > +  size_t      len
> > + * @brief Find the node's path from ihandle.
> > +ssize_t rtems_ofw_instance_to_path(
> > +  ihandle_t  instance,
> > +  char      *buf,
> > +  size_t     len
> > + * @brief Queries the node's reg value.
> > + * This routine fills the buffer @a buf with the values in reg property
> of node
> > + * @a node. It reads all the values of the property and fills the
> buffer to max
> > + * size.
> > + * This routine is local to RTEMS OFW and does not have an corresponding
> > + * FreeBSD OFW pair.
> > + * @param[out] buf Register values are stored in this
> > + * @param[in] size Length of the buffer.
> > + * @retval -1 If reg property is missing.
> > + * @retval  Length of the reg property in bytes.
> > +int rtems_ofw_get_reg(
> > +  phandle_t              node,
> > +  rtems_ofw_memory_area *buf,
> > +  size_t                 size
> > + * @brief Queries the node's interrupt value.
> > + * This routine fills the buffer @a buf with the interrupt number. In
> case of
> > + * multiple numbers it fills the buffer to its full extent.
> > + * @param[out] buf Interrupt values are stored in this
> > + * @retval -1 If interrupts property is missing.
> > + * @retval  The number of interrupt numbers read.
> > +int rtems_ofw_get_interrupts(
> > +  phandle_t            node,
> > +  rtems_vector_number *buf,
> > +  size_t               size
> > + * @brief Queries the node's status.
> > + * @retval true  Status is OK or empty.
> > + * @retval false Status is not OK or missing.
> > +bool rtems_ofw_node_status( phandle_t node );
> > + * @brief Gets node phandle from compatible property.
> > + * @param[in] compat Compatible string
> > + * @retval 0 Node with @a compat as compatible string not found
> > + * @retval Node phandle on success.
> > +phandle_t rtems_ofw_find_device_by_compat( const char *compat );
> > +#ifdef __cplusplus
> > +#endif
> > +#endif /* _OFW_H */
> > diff --git a/bsps/include/ofw/ofw_compat.h
> b/bsps/include/ofw/ofw_compat.h
> > index 0000000000..be4a5ea3ce
> > --- /dev/null
> > +++ b/bsps/include/ofw/ofw_compat.h
> > @@ -0,0 +1,74 @@
> > + * @file
> > + * @ingroup ofw
> > + * This file defines necessary symbols to make the RTEMS OFW API
> compatible
> > + * with FreeBSD OFW.
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#ifndef _OFW_COMPAT_H
> > +#define _OFW_COMPAT_H
> > +#ifdef __cplusplus
> > +extern "C" {
> > +#endif
> > +#include <ofw/ofw.h>
> > +#define OF_peer                   rtems_ofw_peer
> > +#define OF_child                  rtems_ofw_child
> > +#define OF_parent                 rtems_ofw_parent
> > +#define OF_getproplen             rtems_ofw_get_prop_len
> > +#define OF_getprop                rtems_ofw_get_prop
> > +#define OF_getencprop             rtems_ofw_get_enc_prop
> > +#define OF_hasprop                rtems_ofw_has_prop
> > +#define OF_searchprop             rtems_ofw_search_prop
> > +#define OF_searchencprop          rtems_ofw_search_enc_prop
> > +#define OF_getprop_alloc          rtems_ofw_get_prop_alloc
> > +#define OF_getprop_alloc_multi    rtems_ofw_get_prop_alloc_multi
> > +#define OF_getencprop_alloc_multi rtems_ofw_get_enc_prop_alloc_multi
> > +#define OF_getencprop_alloc       rtems_ofw_get_enc_prop_alloc
> > +#define OF_prop_free              rtems_ofw_free
> > +#define OF_nextprop               rtems_ofw_next_prop
> > +#define OF_setprop                rtems_ofw_set_prop
> > +#define OF_canon                  rtems_ofw_canon
> > +#define OF_finddevice             rtems_ofw_find_device
> > +#define OF_package_to_path        rtems_ofw_package_to_path
> > +#define OF_node_from_xref         rtems_ofw_node_from_xref
> > +#define OF_xref_from_node         rtems_ofw_xref_from_node
> > +#define OF_instance_to_package    rtems_ofw_instance_to_package
> > +#define OF_instance_to_path       rtems_ofw_instance_to_path
> > +#ifdef __cplusplus
> > +#endif
> > +#endif /* _OFW_COMPAT_H */
> > diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
> > index 0000000000..c18ee766e1
> > --- /dev/null
> > +++ b/bsps/shared/ofw/ofw.c
> > @@ -0,0 +1,682 @@
> > + * @file
> > + * @ingroup ofw
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <bsp/fdt.h>
> > +#include <sys/param.h>
> > +#include <libfdt.h>
> > +#include <assert.h>
> > +#include <rtems/sysinit.h>
> > +const void *fdtp = NULL;
> > +static phandle_t rtems_fdt_offset_to_phandle( int offset )
> > +  if (offset < 0) {
> > +    return 0;
> > +  return (phandle_t)offset + fdt_off_dt_struct(fdtp);
> > +static int rtems_fdt_phandle_to_offset( phandle_t handle )
> > +  int off;
> > +  int fdt_off;
> > +  off = (int) handle;
> > +  fdt_off = fdt_off_dt_struct(fdtp);
> > +  if (off < fdt_off) {
> > +    return -1;
> > +  return off - fdt_off;
> > +static void rtems_ofw_init( void ) {
> > +  int rv;
> > +  const void *fdt;
> > +  fdt = bsp_fdt_get();
> > +  rv = fdt_check_header(fdt);
> > +   * If the FDT is invalid exit through fatal.
> > +  if (rv != 0) {
> > +    rtems_fatal_error_occurred(RTEMS_NOT_CONFIGURED);
> > +  fdtp = fdt;
> > +RTEMS_SYSINIT_ITEM(
> > +  rtems_ofw_init,
> > +  RTEMS_SYSINIT_BSP_PRE_DRIVERS,
> > +  RTEMS_SYSINIT_ORDER_FIRST
> > +phandle_t rtems_ofw_peer( phandle_t node )
> > +  int offset;
> > +  if (node == 0) {
> > +    int root = fdt_path_offset(fdtp, "/");
> > +    return rtems_fdt_offset_to_phandle(root);
> > +  offset = rtems_fdt_phandle_to_offset(node);
> > +  if (offset < 0) {
> > +    return 0;
> > +  offset = fdt_next_subnode(fdtp, offset);
> > +  return rtems_fdt_offset_to_phandle(offset);
> > +phandle_t rtems_ofw_child( phandle_t node )
> > +  int offset;
> > +  if (offset < 0) {
> > +    return 0;
> > +  offset = fdt_first_subnode(fdtp, offset);
> > +phandle_t rtems_ofw_parent( phandle_t node )
> > +  int offset;
> > +  if (offset < 0) {
> > +    return 0;
> > +  offset = fdt_parent_offset(fdtp, offset);
> > +  phandle_t node,
> > +  int offset;
> > +  int len;
> > +  const void *prop;
> > +  if (offset < 0) {
> > +    return -1;
> > +  prop = fdt_getprop(fdtp, offset, propname, &len);
> > +  if (prop == NULL && strcmp(propname, "name") == 0) {
> > +    fdt_get_name(fdtp, offset, &len);
> > +    return len + 1;
> > +  if (prop == NULL && strcmp(propname, "/chosen") == 0) {
> > +    if (strcmp(propname, "fdtbootcpu") == 0)
> > +      return sizeof(pcell_t);
> > +    if (strcmp(propname, "fdtmemreserv") == 0)
> > +      return 2 * sizeof(uint64_t) * fdt_num_mem_rsv(fdtp);
> > +  if (prop == NULL) {
> > +    return -1;
> > +  return len;
> > +  phandle_t    node,
> > +  void        *buf,
> > +  size_t       bufsize
> > +  const void *prop;
> > +  int offset;
> > +  int len;
> > +  uint32_t cpuid;
> > +  if (offset < 0) {
> > +    return -1;
> > +    prop = fdt_get_name(fdtp, offset, &len);
> > +    strncpy(buf, prop, bufsize);
> > +    return len + 1;
> > +    if (strcmp(propname, "fdtbootcpu") == 0) {
> > +      cpuid = cpu_to_fdt32(fdt_boot_cpuid_phys(fdtp));
> > +      len = sizeof(cpuid);
> > +      prop = &cpuid;
> > +    if (strcmp(propname, "fdtmemreserv") == 0) {
> > +      prop = (char *)fdtp + fdt_off_mem_rsvmap(fdtp);
> > +      len = sizeof(uint64_t)*2*fdt_num_mem_rsv(fdtp);
> > +    return -1;
> > +  bcopy(prop, buf, MIN(len, bufsize));
> > +  return len;
> > +  phandle_t    node,
> > +  const char  *prop,
> > +  pcell_t     *buf,
> > +  size_t       len
> > +  ssize_t rv;
> > +  assert(len % 4 == 0);
> > +  rv = rtems_ofw_get_prop(node, prop, buf, len);
> > +  if (rv < 0) {
> > +    return rv;
> > +  for (int i = 0; i < (len / 4); i++) {
> > +    buf[i] = fdt32_to_cpu(buf[i]);
> > +  return rv;
> > +  phandle_t    node,
> > +  ssize_t rv;
> > +  rv = rtems_ofw_get_prop_len(node, propname);
> > +  return rv >= 0 ? 1 : 0;
> > +  phandle_t    node,
> > +  void        *buf,
> > +  size_t       len
> > +  ssize_t rv;
> > +  for (; node != 0; node = rtems_ofw_parent(node)) {
> > +    if ((rv = rtems_ofw_get_prop(node, propname, buf, len) != -1)) {
> > +      return rv;
> > +  return -1;
> > +  phandle_t    node,
> > +  pcell_t     *buf,
> > +  size_t       len
> > +  ssize_t rv;
> > +    if ((rv = rtems_ofw_get_enc_prop(node, propname, buf, len) != -1)) {
> > +      return rv;
> > +  return -1;
> > +  phandle_t    node,
> > +  void       **buf
> > +  ssize_t len;
> > +  *buf = NULL;
> > +  if ((len = rtems_ofw_get_prop_len(node, propname)) == -1) {
> > +    return -1;
> > +  if (len > 0) {
> > +    *buf = malloc(len);
> > +    if (*buf == NULL) {
> > +      return -1;
> > +    if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
> > +      rtems_ofw_free(buf);
> > +      *buf = NULL;
> > +      return -1;
> > +  return len;
> > +  phandle_t    node,
> > +  int          elsz,
> > +  void       **buf
> > +  ssize_t len;
> > +  *buf = NULL;
> > +  if ((len = rtems_ofw_get_prop_len(node, propname)) == -1 ||
> > +      (len % elsz != 0)) {
> > +    return -1;
> > +  if (len > 0) {
> > +      return -1;
> > +      *buf = NULL;
> > +      return -1;
> > +  return (len / elsz);
> > +  phandle_t    node,
> > +  void       **buf
> > +  ssize_t len;
> > +  *buf = NULL;
> > +    return -1;
> > +  if (len > 0) {
> > +      return -1;
> > +    if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
> > +      *buf = NULL;
> > +      return -1;
> > +  return len;
> > +  phandle_t     node,
> > +  int           elsz,
> > +  void        **buf
> > +  ssize_t len;
> > +  *buf = NULL;
> > +    return -1;
> > +  if (len > 0) {
> > +      return -1;
> > +      *buf = NULL;
> > +      return -1;
> > +void rtems_ofw_free( void *buf )
> > +  free(buf);
> > +  phandle_t    node,
> > +  char        *buf,
> > +  size_t       len
> > +  const void *name;
> > +  const void *prop;
> > +  int offset;
> > +  if (offset < 0) {
> > +    return -1;
> > +  if (previous == NULL) {
> > +    offset = fdt_first_property_offset(fdtp, offset);
> > +  } else {
> > +    fdt_for_each_property_offset(offset, fdtp, offset) {
> > +      prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name,
> NULL);
> > +      if (prop == NULL)
> > +        return -1;
> > +      if (strcmp(previous, name) != 0)
> > +        continue;
> > +      offset = fdt_next_property_offset(fdtp, offset);
> > +      break;
> > +  if (offset < 0)
> > +    return 0;
> &offset);
> > +  if (prop == NULL)
> > +    return -1;
> > +  strncpy(buf, name, len);
> > +  return 1;
> > +  phandle_t    node,
> > +  const char  *name,
> > +  const void  *buf,
> > +  size_t       len
> > +  int offset;
> > +  if (offset < 0)
> > +    return -1;
> > +  if (fdt_setprop_inplace(fdtp, offset, name, buf, len) != 0)
> > +    return (fdt_setprop(fdtp, offset, name, buf, len));
> > +  return 0;
> > +phandle_t rtems_ofw_find_device( const char *path )
> > +  int offset;
> > +  offset = fdt_path_offset(fdtp, path);
> > +  if (offset < 0)
> > +    return -1;
> > +static phandle_t rtems_ofw_get_effective_phandle(
> > +  phandle_t node,
> > +  phandle_t xref
> > +  phandle_t child;
> > +  phandle_t ref;
> > +  for (child = rtems_ofw_child(node); child != 0; child =
> rtems_ofw_peer(child)) {
> > +    ref = rtems_ofw_get_effective_phandle(child, xref);
> > +    if (ref != -1)
> > +      return ref;
> > +    if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref)) ==
> -1 &&
> > +        rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref, sizeof(ref))
> == -1 &&
> > +        rtems_ofw_get_enc_prop(child, "linux,phandle", &ref,
> sizeof(ref)) == -1
> > +      continue;
> > +    if (ref == xref)
> > +      return child;
> > +  return -1;
> > +phandle_t rtems_ofw_node_from_xref( phandle_t xref )
> > +  phandle_t node;
> > +  if ((node = rtems_ofw_get_effective_phandle(rtems_ofw_peer(0), xref))
> == -1)
> > +    return xref;
> > +  return node;
> > +phandle_t rtems_ofw_xref_from_node( phandle_t node )
> > +  phandle_t ref;
> > +    if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref)) ==
> -1 &&
> > +        rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref, sizeof(ref))
> == -1 &&
> > +        rtems_ofw_get_enc_prop(node, "linux,phandle", &ref,
> sizeof(ref)) == -1)
> > +      return node;
> > +    return ref;
> > +phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
> > +  return rtems_ofw_node_from_xref(instance);
> > +  phandle_t   node,
> > +  char       *buf,
> > +  size_t      len
> > +  int offset;
> > +  int rv;
> > +  rv = fdt_get_path(fdtp, offset, buf, len);
> > +  if (rv != 0)
> > +    return -1;
> > +  return rv;
> > +  char      *buf,
> > +  size_t     len
> > +  int offset;
> > +  int rv;
> > +  offset = rtems_ofw_instance_to_package(instance);
> > +  offset = rtems_fdt_phandle_to_offset(offset);
> > +  if (rv != 0)
> > +    return -1;
> > +  return rv;
> > +  phandle_t              node,
> > +  size_t                 size
> > +  int len;
> > +  int offset;
> > +  int nranges;
> > +  int nregs;
> > +  phandle_t parent;
> > +  rtems_ofw_ranges range;
> > +  const rtems_ofw_ranges *ptr;
> > +  len = rtems_ofw_get_enc_prop(node, "reg", (pcell_t *)buf, size);
> > +  if (len <= 0) {
> > +    return len;
> > +  nregs = MIN(len, size) / sizeof(rtems_ofw_memory_area);
> > +  for (parent = rtems_ofw_parent(node); parent > 0;
> > +      parent = rtems_ofw_parent(parent)) {
> > +    offset = rtems_fdt_phandle_to_offset(parent);
> > +    ptr = fdt_getprop(fdtp, offset, "ranges", &len);
> > +    if (len < 0) {
> > +      break;
> > +    nranges = len / sizeof(rtems_ofw_ranges);
> > +    offset = 0;
> > +    for (int i=0; i < nregs; i++) {
> > +      for (int j=0; j < nranges; j++) {
> > +        range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
> > +        range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
> > +        range.size = fdt32_to_cpu(ptr[j].size);
> > +        if (buf[i].start >= range.child_bus &&
> > +            buf[i].start < range.child_bus + range.size) {
> > +          offset = range.parent_bus - range.child_bus;
> > +          break;
> > +      buf[i].start += offset;
> > +  return nregs;
> > +  phandle_t            node,
> > +  size_t               size
> > +  int rv;
> > +  rv = rtems_ofw_get_enc_prop(node, "interrupts", buf, size);
> > +  if (rv <= 0) {
> > +    return rv;
> > +  return MIN(size, rv) / sizeof(rtems_vector_number);
> > +  int len;
> > +  const char buf[10];
> > +  len = rtems_ofw_get_prop(node, "status", &buf[0], sizeof(buf));
> > +  if ((len == -1) ||
> > +      (strncmp(buf, "okay", MIN(5, len)) == 0) ||
> > +      (strncmp(buf, "ok", MIN(3, len)) == 0)) {
> > +      return true;
> > +  return false;
> > +  int offset;
> > +  offset = fdt_node_offset_by_compatible(fdtp, -1, compat);
> > diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> > index a454783d51..b598d54d16 100644
> > --- a/spec/build/bsps/obj.yml
> > +++ b/spec/build/bsps/obj.yml
> > @@ -24,6 +24,10 @@ install:
> >    - bsps/include/bsp/u-boot.h
> >    - bsps/include/bsp/uart-output-char.h
> >    - bsps/include/bsp/utility.h
> > +- destination: ${BSP_INCLUDEDIR}/ofw
> > +  source:
> > +  - bsps/include/ofw/ofw.h
> > +  - bsps/include/ofw/ofw_compat.h
> >  - destination: ${BSP_INCLUDEDIR}/libchip
> >    source:
> >    - bsps/include/libchip/ata.h
> > @@ -96,4 +100,5 @@ source:
> >  - bsps/shared/dev/serial/serprobe.c
> >  - bsps/shared/start/bootcard.c
> >  - bsps/shared/rtems-version.c
> > +- bsps/shared/ofw/ofw.c
> >  type: build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201117/ef016a95/attachment-0001.html>
