[PATCH 7/8] validation/ts-performance-0: Add test suite
Sebastian Huber
Tue Nov 17 07:02:51 UTC 2020
On 17/11/2020 00:15, Chris Johns wrote:
>>>> new file mode 100644
>>>> index 0000000000..0f7db65a8e
>>>> --- /dev/null
>>>> +++ b/testsuites/validation/ts-default.h
>>>> @@ -0,0 +1,237 @@
>>>> +/* SPDX-License-Identifier: BSD-2-Clause */
>>>> + * @file
>>>> + * @brief This header file provides the default validation test suite runner
>>>> + * and application configuration.
>>>> +#define CONFIGURE_SCHEDULER_EDF_SMP
>>>> +#include <rtems/scheduler.h>
>>>> +RTEMS_SCHEDULER_EDF_SMP(a);
>>>> +RTEMS_SCHEDULER_EDF_SMP(b);
>>>> +RTEMS_SCHEDULER_EDF_SMP(c);
>>>> +#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
>>>> + RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
>>>> + RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
>>>> + RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
>>>> +#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
>>>> + RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
>>>> + RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
>>>> + RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
>>> These seems specific but I ma not sure.
>> This configuration provides enough resources to run a wide range of test cases.
>> For example, the SMP scheduler configuration with three schedulers can be used
>> to test most of the SMP support of RTEMS.
>>> Do tests depend on this configuration?
>> Yes, if the configuration provides the necessary resources, they pass, otherwise
>> they fail.
> Any particular reason for those schedulers in that order?
Most tests use one processor. With just two processors you can probably
test more than 90% of the RTEMS SMP support. Only some very specific
corner cases need more than two processors. This is a general purpose
test suite and the configuration will be adapted if a new test case
needs something special. If it is too special, then it can be added to a
dedicated test suite.
>>> Does the number of cores available effect this or the dependent tests? I assume
>>> this is included in a number of tests.
>> If a test needs three processors and a board has only two, then the test case
>> should fail.
> Will those BSPs have the failing tests excluded?
Currently, there is no support for the new test framework in the RTEMS
Tester. You can only specify the expected state of a complete test
suite. I hope to eventually add some support for the new test framework
so that the expected state of individual test cases can be specified.
> I would like to be comfortable the tests and these set ups are not solely
> focused on the LEON.
I am not focused on the LEON. Why do you think something is
LEON-specific in this test suite?
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
