[PATCH rtems 1/9] Add License file for BSD-3-Clause
Tue Nov 17 17:29:14 UTC 2020
this is ok, would have preferred it separately ;)
On Tue, Nov 17, 2020 at 4:05 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> We have some files with a SPDX identifier for this license. Therefore
> the license should be here too.
>  LICENSE.BSD-3-Clause | 27 +++++++++++++++++++++++++++
>  1 file changed, 27 insertions(+)
>  create mode 100644 LICENSE.BSD-3-Clause
> diff --git a/LICENSE.BSD-3-Clause b/LICENSE.BSD-3-Clause
> new file mode 100644
> index 0000000000..09d01c1ff5
> --- /dev/null
> +++ b/LICENSE.BSD-3-Clause
> @@ -0,0 +1,27 @@
> +https://spdx.org/licenses/BSD-3-Clause
> +Redistribution and use in source and binary forms, with or without
> +modification, are permitted provided that the following conditions are
> +met:
> +    1. Redistributions of source code must retain the above copyright
> +       notice, this list of conditions and the following disclaimer.
> +    2. Redistributions in binary form must reproduce the above
> +       copyright notice, this list of conditions and the following
> +       disclaimer in the documentation and/or other materials provided
> +       with the distribution.
> +    3. Neither the name of the copyright holder nor the names of its
> +       contributors may be used to endorse or promote products derived
> +       from this software without specific prior written permission.
> +THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> +"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> +LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
> +A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
> +HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> +SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
> +LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
> +DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
> +THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
> +(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
> +OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> 2.26.2
> devel mailing list
> devel at rtems.org
