[PATCH] Add License file for BSD-3-Clause
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed Nov 18 07:36:30 UTC 2020
We have some files with a SPDX identifier for this license. Therefore
the license should be here too.
Note: This is a resubmission of the patch. Previously I submitted it together
with the patches that add a new imxrt BSP:
https://lists.rtems.org/pipermail/devel/2020-November/063273.html
I only noted that it would have been better separate after Gedare said it.
LICENSE.BSD-3-Clause | 27 +++++++++++++++++++++++++++
1 file changed, 27 insertions(+)
create mode 100644 LICENSE.BSD-3-Clause
diff --git a/LICENSE.BSD-3-Clause b/LICENSE.BSD-3-Clause
new file mode 100644
index 0000000000..09d01c1ff5
--- /dev/null
+++ b/LICENSE.BSD-3-Clause
@@ -0,0 +1,27 @@
+https://spdx.org/licenses/BSD-3-Clause
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions are
+met:
+ 1. Redistributions of source code must retain the above copyright
+ notice, this list of conditions and the following disclaimer.
+ 2. Redistributions in binary form must reproduce the above
+ copyright notice, this list of conditions and the following
+ disclaimer in the documentation and/or other materials provided
+ with the distribution.
+ 3. Neither the name of the copyright holder nor the names of its
+ contributors may be used to endorse or promote products derived
+ from this software without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
2.26.2
