[PATCHES] Add imxrt BSP
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed Nov 18 07:55:39 UTC 2020
Hello Gedare,
Am 17.11.20 um 18:33 schrieb Gedare Bloom:
> Everything except 5 looks good. I or someone else should take a closer
> look at that.
Thanks for the review.
I noted that I most likely have to rework the MPU setup a bit. A table
based approach (similar to the one used for ARMV7_CP15 based BSPs) would
be better to allow a user to overwrite the table if he has a board with
a slightly different memory configuration.
> On Tue, Nov 17, 2020 at 4:04 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> Hello,
>> the following patches add a BSP for IMXRT1050-EVKB. In case the import
>> patch is too big: I pushed the patches here too:
>> https://gitlab.com/c-mauderer/rtems/-/tree/cm/20201117_imxrt
>> Best regards
>> Christian
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
