[PATCH rtems-docs 1/2] user/bsps: Add imxrt
Wed Nov 18 16:08:00 UTC 2020
On Wed, Nov 18, 2020 at 12:52 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Am 17.11.20 um 18:41 schrieb Gedare Bloom:
> > On Tue, Nov 17, 2020 at 4:09 AM Christian Mauderer
> >> Update #4180
> >>   user/bsps/arm/imxrt.rst | 174 ++++++++++++++++++++++++++++++++++++++++
> >>   user/bsps/bsps-arm.rst  |   1 +
> >>   2 files changed, 175 insertions(+)
> >>   create mode 100644 user/bsps/arm/imxrt.rst
> >> diff --git a/user/bsps/arm/imxrt.rst b/user/bsps/arm/imxrt.rst
> >> new file mode 100644
> >> index 0000000..41c6bff
> >> --- /dev/null
> >> +++ b/user/bsps/arm/imxrt.rst
> >> @@ -0,0 +1,174 @@
> >> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> >> +.. Copyright (C) 2020 embedded brains GmbH
> >> +.. Copyright (C) 2020 Christian Mauderer
> >> +imxrt (NXP i.MXRT)
> >> +This BSP offers only one variant, the `imxrt1052`. This variant supports the
> >> +i.MXRT 1052 processor on a IMXRT1050-EVKB (tested with rev A1). You can also
> >> +configure it to work with custom boards.
> >> +Build Configuration Options
> >> +Please see the documentation of the `IMXRT_*` and `BSP_*` configuration options
> >> +for that. You can generate a default set of options with::
> > one colon: I think?
> That's the start for the literal block below. Restructured Text allows
> three syntax variants for that. From Wikipedia:
>    some literal text
> This may also be used inline at the end of a paragraph, like so::
>    some more literal text
> .. code:: python
>     print("A literal block directive explicitly marked as python code")
thanks
> >> +  ./waf bsp_defaults --rtems-bsps=arm/imxrt1052 > config.ini
> >> +Boot Process
> >> +There are two possible boot processes supported:
> >> +1) The ROM code loads a configuration from HyperFlash (connected to FlexSPI),
> >> +   does some initialization (based on device configuration data (DCD)) and then
> >> +   starts the application. This is the default case. `linkcmds.flexspi` is used
> >> +   for this case.
> >> +2) Some custom bootloader does the basic initialization, loads the application
> >> +   to SDRAM and starts it from there. Select the `linkcmds.sdram` for this.
> >> +For programming the HyperFlash in case 1, you can use the on board debugger
> >> +integrated into the IMXRT1050-EVKB. You can generate a flash image out of a
> >> +compiled RTEMS application with for example::
> >> +  arm-rtems6-objcopy -O binary build/arm/imxrt1052/testsuites/samples/hello.exe hello.bin
> >> +Then just copy the generated binary to the mass storage provided by the
> >> +debugger. Wait a bit till the mass storage vanishes and re-appears. After that,
> >> +reset the board and the newly programmed application will start.
> >> +For debugging: Create a special application with a `while(true)` loop at end of
> >> +`bsp_start_hook_1`. Load that application into flash. Then remove the loop
> >> +again, build your BSP for SDRAM and use a debugger to load the application into
> >> +SDRAM after the BSP started from flash did the basic initialization.
> >> +Flash Image
> >> +For booting from a HyperFlash (or other storage connected to FlexSPI), the ROM
> >> +code of the i.MXRT first reads some special flash header information from a
> >> +fixed location of the connected flash device. This consists of the Image vector
> >> +table (IVT), Boot data and Device configuration data (DCD).
> >> +In RTEMS, these flash headers are generated using some C-structures. If you use
> >> +a board other then the IMXRT1050-EVKB, they have to be adapted. To do that
> > s/then/than
> Thanks.
> > s/they have/it has
> I thought that multiple structures for multiple headers have to be
> adapted. Would it really be correct to use "it" for that?
I see. In this case, it would be more clear to say "those structures
have" since it is not entirely clear what "they" refers back to.
> >> +re-define the following variables in your application (you only need the ones
> >> +that need different values):
> >> +.. code-block:: c
> >> +  #include <bsp/flash-headers.h>
> >> +  const uint8_t imxrt_dcd_data[] =
> >> +      { /* Your DCD data here */ };
> >> +  const ivt imxrt_image_vector_table =
> >> +      { /* Your IVT here */ };
> >> +  const BOOT_DATA_T imxrt_boot_data =
> >> +      { /* Your boot data here */ };
> >> +  const flexspi_nor_config_t imxrt_flexspi_config =
> >> +      { /* Your FlexSPI config here */ };
> >> +You can find the default definitions in `bsps/arm/imxrt/start/flash-*.c`. Take a
> >> +look at the `i.MX RT1050 Processor Reference Manual, Rev. 4, 12/2019` chapter
> >> +`9.7 Program image` for details about the contents.
> >> +FDT
> >> +The BSP used a FDT based initialization. The FDT is linked into the application.
> >> +You can find the default FDT used in the BSP in
> >> +`bsps/arm/imxrt/dts/imxrt1050-evkb.dts`. To use your own FDT compile it and
> >> +convert it into a C file with (replace `YOUR.dts` and simmilar with your FDT
> >> +source names)::
> >> +  sh> export BSP_DIR="${RTEMS_SRC_DIR}/bsps/arm/imxrt/"
> >> +  sh> arm-rtems6-cpp -P -x assembler-with-cpp \
> >> +          -I "${BSP_DIR}/include/" \
> >> +          -include "YOUR.dts" /dev/null | \
> >> +      dtc -@ -O dtb -o "YOUR.dtb" -b 0 -p 1024
> >> +  sh> rtems-bin2c -C -N imxrt_dtb "YOUR.dtb" "YOUR.c"
> >> +Make sure that your new c file is compiled and linked into the application.
> >> +Clock Driver
> >> +The clock driver uses the generic `ARMv7-M Clock`.
> >> +IOMUX
> >> +The i.MXRT IOMUXC is initialized based on the FDT. For that, the `pinctrl-0`
> >> +fields of all devices with a status of `ok` or `okay` will be parsed.
> >> +Console Driver
> >> +LPUART drivers are registered based on the FDT. The special `rtems,path`
> >> +attribute defines where the device file for the console is created.
> >> +The `stdout-path` in the `chosen` node determines which LPUART is used for the
> >> +console.
> >> +I2C Driver
> >> +I2C drivers are registered based on the FDT. The special `rtems,path` attribute
> >> +defines where the device file for the I2C bus is created.
> >> +Limitations:
> >> +* Only basic I2C is implemented. This is mostly a driver limitation and not a
> >> +  hardware one.
> >> +SPI Driver
> >> +SPI drivers are registered based on the FDT. The special `rtems,path` attribute
> >> +defines where the device file for the SPI bus is created.
> >> +Note that the SPI-pins on the evaluation board are shared with the SD card.
> >> +Populate R278, R279, R280, R281 on the IMXRT1050-EVKB (Rev A) to use the SPI
> >> +pins on the Arduino connector.
> >> +Limitations:
> >> +* Only a basic SPI driver is implemented. This is mostly a driver limitation and
> >> +  not a hardware one.
> >> +Network Interface Driver
> >> +The network interface driver is provided by the `libbsd`. It is initialized
> > We probably need a libbsd (or update of the networking) manual soon.
> Yes, I agree. I'm just not sure how to start that.
It starts with a ticket ;)
> Most likely someone has to start with some (good) structure that can be
> extended step for step. I'm a bit uncertain how that structure could
> look like.
Yes. We do have an existing networking manual, but I don't know its state.
> Alternatively: Do you know whether there is a new Google Season of Docs
> planned? Maybe we could try to get a technical writer who is officially
> tasked to annoy all of us to give him input for that via that program.
I'm not aware of another GSoD. We'll have to keep an eye out for it.
> >> +according to the device tree.
> >> +Note on the hardware: The i.MXRT1050 EVKB maybe has a wrong termination of the
> >> +RXP, RXN, TXP and TXN lines. The resistors R126 through R129 maybe shouldn't be
> >> +populated because the used KSZ8081RNB already has an internal termination.
> >> +Ethernet does work on short distance anyway. But keep it in mind in case you
> >> +have problems. Source:
> >> +https://community.nxp.com/t5/i-MX-RT/Error-in-IMXRT1050-EVKB-and-1060-schematic-ethernet/m-p/835540#M1587
> >> +NXP SDK files
> >> +A lot of peripherals are currently not yet supported by RTEMS drivers. The NXP
> >> +SDK offers drivers for these. For convenience, the BSP compiles the drivers from
> >> +the SDK. But please note that they are not tested and maybe won't work out of
> >> +the box. Everything that works with interrupts most likely needs some special
> >> +treatment.
> >> +Caveats
> >> +The clock configuration support is quite rudimentary. The same is true for
> >> +SDRAM. It mostly relies on the DCD and on a static clock configuration that is
> >> +taken from the NXP SDK example projects.
> >> +The MPU settings are currently quite permissive. Some stronger rules might could
> >> +improve the security.
> > I'd prefer we avoid statements regarding security here. Just delete
> > the last sentence.
> OK.
> >> +There is no power management support.
> >> diff --git a/user/bsps/bsps-arm.rst b/user/bsps/bsps-arm.rst
> >> index 295ed82..a63dd5f 100644
> >> --- a/user/bsps/bsps-arm.rst
> >> +++ b/user/bsps/bsps-arm.rst
> >> @@ -14,6 +14,7 @@ arm (ARM)
> >>   .. include:: arm/edb7312.rst
> >>   .. include:: arm/gumstix.rst
> >>   .. include:: arm/imx.rst
> >> +.. include:: arm/imxrt.rst
> >>   .. include:: arm/lm3s69xx.rst
> >>   .. include:: arm/lpc176x.rst
> >> 2.26.2
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
