[PATCH] Add License file for BSD-3-Clause
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Nov 19 07:36:00 UTC 2020
Thanks. I pushed it.
Am 18.11.20 um 17:17 schrieb Gedare Bloom:
> Looks good, push it
> On Wed, Nov 18, 2020 at 12:37 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> We have some files with a SPDX identifier for this license. Therefore
>> the license should be here too.
>> Note: This is a resubmission of the patch. Previously I submitted it together
>> with the patches that add a new imxrt BSP:
>> https://lists.rtems.org/pipermail/devel/2020-November/063273.html
>> I only noted that it would have been better separate after Gedare said it.
>> LICENSE.BSD-3-Clause | 27 +++++++++++++++++++++++++++
>> 1 file changed, 27 insertions(+)
>> create mode 100644 LICENSE.BSD-3-Clause
>> diff --git a/LICENSE.BSD-3-Clause b/LICENSE.BSD-3-Clause
>> new file mode 100644
>> index 0000000000..09d01c1ff5
>> --- /dev/null
>> +++ b/LICENSE.BSD-3-Clause
>> @@ -0,0 +1,27 @@
>> +https://spdx.org/licenses/BSD-3-Clause
>> +Redistribution and use in source and binary forms, with or without
>> +modification, are permitted provided that the following conditions are
>> +met:
>> + 1. Redistributions of source code must retain the above copyright
>> + notice, this list of conditions and the following disclaimer.
>> + 2. Redistributions in binary form must reproduce the above
>> + copyright notice, this list of conditions and the following
>> + disclaimer in the documentation and/or other materials provided
>> + with the distribution.
>> + 3. Neither the name of the copyright holder nor the names of its
>> + contributors may be used to endorse or promote products derived
>> + from this software without specific prior written permission.
>> +THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> +"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>> +LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
>> +A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
>> +HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
>> +SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
>> +LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
>> +DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
>> +THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>> +(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
>> +OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
