[PATCH 1/2] config: Simplify task stack allocator init
Thu Nov 19 07:41:38 UTC 2020
Replace runtime checks with compile time assertions.  This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
 cpukit/include/rtems/confdefs/wkspace.h     | 10 ++++++
 cpukit/include/rtems/score/interr.h         |  2 +-
 cpukit/score/src/stackallocatorinit.c       |  8 -----
 spec/build/testsuites/sptests/grp.yml       |  2 --
 spec/build/testsuites/sptests/spfatal06.yml | 19 -----------
 testsuites/sptests/Makefile.am              |  9 -----
 testsuites/sptests/configure.ac             |  1 -
 testsuites/sptests/spfatal06/init.c         | 38 ---------------------
 testsuites/sptests/spfatal06/spfatal06.doc  | 20 -----------
 testsuites/sptests/spfatal06/spfatal06.scn  |  3 --
 testsuites/sptests/spinternalerror01/init.c | 15 ++++++--
 testsuites/sptests/sptimecounter01/init.c   | 15 ++++++--
 12 files changed, 37 insertions(+), 105 deletions(-)
 delete mode 100644 spec/build/testsuites/sptests/spfatal06.yml
 delete mode 100644 testsuites/sptests/spfatal06/init.c
 delete mode 100644 testsuites/sptests/spfatal06/spfatal06.doc
 delete mode 100644 testsuites/sptests/spfatal06/spfatal06.scn
diff --git a/cpukit/include/rtems/confdefs/wkspace.h b/cpukit/include/rtems/confdefs/wkspace.h
index d40194cbec..de555101a1 100644
--- a/cpukit/include/rtems/confdefs/wkspace.h
+++ b/cpukit/include/rtems/confdefs/wkspace.h
@@ -150,9 +150,19 @@ const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
     const Stack_Allocator_initialize _Stack_Allocator_initialize = NULL;
   #endif
+  RTEMS_STATIC_ASSERT(
+    CONFIGURE_TASK_STACK_ALLOCATOR != NULL,
+    CONFIGURE_TASK_STACK_ALLOCATOR_MUST_NOT_BE_NULL
   const Stack_Allocator_allocate _Stack_Allocator_allocate =
     CONFIGURE_TASK_STACK_ALLOCATOR;
+    CONFIGURE_TASK_STACK_DEALLOCATOR != NULL,
+    CONFIGURE_TASK_STACK_DEALLOCATOR_MUST_NOT_BE_NULL
   const Stack_Allocator_free _Stack_Allocator_free =
     CONFIGURE_TASK_STACK_DEALLOCATOR;
diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
index 85767d0bc5..4b06199ae9 100644
--- a/cpukit/include/rtems/score/interr.h
+++ b/cpukit/include/rtems/score/interr.h
@@ -177,7 +177,7 @@ typedef enum {
   INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS = 11,
   INTERNAL_ERROR_OUT_OF_PROXIES = 12,
   INTERNAL_ERROR_INVALID_GLOBAL_ID = 13,
-  INTERNAL_ERROR_BAD_STACK_HOOK = 14,
+  /* INTERNAL_ERROR_BAD_STACK_HOOK = 14, */
   /* INTERNAL_ERROR_BAD_ATTRIBUTES = 15, */
   /* INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY = 16, */
   /* INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL = 17, */
diff --git a/cpukit/score/src/stackallocatorinit.c b/cpukit/score/src/stackallocatorinit.c
index 60d243631f..412e3142b3 100644
--- a/cpukit/score/src/stackallocatorinit.c
+++ b/cpukit/score/src/stackallocatorinit.c
@@ -38,20 +38,12 @@
 #endif
 #include <rtems/score/stack.h>
-#include <rtems/score/interr.h>
 #include <rtems/config.h>
 void _Stack_Allocator_do_initialize( void )
   rtems_stack_allocate_init_hook init_hook;
-  if (
-    rtems_configuration_get_stack_allocate_hook() == NULL
-      || rtems_configuration_get_stack_free_hook() == NULL
-    _Internal_error( INTERNAL_ERROR_BAD_STACK_HOOK );
   init_hook = rtems_configuration_get_stack_allocate_init_hook();
   if ( init_hook  != NULL ) {
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index 64b0a54b0e..1c865777a7 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -226,8 +226,6 @@ links:
   uid: spfatal04
 - role: build-dependency
   uid: spfatal05
-- role: build-dependency
-  uid: spfatal06
   uid: spfatal09
diff --git a/spec/build/testsuites/sptests/spfatal06.yml b/spec/build/testsuites/sptests/spfatal06.yml
deleted file mode 100644
index 6e4be90a2a..0000000000
--- a/spec/build/testsuites/sptests/spfatal06.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-build-type: test-program
-cflags: []
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-cppflags: []
-cxxflags: []
-enabled-by: true
-features: c cprogram
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spfatal06/init.c
-stlib: []
-target: testsuites/sptests/spfatal06.exe
-type: build
-use-after: []
-use-before: []
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 854ec3daf8..14788f7fb1 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -940,15 +940,6 @@ spfatal05_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spfatal05) \
 	$(support_includes)
 endif
-if TEST_spfatal06
-sp_tests += spfatal06
-sp_screens += spfatal06/spfatal06.scn
-sp_docs += spfatal06/spfatal06.doc
-spfatal06_SOURCES = spfatal06/init.c
-spfatal06_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spfatal06) \
-	$(support_includes)
-endif
 if TEST_spfatal09
 sp_tests += spfatal09
 sp_screens += spfatal09/spfatal09.scn
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 460917dd04..099ff0412b 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -141,7 +141,6 @@ RTEMS_TEST_CHECK([spfatal02])
 RTEMS_TEST_CHECK([spfatal03])
 RTEMS_TEST_CHECK([spfatal04])
 RTEMS_TEST_CHECK([spfatal05])
-RTEMS_TEST_CHECK([spfatal06])
 RTEMS_TEST_CHECK([spfatal09])
 RTEMS_TEST_CHECK([spfatal10])
 RTEMS_TEST_CHECK([spfatal11])
diff --git a/testsuites/sptests/spfatal06/init.c b/testsuites/sptests/spfatal06/init.c
index cef38f5fe2..0000000000
--- a/testsuites/sptests/spfatal06/init.c
+++ /dev/null
@@ -1,38 +0,0 @@
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include "../spfatal_support/spfatal.h"
- *  Classic API Init task create failure
- *  COPYRIGHT (c) 1989-2008.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#define FATAL_ERROR_TEST_NAME            "6"
-#define FATAL_ERROR_DESCRIPTION \
-        "Core initialize with invalid stack hook"
-#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_CORE
-#define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_BAD_STACK_HOOK
-#define CONFIGURE_TASK_STACK_ALLOCATOR New_stack_allocate_hook
-#define CONFIGURE_TASK_STACK_DEALLOCATOR NULL
-static void *New_stack_allocate_hook(size_t unused)
-  return NULL;
-static void force_error(void)
-  /* we will not run this far */
-#include "../spfatal_support/spfatalimpl.h"
diff --git a/testsuites/sptests/spfatal06/spfatal06.doc b/testsuites/sptests/spfatal06/spfatal06.doc
index 5deaa3267b..0000000000
--- a/testsuites/sptests/spfatal06/spfatal06.doc
+++ /dev/null
@@ -1,20 +0,0 @@
-#  COPYRIGHT (c) 1989-2009.
-#  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name:  spfatal06
-directives:
-  None specifically
-concepts:
-+ Ensure that the error condition when the BSP specific stack allocator
-  hook is incorrectly configured is properly treated as a fatal error.
diff --git a/testsuites/sptests/spfatal06/spfatal06.scn b/testsuites/sptests/spfatal06/spfatal06.scn
index 69d3d52fd4..0000000000
--- a/testsuites/sptests/spfatal06/spfatal06.scn
+++ /dev/null
@@ -1,3 +0,0 @@
-*** TEST FATAL 6 ***
-Fatal error (Core initialize with invalid stack hook) hit
-*** END OF TEST FATAL 6 ***
diff --git a/testsuites/sptests/spinternalerror01/init.c b/testsuites/sptests/spinternalerror01/init.c
index 592cfcfa58..349f9fa1b9 100644
--- a/testsuites/sptests/spinternalerror01/init.c
+++ b/testsuites/sptests/spinternalerror01/init.c
@@ -58,6 +58,17 @@ static void *idle_body(uintptr_t ignored)
   return NULL;
+static void *stack_allocate(size_t size)
+  (void) size;
+  return NULL;
+static void stack_free(void *ptr)
+  (void) ptr;
 #define CONFIGURE_INITIAL_EXTENSIONS \
   { .fatal = fatal_extension }, \
   RTEMS_TEST_INITIAL_EXTENSION
@@ -76,9 +87,9 @@ static void *idle_body(uintptr_t ignored)
 #define CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER 0
-#define CONFIGURE_TASK_STACK_ALLOCATOR NULL
+#define CONFIGURE_TASK_STACK_ALLOCATOR stack_allocate
+#define CONFIGURE_TASK_STACK_DEALLOCATOR stack_free
 #define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
diff --git a/testsuites/sptests/sptimecounter01/init.c b/testsuites/sptests/sptimecounter01/init.c
index 81b705473e..13a00209fa 100644
--- a/testsuites/sptests/sptimecounter01/init.c
+++ b/testsuites/sptests/sptimecounter01/init.c
@@ -210,6 +210,17 @@ void boot_card(const char *cmdline)
   _Terminate(RTEMS_FATAL_SOURCE_EXIT, 0);
+  (void) size;
+  return NULL;
+  (void) ptr;
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
@@ -224,9 +235,9 @@ void boot_card(const char *cmdline)
2.26.2
