[PATCH rtems v2 3/7] cpu/armv7m: Add table based init for ARMV7M_MPU
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Nov 19 07:46:27 UTC 2020
Am 19.11.20 um 08:19 schrieb Sebastian Huber:
> On 18/11/2020 15:45, Christian Mauderer wrote:
>> + * Higher level region configuration.
>> + * Allows to configure with begin and end which is more convenient for
>> + * calculating the sizes from linker command file. Note that you
>> still have to
>> + * follow the following rules:
>> + * - Begin address has to be aligned to 0x20 (lower 5 bits set to 0)
>> + * - Sizes can only be a value of 2^x with a minimum of 32 Byte. If
>> you have an
>> + * end address that is not aligned, the region will get bigger.
>> + * - Later regions have higher priority.
>> +typedef struct {
>> + const void *begin;
>> + const void *end;
>> + uint32_t flags;
> uint32_t rasr;
> I guess the flags are actually a value stored directly to the RASR?
>> +} ARMV7M_MPU_Region_Config;
> ARMV7M_MPU_Region_config
>> typedef struct {
>> uint32_t dhcsr;
>> uint32_t dcrsr;
>> @@ -611,6 +632,85 @@ void _ARMV7M_Supervisor_call( void );
>> void _ARMV7M_Clock_handler( void );
>> +static inline uint32_t _ARMV7M_MPU_get_region_size(uintptr_t size)
> _ARMV7M_MPU_Get_region_size
>> + if ((size & (size - 1)) == 0) {
>> + return ARMV7M_MPU_RASR_SIZE(30 - __builtin_clz(size));
>> + } else {
>> + return ARMV7M_MPU_RASR_SIZE(31 - __builtin_clz(size));
>> +static inline void _ARMV7M_MPU_set_region(
> _ARMV7M_MPU_Set_region
>> + volatile ARMV7M_MPU *mpu,
>> + uint32_t region,
>> + uint32_t rasr,
>> + const void *begin,
>> + const void *end
>> + uintptr_t size;
>> + uint32_t rbar;
>> + RTEMS_OBFUSCATE_VARIABLE(begin);
>> + RTEMS_OBFUSCATE_VARIABLE(end);
>> + size = (uintptr_t) end - (uintptr_t) begin;
>> + if ( size > 0 ) {
>> + rbar = (uintptr_t) begin | region | ARMV7M_MPU_RBAR_VALID;
>> + rasr |= _ARMV7M_MPU_get_region_size(size);
>> + } else {
>> + rbar = region;
>> + rasr = 0;
>> + mpu->rbar = rbar;
>> + mpu->rasr = rasr;
>> +static inline void _ARMV7M_MPU_disable_region(
> _ARMV7M_MPU_Disable_region
>> + uint32_t region
>> + mpu->rbar = ARMV7M_MPU_RBAR_VALID | region;
>> + mpu->rasr = 0;
>> +static inline void _ARMV7M_MPU_setup_from_config_and_enable(
>> + const ARMV7M_MPU_Region_Config *cfg,
>> + size_t cfg_count
> _ARMV7M_MPU_Setup
> The config is implicit in the parameter. You don't necessarily enable a
> configured region. It depends on the user provided RASR value.
>> + volatile ARMV7M_MPU *mpu;
>> + volatile ARMV7M_SCB *scb;
>> + uint32_t region_count;
>> + uint32_t region;
>> + mpu = _ARMV7M_MPU;
>> + scb = _ARMV7M_SCB;
>> + region_count = ARMV7M_MPU_TYPE_DREGION_GET(mpu->type);
>> + if (cfg_count > region_count) {
>> + rtems_panic("invalid MPU config");
> I think rtems_panic() is too heavy weight at this point. It uses
> printk(). Maybe just use _Assert(). I think we need some light weight
> general purpose fatal error which could just use the return address to
> identify the error location.
>> + for (region = 0; region < region_count; ++region) {
> for (region = cfg_count; region < region_count; ++region)
> Only disable not configured regions?
I think I maybe have to disable the MPU first if I do that. Otherwise it
is possible that there is (for example) a region 0 that prevents access
to all memory and a high region (lets say 5) that allows access to
program memory. As soon as I clear the high one but not the low one, the
system will crash because it can't access the memory any more.
But most likely a similar situation can be constructed with cleaning all
regions. I'll take a look at disabling MPU before setting it up.
>> + _ARMV7M_MPU_disable_region(mpu, region);
>> + for (region = 0; region < cfg_count; ++region) {
>> + _ARMV7M_MPU_set_region(mpu, region, cfg->flags, cfg->begin,
>> cfg->end);
>> + mpu->ctrl = ARMV7M_MPU_CTRL_ENABLE | ARMV7M_MPU_CTRL_PRIVDEFENA;
>> + scb->shcsr |= ARMV7M_SCB_SHCSR_MEMFAULTENA;
>> + _ARM_Data_synchronization_barrier();
>> + _ARM_Instruction_synchronization_barrier();
embedded brains GmbH
Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
