[PATCH rtems v3 3/7] cpu/armv7m: Add table based init for ARMV7M_MPU
Gedare Bloom
gedare at rtems.org
Thu Nov 19 20:13:35 UTC 2020
Hi Sebastian, Christian:
I saw the req
On Thu, Nov 19, 2020 at 3:17 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Am 19.11.20 um 10:22 schrieb Christian Mauderer:
> > Am 19.11.20 um 10:15 schrieb Sebastian Huber:
> >> On 19/11/2020 09:51, Christian Mauderer wrote:
> >>> + mpu = _ARMV7M_MPU;
> >>> + scb = _ARMV7M_SCB;
> >>> + scb->shcsr &= ~ARMV7M_SCB_SHCSR_MEMFAULTENA;
> >> I think it is not necessary to touch the shcsr. Disabling the MPU
> >> should be enough.
> > OK. I'll try it on the imxrt.
> Seems to be no problem to remove that line. I'll do that before pushing.
> >>> + mpu->ctrl = 0;
> >>> + _ARM_Data_synchronization_barrier();
> >>> + _ARM_Instruction_synchronization_barrier();
> embedded brains GmbH
> Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
