Fatal exceptions on context-switching for more than two isolated threads
Utkarsh Rai utkarsh.rai60 at gmail.com
Thu Nov 19 23:00:20 UTC 2020
On Thu, Nov 19, 2020 at 11:39 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Utkarsh,
> On Thu, Nov 19, 2020 at 4:59 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 19/11/2020 11:47, Utkarsh Rai wrote:
> > >     There are a couple of other areas in RTEMS in which the stack of
> > >     another
> > >     thread may be accessed (events, message queues, signals). How did
> you
> > >     solve this?
> > > When we enable the thread stack protection, all the services in which
> > > a different stack is accessed becomes invalid ( This will have to be
> > > documented  ).
> > > The user has to share the stack of the threads that will be using
> > > services like message queue with each other from the application using
> > > mmap(),shm_open(), etc. (This was a part of the work I did during
> GSoC).
> > This is a bit too restrictive from my point of view. Consider for
> > example this very common use of rtems_event_receive():
> > rtems_event_set events;
> > rtems_event_receive(..., &events, ...);
> Let's try to keep the technical discussion on the mailing list.
Oh sorry, I somehow forgot to cc the mailing list.
> I
> agree with Sebastian's point here, which is well taken. Maybe it would
> be good for you to determine the set of tests and from that the
> features that break with strict task isolation. This way, we can
> determine whether each is better handled as imposing a requirement on
> the user, e.g., to mmap/share explicitly in case they want to pass
> data (such as with an mq), or if RTEMS needs to make it work
> implicitly such as with event sets and maybe these iterators.
> Gedare
Ok.
> > embedded brains GmbH
> > Sebastian HUBER
> > Dornierstr. 4
> > 82178 Puchheim
> > Germany
> > email: sebastian.huber at embedded-brains.de
> > Phone: +49-89-18 94 741 - 16
> > Fax:   +49-89-18 94 741 - 08
> > PGP: Public key available on request.
> > Registergericht: Amtsgericht München
> > Registernummer: HRB 157899
> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> > Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201120/819e90a4/attachment.html>
