[PATCH 2/3] score: Add CONFIGURE_INIT_TASK_STORAGE_SIZE
Sebastian Huber
Fri Nov 20 08:31:27 UTC 2020
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_STORAGE_SIZE configuration option. If this option
is specified, then the Classic API initialization task is constructed
with rtems_task_construct().
Update #4181.
cpukit/Makefile.am | 1 +
cpukit/doxygen/appl-config.h | 48 +++++++++++++++
cpukit/include/rtems/confdefs/inittask.h | 53 ++++++++++++++---
cpukit/include/rtems/rtems/tasksdata.h | 45 +++++++++++++-
cpukit/include/rtems/score/interr.h | 3 +-
cpukit/rtems/src/taskconstructuser.c | 65 +++++++++++++++++++++
cpukit/sapi/src/interrtext.c | 3 +-
spec/build/cpukit/librtemscpu.yml | 1 +
spec/build/testsuites/sptests/grp.yml | 2 +
spec/build/testsuites/sptests/spfatal34.yml | 19 ++++++
testsuites/sptests/spfatal34/init.c | 50 ++++++++++++++++
testsuites/sptests/spfatal34/spfatal34.doc | 11 ++++
testsuites/sptests/spfatal34/spfatal34.scn | 8 +++
testsuites/sptests/spinternalerror02/init.c | 2 +-
14 files changed, 296 insertions(+), 15 deletions(-)
create mode 100644 cpukit/rtems/src/taskconstructuser.c
create mode 100644 spec/build/testsuites/sptests/spfatal34.yml
create mode 100644 testsuites/sptests/spfatal34/init.c
create mode 100644 testsuites/sptests/spfatal34/spfatal34.doc
create mode 100644 testsuites/sptests/spfatal34/spfatal34.scn
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 8c7f9c1ed4..b7435d7eb6 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -790,6 +790,7 @@ librtemscpu_a_SOURCES += rtems/src/statustoerrno.c
librtemscpu_a_SOURCES += rtems/src/systemeventreceive.c
librtemscpu_a_SOURCES += rtems/src/systemeventsend.c
librtemscpu_a_SOURCES += rtems/src/taskconstruct.c
+librtemscpu_a_SOURCES += rtems/src/taskconstructuser.c
librtemscpu_a_SOURCES += rtems/src/taskcreate.c
librtemscpu_a_SOURCES += rtems/src/taskdelete.c
librtemscpu_a_SOURCES += rtems/src/taskexit.c
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index 00230ac2d6..f469f8b41c 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -1145,9 +1145,57 @@
* out by ``<rtems/confdefs.h>`` does not overflow an integer of type <a
* href="https://en.cppreference.com/w/c/types/integer">uintptr_t</a>.
* @endparblock
+ * @par Notes
+ * @parblock
+ * The
+ * * ``CONFIGURE_INIT_TASK_STACK_SIZE`` and
+ * * #CONFIGURE_INIT_TASK_STORAGE_SIZE
+ * configuration options are mutually exclusive.
+ * @endparblock
#define CONFIGURE_INIT_TASK_STACK_SIZE
+/* Generated from spec:/acfg/if/init-task-storage-size */
+ * @brief This configuration option is an integer define.
+ * The value of this configuration option defines the task storage size of the
+ * Classic API initialization task. If this configuration option is specified,
+ * then the Classic API initialization task is constructed by
+ * rtems_task_construct() instead of using rtems_task_create().
+ * @par Default Value
+ * The default value is 0.
+ * @par Value Constraints
+ * @parblock
+ * The value of this configuration option shall satisfy all of the following
+ * constraints:
+ * * It shall be greater than or equal to #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
+ * * It shall be defined using RTEMS_TASK_STORAGE_SIZE().
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * A task storage area of the specified size is defined by the configuration
+ * for the Classic API initialization task. The
+ * * #CONFIGURE_INIT_TASK_STACK_SIZE and
+ * * ``CONFIGURE_INIT_TASK_STORAGE_SIZE``
+ * @endparblock
+#define CONFIGURE_INIT_TASK_STORAGE_SIZE
/* Generated from spec:/acfg/if/rtems-init-tasks-table */
diff --git a/cpukit/include/rtems/confdefs/inittask.h b/cpukit/include/rtems/confdefs/inittask.h
index 25453f031d..f1d937e561 100644
--- a/cpukit/include/rtems/confdefs/inittask.h
+++ b/cpukit/include/rtems/confdefs/inittask.h
@@ -48,6 +48,7 @@
#ifdef CONFIGURE_RTEMS_INIT_TASKS_TABLE
#include <rtems/confdefs/percpu.h>
+#include <rtems/confdefs/threads.h>
#include <rtems/rtems/object.h>
#include <rtems/rtems/tasksdata.h>
#include <rtems/sysinit.h>
@@ -72,15 +73,6 @@
#define CONFIGURE_INIT_TASK_PRIORITY 1
#endif
-#ifndef CONFIGURE_INIT_TASK_STACK_SIZE
- #define CONFIGURE_INIT_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
-#endif
-#if CONFIGURE_INIT_TASK_STACK_SIZE > CONFIGURE_MINIMUM_TASK_STACK_SIZE
- #define _CONFIGURE_INIT_TASK_STACK_EXTRA \
- ( CONFIGURE_INIT_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE )
-#endif
#ifdef __cplusplus
extern "C" {
#endif
@@ -113,6 +105,47 @@ RTEMS_STATIC_ASSERT(
#pragma GCC diagnostic pop
+#ifdef CONFIGURE_INIT_TASK_STORAGE_SIZE
+#ifdef CONFIGURE_INIT_TASK_STACK_SIZE
+ #error "CONFIGURE_INIT_TASK_STACK_SIZE and CONFIGURE_INIT_TASK_STORAGE_SIZE are mutually exclusive"
+#endif
+RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
+static char _RTEMS_tasks_User_task_storage[ CONFIGURE_INIT_TASK_STORAGE_SIZE ];
+const RTEMS_tasks_User_task_config _RTEMS_tasks_User_task_config = {
+ CONFIGURE_INIT_TASK_NAME,
+ CONFIGURE_INIT_TASK_PRIORITY,
+ _RTEMS_tasks_User_task_storage,
+ sizeof( _RTEMS_tasks_User_task_storage ),
+ CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE,
+ NULL,
+ CONFIGURE_INIT_TASK_INITIAL_MODES,
+ CONFIGURE_INIT_TASK_ATTRIBUTES,
+ CONFIGURE_INIT_TASK_ENTRY_POINT,
+ CONFIGURE_INIT_TASK_ARGUMENTS
+RTEMS_SYSINIT_ITEM(
+ _RTEMS_tasks_Construct_user_task,
+ RTEMS_SYSINIT_CLASSIC_USER_TASKS,
+ RTEMS_SYSINIT_ORDER_MIDDLE
+#else /* CONFIGURE_INIT_TASK_STORAGE_SIZE */
+#ifndef CONFIGURE_INIT_TASK_STACK_SIZE
+ #define CONFIGURE_INIT_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
+#endif
+#if CONFIGURE_INIT_TASK_STACK_SIZE > CONFIGURE_MINIMUM_TASK_STACK_SIZE
+ #define _CONFIGURE_INIT_TASK_STACK_EXTRA \
+ ( CONFIGURE_INIT_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE )
+#endif
const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table = {
CONFIGURE_INIT_TASK_STACK_SIZE,
@@ -129,6 +162,8 @@ RTEMS_SYSINIT_ITEM(
+#endif /* CONFIGURE_INIT_TASK_STORAGE_SIZE */
#ifdef __cplusplus
#endif
diff --git a/cpukit/include/rtems/rtems/tasksdata.h b/cpukit/include/rtems/rtems/tasksdata.h
index 55090f71b0..8005b522ad 100644
--- a/cpukit/include/rtems/rtems/tasksdata.h
+++ b/cpukit/include/rtems/rtems/tasksdata.h
@@ -61,10 +61,49 @@ typedef struct {
extern const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table;
- * @brief System initialization handler to create and start the first user
- * task.
+ * @brief Creates and starts the Classic API initialization task using
+ * rtems_task_create() and the configuration provided by
+ * ::_RTEMS_tasks_User_task_table.
-extern void _RTEMS_tasks_Initialize_user_task( void );
+void _RTEMS_tasks_Initialize_user_task( void );
+ * @brief This structure provides the configuration to construct and start the
+typedef struct {
+ * @brief This member provides the task configuration for
+ * rtems_task_construct().
+ rtems_task_config config;
+ * @brief This member provides the task entry point for rtems_task_start().
+ rtems_task_entry entry_point;
+ * @brief This member provides the task argument for rtems_task_start().
+ rtems_task_argument argument;
+} RTEMS_tasks_User_task_config;
+ * @brief This structure provides the configuration of the Classic API
+ * initialization task.
+ * It is used by _RTEMS_tasks_Construct_user_task() and initialized via
+ * <rtems/confdefs.h>, see also #CONFIGURE_INIT_TASK_STORAGE_SIZE.
+extern const RTEMS_tasks_User_task_config _RTEMS_tasks_User_task_config;
+ * @brief Constructs and starts the Classic API initialization task using
+ * rtems_task_construct() and the configuration provided by
+ * ::_RTEMS_tasks_User_task_config.
+void _RTEMS_tasks_Construct_user_task( void );
* The following instantiates the information control block used to
diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
index b1f1061c82..01ece772b8 100644
--- a/cpukit/include/rtems/score/interr.h
+++ b/cpukit/include/rtems/score/interr.h
@@ -204,7 +204,8 @@ typedef enum {
INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT = 38,
INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL = 39,
INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA = 40,
- INTERNAL_ERROR_TOO_LARGE_TLS_SIZE = 41
+ INTERNAL_ERROR_TOO_LARGE_TLS_SIZE = 41,
+ INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED = 42,
} Internal_errors_Core_list;
typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/cpukit/rtems/src/taskconstructuser.c b/cpukit/rtems/src/taskconstructuser.c
new file mode 100644
index 0000000000..bc59aabdd2
--- /dev/null
+++ b/cpukit/rtems/src/taskconstructuser.c
@@ -0,0 +1,65 @@
+ * @file
+ * @ingroup ClassicTasks
+ * @brief This source file contains the implementation of
+ * _RTEMS_tasks_Construct_user_task().
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/score/assert.h>
+#include <rtems/score/threadimpl.h>
+#include <rtems/score/interr.h>
+ const RTEMS_tasks_User_task_config *config;
+ rtems_status_code status;
+ rtems_id id;
+ config = &_RTEMS_tasks_User_task_config;
+ status = rtems_task_construct( &config->config, &id );
+ if ( status != RTEMS_SUCCESSFUL ) {
+ _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED );
+ status = rtems_task_start( id, config->entry_point, config->argument );
+ _Assert( status == RTEMS_SUCCESSFUL );
+ (void) status;
+ _Assert( _Thread_Global_constructor == 0 );
+ _Thread_Global_constructor = id;
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 3d49135c44..654b3110ad 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -68,7 +68,8 @@ static const char *const internal_error_text[] = {
"INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT",
"INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL",
"INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA",
- "INTERNAL_ERROR_TOO_LARGE_TLS_SIZE"
+ "INTERNAL_ERROR_TOO_LARGE_TLS_SIZE",
+ "INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED"
const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 8f96af1e75..797aff6322 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1284,6 +1284,7 @@ source:
- cpukit/rtems/src/systemeventreceive.c
- cpukit/rtems/src/systemeventsend.c
- cpukit/rtems/src/taskconstruct.c
+- cpukit/rtems/src/taskconstructuser.c
- cpukit/rtems/src/taskcreate.c
- cpukit/rtems/src/taskdelete.c
- cpukit/rtems/src/taskexit.c
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index b1bf85942d..3ceddfad44 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -254,6 +254,8 @@ links:
uid: spfatal32
- role: build-dependency
uid: spfatal33
+- role: build-dependency
+ uid: spfatal34
uid: spfifo01
diff --git a/spec/build/testsuites/sptests/spfatal34.yml b/spec/build/testsuites/sptests/spfatal34.yml
index 0000000000..b3bea84cda
--- /dev/null
+++ b/spec/build/testsuites/sptests/spfatal34.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spfatal34/init.c
+stlib: []
+target: testsuites/sptests/spfatal34.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/sptests/spfatal34/init.c b/testsuites/sptests/spfatal34/init.c
index 0000000000..7e436e58ed
--- /dev/null
+++ b/testsuites/sptests/spfatal34/init.c
@@ -0,0 +1,50 @@
+ * are met:
+#endif
+#include "../spfatal_support/spfatal.h"
+#define FATAL_ERROR_TEST_NAME "34"
+#define FATAL_ERROR_DESCRIPTION "Classic API Init task construct failure"
+#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
+#define FATAL_ERROR_EXPECTED_ERROR \
+#define CONFIGURE_INIT_TASK_STORAGE_SIZE 0
+static void force_error( void )
+ RTEMS_UNREACHABLE();
+#include "../spfatal_support/spfatalimpl.h"
diff --git a/testsuites/sptests/spfatal34/spfatal34.doc b/testsuites/sptests/spfatal34/spfatal34.doc
index 0000000000..d2640ab8f0
--- /dev/null
+++ b/testsuites/sptests/spfatal34/spfatal34.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spfatal34
+directives:
+ - _RTEMS_tasks_Construct_user_task()
+concepts:
+ - Provoke a Classic API initialization task construct failure.
diff --git a/testsuites/sptests/spfatal34/spfatal34.scn b/testsuites/sptests/spfatal34/spfatal34.scn
index 0000000000..0ad19816a0
--- /dev/null
+++ b/testsuites/sptests/spfatal34/spfatal34.scn
@@ -0,0 +1,8 @@
+*** BEGIN OF TEST SPFATAL 34 ***
+*** TEST VERSION: 6.0.0.be2dc00ae7b5db5381da49a3ec42f2088fa66bc9
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD:
+*** TEST TOOLS: 10.2.1 20200918 (RTEMS 6, RSB 3ce72f014292bbb4e6b3bab9ede9e0b4a71ef5a8, Newlib 749cbcc)
+Fatal error (Classic API Init task construct failure) hit
+*** END OF TEST SPFATAL 34 ***
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 1b7d0b4388..1564061956 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -36,7 +36,7 @@ static void test_internal_error_text(void)
} while ( text != text_last );
rtems_test_assert(
- error - 3 == INTERNAL_ERROR_TOO_LARGE_TLS_SIZE
+ error - 3 == INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED
2.26.2
